[General] Pass Guaranteed Quiz Oracle - High Hit-Rate 1Z1-947 Excellect Pass Rate
90
General Pass Guaranteed Quiz Oracle - High Hit-Rate 1Z1-947 Excellect Pass Rate
Posted at 1/11/2026 14:22:23      View250 | Replies6        Print      Only Author   [Copy Link] 1#
2026 Latest BraindumpsIT 1Z1-947 PDF Dumps and 1Z1-947 Exam Engine Free Share: https://drive.google.com/open?id=1TH_B6fIGxLkoA_pHa7tUfDlHsQHuKt1l
You can download the Oracle GoldenGate 19c Implementation Professional 1Z1-947 product right after purchasing and start your journey toward your big career. The Oracle 1Z1-947 exam questions are very similar to actual Oracle 1Z1-947 Exam Questions. We provide our valuable customers to try a demo before their purchase to test all features of the Oracle 1Z1-947 certification exam product confidently.
Our research materials will provide three different versions of 1Z1-947 valid practice questions, the PDF version, the software version and the online version. Software version of the features are very practical, I think you can try to use our 1Z1-947 test prep software version. I believe you have a different sensory experience for this version of the product. Because the software version of the 1Z1-947 Study Guide can simulate the real test environment, users can realize the effect of the atmosphere of the 1Z1-947 exam at home through the software version.
1Z1-947 Exam Quick Prep, 1Z1-947 Dumps CostOur 1Z1-947 quiz torrent boost 3 versions and they include PDF version, PC version, App online version. Different version boosts different functions and using method. For example, the PDF version is convenient for the download and printing our 1Z1-947 exam torrent and is easy and suitable for browsing learning. It can be printed on the papers which are convenient for you to take notes and learn at any time and place. You can practice 1Z1-947 Quiz prep repeatedly and there are no limits for the amount of the persons and times. And the PC version of 1Z1-947 quiz torrent can stimulate the real exams scenarios, is stalled on the Windows operating system and runs on the Java environment. You can use it any time to test your own Exam stimulation tests scores and whether you have mastered our 1Z1-947 exam torrent.
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q109-Q114):NEW QUESTION # 109
Which of the following is a typical Oracle GoldenGate Manager parameter?
  • A. RmtHost
  • B. Port
  • C. DiscardFile
  • D. ExtTrail
Port, DynamicPortList, Autostart, AutoRestart, Lag parameters, PurgeOldExtracts, and others. These can be found in the section titled "Manager Parameter Categories."
NEW QUESTION # 110
You can create a macro library that contains one or more macros. By using a macro library, you can define a macro once and use it again and again. What is true about macro libraries?
  • A. You can invoke the macros in a library only one time in COLMAP in the Replicat parameter file.
  • B. If a macro is defined in a macro library, you may only call that macro once in a parameter file.
  • C. You can either have the Extract or the Replicat in the same GoldenGate Home invoke the macros in the library but not from with both Extract and Replicat.
  • D. You can share the macros across parameter files.
Macro libraries in Oracle GoldenGate allow you to define reusable macros and share them across multiple parameter files, improving consistency and reducing duplication in Extract and Replicat configurations.
NEW QUESTION # 111
An Oracle GoldenGate topology is a representation of the databases in a GoldenGate environment, how the GoldenGate components are configured on each server, and the flow of data between the components. What topology describes a configuration of data flow from one source site to many target sites?
  • A. Cascading
  • B. Multimaster
  • C. Broadcast
  • D. Integration
Broadcast topology describes a one-to-many data replication model: A single source sends data to multiple target sites Targets often receive the same set of replicated changes
NEW QUESTION # 112
What should be used for disaster tolerance for a database that GoldenGate is using for a source or a target site?
