[General] Pdf HPE7-A02 Format - Latest HPE7-A02 Braindumps Sheet
84
【General】 Pdf HPE7-A02 Format - Latest HPE7-A02 Braindumps Sheet
Posted at 1/11/2026 14:07:42      View:152 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestPassKing HPE7-A02 dumps from Cloud Storage: https://drive.google.com/open?id=1QgrroWxo26sAZY2GjfblUE3xO8I0T_29
The HP HPE7-A02 exam questions on the platform have been gathered by subject matter experts to ensure that they accurately reflect the format and difficulty level of the actual HP HPE7-A02 exam. This makes these Aruba Certified Network Security Professional Exam PDF Questions ideal for individuals looking to pass the HP HPE7-A02 Exam on their first try. You can evaluate the product with a free HPE7-A02 demo.
HP HPE7-A02 exam is a vendor-specific certification offered by Hewlett Packard Enterprise. Candidates who pass the exam will earn the Aruba Certified Network Security Professional (ACNSP) certification, which is recognized globally as a standard of excellence in the field of network security.
HPE7-A02 exam is designed to evaluate the candidate’s knowledge and expertise in network security and to demonstrate their ability to implement and manage secure wireless networks. HPE7-A02 exam includes multiple-choice questions and scenario-based questions that test the candidate’s understanding and expertise in critical areas such as enterprise wireless security, secure network access control, secure remote access, and security monitoring and analysis.
To become certified as an Aruba Certified Network Security Professional, candidates must pass the HPE7-A02 Exam, which consists of 60 multiple-choice questions to be completed in 90 minutes. HPE7-A02 exam is administered in a proctored environment and can be taken at any Pearson VUE testing center worldwide. Upon passing the exam, candidates will receive a certificate that represents their mastery of the concepts and skills required to implement and manage network security solutions using Aruba technology.
Pdf HPE7-A02 Format - HP Aruba Certified Network Security Professional Exam - Latest HPE7-A02 Braindumps SheetThe valid Aruba Certified Network Security Professional Exam (HPE7-A02) practice tests are available in HPE7-A02 pdf format which works on all smart devices. When you have all the actual HPE7-A02 questions in a pdf document, it will be easy for you to prepare successfully for the HPE7-A02 test in a short time. Practice makes a man perfect and we can apply the same thing here.
HP Aruba Certified Network Security Professional Exam Sample Questions (Q41-Q46):NEW QUESTION # 41
What is a typical use case for using HPE Aruba Networking ClearPass Onboard to provision devices?
  • A. Enhancing security for loT devices that need to authenticate with MAC-Auth
  • B. Enabling unmanaged devices to succeed at certificate-based 802.1X
  • C. Enforcing posture-based assessment on managed Windows domain computers
  • D. Enabling managed Windows domain computers to succeed at certificate-based 802.1X
A typical use case for using HPE Aruba Networking ClearPass Onboard is to provision unmanaged devices to succeed at certificate-based 802.1X authentication. ClearPass Onboard allows users to securely configure their personal devices with the necessary certificates and network settings to authenticate on the network using 802.1X, which enhances security and simplifies the onboarding process for unmanaged devices.
1.Certificate-Based Authentication: ClearPass Onboard simplifies the process of issuing and installing certificates on unmanaged devices, ensuring they can authenticate securely using 802.1X.
2.User-Friendly Onboarding: The Onboard process is user-friendly, guiding users through the steps needed to configure their devices for network access.
3.Enhanced Security: By using certificates for authentication, the solution provides a higher level of security compared to traditional username/password methods.
Reference: ClearPass Onboard documentation highlights the use of the platform for provisioning certificates on unmanaged devices to facilitate secure network access via 802.1X.
NEW QUESTION # 42
HPE Aruba Networking Central displays an alert about an Infrastructure Attack that was detected. You go to the Security > RAPIDS events and see that the attack was "Detect adhoc using Valid SSID." What is one possible next step?
  • A. Use HPE Aruba Networking Central floorplans or the detecting AP identities to locate the general area for the threat.
  • B. Look for the IP address associated with the offender and then check for that IP address among HPE Aruba Networking Central clients.
  • C. Make sure that you have tuned the threshold for that check as false positives are common for it.
  • D. Make sure that clients have updated drivers, as faulty drivers are a common explanation for this attack type.
* RAPIDS Ad-Hoc Detection:
* The alert "Detect ad-hoc using Valid SSID" indicates that a device is broadcasting an SSID that matches a valid network SSID in ad-hoc mode. This can be an indication of an infrastructure attack or misconfiguration.
