CTFL_Syll_4.0認證題庫 - CTFL_Syll_4.0最新考古題
Posted at 1/11/2026 22:38:23
2026 NewDumps最新的CTFL_Syll_4.0 PDF版考試題庫和CTFL_Syll_4.0考試問題和答案免費分享:https://drive.google.com/open?id=18uOX4IUTaXzRb30OCRxEy06qSJvucqDA
在IT領域工作的你,肯定想通過IT 認證考試來證明自己的能力吧?而且,擁有IT 認證資格的同事和朋友也愈來愈多了吧。在這種情況下,如果一個資格都沒有就趕不上別人了。那麼,你決定參加哪個考試呢?ISQI的考試怎麼樣呢?比如像CTFL_Syll_4.0認證考試這樣的考試。這是非常有價值的考試,肯定能幫助你實現你的願望。
我們NewDumps ISQI的CTFL_Syll_4.0的考試考古題是經過實踐檢驗的,我們可以提供基於廣泛的研究和現實世界的經驗,我們NewDumps擁有超過計畫0年的IT認證經驗,CTFL_Syll_4.0考試培訓,包括問題和答案。在互聯網上,你可以找到各種培訓工具,準備自己的CTFL_Syll_4.0考試認證,NewDumps的CTFL_Syll_4.0考試試題及答案是最好的培訓資料,我們提供了最全面的驗證問題及答案,讓你得到一年的免費更新期。
快速下載CTFL_Syll_4.0認證題庫擁有模擬真實考試環境與場境的軟件VCE版本&頂尖的CTFL_Syll_4.0最新考古題難道你不想在你的工作生涯中做出一番輝煌的成績嗎?肯定希望那樣吧。那麼,你就有必要時常提升自己了。在ISQI行業工作的你應該怎樣提升自己的水準呢?其實參加IT認證考試獲得認證資格是一個好方法。ISQI的認證考試資格是很重要的資格,因此參加CTFL_Syll_4.0考試的人變得越來越多了。
最新的 ISTQB Foundation Level CTFL_Syll_4.0 免費考試真題 (Q100-Q105):問題 #100
Following a risk-based testing approach you have designed 10 tests to cover a product risk with a high-risk level. You want to estimate, adopting the three-point test estimation technique, the test effort required to reduce the risk level to zero by executing those 10 tests. You made the following three initial estimates:
* most optimistic = 6 person hours
* most likely = 30 person hours
* most pessimistic = 54 person hours
Based only on the given information, which of the following answers about the three-point test estimation technique applied to this problem is true?
- A. The final estimate is between 22 person hours and 38 person hours
- B. The final estimate is exactly 30 person hours because the technique uses the initial most likely estimate as the final estimate
- C. The final estimate is between 6 person hours and 54 person hours
- D. The final estimate is exactly 30 person hours because the technique uses the arithmetic mean of the three initial estimates as the final estimate
答案:A
解題說明:
The three-point test estimation technique is a method of estimating the test effort based on three initial estimates: the most optimistic, the most likely, and the most pessimistic. The technique uses a weighted average of these three estimates to calculate the final estimate, which is also known as the expected value. The formula for the expected value is:
Expected value = (most optimistic + 4 * most likely + most pessimistic) / 6 Using the given values, the expected value is:
Expected value = (6 + 4 * 30 + 54) / 6 Expected value = 30 person hours However, the expected value is not the only factor to consider when estimating the test effort. The technique also calculates the standard deviation, which is a measure of the variability or uncertainty of the estimates.
The formula for the standard deviation is:
Standard deviation = (most pessimistic - most optimistic) / 6
Using the given values, the standard deviation is:
Standard deviation = (54 - 6) / 6 Standard deviation = 8 person hours
The standard deviation can be used to determine a range of possible values for the test effort, based on a certain level of confidence. For example, using a 68% confidence level, the range is:
Expected value ± standard deviation
Using the calculated values, the range is:
30 ± 8 person hours
Therefore, the final estimate is between 22 person hours and 38 person hours, which is option A.
1: ISTQBCertified Tester Foundation Level Syllabus v4.01, Section 2.3.2, page 24-25; ISTQBGlossary v4.
