[General] C-HRHPC-2505全真模擬試験、C-HRHPC-2505試験解説問題
86
【General】 C-HRHPC-2505全真模擬試験、C-HRHPC-2505試験解説問題
Posted at 1/11/2026 13:49:19      View:278 | Replies:4        Print      Only Author   [Copy Link] 1#
無料でクラウドストレージから最新のJpshiken C-HRHPC-2505 PDFダンプをダウンロードする:https://drive.google.com/open?id=18Skw8atCbiHQTto6T0ZkLNys148q4CmD
SAPのC-HRHPC-2505の認定試験に合格すれば、就職機会が多くなります。JpshikenはSAPのC-HRHPC-2505の認定試験の受験生にとっても適合するサイトで、受験生に試験に関する情報を提供するだけでなく、試験の問題と解答をはっきり解説いたします。
SAP C-HRHPC-2505 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Payroll Control Center Tools: This section of the exam measures the skills of payroll implementation consultants and covers the tools and utilities provided within the Payroll Control Center. It includes the use of diagnostic tools and monitors to ensure that payroll processes are running smoothly and errors are addressed proactively.
トピック 2
  • Payroll Control Center Configuration: This section of the exam measures the skills of payroll implementation consultants and covers the full range of configuration tasks required to enable and customise the Payroll Control Center. It addresses setting up validation rules, alerts, checks, and user interfaces that help streamline payroll management.
トピック 3
  • Declustered Payroll Results: This section of the exam measures the skills of payroll implementation consultants and covers the concept and use of declustered payroll results. It introduces how payroll data is stored and accessed more efficiently for reporting and auditing in SAP’s modern payroll architecture.
トピック 4
  • Point-to-Point Integration (Employee Central, Employee Central Time Off): This section of the exam measures the skills of integration analysts and covers the synchronization between Employee Central Time Off and payroll systems through direct integration. It focuses on how leave and absence data are transferred and calculated accurately in payroll.
トピック 5
  • Point-to-Point Integration (Employee Central, Employee Central Configuration)
トピック 6
  • Authorizations In Payroll Control Center: This section of the exam measures the skills of integration analysts and covers how to set up and manage user permissions and access control within the Payroll Control Center. It ensures proper role-based access is maintained to secure payroll data and processes.
トピック 7
  • Payroll Process using Payroll Control Center: This section of the exam measures the skills of payroll implementation consultants and covers how to use the Payroll Control Center to perform payroll runs, monitor process progress, and validate results. It focuses on enabling smooth and efficient payroll execution using standard control center functions.
トピック 8
  • Provisioning Settings for Employee Central Payroll: This section of the exam measures the skills of integration analysts and covers the provisioning-level configurations required to enable Employee Central Payroll functionality. It includes system setup tasks that must be completed during the initial implementation to ensure the system is payroll-ready.
C-HRHPC-2505試験解説問題 & C-HRHPC-2505試験勉強攻略時にはためらうことは多くの機会を逃すことにつながります。 弊社のC-HRHPC-2505試験の多くがPDFをダンプすると思われる場合は、Ifしないでください。 あまりにもheすると、多くの時間を無駄にします。 弊社のC-HRHPC-2505試験ダンプPDFは、気軽に準備して試験に簡単に合格するのに役立ちます。 時間を最大限に活用し、有用な認定を取得すると、他の人よりも先に上級職に就くことができます。 チャンスは準備された心を支持します。 Jpshikenは、この分野の最高のC-HRHPC-2505試験ダンプPDF資料を提供します。
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Payroll 認定 C-HRHPC-2505 試験問題 (Q73-Q78):質問 # 73
Which of the following relates to a minimum set of segments for the Configuration Compound Employee API Query? Note: There are 3 correct answers to this question.
  • A. job_information
  • B. payment_information
  • C. personal_information
  • D. address_information
  • E. compensation_information
正解:A、C、E
質問 # 74
Where do you maintain the earliest selection date for absences?
  • A. Absence counting method
  • B. Data replication configuration
  • C. Data replication proxy
  • D. Accrual rule variables
質問 # 75
What HRIS element changes require push replication?
  • A. employmentInfo
  • B. jobinfo
  • C. paymentInfo
  • D. compInfo
正解:A、B、C
質問 # 76
When you configure country-specific declustering, which activities do you perform? Note: There are 3 correct answers to this question.
  • A. Select the database connection
  • B. Switch wage garnishments off
  • C. Select cluster table PCL4
  • D. Select the payroll tables
  • E. Define declustering for the specific country
正解:A、D、E
質問 # 77
Which of the following can you use to explore released APIs?
  • A. SAP Integration Suite
  • B. SAP Business Accelerator Hub
  • C. SAP Application Interface Framework
質問 # 78
毎年のC-HRHPC-2505試験問題は、テストの目的に基づいてまとめられています。すべての回答はテンプレートであり、2つのパートの主観的および客観的なC-HRHPC-2505試験があります。この目的のために、認定試験のC-HRHPC-2505トレーニング資料では、問題解決スキルを要約し、一般的なテンプレートを紹介しています。ユーザーは、提供された回答テンプレートに基づいて回答をスカウトし、スコアをスカウトできます。そのため、ユニバーサルテンプレートは、ユーザーがC-HRHPC-2505試験を勉強して合格するための貴重な時間を大幅に節約できます。
C-HRHPC-2505試験解説問題: https://www.jpshiken.com/C-HRHPC-2505_shiken.html
ちなみに、Jpshiken C-HRHPC-2505の一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=18Skw8atCbiHQTto6T0ZkLNys148q4CmD
Posted at 1/12/2026 23:23:40        Only Author  2#
No delay, just liking this awesome content. Sharing the Valid exam C_BCFIN_2502 simulator online exam that helped me with my career advancement and raise—it’s free for all today. Best of luck on your professional journey!
Posted at 1/29/2026 21:50:10        Only Author  3#
Amazing stuff here, definitely hitting that like. Here are the free New practice questions 1z0-1066-25 book materials. Best of luck to everyone!
Posted at 2/2/2026 23:02:04        Only Author  4#
I’m very inspired by this article, thank you for the share! Ready to face the CIMAPRA19-F03-1 latest test camp pdf exam! Pray for good results!
Posted at 2/19/2026 01:57:19        Only Author  5#
I can't overstate how much I benefited from it. I’m sharing New C-S4CPB-2508 practice exam fee resources for free. Wishing you all the best!
Posted at 2/23/2026 21:05:46        Only Author  6#
The article gave me so much to think about. Get the Test 156-215.82 sample questions that helped me succeed in my career—for free today!
