Exam NCM-MCI Collection, Training NCM-MCI Kit
Posted at 1/11/2026 16:19:09
What's more, part of that Pass4training NCM-MCI dumps now are free: https://drive.google.com/open?id=1sRNaEMNuEbWxFHnD6vcWn5Upz2t7BzLm
Pass4training provides Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) practice tests (desktop and web-based) to its valuable customers so they get the awareness of the Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) certification exam format. Likewise, Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) exam preparation materials for Nutanix Certified Master - Multicloud Infrastructure v6.10 (NCM-MCI) exam can be downloaded instantly after you make your purchase.
For more info visit:NutanixNCM-MCI Exam Reference
Training NCM-MCI Kit | NCM-MCI Valid Test FormatLike the real exam, Pass4training Nutanix NCM-MCI Exam Dumps not only contain all questions that may appear in the actual exam, also the SOFT version of the dumps comprehensively simulates the real exam. With Pass4training real questions and answers, when you take the exam, you can handle it with ease and get high marks.
Nutanix Certified Master - Multicloud Infrastructure v6.10 Sample Questions (Q15-Q20):NEW QUESTION # 15
Task 9
Part1
An administrator logs into Prism Element and sees an alert stating the following:
Cluster services down on Controller VM (35.197.75.196)
Correct this issue in the least disruptive manner.
Part2
In a separate request, the security team has noticed a newly created cluster is reporting.
CVM [35.197.75.196] is using the default password.
They have provided some new security requirements for cluster level security.
Security requirements:
Update the default password for the root user on the node to match the admin user password: Note: 192.168.x.x is not available. To access a node use the Host IP (172.30.0.x) from a CVM or the supplied external IP address.
Update the default password for the nutanix user on the CVM to match the admin user password.
Resolve the alert that is being reported.
Output the cluster-wide configuration of the SCMA policy to DesktopFilesoutput.txt before changes are made.
Enable the Advance intrusion Detection Environment (AIDE) to run on a weekly basis for the cluster.
Enable high-strength password policies for the cluster.
Ensure CVMs require SSH keys for login instead of passwords. (SSH keys are located in the DesktopFilesSSH folder).
Ensure the clusters meets these requirements. Do not reboot any cluster components.
See the Explanation for step by step solution
To correct the issue of cluster services down on Controller VM (35.197.75.196) in the least disruptive manner, you need to do the following steps:
Log in to Prism Element using the admin user credentials.
Go to the Alerts page and click on the alert to see more details.
You will see which cluster services are down on the Controller VM. For example, it could be cassandra, curator, stargate, etc.
To start the cluster services, you need to SSH to the Controller VM using the nutanix user credentials. You can use any SSH client such as PuTTY or Windows PowerShell to connect to the Controller VM. You will need the IP address and the password of the nutanix user, which you can find in DesktopFilesSSHutanix.txt.
Once you are logged in to the Controller VM, run the command:
cluster status | grep -v UP
This will show you which services are down on the Controller VM.
To start the cluster services, run the command:
cluster start
This will start all the cluster services on the Controller VM.
To verify that the cluster services are running, run the command:
This should show no output, indicating that all services are up.
To clear the alert, go back to Prism Element and click on Resolve in the Alerts page.
To meet the security requirements for cluster level security, you need to do the following steps:
To update the default password for the root user on the node to match the admin user password, you need to SSH to the node using the root user credentials. You can use any SSH client such as PuTTY or Windows PowerShell to connect to the node. You will need the IP address and the password of the root user, which you can find in DesktopFilesSSHoot.txt.
Once you are logged in to the node, run the command:
passwd
This will prompt you to enter a new password for the root user. Enter the same password as the admin user, which you can find in DesktopFilesSSHadmin.txt.
To update the default password for the nutanix user on the CVM to match the admin user password, you need to SSH to the CVM using the nutanix user credentials. You can use any SSH client such as PuTTY or Windows PowerShell to connect to the CVM. You will need the IP address and the password of the nutanix user, which you can find in DesktopFilesSSHutanix.txt.
Once you are logged in to the CVM, run the command:
passwd
This will prompt you to enter a new password for the nutanix user. Enter the same password as the admin user, which you can find in DesktopFilesSSHadmin.txt.
To resolve the alert that is being reported, go back to Prism Element and click on Resolve in the Alerts page.
To output the cluster-wide configuration of SCMA policy to DesktopFilesoutput.txt before changes are made, you need to log in to Prism Element using the admin user credentials.
