SPLK-2002 Sample Test Online | SPLK-2002 Reliable Exam Topics
Posted at 1/12/2026 04:39:03
P.S. Free & New SPLK-2002 dumps are available on Google Drive shared by PDFVCE: https://drive.google.com/open?id=1Z-M8TRsoMXPt0dwgIKvXjprV2jR8_rlY
Our website is a very secure and regular platform. Firstly, we guarantee the security of the company's website whiling purchasing process of SPLK-2002 exam torrent. Secondly, for all customer information about purchasing SPLK-2002 practice test, we will be maintained by specialized personnel and absolutely no information disclosure will occur. To the last but also the most important, our SPLK-2002 Exam Materials have the merit of high quality based on the high pass rate as 98% to 100%. The data speak louder than the other words. You should be confident with our SPLK-2002 training prep.
Splunk SPLK-2002 exam consists of 150 multiple-choice questions that must be completed within 180 minutes. SPLK-2002 exam is available in multiple languages, including English, Japanese, and Simplified Chinese. SPLK-2002 exam covers a wide range of topics related to Splunk, such as data input and parsing, knowledge objects, advanced search, and distributed deployment. Candidates should have a thorough understanding of Splunk architecture and be able to apply best practices to real-world scenarios.
The Splunk SPLK-2002 Exam Tests the candidates' knowledge of Splunk Enterprise architecture, deployment planning, installation, configuration, and optimization. It requires candidates to have a deep understanding of Splunk search processing language (SPL), data onboarding, and data management. SPLK-2002 exam is designed to assess the candidates' ability to implement best practices for security, performance, and scalability of Splunk Enterprise environments.
SPLK-2002 Reliable Exam Topics - SPLK-2002 Download PdfThe proximity of perfection on our SPLK-2002 practice dumps is outstanding. By using our SPLK-2002 preparation materials, we are sure you will pass your exam smoothly and get your dreamed certification. We have a variety of versions for your reference: PDF & Software & APP version. All those versions are high efficient and accurate with passing rate up to 98 to 100 percent. So our SPLK-2002 Study Guide is efficient, high-quality for you.
Splunk Enterprise Certified Architect Sample Questions (Q174-Q179):NEW QUESTION # 174
Which of the following is a good practice for a search head cluster deployer?
- A. The deployer only distributes configurations to search head cluster members with splunk apply shcluster-bundle.
- B. The deployer only distributes configurations to search head cluster members when they "phone home".
- C. The deployer must be used to distribute non-replicable configurations to search head cluster members.
- D. The deployer must distribute configurations to search head cluster members to be valid configurations.
The following is a good practice for a search head cluster deployer: The deployer must be used to distribute non-replicable configurations to search head cluster members. Non-replicable configurations are the configurations that are not replicated by the search factor, such as the apps and the server.conf settings. The deployer is the Splunk server role that distributes these configurations to the search head cluster members, ensuring that they have the same configuration. The deployer does not only distribute configurations to search head cluster members when they "phone home", as this would cause configuration inconsistencies and delays.
The deployer does not distribute configurations to search head cluster members to be valid configurations, as this implies that the configurations are invalid without the deployer. The deployer does not only distribute configurations to search head cluster members with splunk apply shcluster-bundle, as this would require manual intervention by the administrator. For more information, see Use the deployer to distribute apps and configuration updates in the Splunk documentation.
NEW QUESTION # 175
The guidance Splunk gives for estimating size on for syslog data is 50% of original data size. How does this divide between files in the index?
- A. rawdata is: 10%, tsidx is: 40%
- B. rawdata is: 40%, tsidx is: 10%
- C. rawdata is: 35%, tsidx is: 15%
- D. rawdata is: 15%, tsidx is: 35%
The guidance Splunk gives for estimating size on for syslog data is 50% of original data size. This divides between files in the index as follows: rawdata is 15%, tsidx is 35%. The rawdata is the compressed version of the original data, which typically takes about 15% of the original data size. The tsidx is the index file that contains the time-series metadata and the inverted index, which typically takes about 35% of the original data size. The total size of the rawdata and the tsidx is about 50% of the original data size. For more information, see [Estimate your storage requirements] in the Splunk documentation.
NEW QUESTION # 176
(A customer creates a saved search that runs on a specific interval. Which internal Splunk log should be viewed to determine if the search ran recently?)
