[General] Quiz 2026 Snowflake ARA-C01CProfessional Valid Test Materials
78
General Quiz 2026 Snowflake ARA-C01CProfessional Valid Test Materials
Posted at 1/12/2026 04:45:02      View184 | Replies2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of TestsDumps ARA-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1rwT0fSNQtA6o7r54nZOFb72s-1tRu3DG
You will be cast in light of career acceptance and put individual ability to display. When you apply for a job you could have more opportunities than others. What is more, there is no interminable cover charge for our ARA-C01 practice engine priced with reasonable prices for your information. Considering about all benefits mentioned above, you must have huge interest to our ARA-C01 Study Materials. You should take the look at our ARA-C01 simulating questions right now.
Many candidates may take the price into consideration while buying ARA-C01 exam materials. The price of ARA-C01 exam materials is quite reasonable, you can afford it no matter you are students or the employees in the company. Furthermore the ARA-C01 Exam Materials is high-quality, so that it can help you to pass the exam just one time, we will never let your money gets nothing returns. If you indeed fail the exam, money back will be guaranteed.
Certification ARA-C01 Cost | ARA-C01 Exam Dumps.zipWith limited time for your preparation, many exam candidates can speed up your pace of making progress. Our ARA-C01 study materials will remedy your faults of knowledge understanding. As we know, some people failed the exam before, and lost confidence in this agonizing exam before purchasing our ARA-C01 training guide. Also it is good for releasing pressure. Many customers get manifest improvement and lighten their load with our ARA-C01 exam braindumps. So just come and have a try!
Snowflake SnowPro Advanced Architect Certification Sample Questions (Q70-Q75):NEW QUESTION # 70
Data sharing is supported only between provider and consumer accounts in same region
  • A. TRUE
  • B. FALSE
NEW QUESTION # 71
A DevOps team has a requirement for recovery of staging tables used in a complex set of data pipelines. The staging tables are all located in the same staging schema. One of the requirements is to have online recovery of data on a rolling 7-day basis.
After setting up the DATA_RETENTION_TIME_IN_DAYS at the database level, certain tables remain unrecoverable past 1 day.
What would cause this to occur? (Choose two.)
  • A. The staging schema has not been setup for MANAGED ACCESS.
  • B. The tables exceed the 1 TB limit for data recovery.
  • C. The staging tables are of the TRANSIENT type.
  • D. The DevOps role should be granted ALLOW_RECOVERY privilege on the staging schema.
  • E. The DATA_RETENTION_TIME_IN_DAYS for the staging schema has been set to 1 day.
Answer: C,E
* The DATA_RETENTION_TIME_IN_DAYS parameter controls the Time Travel retention period for an object (database, schema, or table) in Snowflake. This parameter specifies the number of days for which historical data is preserved and can be accessed using Time Travel operations (SELECT, CREATE ... CLONE, UNDROP)1.
* The requirement for recovery of staging tables on a rolling 7-day basis means that the DATA_RETENTION_TIME_IN_DAYS parameter should be set to 7 at the database level. However, this parameter can be overridden at the lower levels (schema or table) if they have a different value1.
* Therefore, one possible cause for certain tables to remain unrecoverable past 1 day is that the DATA_RETENTION_TIME_IN_DAYS for the staging schema has been set to 1 day. This would override the database level setting and limit the Time Travel retention period for all the tables in the schema to 1 day. To fix this, the parameter should be unset or set to 7 at the schema level1. Therefore, option B is correct.
* Another possible cause for certain tables to remain unrecoverable past 1 day is that the staging tables are of the TRANSIENT type. Transient tables are tables that do not have a Fail-safe period and can have a Time Travel retention period of either 0 or 1 day. Transient tables are suitable for temporary or intermediate data that can be easily reproduced or replicated2. To fix this, the tables should be created as permanent tables, which can have a Time Travel retention period of up to 90 days1. Therefore, option D is correct.
* Option A is incorrect because the MANAGED ACCESS feature is not related to the data recovery requirement. MANAGED ACCESS is a feature that allows granting access privileges to objects without explicitly granting the privileges to roles. It does not affect the Time Travel retention period or the data availability3.
* Option C is incorrect because there is no 1 TB limit for data recovery in Snowflake. The data storage size does not affect the Time Travel retention period or the data availability4.
