Actual Adobe AD0-E724 Exam Questions and Answers
Posted at 1/12/2026 03:18:02
View187
Replies2
BTW, DOWNLOAD part of Itcertkey AD0-E724 dumps from Cloud Storage: https://drive.google.com/open?id=17i2XcmeeU_ui1I83BtXFGn9kzWXeWp5u
Itcertkey provides the three most convenient formats to prepare for AD0-E724 exam dumps. It offers a desktop practice test, web based practice test and pdf file. Therefore, feel free to go through Commerce Developer Professional (AD0-E724) exam dumps. Each of the three formats is downloaded to all android devices. Therefore, there's no reason to download an additional application to access web-based or desktop-based practice tests.
Why do so many people determine to take part in Adobe AD0-E724 exam? Owing a nice certification will not only testify your professional skills and qualification but also show your knowledge and ability, it will be useful for your career. AD0-E724 New Test Bootcamp materials will be valid and useful for your test. If you get a certification, you will be regards as knowledgeable expert. Now there is a large demand for these skillful senior engineers.
Training AD0-E724 Online | Reliable AD0-E724 Study PlanBefore joining any platform, the Adobe AD0-E724 exam applicant has a number of reservations. They want AD0-E724 Questions that satisfy them and help them prepare successfully for the AD0-E724 exam in a short time. Studying with Adobe AD0-E724 Questions that aren't real results in failure and loss of time and money. The Itcertkey offers updated and real Adobe AD0-E724 questions that help students crack the AD0-E724 test quickly.
Adobe Commerce Developer Professional Sample Questions (Q78-Q83):NEW QUESTION # 78
An Adobe Commerce developer is creating a module (Vendor.ModuleName) to be sold on the Marketplace.
The new module creates a database table using declarative schema and now the developer needs to make sure the table is removed when the module is disabled.
What must the developer do to accomplish this?
- A. There is nothing further the developer needs to do. The table will be removed when the when bin
/magento module:uninstall vendor_ModuleName is run. - B. Add a schema patch that implements MagentoFrameworksetupPatchPatchRevertabieinterface and drops the table in the revert function.
- C. There is nothing further the developer needs to do. The table will be removed when the module is disabled and bin/magento setup:upgrade is run.
When you disable a module, Magento removes all of its declarative schema changes from the database the next time you run bin/magento setup:upgrade." This means that when the developer disables the module and runs setup:upgrade, Adobe Commerce will automatically handle the removal of the database table created by the module's declarative schema.
For reference, here are some key points from the documentation:
* [Disable a Module](https://x.com/i/grok?text=Disable%20a%20Module)- This section explains how Magento handles the database schema when a module is disabled.
* Declarative Schema Configuration- Provides an overview of how declarative schema works, including its behavior when modules are disabled or uninstalled.
Therefore, based on the official Adobe Commerce documentation, the correct action for the developer is to do nothing further beyond disabling the module and running bin/magento setup:upgrade. Magentowill take care of removing the table associated with the module as part of its schema management process.
NEW QUESTION # 79
A developer wants to deploy a new release to the Adobe Commerce Cloud Staging environment, but first they need the latest code from Production.
What would the developer do to update the Staging environment?
- A. 1. Log in to the Project Web Interface.
2. Choose the Staging environment, and click Merge - B. 1. Log in to the Project Web Interface.
2. Choose the Staging environment, and click Sync - C. 1. Checkout to Production environment
2. Use the magento-cloud synchronize <environment-ID> Commerce CLI Command
The developer can update the Staging environment with the latest code from Production by logging in to the Project Web Interface, choosing the Staging environment, and clicking Sync. This will synchronize the code, data, and media files from Production to Staging, creating an exact copy of Production on Staging. The developer can then deploy the new release to Staging and test it before pushing it to Production. Verified References: [Magento 2.4 DevDocs]
NEW QUESTION # 80
Which two actions will the developer need to take to translate strings added in JS files? (Choose two.)
