Hardware
1z0-1104-25 Reliable Test Notes | 1z0-1104-25 New Dumps Questions
Posted at 1/11/2026 14:23:33
View186
Replies3
DOWNLOAD the newest VCEDumps 1z0-1104-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1a0QxrKzUBa1KKlv4W-pRQSdKOO0_Fo0X
Most of the materials on the market do not have a free trial function. Even some of the physical books are sealed up and cannot be read before purchase. As a result, many students have bought materials that are not suitable for them and have wasted a lot of money. Especially for those students who are headaches when reading a book, 1z0-1104-25 study tool is their gospel. Because doing exercises will make it easier for one person to concentrate, and at the same time, in the process of conducting a mock examination to test yourself, seeing the improvement of yourself will makes you feel very fulfilled and have a stronger interest in learning. 1z0-1104-25 Guide Torrent makes your learning process not boring at all.
Oracle 1z0-1104-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Protecting Infrastructure - Network and Applications: This section of the exam measures the skills of Cloud Security Professionals and covers methods for securing networks and applications on OCI. Topics include network security groups, firewalls, and security lists, while also focusing on the use of load balancers for availability. The section further addresses the configuration of OCI certificates and web application firewalls to strengthen infrastructure security.
| | Topic 2 | - OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
| | Topic 3 | - Implementing Identity and Access Management (IAM): This section of the exam measures skills of OCI Administrators and focuses on identity and access controls. It covers IAM domains, users, groups, and compartments, as well as the use of IAM policies to manage access to resources. Candidates are also tested on configuring dynamic groups, network sources, and tag-based access control, along with managing MFA, sign-on policies, and activity monitoring.
| | Topic 4 | - Protecting Data: This section of the exam measures the skills of Cloud Security Professionals and highlights data security practices in OCI. It tests knowledge of using the Key Management Service for encryption keys, managing secrets in the OCI Vault, and applying features of OCI Data Safe to ensure sensitive data remains protected.
| | Topic 5 | - Implementing OS and Workload Protection: This section of the exam measures the skills of OCI Administrators and looks at securing workloads and operating systems. It includes the use of OCI Bastion for time-limited access, vulnerability scanning of hosts and containers, and the use of OS management for automated updates. The goal is to ensure that workloads remain resilient and well-protected.
Oracle 1z0-1104-25 New Dumps Questions, 1z0-1104-25 Study Materials ReviewIf you feel that you always suffer from procrastination and cannot make full use of your spare time, maybe our 1z0-1104-25 study materials can help you solve your problem. We are willing to recommend you to try the 1z0-1104-25 learning guide from our company. Our products are high quality and efficiency test tools for all people with three versions which satisfy all your needs. If you buy our 1z0-1104-25 Preparation questions, you can use our 1z0-1104-25 practice engine for study in anytime and anywhere.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q32-Q37):NEW QUESTION # 32
During your investigation of a load balancer issue, you discovered that all back-end servers associated with one of the affected listeners were reported as unhealthy. However, when you checked the back-end servers, they seemed to be working just fine.
What might be causing this issue?
- A. Misconfigured health check
- B. Incorrect DNS configuration
- C. Overloaded back-end servers
- D. Incorrect subnet configuration
- E. Misconfigured security rule
NEW QUESTION # 33
Task 5: Create a Certificate
Create a certificate, where:
Certificate name: PBT-CERT-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate name should be PBT-CERT-
01990086771abuser01
Ensure you eliminate special characters from the user name.
Common name: PBT-CERT-OCICERT-01
Certificate Authority: PBT-CERT-CA-01 (created in the previous task)
See the solution below in Explanation.
Since I can't create resources or retrieve OCIDs directly in your OCI environment, I'll provide a step-by-step solution based on verified OCI documentation and best practices as of 02:30 PM BST on Thursday, June 12,
2025. Follow these instructions precisely in the OCI Console or CLI, using the preconfigured PBI_Vault_SP vault and the PBT-CERT-CA-01<username> Certificate Authority created in the previous task. Replace
<username> with your actual username (e.g., 99008677-lab.user01), ensuring special characters are removed.
Step 1: Access the OCI Vault
* Log in to the OCI Console.
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Certificate
* In the PBI_Vault_SP vault details page, underResources, clickCertificates.
* ClickCreate Certificate.
* Enter the following details:
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-
0199008677labuser01).
* Common Name: Enter PBT-CERT-OCICERT-01.
* Certificate Authority: Select the PBT-CERT-CA-01<username> CA created in Task 4 (e.g., PBT-CERT-CA-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required.
* Validity Period: Set as needed (e.g., 1 year), or use the default.
* Compartment: Ensure it's set to the root compartment.
