100% Pass 2026 CDCS Online Exam - Realistic Latest EXIN EPI Certified Data Centr
103
Posted at 1/11/2026 20:19:58      View128 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest Pass4sureCert CDCS PDF Dumps and CDCS Exam Engine Free Share: https://drive.google.com/open?id=1m3sHGMOv27u3mJPpug5uUW5h8MUeWGUh
Pass4sureCert has many EXIN EPI Certified Data Centre Specialist (CDCS) practice questions that reflect the pattern of the real EXIN EPI Certified Data Centre Specialist (CDCS) exam. Pass4sureCert allows you to create a EXIN EPI Certified Data Centre Specialist (CDCS) exam dumps according to your preparation. It is easy to create the EXIN CDCS practice questions by following just a few simple steps. Our EXIN EPI Certified Data Centre Specialist (CDCS) exam dumps are customizable based on the time and type of questions. You have the option to change the topic and set the time according to the actual EXIN EPI Certified Data Centre Specialist (CDCS) exam.
EXIN CDCS Exam Syllabus Topics:
  • Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
  • Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
  • Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
2026 High-quality CDCS Online Exam | CDCS 100% Free Latest Exam PracticePass4sureCert has made the EXIN EPI Certified Data Centre Specialist (CDCS) exam dumps after consulting with professionals and getting positive feedback from customers. The team of Pass4sureCert has worked hard in making this product a successful EXIN CDCS Study Material. So we guarantee that you will not face issues anymore in passing the EXIN CDCS certification test with good grades.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q108-Q113):NEW QUESTION # 108
What precaution shall be taken for cabling leading into an equipment rack when a data center is in a seismic-prone area?
  • A. Cables shall be tightly organized to the rack and trays to avoid movement.
  • B. Cables should be replaced by busbar trunking.
  • C. Cables should be loosely organized to allow for movement and be latched at the connectors.
  • D. Cables can be organized in any way as it is not important.
In seismic-prone areas, cables should be tightly secured to racks and cable trays to minimize movement during seismic activity. Properly securing the cables prevents them from being damaged due to excessive motion, which could lead to outages or damage to connected equipment.
Detailed Explanation:
Loose cables can be vulnerable to shaking or sudden jolts during an earthquake, increasing the risk of disconnection or damage. By tightly organizing and securing cables, you ensure they remain in place, even during significant movement, thereby maintaining connection integrity and reducing the risk of physical damage.
EPI Data Center Specialist References:
EPI training includes considerations for data centers in seismic zones, advising that cables be firmly anchored to support structures to reduce movement and mitigate potential damage during seismic events.
NEW QUESTION # 109
The data center has been in operation for about 1 year and 2 months. The dust levels in the computer room are relatively high.
What is the most likely root cause?
  • A. The cleaning crew is not doing their work properly
  • B. Low pressure in the computer room
  • C. Floorboards are most likely not fitted correctly
  • D. Every computer room has high dust levels due to constant high-speed air movement
High dust levels in a computer room are often due to improperly fitted floorboards. When floorboards are not securely installed or do not fit tightly, they allow dust and particles from the subfloor to enter the room. In a data center, this can lead to high levels of dust that affect air quality and equipment performance.
Raised floors in data centers can accumulate dust and debris, especially if the floorboards are not properly sealed. Loose or improperly fitted floorboards allow contaminants from the subfloor to enter the data center environment, increasing the dust levels over time. Proper installation and maintenance of floor panels are essential to prevent dust infiltration and maintain clean conditions.
EPI training emphasizes proper flooring installation and maintenance to control air quality within data centers. Correctly fitted floorboards prevent dust accumulation from the subfloor, which helps protect sensitive equipment and maintains a cleaner environment.
NEW QUESTION # 110
You are working with a customer who requires a guarantee that THDi levels coming from the UPS should not exceed more than 3% THDi. Furthermore, he wants to run a power-efficient data center. The UPS has a 6- Pulse SCR/Thyristor based rectifier. The current load on the UPS is approximately 80%. The customer indicates they are not expecting any changes on the ICT infrastructure for the next 3 years.
What should you recommend?
