[Hardware] Top 2V0-21.23 Premium Files | High Pass-Rate VMware Test 2V0-21.23 Tutorials: VM
62
Hardware Top 2V0-21.23 Premium Files | High Pass-Rate VMware Test 2V0-21.23 Tutorials: VM
Posted at 1/11/2026 20:03:28      View250 | Replies3        Print      Only Author   [Copy Link] 1#
What's more, part of that VerifiedDumps 2V0-21.23 dumps now are free: https://drive.google.com/open?id=1A8czXA4vW7OYoWiC-SF9LMPsIHkXElmq
Firstly, we can give you 100% pass rate guarantee on the 2V0-21.23 exam. Our 2V0-21.23 practice quiz is equipped with a simulated examination system with timing function, allowing you to examine your learning results at any time, keep checking for defects, and improve your strength. Secondly, during the period of using 2V0-21.23 learning guide, we also provide you with 24 hours of free online services, which help to solve any problem for you on the 2V0-21.23 exam questions at any time and sometimes mean a lot to our customers.
VMware is one of the most popular virtualization platforms available on the market. It is used by thousands of enterprises to virtualize their servers, desktops, and applications. VMware vSphere is the flagship product of VMware that enables businesses to build a private or public cloud infrastructure. VMware vSphere enables users to virtualize their data center, which reduces hardware expenditure and increases the flexibility of the IT infrastructure. If you want to prove your VMware vSphere skill set, you can take the VMware 2V0-21.23 (VMware vSphere 8.x Professional) certification exam.
Test 2V0-21.23 Tutorials, 2V0-21.23 Valid Test VoucherWhat 2V0-21.23 study materials can give you is far more than just a piece of information. First of all, 2V0-21.23 study materials can save you time and money. As a saying goes, to sensible men, every day is a day of reckoning. Every minute 2V0-21.23 study material saves for you may make you a huge profit. Secondly, 2V0-21.23 Study Materials will also help you to master a lot of very useful professional knowledge in the process of helping you pass the exam. The 2V0-21.23 study materials are valuable, but knowledge is priceless.
VMware vSphere 8.x Professional Sample Questions (Q13-Q18):NEW QUESTION # 13
An administrator has mapped three vSphere zones to three vSphere clusters.
Which two statements are true for this vSphere with Tanzu zonal Supervisor enablement? (Choose two.)
  • A. One Supervisor will be created across all zones.
  • B. Three Supervisors will be created in Linked Mode.
  • C. One Supervisor will be created in a specific zone.
  • D. Individual vSphere Namespaces will be spread across all zones.
  • E. Individual vSphere Namespaces will be placed into a specific zone.
Answer: C,E
When mapping vSphere zones to vSphere clusters, one Supervisor will be created in each zone, and individual vSphere Namespaces will be placed into a specific zone based on their resource requirements and availability constraints.
https://docs.vmware.com/en/VMwar ... C2E9B5C1-D6F1-4E9B-
NEW QUESTION # 14
Given the configuration shown in the exhibit, what should the administrator do if the latest VM template contains changes that are no longer needed?
  • A. Delete App-LibTemplate (3)
  • B. Revert to App-LibTernplate (2)
  • C. Delete App-LibTemplate (2)
  • D. Check out App-LibTemplate (3)
Deleting App-LibTemplate (3) will remove the changes that are no longer needed and revert to the previous version of the template.
https://docs.vmware.com/en/VMwar ... 3-AE975AF9C865.html If the latest VM template contains changes that are no longer needed, the administrator should revert to the previous version of the template1.
Here are the steps to revert to a previous version of a template1:
Navigate to the Versioning tab of the VM template.
From the vertical timeline, navigate to the previous state of the VM template.
Click the horizontal ellipsis icon (⋮), and select Revert to This Version.
The Revert to Version dialog box opens. Enter a reason for the revert operation and click Revert.
So, in this case, the correct answer is: B.
Revert to App-LibTemplate (2)
This will make App-LibTemplate (2) the current VM template1.
Please note that this operation will not delete App-LibTemplate (3), it will simply make App-LibTemplate (2) the current version1.
NEW QUESTION # 15
An administrator is responsible for performing maintenance tasks on a vSphere cluster. The cluster has the following configuration:
. Identically configured vSphere ESXi hosts (esx01, esx02, esx03 and esx04)
* All workloads are deployed into a single VMFS datastore provided by the external storage array
* vSphere High Availability (HA) has not been enabled
* vSphere Distributed Resource Scheduler (DRS) has not been enabled
Currently, a critical production application workload (VM1) is running on esx01.
