Hardware
Braindumps AWS-Solutions-Architect-Associate Pdf | AWS-Solutions-Architect-Assoc
Posted at 1/12/2026 05:44:39
View219
Replies4
BONUS!!! Download part of PracticeVCE AWS-Solutions-Architect-Associate dumps for free: https://drive.google.com/open?id=1nlwXR8gFFInlHvlT2AcOlBXaKjjiu3mW
Preparing for the AWS-Solutions-Architect-Associate exam can be a daunting task, but with real AWS-Solutions-Architect-Associate exam questions, it can be a lot easier. The importance of actual AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Architect-Associate) questions cannot be overemphasized. AWS-Solutions-Architect-Associate Real Questions are crucial for passing the AWS-Solutions-Architect-Associate exam. When candidates have access to the updated Amazon AWS-Solutions-Architect-Associate practice test questions, they are better prepared to succeed.
The AWS Certified Solutions Architect - Associate certification is highly valued in the IT industry, as it demonstrates a professionals ability to design and deploy scalable and reliable applications on AWS infrastructure. AWS Certified Solutions Architect - Associate (SAA-C03) certification is also a prerequisite for higher-level AWS certifications, such as the AWS Certified Solutions Architect - Professional.
Amazon AWS-Solutions-Architect-Associate Latest Exam Review | New AWS-Solutions-Architect-Associate Test PracticeYou don't need to enroll yourself in expensive AWS-Solutions-Architect-Associate exam training classes. With the AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Architect-Associate) valid dumps, you can easily prepare well for the actual Amazon AWS-Solutions-Architect-Associate Exam at home. AWS Certified Solutions Architect - Associate (SAA-C03) (AWS-Solutions-Architect-Associate) practice test software is compatible with windows and the web-based software will work on many operating systems.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q12-Q17):NEW QUESTION # 12
An auction website enables users to bid on collectible items. The auction rules require that each bid is processed only once and in the order it was received. The current implementation is based on a fleet of Amazon EC2 web servers that write bid records into Amazon Kinesis Data Streams. A single t2.large instance has a cron job that runs the bid processor, which reads incoming bids from Kinesis Data Streams and processes each bid. The auction site is growing in popularity, but users are complaining that some bids are not registering.
Troubleshooting indicates that the bid processor is too slow during peak demand hours, sometimes crashes while processing, and occasionally loses track of which records is being processed.
What changes should make the bid processing more reliable?
- A. Switch the EC2 instance type from t2.large to a larger general compute instance type. Put the bid processor EC2 instances in an Auto Scaling group that scales out the number of EC2 instances running the bid processor, based on the IncomingRecords metric in Kinesis Data Streams.
- B. Refactor the web application to post each incoming bid to an Amazon SNS topic in place of Kinesis Data Streams. Configure the SNS topic to trigger an AWS Lambda function that processes each bid as soon as a user submits it.
- C. Refactor the web application to post each incoming bid to an Amazon SQS FIFO queue in place of Kinesis Data Streams. Refactor the bid processor to continuously the SQS queue. Place the bid processing EC2 instance in an Auto Scaling group with a minimum and a maximum size of 1.
- D. Refactor the web application to use the Amazon Kinesis Producer Library (KPL) when posting bids to Kinesis Data Streams. Refactor the bid processor to flag each record in Kinesis Data Streams as being unread, processing, and processed. At the start of each bid processing run, scan Kinesis Data Streams for unprocessed records.
NEW QUESTION # 13
A company has an application that customers use to upload images to an Amazon S3 bucket Each night, the company launches an Amazon EC2 Spot Fleet that processes all the images that the company received that day. The processing for each image takes 2 minutes and requires 512 MB of memory.
A solutions architect needs to change the application to process the images when the images are uploaded Which change will meet these requirements MOST cost-effectively?
- A. Use S3 Event Notifications to write a message with image details to an Amazon Simple Queue Service (Amazon SQS) queue Configure an EC2 Reserved Instance to read the messages from the queue and to process the images.
- B. Use S3 Event Notifications to publish a message with image details to an Amazon Simple Notification Service (Amazon SNS) topic. Configure a container instance in Amazon Elastic Container Service (Amazon ECS) to subscribe to the topic and to process the images.
- C. Use S3 Event Notifications to publish a message with image details to an Amazon Simple Notification Service (Amazon SNS) topic. to subscribe to the topic and to process the images.
- D. Use S3 Event Notifications to write a message with image details to an Amazon Simple Queue Service (Amazon SQS) queue. Configure an AWS Lambda function to read the messages from the queue and to process the images
Understanding the Requirement: The company needs to process images as they are uploaded to S3 in a cost- effective manner, currently using an EC2 Spot Fleet for nightly processing.
