1z0-1046-24 Latest Test Materials | Best 1z0-1046-24 Preparation Materials
87
Posted at 1/12/2026 08:32:02      View:119 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 Latest 2Pass4sure 1z0-1046-24 PDF Dumps and 1z0-1046-24 Exam Engine Free Share: https://drive.google.com/open?id=1R1Div5w7HRH47G2TqojPRzYAU7sh_Slr
Oracle PDF Questions can be used anywhere or at any time. You can download 1z0-1046-24 dumps pdf files on your laptop, tablet, smartphone, or any other device. Practicing with Web-based and desktop 1z0-1046-24 practice test software, you will get a strong grip on every Oracle 1z0-1046-24 exam topic. You can take multiple Oracle 1z0-1046-24 Practice Exam attempts and identify and overcome your mistakes. Furthermore, through Oracle 1z0-1046-24 practice test software you will improve your time-management skills. You will easily manage your time while attempting the actual 1z0-1046-24 test.
These are all the advantages of the Oracle Global Human Resources Cloud 2024 Implementation Professional (1z0-1046-24) certification exam. To avail of all these advantages you just need to enroll in the Oracle Global Human Resources Cloud 2024 Implementation Professional (1z0-1046-24) exam dumps and pass it with good scores. To pass the Oracle Global Human Resources Cloud 2024 Implementation Professional (1z0-1046-24) exam you can get help from 2Pass4sure 1z0-1046-24 Questions easily.
Oracle Global Human Resources Cloud 2024 Implementation Professional sure torrent & 1z0-1046-24 valid training & Oracle Global Human Resources Cloud 2024 Implementation Professional test pdfAnother version of Oracle Global Human Resources Cloud 2024 Implementation Professional (1z0-1046-24) practice exams is also available at 2Pass4sure and that is web-based. It has all specifications we have discussed above in the section of the Oracle 1z0-1046-24 desktop practice test software. But the only difference is that this web-based 1z0-1046-24 practice exam software works online and needs no software installation. Furthermore, this 1z0-1046-24 Practice Exam is supported by both Windows and iOS, Android, Mac, and Linux. Since it is the web-based 1z0-1046-24 practice exam, you can take it from Opera, Chrome, Safari, Firefox, or any other popular browser.
Oracle Global Human Resources Cloud 2024 Implementation Professional Sample Questions (Q90-Q95):NEW QUESTION # 90
Which three statements are true about Person Number? (Choose three.)
  • A. If the Person Number generation method is once set to manual, it can be changed to automatic if a person record is created.
  • B. Initial Person Number cannot be provided at enterprise level.
  • C. Initial Person Number can be provided at enterprise level.
  • D. Person Numbers for contacts are generated automatically.
  • E. If the Person Number generation method is once set to manual, it can be changed to automatic even if no person record is created.
Answer: C,D,E
Full Detailed in Depth Explanation:
Person Number in Oracle HCM Cloud is a unique identifier assigned to individuals (employees, contingent workers, contacts, etc.). Its generation method can be configured at the enterprise level, and its behavior depends on the setup.
* Option A ("Initial Person Number can be provided at enterprise level"): True. During enterprise setup in the "Manage Enterprise HCM Information" task, you can specify whether Person Numbers are generated automatically or manually and provide an initial value (e.g., starting number). This is documented in the "Implementing Global Human Resources" guide.
* Option C ("erson Numbers for contacts are generated automatically"): True. Contacts (e.g., emergency contacts or dependents) automatically receive Person Numbers when created, regardless of the generation method for employees. This ensures uniqueness across all person types, as per Oracle's standard functionality.
* Option E ("If the Person Number generation method is once set to manual, it can be changed to automatic even if no person record is created"): True. The generation method is configurable in the enterprise setup and can be changed from manual to automatic (or vice versa) at any time before or after records are created, though changes after record creation may require careful handling of existing data.
* Option B ("If the Person Number generation method is once set to manual, it can be changed to automatic if a person record is created"): False. This statement is incomplete and misleading. The method can be changed regardless of whether a record exists, but the wording implies a restriction that isn't accurate.
* Option D ("Initial Person Number cannot be provided at enterprise level"): False. As noted in Option A, the initial value can be set at the enterprise level.
NEW QUESTION # 91
As part of a client's configuration requirements, they have indicated that they want to create divisions by Line of Business in HCM Cloud. After creating them, in which two ways can you associate workers with a specific division?
  • A. You configure and deploy an assignment descriptive flexfield that has a table value set that references the Division object. When you complete a worker's assignment, you select the appropriate division through that flexfield segment.
  • B. Division is a delivered field on the worker assignment. Therefore, when a worker is hired, the correct division would be selected by the user entering the information.
  • C. Division is a delivered field on a position. If you are using Positions, when you associate a worker with a position, they will be associated with the division tied to that position.
  • D. You have configured an Organization Tree, listing the hierarchy of your Legal Entities, Divisions, Business Units, and Departments. You associate a worker with a department that falls within a division to associate the worker with that division.