  • A. Install an active harmonic filter on the UPS
  • B. Nothing, the UPS will be able to take care of the right levels of THDi
  • C. Install a passive harmonic filter on the UPS
  • D. Install an isolation transformer rated at K13 or K20
Given the customer's requirement to limit Total Harmonic Distortion (THDi) to below 3% and the presence of a 6-pulse SCR/Thyristor-based rectifier, an active harmonic filter is the best solution. A 6-pulse rectifier typically generates higher harmonic distortion, often exceeding 3%, especially under substantial loads like
80%. An active harmonic filter dynamically monitors and compensates for harmonic distortion, effectively reducing THDi and supporting a more power-efficient operation, aligning with the customer's energy efficiency goals.
Passive harmonic filters can reduce harmonics but are less effective at maintaining low THDi levels under varying loads. Active filters offer real-time correction and can achieve lower THDi levels than passive filters, especially in systems with fluctuating loads or where strict harmonic limits are required. Installing an active harmonic filter will ensure compliance with the specified THDi limits and optimize power quality.
EPI guidance on power quality management recommends active harmonic filters for environments where strict THDi levels are necessary. Active filters offer better control over harmonic levels, supporting both compliance and operational efficiency.
NEW QUESTION # 111
Smoke sensors need to be tested to ensure that they pick up a potential fire in the data center.
  • A. Test the sensors according to the vendor specification
  • B. Inject smoke at the floor level
  • C. Test the sensors by injecting smoke or simulated smoke directly into the sensor
  • D. Press the self-test button on each sensor in the data center
Testing smoke sensors should be conducted according to the vendor specifications to ensure compliance with safety standards and accurate results. Vendors provide specific testing procedures to account for the sensor type, environment, and operational characteristics, ensuring that tests do not damage the equipment or provide false results.
Smoke sensors can vary by type and sensitivity, so following the vendor's recommended testing procedure ensures the sensors function correctly without risking sensor damage. Injecting smoke or using a self-test might be insufficient or could lead to inaccurate assessments if they do not align with the vendor's testing protocol.
EPI recommends adhering to manufacturer specifications for testing critical safety equipment, ensuring that tests reflect real-world conditions without compromising sensor integrity or reliability.
NEW QUESTION # 112
A data center requires an audit to find out whether it conforms with ANSI/TIA-942 Rated-3 (concurrently maintainable).
Will the network architecture be part of this audit?
  • A. Yes, amongst other aspects, the network architecture should be Rated-3 compliant with the requirements of ANSI/TIA-942.
  • B. Yes, but only if the network administration does not comply with ANSI/TIA-606.
  • C. No, only the type of cabling used will be audited.
  • D. No, as concurrently maintainable only applies to electrical and mechanical (power and cooling).
For a Rated-3 data center, network architecture is indeed a key component of the audit under ANSI/TIA-942. This rating requires concurrent maintainability across all systems, including telecommunications infrastructure. The network architecture must therefore meet specific redundancy and reliability standards to ensure uninterrupted operations during maintenance or failure of any single component.
Rated-3 requirements extend beyond electrical and mechanical systems to include network architecture. This ensures that telecommunications systems are also designed for concurrent maintainability, thus contributing to overall uptime and resilience.
EPI endorses comprehensive assessments for Rated-3 facilities, emphasizing that network systems must meet standards for redundancy and concurrent maintainability, which align with ANSI/TIA-942's holistic approach to data center reliability.
NEW QUESTION # 113
In addition to the PDF questions Pass4sureCert offers desktop CDCS practice exam software and web-based EXIN EPI Certified Data Centre Specialist (CDCS) practice exam, to help you cope with EXIN EPI Certified Data Centre Specialist (CDCS) exam anxiety. These EXIN CDCS Practice Exams simulate the actual EXIN CDCS exam conditions and provide you with an accurate assessment of your readiness for the CDCS exam.
Latest CDCS Exam Practice: https://www.pass4surecert.com/EXIN/CDCS-practice-exam-dumps.html
BTW, DOWNLOAD part of Pass4sureCert CDCS dumps from Cloud Storage: https://drive.google.com/open?id=1m3sHGMOv27u3mJPpug5uUW5h8MUeWGUh
Posted at 1/13/2026 09:34:16        Only Author  2#
Your article is outstanding, thank you for sharing! Dont miss out on the New Analytics-Con-301 test fees in global questionsfree and essential for your promotion and salary increase!
Posted at 1/30/2026 15:43:02        Only Author  3#
The article is very rich in content and has introduced me to many new ideas. Sharpen your IT knowledge with free Valid test E_S4CON_2505 format. Wishing you success!