Analysis of Options:
S3 Event Notifications to SQS and Lambda: This setup allows for event-driven processing with Lambda, which scales automatically based on the number of messages in the queue. It is cost-effective as Lambda charges are based on the compute time used.
S3 Event Notifications to SQS and EC2 Reserved Instance: Involves managing EC2 instances, which adds operational overhead and is less cost-effective.
S3 Event Notifications to SNS and ECS: More complex and potentially less cost-effective compared to using Lambda for simple processing tasks.
S3 Event Notifications to SNS: Requires additional configuration and management to process messages.
Best Solution:
S3 Event Notifications to SQS and Lambda: This option is the most cost-effective and scalable, leveraging AWS managed services with minimal operational overhead.
Amazon S3 Event Notifications
Amazon SQS
AWS Lambda
NEW QUESTION # 14
A company recently launched Linux-based application instances on Amazon EC2 in a private subnet and launched a Linux-based bastion host on an Amazon EC2 instance in a public subnet of a VPC A solutions architect needs to connect from the on-premises network, through the company's internet connection to the bastion host and to the application servers The solutions architect must make sure that the security groups of all the EC2 instances will allow that access Which combination of steps should the solutions architect take to meet these requirements? (Select TWO)
- A. Replace the current security group of the bastion host with one that only allows inbound access from the application instances
- B. Replace the current security group of the bastion host with one that only allows inbound access from the internal IP range for the company
- C. Replace the current security group of the application instances with one that allows inbound SSH access from only the public IP address of the bastion host
- D. Replace the current security group of the bastion host with one that only allows inbound access from the external IP range for the company
- E. Replace the current security group of the application instances with one that allows inbound SSH access from only the private IP address of the bastion host
Answer: D,E
https://digitalcloud.training/ssh-into-ec2-in-private-subnet/
NEW QUESTION # 15
A company has a service that produces event data. The company wants to use AWS to process the event data as it is received. The data is written in a specific order that must be maintained throughout processing The company wants to implement a solution that minimizes operational overhead.
How should a solutions architect accomplish this?
- A. Create an Amazon Simple Notification Service (Amazon SNS) topic to deliver notifications containing payloads to process. Configure an Amazon Simple Queue Service (Amazon SQS) queue as a subscriber.
- B. Create an Amazon Simple Queue Service (Amazon SQS) standard queue to hold messages. Set up an AWS Lambda function to process messages from the queue independently
- C. Create an Amazon Simple Notification Service (Amazon SNS) topic to deliver notifications containing payloads to process Configure an AWS Lambda function as a subscriber.
- D. Create an Amazon Simple Queue Service (Amazon SQS) FIFO queue to hold messages Set up an AWS Lambda function to process messages from the queue
The details are revealed in below url:
https://docs.aws.amazon.com/AWSS ... de/FIFO-queues.html FIFO (First-In-First-Out) queues are designed to enhance messaging between applications when the order of operations and events is critical, or where duplicates can't be tolerated. Examples of situations where you might use FIFO queues include the following: To make sure that user-entered commands are run in the right order. To display the correct product price by sending price modifications in the right order. To prevent a student from enrolling in a course before registering for an account.
NEW QUESTION # 16
A company has a legacy application that processes data in two parts. The second part of the process takes longer than the first, so the company has decided to rewrite the application as two microservices running on Amazon ECS that can scale independently How should a solutions architect integrate the microservices?
- A. Implement code in microservice 1 to send data to an Amazon SQS queue. Implement code in microservice 2 to process messages from the queue.
- B. Implement code in microservice 1 to publish data to an Amazon SNS topic. Implement code In microservice 2 to subscribe to this topic.
- C. Implement code in microservice 1 to send data to an Amazon S3 bucket. Use S3 event notifications to invoke microservice 2
- D. Implement code in microservice 1 to send data to Amazon Kinesis Data Firehose. Implement code in microservice 2 to read from Kinesis Data Firehose.
NEW QUESTION # 17
As what have been demonstrated in the records concerning the pass rate of our AWS-Solutions-Architect-Associate free demo, our pass rate has kept the historical record of 98% to 99% from the very beginning of their foundation. During these years, our PDF version of our AWS-Solutions-Architect-Associate study engine stays true to its original purpose to pursue a higher pass rate that has never been attained in the past. And you will be content about our considerate service on our AWS-Solutions-Architect-Associate training guide. If you have any question, you can just contact us!
