[Hardware] HPE6-A78 Free Download Pdf Exam Latest Release | Updated HPE6-A78 PDF Cram Exam
79
Hardware HPE6-A78 Free Download Pdf Exam Latest Release | Updated HPE6-A78 PDF Cram Exam
Posted at 1/12/2026 02:16:02      View208 | Replies5        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE6-A78 dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=1kV73Ombec6XAaYDZ4V8wF10Ts9s8WHZC
It is no longer an accident for you to pass HPE6-A78 exam after you have use our HPE6-A78 exam software. You will have thorough training and exercises from our huge question dumps, and master every question from the detailed answer analysis. The exam software with such guarantees will clear your worries about HPE6-A78 Exam.
HPE6-A78 exam consists of 60 multiple-choice questions that must be answered within 90 minutes. HPE6-A78 exam is available in English and costs $200. The passing score for the exam is 65%. HPE6-A78 exam can be taken at any Pearson VUE testing center, and candidates must register for the exam on the Pearson VUE website.
HP HPE6-A78 exam covers a range of topics related to Aruba network security, including network security fundamentals, access control, authentication and encryption, and network security architecture. Candidates are expected to have a deep understanding of these topics and be able to apply their knowledge to real-world scenarios. HPE6-A78 Exam Format includes multiple-choice questions, drag and drop questions, and simulation-based questions.
HPE6-A78 PDF Cram Exam - HPE6-A78 Actual ExamsThese HP HPE6-A78 exam questions give you an idea about the final HP HPE6-A78 exam questions formats, exam question structures, and best possible answers, and you will also enhance your exam time management skills. Finally, at the end of HP HPE6-A78 Exam Practice test you will be ready to pass the final HP HPE6-A78 exam easily. Best of luck in HP HP exam and professional career!!!
HPE6-A78 certification exam covers a wide range of topics, including network security fundamentals, firewall technologies, intrusion detection and prevention, VPN technologies, and network access control. Candidates who pass the exam demonstrate the ability to design, implement, and manage secure networks using Aruba technologies.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q50-Q55):NEW QUESTION # 50
What is another setting that you must configure on the switch to meet these requirements?
  • A. Configure a CPPM username and password that match a CPPM admin account.
  • B. Create port-access roles with the same names of the roles that CPPM will send in Aruba-Admin-Role VSAs.
  • C. Disable SSH on the default VRF and enable it on the mgmt VRF instead.
  • D. Set the aaa authentication login method for SSH to the "radius" server-group (with local as backup).
To meet the requirements for configuring an ArubaOS-CX switch for integration with ClearPass Policy Manager (CPPM), it is necessary to set the AAA authentication login method for SSH to use the "radius" server-group, with "local" as a backup. This ensures that when an admin attempts to SSH into the switch, the authentication request is first sent to CPPM via RADIUS. If CPPM is unavailable, the switch will fall back to using local authentication12.
Here's why the other options are not correct:
Option B is incorrect because configuring a CPPM username and password on the switch that matches a CPPM admin account is not required for SSH login; rather, the switch needs to be configured to communicate with CPPM for authentication.
Option C is incorrect because while CPPM will send Aruba-Admin-Role Vendor-Specific Attributes (VSAs), the switch does not need to have port-access roles created with the same names; it needs to interpret the VSA to assign the correct role.
Option D is incorrect because disabling SSH on the default VRF and enabling it on the mgmt VRF is not related to the authentication process with CPPM.
Therefore, the correct answer is A, as setting the AAA authentication login method for SSH to the "radius" server-group with "local" as backup is a key step in ensuring that the switch can authenticate admins through CPPM while providing a fallback method12.
NEW QUESTION # 51
What is one benefit of a Trusted Platform Module (TPM) on an Aruba AP?
  • A. It enables secure boot, which detects if hackers corrupt the OS with malware.
  • B. It deploys the AP with enhanced security, which includes disabling the password recovery mechanism.
  • C. It allows the AP to run in secure mode, which automatically enables CPsec and disables the console port.
  • D. It enables the AP to encrypt and decrypt 802.11 traffic locally, rather than at the MC.
The TPM (Trusted Platform Module) is a hardware-based security feature that can provide various security functions, one of which includes secure boot. Secure boot is a process where the TPM ensures that the device boots using only software that is trusted by the manufacturer. If the OS has been tampered with or infected with malware, the secure boot process can detect this and prevent the system from loading the compromised OS.
