[Hardware] Buy ITCertMagic Cyber AB CMMC-CCA Exam Dumps With Free Updates
91
【Hardware】 Buy ITCertMagic Cyber AB CMMC-CCA Exam Dumps With Free Updates
Posted at 1/11/2026 23:58:45      View:263 | Replies:6        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ITCertMagic CMMC-CCA dumps from Cloud Storage: https://drive.google.com/open?id=1InZJuCuzNXEKLZS6j9o4PIUjmjYE6FM8
PDF design has versatile and printable material for Cyber AB CMMC-CCA certification, so you all can breeze through the Cyber AB CMMC-CCA exam without any problem. You can get to the PDF concentrate on material from workstations, tablets, and cell phones for the readiness of Certified CMMC Assessor (CCA) Exam (CMMC-CCA) exam.
Cyber AB CMMC-CCA Exam Syllabus Topics:
  • CMMC Level 2 Assessment Scoping: This section of the exam measures skills of cybersecurity assessors and revolves around determining the proper scope of a CMMC assessment. It involves analyzing and categorizing Controlled Unclassified Information (CUI) assets, interpreting the Level 2 scoping guidelines, and making accurate judgments in scenario-based exercises to define what assets and systems fall within assessment boundaries.
  • Assessing CMMC Level 2 Practices: This section of the exam measures skills of cybersecurity assessors in evaluating whether organizations meet the required practices of CMMC Level 2. It emphasizes applying CMMC model constructs, understanding model levels, domains, and implementation, and using evidence to determine compliance with established cybersecurity practices.
  • CMMC Assessment Process (CAP): This section of the exam measures skills of compliance professionals and tests knowledge of the full assessment lifecycle. It covers the steps needed to plan, prepare, conduct, and report on a CMMC Level 2 assessment, including the phases of execution and how to document and follow up on findings in alignment with DoD and CMMC-AB expectations.
  • Evaluating Organizations Seeking Certification (OSC) against CMMC Level 2 Requirements: This section of the exam measures skills of cybersecurity assessors and focuses on evaluating the environments of organizations seeking certification at CMMC Level 2. It covers understanding differences between logical and physical settings, recognizing constraints in cloud, hybrid, on-premises, single, and multi-site environments, and knowing what environmental exclusions apply for Level 2 assessments.
2026 Trustable CMMC-CCA Online Training Materials | 100% Free CMMC-CCA Valid Exam SampleThe exam requires an enormous amount of effort and determination and dedication to get to the end goal. ITCertMagic is one of the most reliable platforms that offer an accurate, reliable, and straightforward Cyber AB CMMC-CCA dumps to ensure the success of students on the initial try. ITCertMagic offers the complete package that includes all exam dumps conforming to the syllabus for passing the Certified CMMC Assessor (CCA) Exam (CMMC-CCA) exam certificate in the first try.
Cyber AB Certified CMMC Assessor (CCA) Exam Sample Questions (Q68-Q73):NEW QUESTION # 68
A C3PAO is conducting a Level 2 assessment of a midsized construction contractor that does both private (commercial) and federal work. The contractor's documentation states that all CUI flows through a single building on their office campus and is logically, physically, and administratively isolated from the rest of the environment. Why might an assessor request access to assess controls within a building or area not listed as in- scope in the documentation?
  • A. If Human Resources that supports both commercial and federal sectors sits in the other building or area
  • B. If network diagrams indicate the commercial and federal sectors share a single Internet connection
  • C. If the assessor sees personnel carrying locked cases into the other building or area
  • D. If the OSC has an underground passageway connecting the CUI building to a non-CUI building
A shared Internet connection indicates that Security Protection Assets (SPAs) are present and serving both the CUI environment and other parts of the enterprise. SPAs are always in-scope regardless of where they are located, because they provide security protections for CUI. Therefore, if documentation or diagrams show that the commercial and federal environments share a single Internet connection, the assessor must request access to the other building to confirm proper implementation and isolation.
Exact Extracts (from CMMC Assessor/Study documents):
* "Security Protection Assets provide security functions or capabilities within the OSA's CMMC Assessment Scope. Security Protection Assets are part of the CMMC Assessment Scope and are assessed against Level 2 security requirements that are relevant to the capabilities provided."
* "Contractor Risk Managed Assets are not required to be physically or logically separated from CUI Assets... If documentation or other findings raise questions about these assets, the assessor can conduct a limited check to identify deficiencies."
* "Separation... is required only for Out-of-Scope Assets. Isolation can be achieved... by implementing subnetworks with firewalls or other boundary protection devices."
* "The CMMC Assessment Scope includes all assets in the OSA's environment that will be assessed...
OSAs will be required to provide a network diagram of the CMMC Assessment Scope to facilitate scoping discussions during pre-assessment."