Go to Security > SCMA Policy and click on View Policy Details. This will show you the current settings of SCMA policy for each entity type.
Copy and paste these settings into a new text file named DesktopFilesoutput.txt.
To enable AIDE (Advanced Intrusion Detection Environment) to run on a weekly basis for the cluster, you need to log in to Prism Element using the admin user credentials.
Go to Security > AIDE Configuration and click on Enable AIDE. This will enable AIDE to monitor file system changes on all CVMs and nodes in the cluster.
Select Weekly as the frequency of AIDE scans and click Save.
To enable high-strength password policies for the cluster, you need to log in to Prism Element using the admin user credentials.
Go to Security > Password Policy and click on Edit Policy. This will allow you to modify the password policy settings for each entity type.
For each entity type (Admin User, Console User, CVM User, and Host User), select High Strength as the password policy level and click Save.
To ensure CVMs require SSH keys for login instead of passwords, you need to log in to Prism Element using the admin user credentials.
Go to Security > Cluster Lockdown and click on Configure Lockdown. This will allow you to manage SSH access settings for the cluster.
Uncheck Enable Remote Login with Password. This will disable password-based SSH access to the cluster.
Click New Public Key and enter a name for the key and paste the public key value from DesktopFilesSSHid_rsa.pub. This will add a public key for key-based SSH access to the cluster.
Click Save and Apply Lockdown. This will apply the changes and ensure CVMs require SSH keys for login instead of passwords.
Part1
Enter CVM ssh and execute:
cluster start
If there are issues starting some services, check the following:
Check if the node is in maintenance mode by running the ncli host ls command on the CVM. Verify if the parameter Under Maintenance Mode is set to False for the node where the services are down. If the parameter Under Maintenance Mode is set to True, remove the node from maintenance mode by running the following command:
* nutanix@cvm$ ncli host edit id=<host id> enable-maintenance-mode=false You can determine the host ID by using ncli host ls.
See the troubleshooting topics related to failed cluster services in the Advanced Administration Guide available from the Nutanix Portal's Software Documentation page. (Use the filters to search for the guide for your AOS version). These topics have information about common and AOS-specific logs, such as Stargate, Cassandra, and other modules.
* Check for any latest FATALs for the service that is down. The following command prints all the FATALs for a CVM. Run this command on all CVMs.
nutanix@cvm$ for i in `svmips`; do echo "CVM: $i"; ssh $i "ls -ltr /home/nutanix/data/logs/*.FATAL"; done NCC Health Check: cluster_services_down_check (nutanix.com) Part2 Update the default password for the root user on the node to match the admin user password echo -e "CHANGING ALL AHV HOST ROOT PASSWORDS.Please input new password: "; read -rs password1; echo "Confirm new password: "; read -rs password2; if [ "$password1" == "$password2" ]; then for host in $(hostips); do echo Host $host; echo $password1 | ssh root@$host "passwd --stdin root"; done; else echo "The passwords do not match"; fi Update the default password for the nutanix user on the CVM sudo passwd nutanix Output the cluster-wide configuration of the SCMA policy ncli cluster get-hypervisor-security-config Output Example:
nutanix@NTNX-372a19a3-A-CVM:10.35.150.184:~$ ncli cluster get-hypervisor-security-config Enable Aide : false Enable Core : false Enable High Strength P... : false Enable Banner : false Schedule : DAILY Enable iTLB Multihit M... : false Enable the Advance intrusion Detection Environment (AIDE) to run on a weekly basis for the cluster.
ncli cluster edit-hypervisor-security-params enable-aide=true
ncli cluster edit-hypervisor-security-params schedule=weekly
ncli cluster edit-hypervisor-security-params enable-high-strength-password=true Ensure CVMs require SSH keys for login instead of passwords
https://portal.nutanix.com/page/ ... =kA0600000008gb3CAA
NEW QUESTION # 16
Task 16
Running NCC on a cluster prior to an upgrade results in the following output FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%) Identify the CVM with the issue, remove the fil causing the storage bloat, and check the health again by running the individual disk usage health check only on the problematic CVM do not run NCC health check Note: Make sure only the individual health check is executed from the affected node
To identify the CVM with the issue, remove the file causing the storage bloat, and check the health again, you can follow these steps:
Log in to Prism Central and click on Entities on the left menu.
Select Virtual Machines from the drop-down menu and find the NCC health check output file from the list. You can use the date and time information to locate the file. The file name should be something like ncc-output-YYYY-MM-DD-HH-MM-SS.log.