NEW QUESTION # 52
What is one of the policies that a company should define for digital forensics?
  • A. which data should be routinely logged, where logs should be forwarded, and which logs should be archived
  • B. to which resources should various users be allowed access, based on their identity and the identity of their clients
  • C. which type of EAP method is most secure for authenticating wired and wireless users with 802.1
  • D. what are the first steps that a company can take to implement micro-segmentation in their environment
In the context of digital forensics, policy A is the most relevant. It defines which data should be logged, where logs should be forwarded for analysis or storage, and which logs should be archived for future forensic analysis or audit purposes. This ensures that evidence is preserved in a way that supports forensic activities.
NEW QUESTION # 53
NEW QUESTION # 54
A company has an Aruba Instant AP cluster. A Windows 10 client is attempting to connect a WLAN that enforces WPA3-Enterprise with authentication to ClearPass Policy Manager (CPPM). CPPM is configured to require EAP-TLS. The client authentication fails. In the record for this client's authentication attempt on CPPM, you see this alert.
What is one thing that you check to resolve this issue?
  • A. whether EAP-TLS is enabled in the SSID Profile settings for the WLAN on the IAP cluster
  • B. whether the client has a third-party 802.1 X supplicant, as Windows 10 does not support EAP-TLS
  • C. whether EAP-TLS is enabled in the AAA Profile settings for the WLAN on the IAP cluster
  • D. whether the client has a valid certificate installed on it to let it support EAP-TLS
In the context of WPA3-Enterprise with EAP-TLS authentication, the error message "Client doesn't support configured EAP methods" suggests that the client is not able to complete the EAP-TLS authentication process. EAP-TLS requires that both the server (in this case, CPPM) and the client have a valid certificate for mutual authentication. Windows 10 does support EAP-TLS natively, so options A, C, and D can be ruled out.
The most likely reason for the authentication failure is that the client device does not have the correct client certificate installed, which is required to establish a TLS session with the server. Therefore, ensuring that the client has a valid certificate installed that matches the server's requirements is the correct step to resolve this issue.
NEW QUESTION # 55
HPE6-A78 PDF Cram Exam: https://www.newpassleader.com/HP/HPE6-A78-exam-preparation-materials.html
BTW, DOWNLOAD part of NewPassLeader HPE6-A78 dumps from Cloud Storage: https://drive.google.com/open?id=1kV73Ombec6XAaYDZ4V8wF10Ts9s8WHZC
Posted at 1/13/2026 11:17:59        Only Author  2#
ɹäƤΤϤɤǤΤ褦|ˤޤ˽ϴ𤨤Ƥޤ衣CertShikenxɹx֤ȤȤǤCertShikenBICSIRCDDv15ԇYȥ`˥YϤITJ^ԇYܤȫƤYԇY˺ϸ񤹤뤳ȤΤǤYϤBICSIRCDDv15ԇYΤ؄eо줿ΤǡYu򤿤餤ޤCertShikenBICSIRCDDv15ԇYȥ`˥YϤx餼ҳɹȤȤ^ޤ
Posted at 2/11/2026 03:50:02        Only Author  3#
어떻게 하면 가장 편하고 수월하게 Amazon AWS-Developer-KR시험을 패스할수 있을가요? 그 답은 바로 Itexamdump에서 찾아볼수 있습니다. Amazon AWS-Developer-KR덤프로 시험에 도전해보지 않으실래요? Itexamdump는 당신을 위해Amazon AWS-Developer-KR덤프로Amazon AWS-Developer-KR인증시험이라는 높은 벽을 순식간에 무너뜨립니다.
Posted at 2/17/2026 00:25:11        Only Author  4#
I love how inspiring this article is, thanks for sharing! Get the TDA-C01 new study guide questions test questions for free and good luck with your exam preparation!
Posted at 2/18/2026 20:34:31        Only Author  5#
Reading this article has helped me plan for my future work. The COF-C02 latest test passing score material is very good, and its free to access.
Posted at 2/20/2026 01:08:57        Only Author  6#
S HP JCԽԽĿ͑ע⵽ HP ҪԣĿǰǽ˥˵ĕrڣһݹףȡ HP JCCȻõģ܉㷀λãšķaڜʂ HPE7-A08 ԇ}Ŀʹ𰸵ӈDʽҜyԇܛwԫ@m֪Rͼܣͨ^ HPE7-A08 ԇԑ{ VCESoft }Wµ}ͨ^ԓԇ
