[General] 100% Pass Quiz Snowflake - GES-C01 - Efficient Cert SnowPro® Specialty: Gen
87
General 100% Pass Quiz Snowflake - GES-C01 - Efficient Cert SnowPro® Specialty: Gen
Posted at 1/12/2026 08:13:39      View157 | Replies1        Print      Only Author   [Copy Link] 1#
What's more, part of that PassLeaderVCE GES-C01 dumps now are free: https://drive.google.com/open?id=1YIOqiQ0n2SdtmWH5CMHwgtgJliWHY42g
There are multiple companies offering GES-C01 exam material in the market, so we totally understand your inquisitiveness that whom to trust. For your convenience, PassLeaderVCE gives you a chance to try a free demo of Snowflake GES-C01 Exam Questions, which means you can buy the product once you are satisfied with the features and you think it can actually help you to pass your certification exam.
No matter how the surrounding environment changes, you can easily deal with it wiht our GES-C01 exam questions. Do you want to be abandoned by others or have the right to pick someone else? Our GES-C01 simulating exam make you more outstanding and become the owner of your own life! Maybe you need to know more about our GES-C01 training prep to make a decision. Then you can free download the demos of our GES-C01 study guide, and you can have a experience on them before you pay for them.
Download Snowflake GES-C01 Exam Dumps InstantlyLearning with our GES-C01 learning guide is quiet a simple thing, but some problems might emerge during your process of GES-C01 exam materials or buying. Considering that our customers are from different countries, there is a time difference between us, but we still provide the most thoughtful online after-sale service twenty four hours a day, seven days a week, so just feel free to contact with us through email anywhere at any time. Our commitment of helping you to Pass GES-C01 Exam will never change. Considerate 24/7 service shows our attitudes, we always consider our candidates benefits and we guarantee that our GES-C01 test questions are the most excellent path for you to pass the exam.
Snowflake SnowPro® Specialty: Gen AI Certification Exam Sample Questions (Q80-Q85):NEW QUESTION # 80
A data science team is fine-tuning a mistral-lb model within Snowflake Cortex using proprietary customer interaction logs. Which of the following principles and practices apply to this fine-tuning process concerning data privacy, model ownership, and subsequent inference?
  • A. The fine-tuned model, which is a CORTEX_FINETUNED type, can be shared with other Snowflake accounts using secure data sharing.
  • B. The resulting fine-tuned model is exclusively available to the data science team and cannot be accessed by other Snowflake customers.
  • C. The proprietary customer interaction logs used for fine-tuning are leveraged by Snowflake to improve the base mistral -7b model for all customers.
  • D. The fine-tuned model is fully managed by the Snowflake Model Registry API, allowing programmatic management of its lifecycle.
  • E. The fine-tuning process occurs entirely within Snowflake's security and governance boundaries, ensuring the data never leaves the Snowflake environment.
Answer: A,B,E
Cortex Fine-tuning is a fully managed service that lets you fine-tune popular LLMs using your data, all within Snowflake. Your Usage and Customer Data (including inputs and outputs) are NOT used to train, re-train, or fine-tune Models made available to others. Fine-tuned Models built using your data can only be used by you. Therefore, Option A is incorrect. Options B and C are correct, as the fine-tuned model is exclusive to the customer, and the process is managed within Snowflake's boundaries. Option D is also correct because models generated with Cortex Fine- tuning (CORTEX_FINETUNED type) can be shared using Data Sharing. Option E is incorrect because Cortex Fine-Tuned LLMs appear in the model registry's Snowsight UI, but are not managed by the model registry API.
NEW QUESTION # 81
A Snowflake user attempts to access the Cortex Playground to experiment with LLM functions but receives an error indicating insufficient privileges. They have an active Snowflake session. Which of the following steps must be taken to ensure they can successfully use the Cortex Playground?
  • A. Option C
  • B. Option A
  • C. Option B
  • D. Option D
  • E. Option E
NEW QUESTION # 82
A development team is preparing to deploy a new Retrieval-Augmented Generation (RAG) application written in Python. They intend to use Snowflake AI Observability to capture detailed logs and traces for debugging and performance analysis. Which of the following configurations are essential prerequisites for enabling this logging capability effectively?
  • A. Option D
  • B. Option C
  • C. Option A
  • D. Option E
  • E. Option B
Answer: B,C,D,E
NEW QUESTION # 83
A Gen AI Specialist is setting up their Snowflake environment to deploy a high-performance open-source LLM for real-time inference using Snowpark Container Services (SPCS). They need to create a compute pool that can leverage NVIDIAAIOG GPUs to optimize model performance. Which of the following SQL statements correctly creates a compute pool capable of supporting an intensive GPU usage scenario, such as serving LLMs, while adhering to common configuration best practices for a new, small-scale deployment in Snowpark Container Services?
  • A.
  • B.
  • C.
  • D.
  • E.
