CFE-Investigation考古題分享|通過保證|退款保證
93
Posted at 1/12/2026 06:23:03      View:156 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. NewDumps在Google Drive上分享了免費的、最新的CFE-Investigation考試題庫:https://drive.google.com/open?id=1smpZmjanHm2Ni7TcOdqoFWh99yZQFOny
如果你不知道如何更有效的通過考試,我給你一個建議是選擇一個良好的培訓網站,這樣可以起到事半功倍的效果。我們NewDumps網站始終致力於為廣大考生提供全部真實的 ACFE的CFE-Investigation認證的考試培訓資料,NewDumps ACFE的CFE-Investigation認證考試考古題軟體供應商授權的產品,覆蓋率廣,可以為你節省大量的時間和精力。
CFE-Investigation證書針對那些積極從事欺詐調查領域的專業人士。ACFE認識到即使具有CFE證書,仍然需要專業知識來進行欺詐調查。因此,他們創建了一個專注於進階技巧和技能的證書,以進行有效的欺詐調查。
ACFE CFE-Investigation考試是一項綜合認證,旨在測試參與詐騙調查的個人的知識和技能。該認證在全球范圍內得到認可,被廣泛認為是詐騙調查領域卓越的基準。該考試是嚴格的,需要對主題有透徹的理解。該認證得到雇主、政府機構和其他參與打擊金融犯罪的組織的認可。
優秀的CFE-Investigation考古題分享和資格考試中的領先提供商和快速下載CFE-Investigation:Certified Fraud Examiner - Investigation ExamNewDumps的CFE-Investigation考古題的命中率很高,可以幫助大家一次通過考試。這是經過很多考生證明過的事實。所以不用擔心這個考古題的品質,這絕對是最值得你信賴的考試資料。如果你還是不相信的話,那就趕快自己來體驗一下吧。你绝对会相信我的话的。
最新的 Certified Fraud Examiner CFE-Investigation 免費考試真題 (Q90-Q95):問題 #90
Which of the following questions would be MOST EFFECTIVE when establishing a baseline during an interview?
  • A. "How long have you been in this department?"
  • B. "Have you committed any misconduct against the company?"
  • C. "Are you familiar with the company's policies regarding ethics?"
  • D. "Do you know who had access to the file?"
答案:A
解題說明:
The manual explains:
"After the interviewer establishes rapport through normal conversation, he must observe the respondent's reactions. This will serve as a baseline for observing behaviour when questions that are more sensitive are asked." A neutral, non-threatening question such as"How long have you been in this department?"is ideal for establishing a baseline.
問題 #91
Beta, a Certified Fraud Examiner (CFE). is conducting an admission-seeking interview of Delta, a fraudsuspect. In establishing a rationalization. Beta says to Delta. "I know you didn't do this for yourself: it was for your family." This technique seeks to establish rationalization by:
  • A. Establishing that Delta's family was being treated unfairly
  • B. Reducing Delta's perception of the legal seriousness of the matter
  • C. Reducing Delta's stress about possibly being fired
  • D. Claiming Delta's action was for altruistic reasons
答案:D
解題說明:
Duringadmission-seeking interviews, fraud examiners often employrationalization techniquesto help the suspect justify their misconduct and make it easier to confess. One of these rationalizations is thealtruistic appeal.
From the2014 International Fraud Examiners Manual:
"Facilitators of communication are those socio-psychological forces that make conversations, including interviews, easier to accomplish. These facilitators require a basic understanding of what motivates people.
The facilitators are: fulfilling expectations, recognition,altruistic appeals, sympathetic understanding, new experience, catharsis, need for meaning, and extrinsic rewards." From theCFE Prep - Investigationsstudy guide:
"Facilitators of communication... include fulfilling expectations, recognition,altruistic appeals, sympathetic understanding, new experience, catharsis, need for meaning, and extrinsic rewards."
#Application to Scenario:
* Beta says:"I know you didn't do this for yourself; it was for your family."
* This is aclassic altruistic appeal- reframing the suspect's motive asselfless or for the benefit of others, rather than selfish wrongdoing.
* The purpose is toreduce internal resistanceto confessing by allowing the suspect to rationalize the act as being for a noble reason.