02, page 33.
問題 #101
Which of the following are the phases of the ISTQB fundamental test process?
- A. Test planning. Test specification and design. Test implementation and execution. Evaluating exit criteria and reporting. Retesting and test closure activities
- B. Test planning and control, Test analysis and design, Test implementation and execution, Evaluating ex t criteria and reporting. Test closure activities
- C. Test planning and control, Test specification and design. Test implementation and execution, Evaluating test coverage and reporting, Retesting and regression testing, Test closure activities
- D. Test planning, Test analysis and design. Test implementation and control. Checking test coverage and reporting, Test closure activities
答案:B
解題說明:
The ISTQB fundamental test process consists of five main phases, as described in the ISTQB Foundation Level Syllabus, Version 4.0, 2018, Section 2.2, page 15:
* Test planning and control: This phase involves defining the test objectives, scope, strategy, resources, schedule, risks, and metrics, as well as monitoring and controlling the test activities and results throughout the test process.
* Test analysis and design: This phase involves analyzing the test basis (such as requirements, specifications, or user stories) to identify test conditions (such as features, functions, or scenarios) that need to be tested, and designing test cases and test procedures (such as inputs, expected outcomes, and execution steps) to cover the test conditions. This phase also involves evaluating the testability of the test basis and the test items (such as software or system components), and selecting and implementing test techniques (such as equivalence partitioning, boundary value analysis, or state transition testing) to achieve the test objectives and optimize the test coverage and efficiency.
* Test implementation and execution: This phase involves preparing the test environment (such as hardware, software, data, or tools) and testware (such as test cases, test procedures, test data, or test scripts) for test execution, and executing the test procedures or scripts according to the test plan and schedule. This phase also involves logging the outcome of test execution, comparing the actual results with the expected results, and reporting any discrepancies as incidents (such as defects, errors, or failures).
* Evaluating exit criteria and reporting: This phase involves checking if the planned test activities have been completed and the exit criteria (such as quality, coverage, or risk levels) have been met, and reporting the test results and outcomes to the stakeholders. This phase also involves making recommendations for the release or acceptance decision based on the test results and outcomes, and identifying any residual risks (such as known defects or untested areas) that need to be addressed or mitigated.
* Test closure activities: This phase involves finalizing and archiving the testware and test environment for future reuse, and evaluating the test process and the test project against the test objectives and the test plan. This phase also involves identifying any lessons learned and best practices, and communicating the findings and suggestions for improvement to the relevant parties.
References = ISTQB Certified Tester Foundation Level Syllabus, Version 4.0, 2018, Section 2.2, page 15; ISTQB Glossary of Testing Terms, Version 4.0, 2018, pages 37-38; ISTQB CTFL 4.0 - Sample Exam - Answers, Version 1.1, 2023, Question 88, page 32.
問題 #102
Which ONE of the following work products TYPICALLY belongs to test execution?
- A. Automated test scripts used for test execution.
- B. Test logs that document the results of test execution.
- C. A test plan that describes the test strategy and test objectives.
- D. A list of test conditions prioritized during test analysis.
答案:B
解題說明:
Test execution involves running test cases and documenting results. Test logs (A) provide evidence of executed tests, failures, and actual outcomes. Automated test scripts (B) are part of test implementation, test plans (C) belong to test planning, and test conditions (D) are identified during test analysis.
問題 #103
A calculator software is used to calculate the result for 5+6.
The user noticed that the result given is 6.
This is an example of;
- A. Error
- B. Mistake
- C. Failure
- D. Fault
答案:C
解題說明:
According to the ISTQB Glossary of Testing Terms, Version 4.0, 2018, page 18, a failure is "an event in which a component or system does not perform a required function within specified limits". In this case, the calculator software does not perform the required function of calculating the correct result for 5+6 within the specified limits of accuracy and precision. Therefore, this is an example of a failure.
The other options are incorrect because:
A mistake is "a human action that produces an incorrect result" (page 25). A mistake is not an event, but an action, and it may or may not lead to a failure. For example, a mistake could be a typo in the code, a wrong assumption in the design, or a misunderstanding of the requirement.