AWS-Solutions-Architect-Associate Latest Exam Review: https://www.practicevce.com/Amazon/AWS-Solutions-Architect-Associate-practice-exam-dumps.html
- Braindumps AWS-Solutions-Architect-Associate Pdf - Pass AWS-Solutions-Architect-Associate in One Time - Newest AWS-Solutions-Architect-Associate Latest Exam Review 😛 Open ▛ [url]www.pdfdumps.com ▟ and search for { AWS-Solutions-Architect-Associate } to download exam materials for free 🔧Exam AWS-Solutions-Architect-Associate Passing Score[/url]
- Latest AWS-Solutions-Architect-Associate Exam Materials ⏩ AWS-Solutions-Architect-Associate Authorized Test Dumps 🚬 Valid AWS-Solutions-Architect-Associate Test Objectives 🐶 Search for ☀ AWS-Solutions-Architect-Associate ️☀️ and easily obtain a free download on ▷ [url]www.pdfvce.com ◁ ✴AWS-Solutions-Architect-Associate Reliable Braindumps Ebook[/url]
- Valid Braindumps AWS-Solutions-Architect-Associate Pdf ✒ Test AWS-Solutions-Architect-Associate Prep 👆 Free AWS-Solutions-Architect-Associate Dumps 🕢 Simply search for AWS-Solutions-Architect-Associate for free download on { [url]www.prep4sures.top } 🧃Valid Braindumps AWS-Solutions-Architect-Associate Pdf[/url]
- 100% Pass Quiz Amazon - AWS-Solutions-Architect-Associate - AWS Certified Solutions Architect - Associate (SAA-C03) Fantastic Braindumps Pdf 🃏 Search for ▶ AWS-Solutions-Architect-Associate ◀ and download exam materials for free through [url]www.pdfvce.com 😣Free AWS-Solutions-Architect-Associate Dumps[/url]
- Free PDF Quiz 2026 AWS-Solutions-Architect-Associate: Reliable Braindumps AWS Certified Solutions Architect - Associate (SAA-C03) Pdf ⏫ Open [ [url]www.dumpsquestion.com ] enter ✔ AWS-Solutions-Architect-Associate ️✔️ and obtain a free download 🍝AWS-Solutions-Architect-Associate Valid Test Pdf[/url]
- Accurate AWS-Solutions-Architect-Associate Study Material 🎏 Accurate AWS-Solutions-Architect-Associate Study Material 🌝 Accurate AWS-Solutions-Architect-Associate Study Material ⭐ Immediately open ➥ [url]www.pdfvce.com 🡄 and search for ⇛ AWS-Solutions-Architect-Associate ⇚ to obtain a free download 🟪Exam AWS-Solutions-Architect-Associate Passing Score[/url]
- AWS-Solutions-Architect-Associate Authorized Test Dumps ❔ AWS-Solutions-Architect-Associate Reliable Braindumps Ebook 🤫 Test AWS-Solutions-Architect-Associate Prep 🕔 Download ⇛ AWS-Solutions-Architect-Associate ⇚ for free by simply searching on ➤ [url]www.examcollectionpass.com ⮘ 🍒Latest AWS-Solutions-Architect-Associate Exam Materials[/url]
- Pdf AWS-Solutions-Architect-Associate Pass Leader 🚜 AWS-Solutions-Architect-Associate High Quality 💄 Free AWS-Solutions-Architect-Associate Dumps 🍞 Search for AWS-Solutions-Architect-Associate and easily obtain a free download on ➤ [url]www.pdfvce.com ⮘ ⛑AWS-Solutions-Architect-Associate High Quality[/url]
- Amazon Braindumps AWS-Solutions-Architect-Associate Pdf: AWS Certified Solutions Architect - Associate (SAA-C03) - [url]www.examcollectionpass.com Help you Pass for Sure ⏮ Go to website www.examcollectionpass.com open and search for ☀ AWS-Solutions-Architect-Associate ️☀️ to download for free 😶Free AWS-Solutions-Architect-Associate Dumps[/url]
- Free PDF Quiz 2026 AWS-Solutions-Architect-Associate: Reliable Braindumps AWS Certified Solutions Architect - Associate (SAA-C03) Pdf 😯 Enter ➥ [url]www.pdfvce.com 🡄 and search for AWS-Solutions-Architect-Associate to download for free 👞Valid AWS-Solutions-Architect-Associate Exam Tutorial[/url]
- 100% Pass Quiz Amazon - AWS-Solutions-Architect-Associate - AWS Certified Solutions Architect - Associate (SAA-C03) Fantastic Braindumps Pdf 🏭 Enter ➽ [url]www.dumpsmaterials.com 🢪 and search for ⇛ AWS-Solutions-Architect-Associate ⇚ to download for free 🦦Real AWS-Solutions-Architect-Associate Questions[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, app.gxbs.net, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.huajiaoshu.com, www.stes.tyc.edu.tw, aoiacademy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, incomepuzzle.com, Disposable vapes
What's more, part of that PracticeVCE AWS-Solutions-Architect-Associate dumps now are free: https://drive.google.com/open?id=1nlwXR8gFFInlHvlT2AcOlBXaKjjiu3mW