- A. translate('<string>');
- B. define ([
'jquery,
'mage/translate'
), function ($, $t) {." - C. $ trans( ,<string>')
- D. $.mage._('<string>);
To translate strings added in JavaScript files in Adobe Commerce, developers need to use themage/translate RequireJS module along with the$.mage.__('<string>')function to mark strings for translation. This approach ensures that any text strings embedded within JavaScript code can be localized according to the store's current locale, providing a consistent and accessible user experience across different languages and regions. Themage
/translatemodule and the$.mage.__()function work together to retrieve the corresponding translated strings from Magento's translation dictionaries, dynamically replacing the original text in the JavaScript code with the appropriate translations.
NEW QUESTION # 81
An Adobe Commerce developer is creating a new module to extend the functionality of the cart. The module is installed in app/code/CompanyName/ModuleName/.
How would an Adobe Commerce developer extend the existing CartltemPrices GraphQL schema to include a custom base_price field?
- A. Option B
- B. Create and Configure a <prefffrence> for HagentoQuoteGraphQlModelResolverCartItemPrices that adds the base_price field in the resolve() function.
- C. Option A
- D. Add the following to the module's etc/schema.graphqis file:
A black text on a white background AI-generated content may be incorrect.
C)
Add the following to the module's etc/graphqi/di.xmi file:
A screen shot of a computer code AI-generated content may be incorrect.
![]() - E. Option C
The developer can extend the existing CartltemPrices GraphQL schema to include a custom base_price field by adding the following code to the module's etc/schema.graphqls file:
extend type CartltemPrices { base_price: Money! @doc(description: "The base price of the cart item") } This code adds a new field called base_price to the CartltemPrices type and specifies that it is of type Money and it is not nullable. The @doc directive adds a description for the field that will be shown in the schema documentation. The developer also needs to create a custom resolver class for the base_price field and declare it in the di.xml file of the module. Verified References: [Magento 2.4 DevDocs] [Magento Stack Exchange]
NEW QUESTION # 82
Which action, if any, can be taken to change the URL key of the product?
- A. The product URL key is generated automatically, so it cannot be changed.
- B. Use URL rewrite to map product id with the custom URL key.
- C. In the product admin form, under the Search Engine Optimization fieldset, the URL key can be set
The URL key of a product is the text that is used to generate the product's URL. This text can be set by the merchant in the product admin form.
The URL key of a product in Adobe Commerce can be changed in the product admin form under the "Search Engine Optimization" fieldset. Here, the URL key can be set or edited manually, allowing for customization beyond the automatically generated value. This field is typically used to ensure that the product URL is search-engine friendly and relevant to the product.
NEW QUESTION # 83
Our AD0-E724 latest preparation materials provide users with three different versions, including a PDF version, a software version, and an online version. Although involved three versions of the AD0-E724 teaching content is the same, but for all types of users can realize their own needs, whether it is which version of AD0-E724 Learning Materials, believe that can give the user a better AD0-E724 learning experience. Below, I would like to introduce you to the main advantages of our research materials, and I'm sure you won't want to miss it.
Training AD0-E724 Online: https://www.itcertkey.com/AD0-E724_braindumps.html
Adobe Valid AD0-E724 Test Forum As you know, useless practice materials will be agonizing to your preparation of the exam, The AD0-E724 exam materials provided by Itcertkey are collected and sorted out by experienced team, The AD0-E724 practice dumps can allow users to use the time of debris anytime and anywhere to study and make more reasonable arrangements for their study and life, Adobe Valid AD0-E724 Test Forum However, it is only compatible with Windows.
Initially, these incremental innovations appear to be successful, AD0-E724 Once the Sharpening settings have been optimized, you can clearly see the improvement in the image detail.
As you know, useless practice materials will be agonizing to your preparation of the exam, The AD0-E724 Exam Materials provided by Itcertkey are collected and sorted out by experienced team.