A fault is "a defect in a component or system that can cause the component or system to fail to perform its required function" (page 16). A fault is not an event, but a defect, and it may or may not cause a failure. For example, a fault could be a logical error in the code, a missing specification in the design, or a contradiction in the requirement.
An error is "the difference between a computed, observed, or measured value or condition and the true, specified, or theoretically correct value or condition" (page 15). An error is not an event, but a difference, and it may or may not result in a failure. For example, an error could be a rounding error in the calculation, a measurement error in the observation, or a deviation error in the condition.
Reference = ISTQB Glossary of Testing Terms, Version 4.0, 2018, pages 15-18, 25; ISTQB CTFL 4.0 - Sample Exam - Answers, Version 1.1, 2023, Question 96, page 34.
問題 #104
The whole-team approach:
- A. promotes the idea that all team members should be responsible for the quality of the product
- B. is mostly adopted in projects aimed at developing safety-critical systems, as it ensures the highest level of testing independence
- C. is a consensus-based approach that engages the whole team in estimating the user stories
- D. promotes the idea that all team members should have a thorough understanding of test techniques
答案:A
解題說明:
This answer is correct because the whole-team approach is a way of working in agile projects where all team members share the responsibility for the quality of the product, and collaborate on delivering value to the customer. The whole-team approach involves testers, developers, business analysts, product owners, and other stakeholders in planning, designing, developing, testing, and delivering the product. The whole-team approach fosters communication, feedback, learning, and continuous improvement within the team. References: ISTQB Glossary of Testing Terms v4.0, ISTQB Foundation Level Syllabus v4.0, Section 3.1.1.1
問題 #105
想通過學習ISQI的CTFL_Syll_4.0認證考試的相關知識來提高自己的技能,讓別人更加認可你嗎?ISQI的考試可以讓你更好地提升你自己。如果你取得了CTFL_Syll_4.0認證考試的資格,那麼你就可以更好地完成你的工作。雖然這個考試很難,但是你準備考試時不用那麼辛苦。使用NewDumps的CTFL_Syll_4.0考古題以後你不僅可以一次輕鬆通過考試,還可以掌握考試要求的技能。
CTFL_Syll_4.0最新考古題: https://www.newdumpspdf.com/CTFL_Syll_4.0-exam-new-dumps.html
而CTFL_Syll_4.0考題資料能幫考生掌握考試所需要的知識點,擁有良好的口碑,只要你選擇ISQI CTFL_Syll_4.0考古題作為你的考前復習資料,你就會相信自己的選擇不會錯,NewDumps的培訓課程是NewDumps的專家團隊利用自己的知識和經驗為ISQI CTFL_Syll_4.0 認證考試而研究出來的,NewDumps CTFL_Syll_4.0最新考古題考題網成立於2010年,練習CTFL_Syll_4.0题库的效率以及成果和很多因素都有著密切的相關性,你可以選擇我們的NewDumps CTFL_Syll_4.0最新考古題為你提供的培訓資料,為您提供便捷的在線服務爲您解決任何有關CTFL_Syll_4.0擬真試題的疑問,我們提供給您最高品質的ISQI CTFL_Syll_4.0題庫問題及答案,覆蓋面廣,可以幫助考生進行有效的考前學習。