Divisions in Oracle HCM Cloud are organizational units often aligned with lines of business. Associating workers with divisions requires leveraging existing structures or custom fields.
* Option B ("You configure and deploy an assignment descriptive flexfield that has a table value set that references the Division object"): True. A Descriptive Flexfield (DFF) on the assignment can be configured with a value set linked to the Division object, allowing manual selection during assignment updates, as per the "Implementing Global Human Resources" guide.
* Option D ("You have configured an Organization Tree, listing the hierarchy of your Legal Entities, Divisions, Business Units, and Departments"): True. By associating a worker with a department within a division via the organization hierarchy, the worker is indirectly linked to that division, a standard practice in workforce structures.
* Option A ("Division is a delivered field on a position"): False. Position has fields like Department, but Division is not a standard delivered field.
* Option C ("Division is a delivered field on the worker assignment"): False. Assignment includes fields like Department, not Division directly.
NEW QUESTION # 92
A manager checks the availability of a worker. The manager is not aware that the worker does not have a work schedule assigned. Which three items will be used to determine the availability of a worker?
  • A. Calendar Events
  • B. Standard Working Hours
  • C. Time Sheet
  • D. Absences
  • E. Contract Data
Answer: A,B,D
Full Detailed In-Depth Explanation:
In Oracle Global Human Resources Cloud, a worker's availability is determined by combining multiple data points that define their working and non-working time. When a work schedule is not assigned, the system relies on alternative sources to calculate availability, as seen in the "Check Availability" feature (e.g., in the Directory or My Team).
* Option A: Contract Data defines employment terms (e.g., full-time/part-time status) but does not directly specify daily or hourly availability without a linked schedule or hours. It's not a primary factor here.
* Option B: Absences (e.g., vacation, sick leave) reduce a worker's availability by indicating time they are not available to work. This is a key component, making it correct.
* Option C: Calendar Events (e.g., public holidays, company-wide closures) from the worker's assigned work day calendar affect availability by marking non-working days. This is included, making it correct.
* Option D: Standard Working Hours, defined at the enterprise or legal employer level (via Manage Enterprise HCM Information or Manage Legal Entity HCM Information), provide a default working pattern (e.g., 9 AM-5 PM) when no specific work schedule is assigned. This is a fallback mechanism and is correct.
* Option E: Time Sheet data tracks actual hours worked but is not used proactively to determine future availability; it's more for payroll or historical analysis.
Thus, the three items used areB (Absences),C (Calendar Events), andD (Standard Working Hours), as outlined in "Using Global Human Resources" under Availability Management.
NEW QUESTION # 93
Which three HCM Cloud capabilities are considered part of the Global Human Resources Business Process?
  • A. Workforce Directory
  • B. Time and Labor
  • C. Core Human Resources
  • D. Workforce Modeling
  • E. Workforce Compensation
Answer: A,C,D
The Global Human Resources (HR) Business Process in Oracle HCM Cloud encompasses core capabilities that manage workforce data, structures, and planning at a global level. According to Oracle documentation:
* Workforce Directory (A): Provides a centralized view of the workforce, including organizational hierarchies and worker details, which is integral to Global HR.
* Workforce Modeling (D): Enables scenario planning and organizational modeling, a key feature of Global HR for strategic workforce management.
* Core Human Resources (E): Covers essential HR functions like person management,employment records, and organizational structures, forming the backbone of Global HR.
NEW QUESTION # 94
Which is a new feature available on the Redwood Cancel Work Relationship page?
  • A. Option to generate automated performance reports
  • B. Ability to track employee attendance and absences
  • C. Capability to record additional information during work relationship cancellation
The Redwood Cancel Work Relationship page in Oracle Global Human Resources Cloud introduces enhancements designed to improve user experience and streamline the process of terminating work relationships. According to Oracle's 24C and subsequent release notes, one of the key new features is the ability to record additional information during the cancellation of a work relationship. This includes selecting actions and action reasons for the cancellation and utilizing the action occurrence extensible flexfield (EFF) to store extra details in an "Additional Info" section, which is displayed only when configured for the action occurrence EFF. This feature enhances flexibility and allows organizations to capture enterprise-specific data during the termination process.
* Option A: Ability to track employee attendance and absencesTracking employee attendance and absences is not a feature associated with the Redwood Cancel Work Relationship page. Attendance and absence management are handled through separate modules, such as Oracle Absence Management or Time and Labor, and are not integrated into the work relationship cancellation process. Oracle documentation does not mention attendance or absence tracking as part of this page's functionality, making this option incorrect.
* Option B: Capability to record additional information during work relationship cancellationThis is the correct answer. Oracle's 24C release notes specify that the Redwood Cancel Work Relationship page allows users to configure multiple actions for the cancellation process and includes an action occurrence EFF in the Additional Info section. This enables the storage of extra information, such as specific reasons or contextual details, during the cancellation. The feature is supported by configuration in the Business Rules to show the Additional Info section and is available only on the Redwood page, not the responsive version, enhancing the user experience with greater customization.