- A. scheduler.log
- B. metrics.log
- C. btool.log
- D. kvstore.log
According to Splunk's Search Scheduler and Job Management documentation, the scheduler.log file, located within the _internal index, records the execution of scheduled and saved searches. This log provides a detailed record of when each search is triggered, how long it runs, and its success or failure status.
Each time a scheduled search runs (for example, alerts, reports, or summary index searches), an entry is written to scheduler.log with fields such as:
* sid (search job ID)
* app (application context)
* savedsearch_name (name of the saved search)
* user (owner)
* status (success, skipped, or failed)
* run_time and result_count
By searching the _internal index for sourcetype=scheduler (or directly viewing scheduler.log), administrators can confirm whether a specific saved search executed as expected and diagnose skipped or delayed runs due to resource contention or concurrency limits.
Other internal logs serve different purposes:
* metrics.log records performance metrics.
* kvstore.log tracks KV Store operations.
* btool.log does not exist - btool outputs configuration data to the console, not a log file.
Hence, scheduler.log is the definitive and Splunk-documented source for validating scheduled search activity.
References (Splunk Enterprise Documentation):
* Saved Searches and Alerts - Scheduler Operation Details
* scheduler.log Reference - Monitoring Scheduled Search Execution
* Monitoring Console: Search Scheduler Health Dashboard
* Troubleshooting Skipped or Delayed Scheduled Searches
NEW QUESTION # 177
(Which of the following is not facilitated by the deployer?)
- A. Distribute non-replicated, non-runtime configuration updates.
- B. Replication of knowledge objects.
- C. Migration of app and user configurations into the search head cluster.
- D. Deployment of baseline app configurations.
Per the Search Head Clustering (SHC) Deployer Administration Guide, the deployer is responsible for distributing configuration bundles, apps, and baseline settings to all members of a Search Head Cluster (SHC). However, the replication of knowledge objects (Option A) is not handled by the deployer.
Knowledge object replication-covering items such as saved searches, dashboards, lookups, and alerts-is managed internally within the Search Head Cluster using the captain node. The captain coordinates replication among all SHC members using a mechanism called Knowledge Object Replication Framework, which ensures that user-created or runtime configuration changes (e.g., dashboards saved in Splunk Web) are automatically shared across members.
In contrast, the deployer's primary responsibilities include:
* Deploying and updating baseline app configurations (Option B).
* Distributing non-replicated, non-runtime configuration updates like props, transforms, and inputs (Option C).
* Assisting in the initial migration of apps and configurations into a cluster during setup (Option D).
Therefore, while the deployer handles static configuration management, knowledge object replication is performed dynamically by the SHC itself under captain control, making Option A the correct answer.
* Search Head Clustering: How the Deployer Works
* Managing Knowledge Object Replication in Search Head Clusters
* Splunk Enterprise Admin Manual - Deployer vs. Captain Responsibilities
* Distributing Apps and Configurations with the Deployer
NEW QUESTION # 178
Which of the following clarification steps should be taken if apps are not appearing on a deployment client?
(Select all that apply.)
- A. Check deploymentclient.conf of the deployment client.
- B. Check serverclass.conf of the deployment server.
- C. Search for relevant events in splunkd.log of the deployment server.
- D. Check the content of SPLUNK_HOME/etc/apps of the deployment server.
Answer: A,B,C
The following clarification steps should be taken if apps are not appearing on a deployment client:
* Check serverclass.conf of the deployment server. This file defines the server classes and the apps and configurations that they should receive from the deployment server. Make sure that the deployment client belongs to the correct server class and that the server class has the desired apps and configurations.
* Check deploymentclient.conf of the deployment client. This file specifies the deployment server that the
* deployment client contacts and the client name that it uses. Make sure that the deployment client is pointing to the correct deployment server and that the client name matches the server class criteria.
* Search for relevant events in splunkd.log of the deployment server. This file contains information about the deployment server activities, such as sending apps and configurations to the deployment clients, detecting client check-ins, and logging any errors or warnings. Look for any events that indicate a problem with the deployment server or the deployment client.
* Checking the content of SPLUNK_HOME/etc/apps of the deployment server is not a necessary clarification step, as this directory does not contain the apps and configurations that are distributed to the deployment clients. The apps and configurations for the deployment server are stored in SPLUNK_HOME/etc/deployment-apps. For more information, see Configure deployment server and clients in the Splunk documentation.