* "An OSC can obtain a Level 2 certification assessment for an entire enterprise network or for a specific enclave(s), depending upon how the CMMC Assessment Scope is defined..." Why the other options are not correct:
* A (locked cases): Physical movement of materials does not establish scope. Scoping is determined by CUI flow and security protection assets, not incidental observation of personnel activities.
* B (underground passageway): Physical tunnels or building connections do not affect scope unless they result in shared IT/security functions.
* D (HR location): HR is not a SPA because it does not provide security functions to protect CUI.
Unless HR systems process or store CUI directly, they remain out of scope.
References (official CCA/CMMC documents):
* CMMC Assessment Scope - Level 2, Version 2.13 (Scoping Guide): Asset Categories, SPA definitions and examples; CRMA limited-check language; Separation requirements; network diagram requirements (pp. 3-13).
* CMMC Assessment Guide - Level 2, Version 2.13: Assessment scope, enclave validation, and assessor methods (pp. 1-4, 8-10).
NEW QUESTION # 69
When a new employee is issued a laptop, only the user's credentials need to be set up. According to the IT department, the IT manager is the only person who can change laptop setup and user privileges. What documentation should be examined to determine if this is the case?
  • A. System audit logs
  • B. Acceptable use policy
  • C. Remote access procedures
  • D. Inventory records
* Applicable Requirement: AC.L2-3.1.5 - "Employ the principle of least privilege, including for specific security functions and privileged accounts."
* Why A is Correct: Audit logs document when privileged functions (such as account creation, privilege changes, or configuration changes) occur, who performed them, and whether access control restrictions are enforced. Reviewing logs is the only way to confirm the IT manager alone has the capability.
Why Other Options Are Insufficient:
* B (Inventory records): Shows ownership, not privilege changes.
* C (Acceptable use): Policy guidance, not enforcement evidence.
* D (Remote access): Deals with remote connections, not privilege management.
References (CCA Official Sources):
* NIST SP 800-171 Rev. 2 - AC.L2-3.1.5
* NIST SP 800-171A - AC.L2-3.1.5 Assessment Methods
NEW QUESTION # 70
An OSC processes data in its owned data center. The data center includes a very early smoke detection apparatus (VESDA). The apparatus only captures log information from its sensors around the data center. It is not intended, nor capable of, processing CUI. The VESDA is on a separate VLAN and is in a separate locked room in the data center.
Should the assessor agree that the VESDA is out-of-scope?
  • A. Yes. The VESDA serves a non-data processing purpose and is only connected to sensors. Sensors are out-of-scope, so the VESDA is out-of-scope.
  • B. No. Even though the sensors are out-of-scope, the VESDA could provide access to the outside network if sensors were misused, and CUI could be exfiltrated.
  • C. Yes. The VESDA is physically and logically separated from the other data center equipment, and it is not intended nor capable of processing CUI.
  • D. No. Even though the VESDA controller is in a locked room and on a separate VLAN, the VESDA is an essential security function as an early warning system.
The CMMC Scoping Guidance allows assets to be classified as Out-of-Scope if:
* They are physically/logically isolated, and
* They cannot process, store, or transmit CUI.
Extract:
"Out-of-Scope assets are those that cannot process, store, or transmit CUI and are physically or logically separated from CUI assets." The VESDA system only monitors environmental conditions and does not interact with CUI. Its segregation supports an out-of-scope classification.
Reference: CMMC Scoping Guidance - Out-of-Scope Assets.
NEW QUESTION # 71
You are part of the Assessment Team evaluating an OSC's implementation of AC.L2-3.1.13 - Remote Access Confidentiality. This requirement mandates the organization to employ cryptographic mechanisms to protect the confidentiality of remote access sessions. During your assessment, you want to determine whether these cryptographic mechanisms have been properly identified as required by assessment objective [a]. What specification can you use to make this determination?
  • A. Remote access authorizations
  • B. Interviews of personnel responsible for remote access
  • C. The organization's Access Control Policy and Procedures and system design documentation
  • D. Interviews with security administrators
Comprehensive and Detailed in Depth Explanation:
AC.L2-3.1.13[a] requires the OSC to identify cryptographic mechanisms protecting remote access session confidentiality, per NIST SP 800-171A and CMMC Level 2 guidelines. The organization's Access Control Policy and Procedures outline the standards and requirements for cryptography (e.g., FIPS-validated modules), while system design documentation details the specific mechanisms implemented (e.g., TLS, VPN configurations). These documents directly address the identification of cryptographic controls, making them the primary specifications for this objective.
Option A and B (interviews) provide supplementary insights but lack the authoritative detail of written policies and designs. Option C (remote access authorizations) focuses on permissions, not cryptographic mechanisms. Option D is the correct answer, as it aligns with NIST SP 800-171A'semphasis on examining specifications for objective [a].