* ClickCreate Certificateand wait for the certificate to be issued.
Step 3: Verify the Certificate
* After creation, go to theCertificatessection under PBI_Vault_SP.
* Confirm the certificate PBT-CERT-01<username> (e.g., PBT-CERT-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 34
Based on the provided diagram, you have a group of critical compute instances in a private subnet that require vulnerability using the Oracle Cloud Infrastructure(OCI) Vulnerability Scanning Service (VSS).
"What additional configuration is required to enable VSS to scan instances in the private subnet
- A. No additional configuration is needed. VSS can access private instances by default.
- B. Use an OCI Bastion session to establish connectivity and forward scan results from the private instances."
- C. Configure a service gateway in the VCN and a route rule to direct traffic for the VSS service through the gateway.
- D. VSS cannot scan private instances. You need to move them to a public subnet for vulnerability scanning.
NEW QUESTION # 35
You are the first responder of a security incident for ABC Org. You have identified several IP addresses and URLs in the logs that you suspect may be related to the incident. However, you need more information to confidently determine whether they are indeed malicious or not.
Which OCI service can you use to obtain a more refined information and confidence score for these identified indicators?
- A. OCI Web Application Firewall
- B. OCI Incidence Responder
- C. OCI Threat Intelligence
- D. OCI Security Zones
NEW QUESTION # 36
Challenge 2 -Task 1
In deploying a new application, a cloud customer needs to reflect different security postures. If a security zone is enabled with the Maximum Security Zone recipe, the customer will be unable to create or update a resource in the security zone if the action violates the attached Maximum Security Zone policy.
As an application requirement, the customer requires a compute instance in the public subnet. You therefore, need to configure Custom Security Zones that allow the creation of compute instances in the public subnet.
Review the architecture diagram, which outlines the resoures you'll need to address the requirement:
Preconfigured
To complete this requirement, you are provided with the following:
Access to an OCI tenancy, an assigned compartment, and OCI credentials
Required IAM policies
Task 4: Create a Public Subnet
Create a public subnet named IAD-SP-PBT-PUBSNET-01, within the VCN IAD-SP-PBT-VCN-01 use a CIDR block of 10.0.1.0/24 and configure the subnet to use the internet Gateway See the solution below in Explanation.
To create a public subnet named IAD-SP-PBT-PUBSNET-01 within the VCN IAD-SP-PBT-VCN-01 using a CIDR block of 10.0.1.0/24 and configure it to use the Internet Gateway, follow these steps based on the Oracle Cloud Infrastructure (OCI) Networking documentation.
Step-by-Step Solution for Task 4: Create a Public Subnet
* Log in to the OCI Console:
* Use your OCI credentials to log in to the OCI Console (https://console.us-ashburn-1.oraclecloud.
com).
* Ensure you have access to the assigned compartment.
* Navigate to Virtual Cloud Networks:
* From the OCI Console, click the navigation menu (hamburger icon) on the top left.
* UnderNetworking, selectVirtual Cloud Networks.
* Select the VCN:
* Locate and click on the VCN named IAD-SP-PBT-VCN-01 created in Task 3.
* UnderResources, selectSubnets.
* Create a New Subnet:
* Click theCreate Subnetbutton.
* Configure the Subnet Details:
* Name:Enter IAD-SP-PBT-PUBSNET-01.
* Compartment:Ensure it is set to the assigned compartment.
* Subnet Type:SelectPublic Subnet.
* CIDR Block:Enter 10.0.1.0/24.
* Route Table:Select the default route table associated with the VCN (ensure it includes a route to the Internet Gateway with destination 0.0.0.0/0).
* Subnet Access:SelectPublic Subnetand ensure the Internet Gateway is associated.
* DHCP Options eave as default or customize if required.
* Security List:Use the default security list or create a new one with appropriate ingress/egress rules (e.g., allow TCP port 22 for SSH and all egress traffic).
* Associate the Internet Gateway:
* Verify that the subnet is configured to route traffic through the Internet Gateway. This is automatically handled if you selected the public subnet option and the VCN's route table is correctly set (as configured in Task 3).
* If needed, edit the route table for the subnet to ensure a rule exists:
* Destination CIDR Block:0.0.0.0/0
* Target Type:Internet Gateway
* Target:Select the Internet Gateway associated with IAD-SP-PBT-VCN-01.
* Create the Subnet:
* ClickCreateto provision the subnet.
* Once created, the subnet will be listed under the VCN's subnets.
* Verify the Configuration:
* Go to the subnet details page for IAD-SP-PBT-PUBSNET-01.
* Confirm the CIDR block is 10.0.1.0/24 and that it is a public subnet with Internet Gateway access.