NEW QUESTION # 179
In recent years, many people are interested in Splunk certification exam. So, Splunk SPLK-2002 test also gets more and more important. As the top-rated exam in IT industry, SPLK-2002 certification is one of the most important exams. With SPLK-2002 certificate, you can get more benefits. If you want to attend the exam, PDFVCE Splunk SPLK-2002 questions and answers can offer you convenience. The dumps are indispensable and the best.
SPLK-2002 Reliable Exam Topics: https://www.pdfvce.com/Splunk/SPLK-2002-exam-pdf-dumps.html
- Free PDF 2026 Valid Splunk SPLK-2002 Sample Test Online 🏢 Go to website ➥ [url]www.prepawaypdf.com 🡄 open and search for ➤ SPLK-2002 ⮘ to download for free 😷Latest SPLK-2002 Test Voucher[/url]
- Valid SPLK-2002 Exam Duration ♻ Associate SPLK-2002 Level Exam ⚜ Associate SPLK-2002 Level Exam ⚾ Immediately open ➠ [url]www.pdfvce.com 🠰 and search for 《 SPLK-2002 》 to obtain a free download 🔡Valid SPLK-2002 Vce Dumps[/url]
- Exam SPLK-2002 Price 👉 Valid SPLK-2002 Exam Duration 🍿 Latest SPLK-2002 Test Voucher 🤲 The page for free download of [ SPLK-2002 ] on ⏩ [url]www.prepawaypdf.com ⏪ will open immediately 🎰SPLK-2002 New Test Materials[/url]
- Splunk SPLK-2002 Exam Questions - Updated Frequently 🚧 [ [url]www.pdfvce.com ] is best website to obtain ➠ SPLK-2002 🠰 for free download 🙀SPLK-2002 Latest Test Guide[/url]
- SPLK-2002 New Test Materials 🎪 Valid SPLK-2002 Test Cram 🍙 Latest SPLK-2002 Test Voucher 😋 Search for ▷ SPLK-2002 ◁ and download exam materials for free through ▶ [url]www.easy4engine.com ◀ ☑SPLK-2002 Reliable Test Simulator[/url]
- Splunk SPLK-2002 Unparalleled Sample Test Online Pass Guaranteed Quiz 🤖 Copy URL ✔ [url]www.pdfvce.com ️✔️ open and search for ▛ SPLK-2002 ▟ to download for free 🌼SPLK-2002 New Test Materials[/url]
- 100% Pass High Hit-Rate Splunk - SPLK-2002 Sample Test Online 💂 Easily obtain free download of [ SPLK-2002 ] by searching on ➤ [url]www.dumpsquestion.com ⮘ 🍪SPLK-2002 Passleader Review[/url]
- High-quality SPLK-2002 Sample Test Online - Accurate Splunk Certification Training - Accurate Splunk Splunk Enterprise Certified Architect 🔐 Go to website { [url]www.pdfvce.com } open and search for ⏩ SPLK-2002 ⏪ to download for free 🩸SPLK-2002 Test Engine[/url]
- 100% Pass High Hit-Rate Splunk - SPLK-2002 Sample Test Online 🔋 Download [ SPLK-2002 ] for free by simply entering “ [url]www.examcollectionpass.com ” website 📃Examinations SPLK-2002 Actual Questions[/url]
- [url=https://klandreville.com/?s=Splunk%20SPLK-2002%20Exam%20Questions%20-%20Updated%20Frequently%20%f0%9f%93%8b%20Go%20to%20website%20%e2%87%9b%20www.pdfvce.com%20%e2%87%9a%20open%20and%20search%20for%20[%20SPLK-2002%20]%20to%20download%20for%20free%20%f0%9f%8c%b9Exam%20SPLK-2002%20Price]Splunk SPLK-2002 Exam Questions - Updated Frequently 📋 Go to website ⇛ www.pdfvce.com ⇚ open and search for [ SPLK-2002 ] to download for free 🌹Exam SPLK-2002 Price[/url]
- 2026 Excellent SPLK-2002 – 100% Free Sample Test Online | SPLK-2002 Reliable Exam Topics 🔗 Open website ▷ [url]www.prep4sures.top ◁ and search for ➥ SPLK-2002 🡄 for free download 🔘SPLK-2002 Exam Dumps.zip[/url]
- bbs.t-firefly.com, recordtycoon.com, cq.x7cq.vip, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, daotao.wisebusiness.edu.vn, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.wisgrid.cn, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that PDFVCE SPLK-2002 dumps now are free: https://drive.google.com/open?id=1Z-M8TRsoMXPt0dwgIKvXjprV2jR8_rlY