Open the file and look for the line that says FAIL: CVM System Partition /home usage at 93% (greater than threshold, 90%). Note down the IP address of the CVM that has this issue. It should be something like X.X.X.X.
Log in to the CVM using SSH or console with the username and password provided.
Run the command du -sh /home/* to see the disk usage of each file and directory under /home. Identify the file that is taking up most of the space. It could be a log file, a backup file, or a temporary file. Make sure it is not a system file or a configuration file that is needed by the CVM.
Run the command rm -f /home/<filename> to remove the file causing the storage bloat. Replace <filename> with the actual name of the file.
Run the command ncc health_checks hardware_checks disk_checks disk_usage_check --cvm_list=X.X.X.X to check the health again by running the individual disk usage health check only on the problematic CVM. Replace X.X.X.X with the IP address of the CVM that you noted down earlier.
Verify that the output shows PASS: CVM System Partition /home usage at XX% (less than threshold, 90%). This means that the issue has been resolved.
#access to CVM IP by Putty
allssh df -h #look for the path /dev/sdb3 and select the IP of the CVM
ssh CVM_IP
ls
cd software_downloads
ls
cd nos
ls -l -h
rm files_name
df -h
NEW QUESTION # 17
TASK2
The security team has provided some new security requirements for cluster level security on Cluster 2.
Update the password for the root user on the Cluster 2 node to match the admin user password.
Note: The 192.168.x.x network is not available. To access a node use the host IP (172.30.0.x) from the CVM.
Output the cluster-wide configuration of the SCMA policy to desktopoutput.txt before changes are made.
Enable the Advanced Intrusion Detection Environment (AIDE) to run on a weekly basis for the hypervisor and cvms for Cluster 2.
Enable high-strength password policies for the hypervisor and cluster.
Ensure CVMs require SSH keys for login instead of passwords. (SSH keys are located in the desktopFilesSSH folder.) Ensure the cluster meets these requirements. Do not reboot any cluster components.
Note: Please ensure you are modifying the correct components.
See the Explanation
This task focuses on Security Technical Implementation Guides (STIGs) and general hardening of the Nutanix cluster. Most of these tasks are best performed via the Nutanix Command Line Interface (ncli) on the CVM, though the SSH key requirement is often easier to handle via the Prism GUI.
Here is the step-by-step procedure to complete Task 2.
Prerequisites: Connection
Open PuTTY (or the available terminal) from the provided Windows Desktop.
SSH into the Cluster 2 CVM. (If the Virtual IP is unknown, check Prism Element for the CVM IP).
Log in using the provided credentials (usually nutanix / nutanix/4u or the admin password provided in your instructions).
Step 1: Output SCMA Policy (Do this FIRST)
Requirement: Output the cluster-wide configuration of the SCMA policy to desktopoutput.txt before changes are made.
In the SSH session on the CVM, run:
Bash
ncli cluster get-software-config-management-policy
Copy the output from the terminal window.
Open Notepad on the Windows Desktop.
Paste the output.
Save the file as output.txt on the Desktop.
Step 2: Enable AIDE (Weekly)
Requirement: Enable the Advanced Intrusion Detection Environment (AIDE) to run on a weekly basis for the hypervisor and CVMs.
In the same CVM SSH session, run the following command to modify the SCMA policy:
Bash
ncli cluster edit-software-config-management-policy enable-aide=true schedule-interval=WEEKLY (Note: This single command applies the policy to both Hypervisor and CVMs by default in most versions).
Step 3: Enable High-Strength Password Policies
Requirement: Enable high-strength password policies for the hypervisor and cluster.
Run the following command:
Bash
ncli cluster set-high-strength-password-policy enable=true
Step 4: Update Root Password for Cluster Nodes
Requirement: Update the password for the root user on the Cluster 2 node to match the admin user password.
Method A: The Automated Way (Recommended)
Use ncli to set the password for all hypervisor nodes at once without needing to SSH into them individually.
Run:
Bash
ncli cluster set-hypervisor-password
When prompted, enter the current admin password (this becomes the new root password).
Method B: The Manual Way (If NCLI fails or manual access is required)
Note: Use this if the exam specifically wants you to touch the node via the 172.x network.
From the CVM, SSH to the host using the internal IP:
Bash
ssh root@172.30.0.x (Replace x with the host ID, e.g., 4 or 5)
Run the password change command:
Bash
passwd
Enter the admin password twice.
Repeat for other nodes in Cluster 2.
Step 5: Cluster Lockdown (SSH Keys)
Requirement: Ensure CVMs require SSH keys for login instead of passwords.