  • A. Recovery Manager
  • B. Zero database
  • C. Active Data Guard
  • D. Flashback database
Oracle Active Data Guard is recommended for disaster tolerance in GoldenGate environments because: It provides a real-time, physical standby database Keeps the standby in sync with the source Ensures high availability and fast failover Supports read-only workloads at the standby site - ideal for reporting
NEW QUESTION # 113
Proper prerequisite planning will ensure a successful Initial Load. To ensure not to miss any data, before starting any instantiation method, it is important you verify that all open transactions that existed when Extract was started are completed. Which two sources do you use to see that transactions no longer exist before beginning instantiation?
  • A. GG$TRANSACTION
  • B. DBA$TRANSACTION
  • C. V$TRANSACTION
  • D. GV$TRANSACTION
GV$TRANSACTION - shows active transactions across all RAC instances
EXCLUDEHIDDENCOLUMNS
NEW QUESTION # 114
Perhaps you worry about that you have difficulty in understanding our 1Z1-947 training questions. Frankly speaking, we have taken all your worries into account. Firstly, all knowledge of the 1Z1-947 exam materials have been simplified a lot. Also, we have tested many volunteers who can prove that after studying our 1Z1-947 Exam Questions for 20 to 30 hours, it is easy to pass the exam. The results show that our 1Z1-947 study materials are easy for them to understand. In addition, they all enjoy learning on our 1Z1-947 practice exam study materials.
1Z1-947 Exam Quick Prep: https://www.braindumpsit.com/1Z1-947_real-exam.html
You can get the authoritative 1Z1-947 test practice material in first try without attending any expensive training institution classes, With our professional ability, we can accord to the necessary testing points to edit 1Z1-947 exam questions, Oracle 1Z1-947 Excellect Pass Rate Our experts are highly responsible for you who are eager to make success in the forthcoming exam, You don't worry the information out of date, while you can reserve the latest 1Z1-947 valid study cram all the time.
It still has valuable uses, Dr Stefan Möller, You can get the authoritative 1Z1-947 Test Practice material in first try without attending any expensive training institution classes.
With our professional ability, we can accord to the necessary testing points to edit 1Z1-947 exam questions, Our experts are highly responsible for you who are eager to make success in the forthcoming exam.
Free PDF Quiz 1Z1-947 - Useful Oracle GoldenGate 19c Implementation Professional Excellect Pass RateYou don't worry the information out of date, while you can reserve the latest 1Z1-947 valid study cram all the time, Verified Answers Researched by Industry Experts.
P.S. Free & New 1Z1-947 dumps are available on Google Drive shared by BraindumpsIT: https://drive.google.com/open?id=1TH_B6fIGxLkoA_pHa7tUfDlHsQHuKt1l
Posted at 1/16/2026 15:43:59        Only Author  2#
By reading this article, Ive developed a new understanding of both my work and life. Enhance your IT knowledge with free Workday-Pro-Talent-and-Performance reliable test questions explanations. Best of luck on your exams!
Posted at 1/25/2026 19:52:01        Only Author  3#
This article has really touched me, thank you for sharing! Free C_ARSOR_2404 reliable test testking available to enhance your IT expertise. Good luck!
Posted at 1/27/2026 12:46:38        Only Author  4#
21o@ITИIx͵ĕrǺܼҵġȻģITИISalesforce Health-Cloud-Accredited-ProfessionalJCԇɞһܟTĿԇӿԇԽԽ࣬Kͨ^@JCԇҲЩIJITIʿĉ롣
Posted at 2/3/2026 13:33:17        Only Author  5#
Im truly thankful for your article, it left a lasting and meaningful impression. Improve your IT skills and get free Reliable L5M5 test cram sheet. Best of luck in your studies!
Posted at 2/18/2026 03:27:32        Only Author  6#
Im so appreciative of your article, its left a big impression. Preparing for the EX200 exam details exam. Hope it goes smoothly!
Posted at 2/20/2026 12:50:32        Only Author  7#
This article is truly remarkable, thank you so much for sharing! This Customizable Information-Technology-Management exam mode helped me get a promotion and salary hike. Im now making it available for free. Wishing you all career success!