Given this scenario, which two actions are required to ensure VM1 continues to run when esx01 is placed into maintenance mode? (Choose two.)
  • A. VM1 must be manually migrated to another host within the cluster using vSphere Storage vMotion before esx01 is placed into maintenance mode.
  • B. vSphere HA must be enabled on the cluster so that VM1 will be automatically migrated to another host within the cluster when esx01 is placed into maintenance mode.
  • C. VM1 must be manually live migrated to another host within the cluster using vSphere vMotion before esx01 is placed into maintenance mode.
  • D. Fully automated DRS must be enabled on the cluster so that VM1 will be automatically migrated to another host within the cluster when esx01 is placed into maintenance mode.
  • E. VM1 must be manually shut down and cold migrated to another host within the cluster using vSphere vMotion before esx01 is placed into maintenance mode.
Two actions that are required to ensure VM1 continues to run when esx01 is placed into maintenance mode are enabling fully automated DRS on the cluster, which allows balancing the workload across hosts and migrating VMs without user intervention; and manually live migrating VM1 to another host within the cluster using vSphere vMotion, which allows moving a running VM without downtime.
NEW QUESTION # 16
An administrator creates a virtual machine that contains the latest company-approved software, tools and security updates. Company policy requires that only full clones are allowed for server workloads.
A combination of which two tasks should the administrator complete to prepare for the deployment of this virtual machine for multiple users? (Choose two.)
  • A. Take a snapshot of the virtual machine.
  • B. Convert the virtual machine to a template.
  • C. Create a virtual machine customization specification.
  • D. Set appropriate permissions on the virtual machine.
  • E. Upgrade the virtual hardware.
Option B and D are correct because they allow the administrator to create a virtual machine customization specification, which can be used to customize guest operating system settings for multiple virtual machines, and convert the virtual machine to a template, which can be used to create full clones of server workloads.
Option A is incorrect because assigning appropriate permissions on the virtual machine does not prepare it for deployment for multiple users. Option C is incorrect because upgrading the virtual hardware does not prepare it for deployment for multiple users. Option E is incorrect because taking a snapshot of the virtual machine does not prepare it for deployment for multiple users. References:
https://docs.vmware.com/en/VMwar ... /GUID-9F9E3F8C-0E2B
NEW QUESTION # 17
An administrator is investigating user logon failures for a VMware vCenter instance Where can the administrator find log files containing information related to user login activities?
  • A. On the vCenter Server Appliance
  • B. On the vCenter Management Interface
  • C. On the ESXi host using the Direct Console User Interface
  • D. In the vSphere Client when viewing the vCenter virtual machine
The administrator can find log files containing information related to user login activities on the vCenter Server Appliance, which is a preconfigured Linux-based virtual machine that runs all vCenter Server services. The log files are located in /var/log/vmware/vmware-vpx/vpxd.log and /var/log/vmware/sso/ssoAdminServer.log directories. Reference: https://docs.vmware.com/en/VMwar ... A-CAC5EE8E3734.html
NEW QUESTION # 18
After the user has purchased our 2V0-21.23 learning materials, we will discover in the course of use that our product design is extremely scientific and reasonable. Details determine success or failure, so our every detail is strictly controlled. For example, our learning material's Windows Software page is clearly, our 2V0-21.23 Learning material interface is simple and beautiful. There are no additional ads to disturb the user to use the VMware vSphere 8.x Professional qualification question. Once you have submitted your practice time, 2V0-21.23 study tool system will automatically complete your operation.
Test 2V0-21.23 Tutorials: https://www.verifieddumps.com/2V0-21.23-valid-exam-braindumps.html
P.S. Free & New 2V0-21.23 dumps are available on Google Drive shared by VerifiedDumps: https://drive.google.com/open?id=1A8czXA4vW7OYoWiC-SF9LMPsIHkXElmq
Posted at 1/14/2026 23:03:02        Only Author  2#
This article is very practical, and I have gained a lot of inspiration from it. Enhance your IT abilities and grab free Valid AP-208 test collection file. Wishing you all the best!
Posted at 1/19/2026 15:52:21        Only Author  3#
I really appreciate your article, it has deeply impacted me. The New practice questions PAP-001 ppt helped me secure a promotion and raise. Its now free to all. Wishing you success in your promotion journey!
Posted at 2/5/2026 14:23:36        Only Author  4#
I found the article very inspiring, thanks for the share! Wish me luck as I take on the 300-715 valid study guide ebook exam!
