[General] Visual Professional-Cloud-Network-Engineer Cert Exam - Valid Dumps Professional-
92
【General】 Visual Professional-Cloud-Network-Engineer Cert Exam - Valid Dumps Professional-
Posted at 1/12/2026 04:56:05      View:170 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of VerifiedDumps Professional-Cloud-Network-Engineer dumps for free: https://drive.google.com/open?id=1MxKv7x6vN6zqHR87xnSS59xE2oRVH_zP
Do you want your IT capability to be most authoritatively recognized? One of the best method is to pass the Professional-Cloud-Network-Engineer certification exam. The Professional-Cloud-Network-Engineer exam software designed by our VerifiedDumps will help you master Professional-Cloud-Network-Engineer Exam skills. Besides, abundant materials, user-friendly design and one-year free update after payment are the best favor for you to pass Professional-Cloud-Network-Engineer exam.
You can easily get Google Professional-Cloud-Network-Engineer certified if you prepare with our Google Professional-Cloud-Network-Engineer questions. Our product contains everything you need to ace the Professional-Cloud-Network-Engineer certification exam and become a certified professional. So what are you waiting for? Purchase this updated Google Professional-Cloud-Network-Engineer Exam Practice material today and start your journey to a shining career.
Valid Dumps Professional-Cloud-Network-Engineer Book - New Professional-Cloud-Network-Engineer Test Pass4sureNew developments in the tech sector always bring new job opportunities. These new jobs have to be filled with the Professional-Cloud-Network-Engineer certification holders. So to fill the space, you need to pass the Professional-Cloud-Network-Engineer Exam. Earning the Professional-Cloud-Network-Engineer certification helps you clear the obstacles you face while working in the Google field.
Google Professional-Cloud-Network-Engineer Certification Exam is designed to test the skills and knowledge of individuals who work with Google Cloud Platform and specialize in network engineering. Google Cloud Certified - Professional Cloud Network Engineer certification demonstrates that an individual has the expertise to design, implement, and manage secure, scalable, and highly available networks on Google Cloud Platform. Professional-Cloud-Network-Engineer Exam is intended for professionals with at least three years of experience in network engineering and a thorough understanding of cloud networking principles.
Google Cloud Certified - Professional Cloud Network Engineer Sample Questions (Q62-Q67):NEW QUESTION # 62
You have the following firewall ruleset applied to all instances in your Virtual Private Cloud (VPC):
You need to update the firewall rule to add the following rule to the ruleset:
You are using a new user account. You must assign the appropriate identity and Access Management (IAM) user roles to this new user account before updating the firewall rule. The new user account must be able to apply the update and view firewall logs. What should you do?
  • A. Assign the compute.orgSecurityPolicyAdmin and logging.viewer role to the new user account. Apply the new firewall rule with a priority of 50.
  • B. Assign the compute.securityAdmin and logging.viewer rule to the new user account. Apply the new firewall rule with a priority of 50.
  • C. Assign the compute.orgSecurityPolicyAdmin and logging.bucketWriter role to the new user account.Apply the new firewall rule with a priority of 150.
  • D. Assign the compute.securityAdmin and logging.bucketWriter role to the new user account. Apply the new firewall rule with a priority of 150.
NEW QUESTION # 63
You want to set up two Cloud Routers so that one has an active Border Gateway Protocol (BGP) session, and the other one acts as a standby.
Which BGP attribute should you use on your on-premises router?
  • A. Local Preference
  • B. AS-Path
  • C. Multi-exit Discriminator
  • D. Community
NEW QUESTION # 64
You are migrating a three-tier application architecture from on-premises to Google Cloud. As a first step in the migration, you want to create a new Virtual Private Cloud (VPC) with an external HTTP(S) load balancer.
This load balancer will forward traffic back to the on-premises compute resources that run the presentation tier. You need to stop malicious traffic from entering your VPC and consuming resources at the edge, so you must configure this policy to filter IP addresses and stop cross-site scripting (XSS) attacks. What should you do?
  • A. Create a VPC firewall ruleset, and apply it to all instances in unmanaged instance groups.
  • B. Create a hierarchical firewall ruleset, and apply it to the VPC's parent organization resource node.
  • C. Create a Google Cloud Armor policy, and apply it to a backend service that uses an unmanaged instance group backend.
  • D. Create a Google Cloud Armor policy, and apply it to a backend service that uses an internet network endpoint group (NEG) backend.
NEW QUESTION # 65
You are deploying GKE clusters in your organization's Google Cloud environment. The pods in these clusters need to egress directly to the internet for a majority of their communications. You need to deploy the clusters and associated networking features using the most cost-efficient approach, and following Google- recommended practices. What should you do?
  • A. Q Deploy the GKE cluster with private cluster nodes. Deploy Secure Web Proxy, and configure the pods to use Secure Web Proxy as an HTTP(S) proxy.
  • B. Q Deploy the GKE cluster with private cluster nodes. Deploy Cloud NAT for the primary subnet of the cluster.
  • C. Q Deploy the GKE cluster with public cluster nodes. Deploy Secure Web Proxy, and configure the pods to use Secure Web Proxy as an HTTP(S) proxy.
  • D. Q Deploy the GKE cluster with public cluster nodes. Do not deploy Cloud NAT or Secure Web Proxy for the cluster.
For GKE pods that need to egress directly to the internet for most of their communications, the most cost- efficient and straightforward approach is to deploy a GKE cluster with public cluster nodes. Public nodes have external IP addresses, allowing pods to directly reach the internet. This eliminates the need for additional services like Cloud NAT or Secure Web Proxy for outbound internet access, which would incur extra costs and management overhead.
Exact Extract:
"ublic clusters have nodes with external IP addresses, allowing them to directly initiate connections to the internet. This is the simplest configuration for clusters that require direct internet egress for their workloads."
"When using public clusters, Cloud NAT is not required for outbound internet connectivity from the nodes or pods, as they can use their external IP addresses. This can reduce operational overhead and cost compared to private clusters that need NAT."Reference: Google Kubernetes Engine Documentation - Cluster network configuration, Public clusters vs Private clusters
NEW QUESTION # 66
You want to apply a new Cloud Armor policy to an application that is deployed in Google Kubernetes Engine (GKE). You want to find out which target to use for your Cloud Armor policy.
Which GKE resource should you use?
  • A. GKE Pod
  • B. GKE Cluster
  • C. GKE Node
  • D. GKE Ingress
Explanation/Reference: https://cloud.google.com/kuberne ... armor-backendconfig
NEW QUESTION # 67
Beyond knowing the answer, and actually understanding the Professional-Cloud-Network-Engineer test questions puts you one step ahead of the test. Completely understanding a concept and reasoning behind how something works, makes your task second nature. Your Professional-Cloud-Network-Engineer test questions will melt in your hands if you know the logic behind the concepts. Any legitimate Professional-Cloud-Network-Engineer Test Questions should enforce this style of learning - but you will be hard pressed to find more than a Professional-Cloud-Network-Engineer test questions anywhere other than VerifiedDumps.
Valid Dumps Professional-Cloud-Network-Engineer Book: https://www.verifieddumps.com/Professional-Cloud-Network-Engineer-valid-exam-braindumps.html
Posted at 2/24/2026 10:39:58        Only Author  2#
Truly a brilliant article, I’m so appreciative of your sharing. Get free Reliable study questions Marketing-Cloud-Administrator files to level up your IT knowledge. Wishing you success!
