[Linux] [Core-PX30-JD4] Problem with custom board boot state
67
Linux [Core-PX30-JD4] Problem with custom board boot state
Posted at 4/6/2022 17:21:26      View4451 | Replies5        Print      Only Author   [Copy Link] 1#
Hi
So I have finish building a firmware for PX30-JD4 for the development board (which runs OK) and now i want to test it with my own custom board. Then when I flash it into the eMMC, the boot time is very long (about 10 mins) and when I can access to root user space, the computer is very laggy and it got crash after just a few minutes. In addition, I also notice that when I flash the same firmware in the PX30-JD4 development board, when it finish booting to rootfs, the name in terminal is [root@px30_4]# while in my custom board it just [root@buildroot:/]#. Then, when finish init the kernel, there is an error in starting eudev "udevadm settle failed" and I guess that it is the reason why but I do not know how to fix it. I have attach the console log to the thread. the config in buildroot menuconfig is almost the same with just the only change is the system welcome banner. file:///mnt/eb33cb52-1fac-44ec-b87e-5d30775874f5/Project/Test/PX30/px30_linux_release_20210304/log
Please help, thank you for any helps,
Tu
log.txt.zip
12.97 KB, Down times: 3
console log when boot up
administrator
Rank: 9Rank: 9Rank: 9
Posted at 4/8/2022 09:06:10        Only Author  2#
Hello, sorry for keeping you waiting.  The engineer is following this.  He will reply you soon.
Posted at 4/8/2022 14:39:25        Only Author  3#
You should have noticed that after flashing the firmware for the first time, the system will boot twice. On first boot, it formats the userdata partition with the user called  `[root@buildroot:/]#`. Then reboot, user called `[root@px30_4]#` .
I suspect there is a problem with your emmc. From the information, it's just too slow to format the userdata partition, nothing else.
Posted at 4/14/2022 15:17:01        Only Author  4#
ʱĺ Posted at 4/8/2022 14:39
You should have noticed that after flashing the firmware for the first time, the system will boot tw ...
Thanks you ʱĺ for your answer. So if the problem is with the emmc can I just config the format process to happen at a slower speed to be suitable with my emmc. If it is possible can you give me some hint how to do it. Thank you
Posted at 1/13/2026 21:34:07        Only Author  5#
Sie können nur die Fragen und Antworten zur CompTIA CV0-004 (CompTIA Cloud+ (2025)) Zertifizierungsprfung von PrfungFrage als Simulationsprfung benutzen, dann können Sie einfach die Prfung bestehen. Mit dem CompTIA CV0-004 Zertfikat steht Ihr professionelles Niveau höher als das der anderen. Sie bekommen deshalb große Beförderungschance. Fgen Sie CompTIA CV0-004 Fragen und Antworten von PrfungFrage in den Warenkorb hinzu. PrfungFrage bietet Ihnen rund um die Uhr Online-Service.
Posted at 1/22/2026 13:17:27        Only Author  6#
Cant resist liking this great content. Free AZ-700 Actual Test resources are sharedgood luck to all!