問題 #92
If the following statements were Included in a fraud examination report of a qualified expert, which of them would be IMPROPER?
  • A. ''When asked s second lima about the amount of funds missing the suspect contradicted their previous testimony"
  • B. The evidence shows that between S1 million and $1.5 million in assets were transferred to an offshore account".
  • C. "In light of all the evidence the suspect is most Italy guilty of fraud against the organization
  • D. the organization must address the inadequate segregation of accounting duties to prevent such an event from happening again.''
答案:C
問題 #93
Anita is interviewing her client's employee whom she suspects committed check fraud. During the interview Anita asks if she can obtain account records from the suspect s bank. If the suspect only gives Anita oral consent. the suspect's bank is required to allow Anita access to the suspect s account records
  • A. False
  • B. True
答案:B
問題 #94
Marilyn a Certified Fraud Examiner (CFE) is reasonably sure that Shelly, her primary suspect committed the fraud in question. Before scheduling an admission-seeking interview with Shelly. Marllyn should be reasonably sure of all of the following EXCEPT.
  • A. That all reasonable investigative steps have been taken
  • B. That the interview's time and location can be consoled
  • C. That the interview's subject matter can be controlled
  • D. That no other person was invoked in the fraud in question
答案:D
問題 #95
CFE-Investigation 是一個占有一定比重的認證科目。由於人數太少,加上需求太大,導致擁有 CFE-Investigation 認證的人成為薪酬最高的資訊技術專業認證人員。由於技能是本身擁有的,加上在全球範圍內的幾乎所有國家都有類似需求。所以,ACFE 的 CFE-Investigation 認證為網路工程師打開了通往全球各地的大門。如果您通過了CFE-Investigation 的考試,將證明你的專業技能和貢獻,展示你的知識與能力。如果你被認證為一個 CFE-Investigation 網路公司的專家,你就會成為這個領域中最有知識的專家之一。
CFE-Investigation套裝: https://www.newdumpspdf.com/CFE-Investigation-exam-new-dumps.html
如果你想知道NewDumps CFE-Investigation套裝的考古題是不是適合你,那麼先下載考古題的demo體驗一下吧,ACFE CFE-Investigation考古題分享 但是,當屬於我們的機會到來的時候我們是否能成功地抓住它呢,CFE-Investigation考試合格分數:70%,CFE-Investigation考試價格:250美元,NewDumps ACFE的CFE-Investigation考試培訓資料是個性價很高的培訓資料,與眾多培訓資料相比,NewDumps ACFE的CFE-Investigation考試培訓資料是最好的,如果你需要IT認證培訓資料,不選擇NewDumps ACFE的CFE-Investigation考試培訓資料,你將後悔一輩子,選擇了NewDumps ACFE的CFE-Investigation考試培訓資料,你將終身受益,CFE-Investigation題庫可以在您考前模擬真實的考試環境,也是最有效的考古題。
這些人就是墻頭草,這麽容易倒了,就像大象,絕不會在意螻蟻般的存在,如果你CFE-Investigation想知道NewDumps的考古題是不是適合你,那麼先下載考古題的demo體驗一下吧,但是,當屬於我們的機會到來的時候我們是否能成功地抓住它呢?
選擇我們的高質量的CFE-Investigation考古題分享:Certified Fraud Examiner - Investigation Exam,ACFE CFE-Investigation一定會很簡單CFE-Investigation考試合格分數:70%,CFE-Investigation考試價格:250美元,NewDumps ACFE的CFE-Investigation考試培訓資料是個性價很高的培訓資料,與眾多培訓資料相比,NewDumps ACFE的CFE-Investigation考試培訓資料是最好的,如果你需要IT認證培訓資料,不選擇NewDumps ACFE的CFE-Investigation考試培訓資料,你將後悔一輩子,選擇了NewDumps ACFE的CFE-Investigation考試培訓資料,你將終身受益。
順便提一下,可以從雲存儲中下載NewDumps CFE-Investigation考試題庫的完整版:https://drive.google.com/open?id=1smpZmjanHm2Ni7TcOdqoFWh99yZQFOny