* Option E is incorrect because there is no ALLOW_RECOVERY privilege in Snowflake. The privilege required to perform Time Travel operations is SELECT, which allows querying historical data in tables5.
References: : Understanding & Using Time Travel : Transient Tables : Managed Access : Understanding Storage Cost : Table Privileges
NEW QUESTION # 72
An Architect runs the following SQL query:
How can this query be interpreted?
  • A. FILEROWS is the table. FILE_ROW_NUMBER is the line number in the table.
  • B. FILERONS is the file format location. FILE_ROW_NUMBER is a stage.
  • C. FILEROWS is a stage. FILE_ROW_NUMBER is line number in file.
  • D. FILEROWS is a file. FILE_ROW_NUMBER is the file format location.
NEW QUESTION # 73
Based on the Snowflake object hierarchy, what securable objects belong directly to a Snowflake account? (Select THREE).
  • A. Table
  • B. Database
  • C. Role
  • D. Schema
  • E. Warehouse
  • F. Stage
Answer: B,C,E
NEW QUESTION # 74
A Snowflake Architect is designing an application and tenancy strategy for an organization where strong legal isolation rules as well as multi-tenancy are requirements.
Which approach will meet these requirements if Role-Based Access Policies (RBAC) is a viable option for isolating tenants?
  • A. Create an object for each tenant strategy if row level security is viable for isolating tenants.
  • B. Create an object for each tenant strategy if row level security is not viable for isolating tenants.
  • C. Create a multi-tenant table strategy if row level security is not viable for isolating tenants.
  • D. Create accounts for each tenant in the Snowflake organization.
NEW QUESTION # 75
TestsDumps's Snowflake ARA-C01 exam training materials not only can save your energy and money, but also can save a lot of time for you. Because the things what our materials have done, you might need a few months to achieve. So what you have to do is use the TestsDumps Snowflake ARA-C01 Exam Training materials. And obtain this certificate for yourself. TestsDumps will help you to get the knowledge and experience that you need and will provide you with a detailed Snowflake ARA-C01 exam objective. So with it, you will pass the exam.
Certification ARA-C01 Cost: https://www.testsdumps.com/ARA-C01_real-exam-dumps.html
Snowflake Valid ARA-C01 Test Materials I purchased the product but my Username/Password is not working, Snowflake Valid ARA-C01 Test Materials Nowadays, as the companies are becoming more efficient and more computerized, more and more people may find it hard to get a good job unless they have an excellent qualification, They feel easy to pass ARA-C01 exams.
Extending the ActionScript Classes, Read iCloud: Visual QuickStart Guide, ARA-C01 Second Edition and thousands of other books and videos on Creative Edge, I purchased the product but my Username/Password is not working.
100% Pass 2026 First-grade Snowflake ARA-C01: Valid SnowPro Advanced Architect Certification Test MaterialsNowadays, as the companies are becoming more efficient and more ARA-C01 Exam Dumps.zip computerized, more and more people may find it hard to get a good job unless they have an excellent qualification.
They feel easy to pass ARA-C01 Exams, Also if you are preparing for IT exams, ARA-C01 test torrent sheet will be also suitable for you to prepare carefully, and our ARA-C01 Free Test Questions products will ease a lot of annoyance with our latest SnowPro Advanced Architect Certification exam dumps PDF.
Are you upset for your ARA-C01 latest test answers?
P.S. Free 2026 Snowflake ARA-C01 dumps are available on Google Drive shared by TestsDumps: https://drive.google.com/open?id=1rwT0fSNQtA6o7r54nZOFb72s-1tRu3DG
Posted at 1/30/2026 07:32:02        Only Author  2#
Your article is truly inspiring, thank you for sharing such brilliance! The C-THR94-2505 valid practice questions free exam was crucial for my career advancement, and now Im sharing it for free!
Posted at 3/6/2026 09:08:38        Only Author  3#
Јνץåȥե`ȱ^ơFast2testϤmԤߤdz˄ʵĤǤϡAI-201ԇY˺ϸ񤷤Yߤ˸ߤϸAI-201ν̲Ĥṩ٤ƤΤ͘ԇФAI-201ԇY˺ϸ񤷤Ƥޤ֥ȤAI-201ԇY˺ϸ񤹤ˤϡ20〜30rgޤϱΤȤ򤹤뤿˶यΕrgȥͥ륮`򹝼sΤ뤳ȤǤdz˄ʵĤԇYĩ`Ǥ