* Next Steps:
* Use Aruba Central floorplans or AP location data to identify the physical area where the offending device is detected.
* Locate and investigate the device to determine if it is malicious or simply misconfigured.
* Option Analysis:
* Option A: Incorrect. While tuning thresholds is useful for reducing false positives, this step does not directly address a potential threat.
* Option B: Incorrect. Faulty drivers can cause similar behavior, but this step is not immediately actionable without locating the device first.
* Option C: Correct. Floorplans or AP identities help locate the threat's physical area for further investigation.
* Option D: Incorrect. RAPIDS focuses on detecting devices via SSID and MAC, not IP addresses, making this approach less relevant.
NEW QUESTION # 43
You have set up a mirroring session between an AOS-CX switch and a management station, running Wireshark. You want to capture just the traffic sent in the mirroring session, not the management station's other traffic.
What should you do?
  • A. Edit protocol preferences and enable ARUBA_ERM.
  • B. Edit protocol preferences and enable HPE_ERM.
  • C. Apply this capture filter: ip proto 47
  • D. Apply this capture filter: udp port 5555
To capture only the traffic sent in the mirroring session between an AOS-CX switch and a management station running Wireshark, you should apply a capture filter that isolates the specific traffic of interest. In this case, using the filter udp port 5555 will capture the traffic associated with the mirroring session. This is because AOS-CX switches typically use UDP port 5555 for mirrored traffic, ensuring that only the relevant mirrored packets are captured and excluding other traffic generated by the management station.
Reference: Aruba's AOS-CX documentation and network management guides detail the configuration and monitoring of traffic mirroring sessions, including the use of specific ports for mirrored traffic.
NEW QUESTION # 44
A company is implementing a client-to-site VPN based on tunnel-mode IPsec.
Which devices are responsible for the IPsec encapsulation?
  • A. Gateways at the remote clients' locations and a gateway at the main site
  • B. The remote clients and a gateway at the main site
  • C. Gateways at the remote clients' locations and devices accessed by the clients at the main site
  • D. The remote clients and devices accessed by the clients at the main site
In a client-to-site VPN based on tunnel-mode IPsec, the remote clients and a gateway at the main site are responsible for the IPsec encapsulation. The remote clients initiate the VPN connection and encapsulate their traffic in IPsec, which is then decapsulated by the gateway at the main site.
1.IPsec Encapsulation: The remote clients encapsulate their traffic using IPsec protocols before sending it over the internet to the main site.
2.Gateway Role: The gateway at the main site receives the encapsulated traffic, decapsulates it, and forwards it to the internal network. Similarly, traffic from the main site to the remote clients is encapsulated by the gateway and decapsulated by the clients.
3.Security: This setup ensures that data is securely transmitted between the remote clients and the main site, protecting it from eavesdropping and tampering.
NEW QUESTION # 45
What is a use case for the HPE Aruba Networking ClearPass OnGuard dissolvable agent?
  • A. Auto-remediating posture issues on clients
  • B. Implementing a one-time compliance scan
  • C. Continuously monitoring Windows domain clients for compliance
  • D. Periodically scanning Linux clients for security issues
The use case for the HPE Aruba Networking ClearPass OnGuard dissolvable agent is implementing a one-time compliance scan. The dissolvable agent is designed to perform a compliance check without requiring a permanent installation on the client device. This is ideal for environments where a quick, temporary assessment of the device's security posture is needed without the overhead of a persistent agent.
1.Dissolvable Agent: The dissolvable agent is downloaded and executed on the client device for a single session, performing the necessary compliance checks before being removed automatically.
2.One-time Compliance Scan: This method is particularly useful for guest or unmanaged devices where a temporary compliance scan is sufficient to ensure security standards are met.
3.Minimal Impact: Since the agent does not persist on the client device, it minimizes the impact on the user's system and does not require ongoing maintenance or updates.
NEW QUESTION # 46
How can our HPE7-A02 study questions are so famous and become the leader in the market? Because our HPE7-A02 learning braindumps comprise the most significant questions and answers that have every possibility to be the part of the real exam. As you study with our HPE7-A02 Practice Guide, you will find the feeling that you are doing the real exam. Especially if you choose the Software version of our HPE7-A02 training engine, which can simulate the real exam.
Latest HPE7-A02 Braindumps Sheet: https://www.testpassking.com/HPE7-A02-exam-testking-pass.html
2026 Latest TestPassKing HPE7-A02 PDF Dumps and HPE7-A02 Exam Engine Free Share: https://drive.google.com/open?id=1QgrroWxo26sAZY2GjfblUE3xO8I0T_29