* Option C: Option to generate automated performance reportsGenerating automated performance reports is not a feature of the Redwood Cancel Work Relationship page. Performance reports are typically managed through Oracle Performance Management or Talent Management modules, and no Oracle documentation indicates that the Cancel Work Relationship page includes this capability. This option is unrelated to the termination process and is therefore incorrect.
References
* Oracle Fusion Cloud Human Resources 24C What's New, Document ID: docs.oracle.com, Published:
2024-08-27
* Section: Redwood Experience for Cancel Work Relationship Page: "Ability to record extra info while canceling a work relationship - You can now select the action and action reason for canceling the work relationship. You can now configure multiple actions as a part of the Cancel Work Relationship action type. Additionally, the action occurrence extensible flexfield (EFF) is added in the Additional info section so that you can store extra information while canceling a work relationship."
* Oracle Global Human Resources Cloud: Using Global Human Resources, Document ID: docs.oracle.
com, Published: 2024-07-02
* Section: Cancel Work Relationships: "Describes the process to cancel work relationships, including configuration of actions and reasons."
* Oracle Global Human Resources Cloud: Implementing Global Human Resources, Document ID: docs.
oracle.com, Published: 2023-12-12
* Section: Extensible Flexfields: "Explains how EFFs can be configured to capture additional attributes for actions like work relationship cancellation
NEW QUESTION # 95
Now IT industry is more and more competitive. Passing Oracle 1z0-1046-24 exam certification can effectively help you entrench yourself and enhance your status in this competitive IT area. In our 2Pass4sure you can get the related Oracle 1z0-1046-24 exam certification training tools. Our 2Pass4sure IT experts team will timely provide you the accurate and detailed training materials about Oracle Certification 1z0-1046-24 Exam. Through the learning materials and exam practice questions and answers provided by 2Pass4sure, we can ensure you have a successful challenge when you are the first time to participate in the Oracle certification 1z0-1046-24 exam. Above all, using 2Pass4sure you do not spend a lot of time and effort to prepare for the exam.
Best 1z0-1046-24 Preparation Materials: https://www.2pass4sure.com/Oracle-Global-Human-Resources-Cloud/1z0-1046-24-actual-exam-braindumps.html
Firstly, 1z0-1046-24 online training can simulate the actual test environment and bring you to the mirror scene, which let you have a good knowledge of the actual test situation, If you prefer to practice 1z0-1046-24 exam dumps on paper, you can try the exam dumps of us, The average passing rate for Oracle 1z0-1046-24 exam is 15% or so every year, Superior to other exam questions, 1z0-1046-24 dumps PDF: Oracle Global Human Resources Cloud 2024 Implementation Professional can give you the most understandable explains.
To Photoshop's advantage, its selection tools need work 1z0-1046-24 only with still images, Topics include creating great-looking slides using templates or your own designs;
Firstly, 1z0-1046-24 Online Training can simulate the actual test environment and bring you to the mirror scene, which let you have a good knowledge of the actual test situation.
Get Authoritative 1z0-1046-24 Latest Test Materials and Useful Best 1z0-1046-24 Preparation MaterialsIf you prefer to practice 1z0-1046-24 exam dumps on paper, you can try the exam dumps of us, The average passing rate for Oracle 1z0-1046-24 exam is 15% or so every year.
Superior to other exam questions, 1z0-1046-24 dumps PDF: Oracle Global Human Resources Cloud 2024 Implementation Professional can give you the most understandable explains, They dedicated to make it better both in your aim to pass practice exam efficiently and content to be easy-remembering.
DOWNLOAD the newest 2Pass4sure 1z0-1046-24 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1R1Div5w7HRH47G2TqojPRzYAU7sh_Slr
Posted at 1/13/2026 20:43:17        Only Author  2#
Thank you for your brilliant article, it’s truly mind-blowing! Wish me all the luck in the world for the Test NSE5_FSW_AD-7.6 dumps demo exam!
Posted at 1/21/2026 20:43:03        Only Author  3#
SAP 인증C_P2W12_2311인증시험공부자료는ass4Test에서 제공해드리는SAP 인증C_P2W12_2311덤프가 가장 좋은 선택입니다. Pass4Test에서는 시험문제가 업데이트되면 덤프도 업데이트 진행하도록 최선을 다하여 업데이트서비스를 제공해드려 고객님께서소유하신 덤프가 시장에서 가장 최신버전덤프로 되도록 보장하여 시험을 맞이할수 있게 도와드립니다.
Posted at 2/23/2026 05:40:26        Only Author  4#
Your article really shocked me; thank you for sharing! Thanks to the Valid dumps NETA_2 ebook, I got promoted and received a raise. Now, I’m offering it for free to everyone. Best of luck in your career endeavors!