Option D is correct. The 'GPU NV_M' instance family is explicitly described as "Optimized for intensive GPU usage scenarios like Computer Vision or LLMsNLMs", providing 4 NVIDIAAIOG GPUs. Setting = 1' and 'MAX_NODES = 1' is appropriate for a small- scale deployment, and = 1800' (30 minutes) is a sound practice for cost management during inactivity. Option A is incorrect because is a generic CPU instance, not a GPU instance suitable for LLMs. Option B uses which is a GPU instance and the "smallest NVIDIA GPU size available for Snowpark Containers to get started". While functional, ' GPU is more directly aligned with "intensive GPU usage scenarios like LLMs" as stated in the question. 'AUTO RESUME = TRUE is the default behavior. Option C is incorrect because is a high-memory CPU instance, not a GPU instance. Setting = 0' means the compute pool will not suspend automatically, which is generally not a best practice for a new, small-scale deployment unless continuous availability is strictly required. Option E uses which is a CPU instance, making it unsuitable for GPU-accelerated workloads.
NEW QUESTION # 84
A data science team is fine-tuning a Snowflake Document AI model to improve the extraction accuracy of specific fields from a new type of complex legal document. They are consistently observing low confidence scores and inconsistent 'value' keys for extracted entities, even after initial training. Which two of the following best practices should the team follow to most effectively improve the model's extraction accuracy and confidence for this complex document type?
  • A. Prioritize extensive prompt engineering by creating highly detailed and complex questions with intricate logic to guide the LLM's understanding of the extraction task.
  • B. Set the 'temperature' parameter to a higher value (e.g., 0.7) during '!PREDICT calls to encourage more creative and diverse interpretations by the model.
  • C. Limit the fine-tuning training data exclusively to perfectly formatted and clean documents to ensure the model learns from ideal examples without noise.
  • D. Ensure the training dataset used for fine-tuning includes diverse documents representing various layouts, data variations, and explicit examples of values or empty cells where appropriate.
  • E. Actively involve subject matter experts (SMEs) or document owners throughout the iterative process to help define data values, provide annotations, and evaluate the model's effectiveness.
Answer: D,E
To improve Document AI model training, it is crucial to ensure that the documents uploaded for training represent a real use case and that the dataset consists of diverse documents in terms of both layout and data. If all documents contain the same data or are always presented in the same form, the model might provide incorrect results. For table extraction, it is vital that enough data is used to train the model to include ' NULC values and maintain order. Therefore, ensuring a diverse training dataset (Option B) is a key best practice. Additionally, Subject Matter Experts (SMEs) and document owners are crucial partners in understanding and evaluating the model's effectiveness in extracting the required information. Their involvement in defining data values, providing annotations, and evaluating results will significantly improve accuracy (Option C). Option A is not a best practice; it's recommended to keep questions as encompassing as possible and rely on training with annotations rather than complex prompt engineering, especially for document variability. Option D is incorrect; a higher 'temperature' value increases the randomness and diversity of the model's output, which is generally undesirable for accurate data extraction where deterministic results are preferred. For most consistent results, 'temperature' should be set to 0. Option E is incorrect because training on a restricted set of perfectly formatted documents can lead to a model that performs poorly on real-world, varied documents; diversity in training data is essential.
NEW QUESTION # 85
Our windows software and online test engine of the GES-C01 exam questions are suitable for all age groups. At the same time, our operation system is durable and powerful. So you totally can control the GES-C01 study materials flexibly. It is enough to wipe out your doubts now. If you still have suspicions, please directly write your questions and contact our online workers. And we will give you the most professions suggestions on our GES-C01 learning guide.
Valid GES-C01 Test Cost: https://www.passleadervce.com/Snowflake-Certification/reliable-GES-C01-exam-learning-guide.html
After using our GES-C01 study dumps, users can devote more time and energy to focus on their major and makes themselves more and more prominent in the professional field, The GES-C01 actual exam guide can provide them with efficient and convenient learning platform so that they can get the certification as soon as possible in the shortest possible time, The Snowflake GES-C01 exam dumps are similar to real exam questions.
And because there's no waiting for the canvas to refresh, you can try out different GES-C01 alternatives immediately on the canvas, The organization should establish a policy on accounting for this zero function point maintenance.
2026 The Best Cert GES-C01 Exam | 100% Free Valid SnowPro® Specialty: Gen AI Certification Exam Test CostAfter using our GES-C01 Study Dumps, users can devote more time and energy to focus on their major and makes themselves more and more prominent in the professional field.
The GES-C01 actual exam guide can provide them with efficient and convenient learning platform so that they can get the certification as soon as possible in the shortest possible time.
The Snowflake GES-C01 exam dumps are similar to real exam questions, Do you want to be an excellent talent, On one hand we provide the latest questions and answers about the Snowflake GES-C01 exam, on the other hand we update our GES-C01 verified study torrent constantly to keep the accuracy of the questions.
BONUS!!! Download part of PassLeaderVCE GES-C01 dumps for free: https://drive.google.com/open?id=1YIOqiQ0n2SdtmWH5CMHwgtgJliWHY42g
Posted at 1/13/2026 06:58:47        Only Author  2#
Thank you for the brilliant share, the article is truly eye-opening! Sharing free Pdf FCP_FAZ_AN-7.6 exam dump study materials. Wishing you the best of luck!