Reference Extract:
* NIST SP 800-171A, AC-3.1.13[a]:"Examine access control policy; procedures addressing remote access... system design documentation to determine if cryptographic mechanisms are identified."
* CMMC AG Level 2, AC.L2-3.1.13:"Verify cryptographic mechanisms via policy and design specs." Resources:https://csrc.nist.gov/pubs/sp/800/171/a/final;[url]https://dodcio.defense.gov/Portals/0/Documents[/url]
/CMMC/AG_Level2_MasterV2.0_FINAL_202112016_508.pdf
NEW QUESTION # 72
An OSC employs guards to protect the manufacturing shop where a magnetic radar-absorbing coating is manufactured. This specific coating is used by the Army for a particular fleet ofunmanned aerial vehicles (UAVs). The facility is under constant surveillance with the help of HD CCTVs. Within the OSC's facilities, there is a Vector Network Analyzer (VNA) that measures the reflection and transmission properties of the coating over a range of frequencies. Guards protect the OSC's anechoic chamber, and anyone entering must use an iris scanner and sign a physical form detailing their name and reason for being there. At the door is a huge sign reading "Authorized Personnel Only." Which of the following statements is true about handling the Vector Network Analyzer (VNA) in a CMMC assessment?
  • A. If appropriately documented, the assets should not be assessed against other CMMC practices.
  • B. The VNA is out of scope for a CMMC assessment.
  • C. The VNA should be assessed against CMMC practices.
  • D. The VNA should be reviewed in the SSP in accordance with practice CA.L2-3.12.4 - System Security Plan.
The VNA, used to measure coating properties, is a Specialized Asset per the CMMC Assessment Scope - Level 2, as it is test equipment tied to contract performance. Specialized Assets are in scope but not assessed against the full 110 CMMC practices unless they process, store, or transmit CUI (not indicated here). Instead, they must be documented and reviewed in the SSP per practice CA.L2-3.12.4 to ensure risk-based management. Option A is incorrect as it's in scope. Option C overextends the assessment requirement. Option D is vague but aligns partially with B, which is more precise.
CMMC Assessment Scope - Level 2, Section 2.3.4 (Specialized Assets), p. 6: "Specialized Assets are reviewed in the SSP per CA.L2-3.12.4."
NEW QUESTION # 73
The Cyber AB PDF Questions format designed by the ITCertMagic will facilitate its consumers. Its portability helps you carry on with the study anywhere because it functions on all smart devices. You can also make notes or print out the Certified CMMC Assessor (CCA) Exam (CMMC-CCA) pdf questions. The simple, systematic, and user-friendly Interface of the Certified CMMC Assessor (CCA) Exam (CMMC-CCA) PDF dumps format will make your preparation convenient.
CMMC-CCA Valid Exam Sample: https://www.itcertmagic.com/Cyber-AB/real-CMMC-CCA-exam-prep-dumps.html
P.S. Free 2026 Cyber AB CMMC-CCA dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1InZJuCuzNXEKLZS6j9o4PIUjmjYE6FM8
Posted at 1/12/2026 23:50:31        Only Author  2#
Xhs1991は多くのIT職員の夢を達成することであるウェブサイトです。IT夢を持っていたら、速くXhs1991に来ましょう。 Xhs1991にはすごいトレーニング即ち VMwareの2V0-16.25試験トレーニング資料があります。これはIT職員の皆が熱望しているものです。あなたが試験に合格することを助けられますから。
Posted at 1/14/2026 09:16:05        Only Author  3#
The content of your article is so remarkable, thank you for sharing! This is the CCFR-201b Certification Training exam that helped me achieve a promotion and pay raise. It’s free today—wishing you career success!
Posted at 1/21/2026 08:06:35        Only Author  4#
I am still in awe after reading your article, thank you for sharing! Here are the free Exam CY0-001 score resources—good luck, everyone!
Posted at 1/28/2026 01:07:49        Only Author  5#
The article is written with great depth, and I have learned a lot of practical knowledge. Free B2C-Commerce-Architect pass guaranteed exam papers for you to download. Best of luck in your exams!
Posted at 1/30/2026 02:25:26        Only Author  6#
Amazon認証試験に参加する方はCertShikenの問題集を買ってください。CLF-C02試験の成功を祈ります。
Posted at 2/1/2026 14:32:41        Only Author  7#
Salesforce Analytics-Con-301 시험을 보시는 분이 점점 많아지고 있는데 하루빨리 다른 분들보다 Salesforce Analytics-Con-301시험을 패스하여 자격증을 취득하는 편이 좋지 않을가요? 자격증이 보편화되면 자격증의 가치도 그만큼 떨어지니깐요. Salesforce Analytics-Con-301덤프는 이미 많은분들의 시험패스로 검증된 믿을만한 최고의 시험자료입니다.