100% Pass Quiz AD0-E724 Marvelous Valid Commerce Developer Professional Test ForumThe AD0-E724 practice dumps can allow users to use the time of debris anytime and anywhere to study and make more reasonable arrangements for their study and life.
However, it is only compatible Valid AD0-E724 Test Forum with Windows, Additional related Web references included.
- Newest Valid AD0-E724 Test Forum - Pass AD0-E724 Exam 🐄 Download ✔ AD0-E724 ️✔️ for free by simply entering [url]www.exam4labs.com website 🙇Latest AD0-E724 Dumps Ppt[/url]
- Efficient Valid AD0-E724 Test Forum | Amazing Pass Rate For AD0-E724 Exam | Professional AD0-E724: Commerce Developer Professional 🏠 Download ➠ AD0-E724 🠰 for free by simply entering [ [url]www.pdfvce.com ] website 🥧Certification AD0-E724 Sample Questions[/url]
- Free AD0-E724 Learning Cram 🥑 AD0-E724 Latest Braindumps Book 🥳 AD0-E724 Reliable Test Preparation 🥅 Search on ▛ [url]www.pdfdumps.com ▟ for [ AD0-E724 ] to obtain exam materials for free download 🐤AD0-E724 Reliable Test Preparation[/url]
- AD0-E724 Valid Mock Test 🍺 Latest AD0-E724 Dumps Ppt 👲 Valid AD0-E724 Test Pdf 🗜 Search for AD0-E724 and download it for free on ➥ [url]www.pdfvce.com 🡄 website 🦐
ositive AD0-E724 Feedback[/url] - AD0-E724 Reliable Test Preparation 🤑 AD0-E724 Trustworthy Exam Content 🌆 Testking AD0-E724 Exam Questions 🙍 Search for { AD0-E724 } on [url]www.troytecdumps.com immediately to obtain a free download 🤳AD0-E724 Latest Braindumps Book[/url]
- Newest Valid AD0-E724 Test Forum - Pass AD0-E724 Exam 🥁 The page for free download of ✔ AD0-E724 ️✔️ on { [url]www.pdfvce.com } will open immediately 😳Testking AD0-E724 Exam Questions[/url]
- 100% Pass 2026 AD0-E724: High Hit-Rate Valid Commerce Developer Professional Test Forum 🧄 Open website ⮆ [url]www.vce4dumps.com ⮄ and search for ▶ AD0-E724 ◀ for free download 😂AD0-E724 Questions Answers[/url]
- Valid AD0-E724 Test Pdf 🦀 Valid AD0-E724 Exam Fee 🕔 AD0-E724 Reliable Exam Materials 👲 Simply search for AD0-E724 for free download on [url]www.pdfvce.com 🕵Free AD0-E724 Learning Cram[/url]
- AD0-E724 Sample Questions Pdf 😱 AD0-E724 Valid Mock Test 💆 AD0-E724 Reliable Test Preparation 🗼 Enter [ [url]www.exam4labs.com ] and search for [ AD0-E724 ] to download for free ‼Valid AD0-E724 Test Pdf[/url]
- 100% Pass 2026 AD0-E724: High Hit-Rate Valid Commerce Developer Professional Test Forum 🛀 Download AD0-E724 for free by simply entering ⮆ [url]www.pdfvce.com ⮄ website 🐭Free AD0-E724 Learning Cram[/url]
- AD0-E724 Valid Mock Test 🍞 Braindumps AD0-E724 Downloads 🎦 Valid AD0-E724 Test Pdf 🎡 Easily obtain AD0-E724 for free download through ⏩ [url]www.troytecdumps.com ⏪ 🦡AD0-E724 Latest Braindumps Book[/url]
- bbs.t-firefly.com, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.wcs.edu.eu, bbs.t-firefly.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New AD0-E724 dumps are available on Google Drive shared by Itcertkey: https://drive.google.com/open?id=17i2XcmeeU_ui1I83BtXFGn9kzWXeWp5u