It is safest to do this via the Prism Element GUI to prevent locking yourself out.
Open Prism Element for Cluster 2 in the browser.
Click the Gear Icon (Settings) -> Cluster Lockdown.
Uncheck the box "Enable Remote Login with Password".
Click New Public Key (or Add Key).
Open the folder DesktopFilesSSH on the Windows desktop.
Open the public key file (usually ends in .pub) in Notepad and copy the contents.
Paste the key into the Prism "Key" box.
Click Save.
Note: Do not reboot the cluster. The SCMA and Password policies take effect immediately without a reboot.
NEW QUESTION # 18
Task 14
The application team has requested several mission-critical VMs to be configured for disaster recovery. The remote site (when added) will not be managed by Prism Central. As such, this solution should be built using the Web Console.
Disaster Recovery requirements per VM:
Mkt01
RPO: 2 hours
Retention: 5 snapshots
Fin01
RPO: 15 minutes
Retention: 7 days
Dev01
RPO: 1 day
Retention: 2 snapshots
Configure a DR solution that meets the stated requirements.
Any objects created in this item must start with the name of the VM being protected.
Note: the remote site will be added later
To configure a DR solution that meets the stated requirements, you can follow these steps:
Log in to the Web Console of the source cluster where the VMs are running.
Click on Protection Domains on the left menu and click on Create Protection Domain.
Enter a name for the protection domain, such as PD_Mkt01, and a description if required. Click Next.
Select Mkt01 from the list of VMs and click Next.
Select Schedule Based from the drop-down menu and enter 2 hours as the interval. Click Next.
Select Remote Site from the drop-down menu and choose the remote site where you want to replicate the VM. Click Next.
Enter 5 as the number of snapshots to retain on both local and remote sites. Click Next.
Review the protection domain details and click Finish.
Repeat the same steps for Fin01 and Dev01, using PD_Fin01 and PD_Dev01 as the protection domain names, and adjusting the interval and retention values according to the requirements.
NEW QUESTION # 19
Task 10
An administrator is working to create a VM using Nutanix V3 API calls with the following specifications.
* VM specifications:
* vCPUs: 2
* Memory: BGb
* Disk Size: 50Gb
* Cluster: Cluster A
* Network: default- net
The API call is falling, indicating an issue with the payload:
The body is saved in Desktop/ Files/API_Create_VM,text
Correct any issues in the text file that would prevent from creating the VM. Also ensure the VM will be created as speeded and make sure it is saved for re-use using that filename.
Deploy the vm through the API
Note: Do not power on the VM.
https://portal.nutanix.com/page/ ... =kA00e000000LLEzCAO
https://jsonformatter.curiousconcept.com/#
acli net.list (uuid network defult_net)
ncli cluster info (uuid cluster)
Put Call: https://Prism Central IP address : 9440/api/nutanix/v3vms
Edit these lines to fix the API call, do not add new lines or copy lines.
You can test using the Prism Element API explorer or PostMan
Body:
"spec": {
"name": "Test_Deploy",
"resources": {
"power_state":"OFF",
"num_vcpus_per_socket": ,
"num_sockets": 1,
"memory_size_mib": 8192,
"disk_list": [
"disk_size_mib": 51200,
"device_properties": {
"device_type":"DISK"
"device_type":"CDROM"
"nic_list":[
"nic_type": "NORMAL_NIC",
"is_connected": true,
"ip_endpoint_list": [
"ip_type": "DHCP"
"subnet_reference": {
"kind": "subnet",
"name": "default_net",
"uuid": "00000000-0000-0000-0000-000000000000"
"cluster_reference": {
"kind": "cluster",
"name": "NTNXDemo",
"api_version": "3.1.0",
"metadata": {
"kind": "vm"
https://www.nutanix.dev/2019/08/ ... t-api-post-request/ Reference
NEW QUESTION # 20
Once you use our NCM-MCI exam materials, you don't have to worry about consuming too much time, because high efficiency is our great advantage. You only need to spend 20 to 30 hours on practicing and consolidating of our NCM-MCI learning material, you will have a good result. After years of development practice, our NCM-MCI test torrent is absolutely the best. You will embrace a better future if you choose our NCM-MCI exam materials.
Training NCM-MCI Kit: https://www.pass4training.com/NCM-MCI-pass-exam-training.html
NCM-MCI reliable exam dumps will help you pass exam and obtain a valuable change, Nutanix Exam NCM-MCI Collection the study guide contains 1610 pages which i found to be very helpful, Nutanix Exam NCM-MCI Collection No restriction to install, So stop hesitating, our NCM-MCI guide torrent are your right choice, With NCM-MCI exam study guides, you will own the key to pass NCM-MCI actual exam, which will make you develop better in this industry.