Notes
* Ensure the CIDR block 10.0.1.0/24 does not overlap with existing subnets in the VCN (10.0.0.0/16, including 10.0.10.0/24 from Task 3).
* The Internet Gateway association relies on the route table configuration from Task 3. If it's missing, update the route table as described in Step 6.
NEW QUESTION # 37
With the aid of our Oracle 1z0-1104-25 exam preparation to improve your grade and change your states of life and get amazing changes in career, everything is possible. It all starts from our Oracle 1z0-1104-25 learning questions. Our Oracle 1z0-1104-25 training questions are the accumulation of professional knowledge worthy practicing and remembering.
1z0-1104-25 New Dumps Questions: https://www.vcedumps.com/1z0-1104-25-examcollection.html
- Valid 1z0-1104-25 Reliable Test Notes Offers Candidates High Pass-rate Actual Oracle Oracle Cloud Infrastructure 2025 Security Professional Exam Products 🚼 Enter ➤ [url]www.exam4labs.com ⮘ and search for ☀ 1z0-1104-25 ️☀️ to download for free 🙅Exam 1z0-1104-25 Pattern[/url]
- Pass Guaranteed Quiz 2026 Oracle First-grade 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional Reliable Test Notes 🥨 Copy URL [url]www.pdfvce.com open and search for ➠ 1z0-1104-25 🠰 to download for free 🧶1z0-1104-25 Interactive Questions[/url]
- Exam 1z0-1104-25 Pattern 🎤 Key 1z0-1104-25 Concepts 🤶 1z0-1104-25 Latest Exam Experience 🔬 Enter [url]www.dumpsmaterials.com and search for ➠ 1z0-1104-25 🠰 to download for free 🔥1z0-1104-25 Reliable Learning Materials[/url]
- Latest 1z0-1104-25 Examprep 🦱 Unlimited 1z0-1104-25 Exam Practice 🕵 1z0-1104-25 Test Price 🩺 Easily obtain free download of 1z0-1104-25 by searching on [url]www.pdfvce.com 📷1z0-1104-25 Boot Camp[/url]
- Reliable 1z0-1104-25 Learning Materials 🎧 Key 1z0-1104-25 Concepts 🚉 New 1z0-1104-25 Dumps Book ❇ Copy URL ➡ [url]www.easy4engine.com ️⬅️ open and search for ➥ 1z0-1104-25 🡄 to download for free 🌐1z0-1104-25 Latest Exam Experience[/url]
- 1z0-1104-25 Interactive Questions ❓ 1z0-1104-25 Latest Exam Experience 🌞 Exam 1z0-1104-25 Pattern 🥠 Open ✔ [url]www.pdfvce.com ️✔️ and search for ➽ 1z0-1104-25 🢪 to download exam materials for free 🕸Guide 1z0-1104-25 Torrent[/url]
- Free PDF 2026 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional CHigh Pass-Rate Reliable Test Notes 🛢 Search for ▶ 1z0-1104-25 ◀ and easily obtain a free download on ⏩ [url]www.troytecdumps.com ⏪ 🦪Key 1z0-1104-25 Concepts[/url]
- Free PDF Quiz 2026 Efficient 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional Reliable Test Notes 🥩 Search for 1z0-1104-25 and download exam materials for free through [url]www.pdfvce.com 🏃1z0-1104-25 Valid Dumps Ppt[/url]
- Pass Guaranteed Quiz 2026 Oracle First-grade 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional Reliable Test Notes 🩳 Enter [url]www.prep4sures.top and search for ⇛ 1z0-1104-25 ⇚ to download for free 🤩Key 1z0-1104-25 Concepts[/url]
- Hot 1z0-1104-25 Reliable Test Notes | Amazing Pass Rate For 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional | Free PDF 1z0-1104-25 New Dumps Questions 🌳 Search on ⏩ [url]www.pdfvce.com ⏪ for ➥ 1z0-1104-25 🡄 to obtain exam materials for free download 🐜1z0-1104-25 Latest Exam Experience[/url]
- Pass Guaranteed Quiz 2026 Oracle First-grade 1z0-1104-25: Oracle Cloud Infrastructure 2025 Security Professional Reliable Test Notes 💖 Search for ⏩ 1z0-1104-25 ⏪ and download it for free on ➡ [url]www.pass4test.com ️⬅️ website 🐅1z0-1104-25 Latest Exam Fee[/url]
- academy.wassimamanssour.com, www.stes.tyc.edu.tw, hhi.instructure.com, bbs.t-firefly.com, school.celebrationministries.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of VCEDumps 1z0-1104-25 dumps from Cloud Storage: https://drive.google.com/open?id=1a0QxrKzUBa1KKlv4W-pRQSdKOO0_Fo0X
