[Linux] ROC-RK3308B-CC-PLUS Ubuntu Minimal Firmware not working + swap option in kernel
25
Posted at 1/5/2022 06:26:35
First the current "ROC-RK3308B-CC-PLUS Ubuntu Minimal Firmware" isn't working. If you unpack the image and replace the boot.img with the one from the "ROC-RK3308B-CC-PLUS Ubuntu Desktop Firmware' it works.
Second both the ubuntu firmwares (ROC-RK3308B-CC-PLUS Ubuntu Minimal Firmware and ROC-RK3308B-CC-PLUS Ubuntu Desktop Firmware) for this board are compiled without the swap option enabled in the kernel. Could you generate the firmwares with this option enabled ? I think this is something generally desirable.
Posted at 1/5/2022 10:02:17
what is not working? any log will help.
Posted at 1/5/2022 16:02:50
Javier Posted at 1/5/2022 10:02
I'm pointing out 2 things. The minimal ubuntu firmware from https://en.t-firefly.com/doc/download/page/id/84.html isn't working when downloaded from the site and uploaded to the board. The red light keeps flashing, i don't have a log, but probably kernel panic. It can be solved by replacing the boot.img that's within the firmware image of the small ubuntu firmware with the one from the full ubuntu firmware and upload that to the board.
The other thing is that both ubuntu images are built with a kernel where the swap option has been disabled. This means that when executing the following script to configure 1 gb of swap space on the board:
dd if=/dev/zero of=/var/swap1 count=1K bs=1M
mkswap /var/swap1
sudo chown root:root /var/swap1
sudo chmod 600 /var/swap1
sudo swapon /var/swap1
The last command gives the following error:
        swapon failed: Function not implemented
I think firefly needs to rebuild and replace the small ubuntu image on the site with a good one and when doing so recompile the kernel with the swap option enabled. And probably do the same for the other full ubuntu image.
Posted at 11/23/2022 18:39:54
ecbouma Posted at 1/5/2022 16:02
I'm pointing out 2 things. The minimal ubuntu firmware from https://en.t-firefly.com/doc/download/ ...
So helpful. Thanks for your sharing.
Posted at 1/10/2026 09:09:31
The article is excellently written, and it has benefited me greatly. I achieved my promotion and salary raise with this Reliable C_THR92_2505 braindumps free. Now its free for all. Hope you get promoted soon!
Posted at 1/12/2026 23:35:45
This article is truly eye-opening, thank you for sharing. I used the Training CInP Tools to get promoted and raise my salary. Its now free for everyone. Best of luck with your career goals!
Posted at 1/29/2026 09:29:58
Im really moved by this article, thanks for sharing! The JN0-351 latest test fee content is excellent, and its available to everyone free of charge.
Posted at 2/12/2026 06:56:05
̤rgԷ֤ITܤ򉈏ɡ|ѧ̲ĤʤΤǐǤޤʤPass4TestCompTIAXK0-005-JPNԇYȥ`˥YϤ֤ʤ顢ITvJԇYϤʤǤS˺ϸǤޤPass4Test CompTIAXK0-005-JPNԇYȥ`˥YϤϸ߶ȤJ^줿ITIΌTҤνUYȄ򺬤ƤΤǤPass4TestϾˤȤäơ٥ȤxkȤäƤǤ
Posted at 2/21/2026 22:50:57
Your article is outstanding, thank you for sharing! Get the Valid exam ISO-9001-Lead-Auditor practice exam questions for freewishing you all the best in your exams!
Posted at 3/10/2026 01:35:55
Wenn Sie die EchteFrage Website klicken, wundern Sie sich vielleicht, dass viele Leute jedentag EchteFrage besuchen. Das ist ganz normal. Wir bieten den Kandidaten zahlreiche Schulungsunterlagen, mit denen sie die PMI PMI-ACP Prfung bestehen können. Das heißt, dass die Schulungsunterlagen wirklich wirksam sind. Wenn Sie die PMI PMI-ACP Fragenkatalog kaufen wollen, verpassen Sie EchteFrage nicht. Und Sie werden sicher mit unseren Produkten zufrieden.