It was just marvelous, Deepak Iyengar received his Ph.D, NCM-MCI Reliable Exam Dumps will help you pass exam and obtain a valuable change, the study guide contains 1610 pages which i found to be very helpful.
Exam NCM-MCI Collection | Latest Training NCM-MCI Kit: Nutanix Certified Master - Multicloud Infrastructure v6.10 100% PassNo restriction to install, So stop hesitating, our NCM-MCI guide torrent are your right choice, With NCM-MCI exam study guides, you will own the key to pass NCM-MCI actual exam, which will make you develop better in this industry.
- Full fill Your Goals by Achieve the Nutanix NCM-MCI Certification 🔭 The page for free download of 【 NCM-MCI 】 on 「 [url]www.torrentvce.com 」 will open immediately 🐁NCM-MCI Dump[/url]
- 100% Pass Quiz Nutanix - NCM-MCI - Nutanix Certified Master - Multicloud Infrastructure v6.10 –The Best Exam Collection ⏮ Easily obtain ⮆ NCM-MCI ⮄ for free download through ▶ [url]www.pdfvce.com ◀ 🖤Dump NCM-MCI Collection[/url]
- NCM-MCI Practice Guide Materials: Nutanix Certified Master - Multicloud Infrastructure v6.10 and NCM-MCI Study Torrent - [url]www.exam4labs.com 😛 Search for ⮆ NCM-MCI ⮄ and easily obtain a free download on ( www.exam4labs.com ) 🚣NCM-MCI Valid Learning Materials[/url]
- Free PDF Nutanix - NCM-MCI High Hit-Rate Exam Collection 🤦 Download ➡ NCM-MCI ️⬅️ for free by simply searching on ▶ [url]www.pdfvce.com ◀ 🏹NCM-MCI Valid Cram Materials[/url]
- NCM-MCI Exam Pass Guide 🕋 NCM-MCI Valid Learning Materials 🚡 NCM-MCI Valid Learning Materials 🆗 Download { NCM-MCI } for free by simply entering ( [url]www.pass4test.com ) website 🍗NCM-MCI Braindump Pdf[/url]
- NCM-MCI Practice Guide Materials: Nutanix Certified Master - Multicloud Infrastructure v6.10 and NCM-MCI Study Torrent - Pdfvce ☎ Search for { NCM-MCI } and download it for free on ➥ [url]www.pdfvce.com 🡄 website 🚾NCM-MCI New Braindumps Questions[/url]
- 100% Pass Quiz Nutanix - NCM-MCI - Nutanix Certified Master - Multicloud Infrastructure v6.10 –The Best Exam Collection 🌛 Open ▶ [url]www.vceengine.com ◀ enter ➥ NCM-MCI 🡄 and obtain a free download 🦊NCM-MCI Valid Cram Materials[/url]
- NCM-MCI Valid Cram Materials 👹 NCM-MCI Latest Test Materials 🎲 NCM-MCI Braindump Pdf 🏁 Easily obtain ( NCM-MCI ) for free download through ▶ [url]www.pdfvce.com ◀ ✍NCM-MCI Valid Cram Materials[/url]
- 100% Pass Quiz Nutanix - NCM-MCI - Nutanix Certified Master - Multicloud Infrastructure v6.10 –The Best Exam Collection 🥅 Open ➤ [url]www.dumpsquestion.com ⮘ and search for ✔ NCM-MCI ️✔️ to download exam materials for free 🧍NCM-MCI Braindump Pdf[/url]
- Updated Nutanix NCM-MCI Practice Exams for Self-Assessment (Web-Based and Desktop) 👫 Download 「 NCM-MCI 」 for free by simply searching on 【 [url]www.pdfvce.com 】 ➡NCM-MCI Exam Pass Guide[/url]
- Exam-oriented NCM-MCI Exam Questions Compose of the Most Accurate Practice Braindumps - [url]www.examcollectionpass.com 🚃 Immediately open ➠ www.examcollectionpass.com 🠰 and search for ➤ NCM-MCI ⮘ to obtain a free download 🤏Latest NCM-MCI Exam Format[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, ghrcn.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, wanderlog.com, bbs.t-firefly.com, elevatetoexpert.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, abdanielscareacademy.com.ng, Disposable vapes