虬髯大漢譏諷道,夜羽說完之後看到了水月洞天如今的現狀,而CTFL_Syll_4.0考題資料能幫考生掌握考試所需要的知識點,擁有良好的口碑,只要你選擇ISQI CTFL_Syll_4.0考古題作為你的考前復習資料,你就會相信自己的選擇不會錯。
實用的CTFL_Syll_4.0認證題庫 |高通過率的考試材料|有效的CTFL_Syll_4.0:ISTQB Certified Tester Foundation Level (CTFL) v4.0NewDumps的培訓課程是NewDumps的專家團隊利用自己的知識和經驗為ISQI CTFL_Syll_4.0 認證考試而研究出來的,NewDumps考題網成立於2010年,練習CTFL_Syll_4.0题库的效率以及成果和很多因素都有著密切的相關性,你可以選擇我們的NewDumps為你提供的培訓資料。
- 精心準備的ISQI CTFL_Syll_4.0認證題庫是行業領先材料&準確的CTFL_Syll_4.0:ISTQB Certified Tester Foundation Level (CTFL) v4.0 ❇ 立即打開➽ tw.fast2test.com 🢪並搜索➤ CTFL_Syll_4.0 ⮘以獲取免費下載CTFL_Syll_4.0測試引擎
- CTFL_Syll_4.0資訊 🎵 CTFL_Syll_4.0在線題庫 😊 CTFL_Syll_4.0題庫更新 🤴 複製網址⇛ [url]www.newdumpspdf.com ⇚打開並搜索➠ CTFL_Syll_4.0 🠰免費下載CTFL_Syll_4.0題庫更新[/url]
- CTFL_Syll_4.0考題套裝 🧧 CTFL_Syll_4.0題庫資料 🔏 CTFL_Syll_4.0考題套裝 🌞 「 [url]www.newdumpspdf.com 」上搜索➤ CTFL_Syll_4.0 ⮘輕鬆獲取免費下載新版CTFL_Syll_4.0題庫[/url]
- CTFL_Syll_4.0認證題庫,ISQI CTFL_Syll_4.0最新考古題 🐀 ▛ [url]www.newdumpspdf.com ▟上的免費下載⇛ CTFL_Syll_4.0 ⇚頁面立即打開CTFL_Syll_4.0最新考證[/url]
- CTFL_Syll_4.0題庫更新 🎓 CTFL_Syll_4.0在線題庫 🏛 CTFL_Syll_4.0資料 📃 複製網址“ [url]www.pdfexamdumps.com ”打開並搜索「 CTFL_Syll_4.0 」免費下載CTFL_Syll_4.0學習資料[/url]
- CTFL_Syll_4.0新版題庫上線 🔕 CTFL_Syll_4.0題庫資料 🤙 CTFL_Syll_4.0證照信息 🦯 開啟[ [url]www.newdumpspdf.com ]輸入「 CTFL_Syll_4.0 」並獲取免費下載CTFL_Syll_4.0學習資料[/url]
- CTFL_Syll_4.0題庫資料 🏜 CTFL_Syll_4.0資料 📍 CTFL_Syll_4.0在線考題 🦰 開啟➥ [url]www.newdumpspdf.com 🡄輸入▷ CTFL_Syll_4.0 ◁並獲取免費下載CTFL_Syll_4.0證照信息[/url]
- CTFL_Syll_4.0認證題庫 - 您通過ISTQB Certified Tester Foundation Level (CTFL) v4.0的可靠支持 🔶 透過《 [url]www.newdumpspdf.com 》輕鬆獲取▶ CTFL_Syll_4.0 ◀免費下載CTFL_Syll_4.0題庫資料[/url]
- CTFL_Syll_4.0學習資料 🤴 新版CTFL_Syll_4.0題庫 🎲 CTFL_Syll_4.0題庫資料 🤤 立即到⇛ [url]www.pdfexamdumps.com ⇚上搜索【 CTFL_Syll_4.0 】以獲取免費下載CTFL_Syll_4.0软件版[/url]
- 免費PDF CTFL_Syll_4.0認證題庫 - ISQI CTFL_Syll_4.0通過了考試 🎰 在「 [url]www.newdumpspdf.com 」網站下載免費▛ CTFL_Syll_4.0 ▟題庫收集CTFL_Syll_4.0软件版[/url]
- 最實用的CTFL_Syll_4.0認證考古題 🧾 打開➤ [url]www.pdfexamdumps.com ⮘搜尋《 CTFL_Syll_4.0 》以免費下載考試資料CTFL_Syll_4.0考題套裝[/url]
- www.peiyuege.com, www.dkcomposite.com, www.stes.tyc.edu.tw, faithlife.com, ddy.hackp.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.weitongquan.com, bbs.sdhuifa.com, davecoll.alboompro.com, www.stes.tyc.edu.tw, Disposable vapes
P.S. NewDumps在Google Drive上分享了免費的2026 ISQI CTFL_Syll_4.0考試題庫:https://drive.google.com/open?id=18uOX4IUTaXzRb30OCRxEy06qSJvucqDA
