Real MB-820 Exams - MB-820 Exam Engine
Posted at 1/12/2026 08:47:09
2026 Latest Actual4Labs MB-820 PDF Dumps and MB-820 Exam Engine Free Share: https://drive.google.com/open?id=1b7tmJUJ0pYVEEASsVUx6p4RK1lvG4yS1
As old saying goes, knowledge is wealth. So our MB-820 exam questions will truly teach you a lot of useful knowledge, which can compensate for your shortcomings. Actions speak louder than words. You are supposed to learn to make a rational plan of life. Our MB-820 Real Exam will accompany you to grow stronger. And the more you know, the more easily you can cope with the difficulties in your work. And the most important is that you can get the MB-820 certification.
Microsoft MB-820 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
| | Topic 2 | - Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
| | Topic 3 | - Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
2026 MB-820 – 100% Free Real Exams | Pass-Sure MB-820 Exam EngineBefore you really attend the MB-820 exam and choose your materials, we want to remind you of the importance of holding a certificate like this one. Obtaining a MB-820 certificate likes this one can help you master a lot of agreeable outcomes in the future, like higher salary, the opportunities to promotion and being trusted by the superiors and colleagues. Our MB-820 Exam Questions can help you achieve all of your dreams.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q82-Q87):NEW QUESTION # 82
You need to parse the API JSON response and retrieve each order no. in the response body.
How should you complete the code segment? To answer select the appropriate options in the answer area.
NEW QUESTION # 83
A company is setting up a sandbox environment.
You observe the following issues in Visual Studio Code:
* When you open the User Settings window, no AL command is available
* In the Problems tab. the error 'The target page Customer List for the extension object is not found' is displayed.
You need to identify a solution for each issue.
Which solutions should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 84
A developer creates a profile for part-time shop supervisors and adds customizations.
You plan to add new requirements to the profile.
You need to analyze the code to understand the profile and make sure there are no errors.
The Part Time Shop Supervisor profile will be applied only to users with "Register Time" = true on User Setup: No Variables, procedures, and triggers cannot be added on page customization objects: Yes Line 10 should use extends instead of customizes: No In line 18, "Unit Cost" will be moved after "Costing Method": Yes The Part Time Shop Supervisor profile will be applied only to users with "Register Time" = true on User Setup.
* No
* The code doesn't contain any reference to the User Setup table or the Register Time field, so this is not correct. Profiles are not applied conditionally based on fields like this.
Variables, procedures, and triggers cannot be added on page customization objects.
* Yes
* Page customization objects are meant for UI modifications, such as moving or hiding fields. You cannot add variables, procedures, or triggers in a page customization object.
Line 10 should use extends instead of customizes.
* No
* In AL, when customizing a page within a profile, you use customizes rather than extends. Extends is used when modifying base application objects, but customizes is used to customize pages within a profile.
In line 18, "Unit Cost" will be moved after "Costing Method".
* Yes
* The code in line 18 is correct. The moveafter directive will move the "Unit Cost" field after the " Costing Method" field on the page layout.
NEW QUESTION # 85
A company uses Business Central.
The company has sales orders that have a different location in the header than in the customer's card. You plan to add a check on sales order posting.
The check must meet the following requirements.
* Sales Order must have the same Location Code as the Location Code set up on the customer's card.
* Must not be run in preview mode.
* Must be run even if the user is only shipping items and not invoicing.
You create an event subscription for codeunit 80 "Sales-Post" You need to identify which event to subscribe to Which event should you identify?
* This event occurs before posting a sales document.
* PreviewMode is available in the parameters, which allows checking whether the process is being run in preview mode.
* This event is typically used for sales order posting and can be used for both shipping and invoicing.
This event matches the requirements because:
* You can check if PreviewMode is false.
* It can run for both shipping and invoicing.
NEW QUESTION # 86
You need to define the data types for the fields of the N on-conformity table.
Which two data types should you use? Each correct answer presents part of the solution.
- A. Date for the Non-Conformity Date field
- B. Date Time for the Non-Conformity Date field
- C. Char for the Non-Conformity Number field
- D. Integer for the N on-conformity Number field
- E. Code for the Non-Conformity Number field
Answer: C,E
In Business Central, fields in tables are assigned specific data types that determine the kind of data they can store. For the Non-conformity table mentioned in the case study, the following data types should be used:
Date for the Non-Conformity Date field: This is because the Non-conformity Date field is required to store only the date when the non-conformity was recorded. The Date data type is appropriate for storing dates without times.
Code for the Non-Conformity Number field: The Non-conformity Number field is described to use alphanumeric values with a format that includes "NC" and the year, like "NC24-001". In Business Central, the Code data type is used for fields that store alphanumeric keys. It is a text field with a limited length, which makes it suitable for number series that contain letters and numbers.
Other options are not suitable:
A . Integer for the Non-conformity Number field: This would not be appropriate because the Non-conformity Number includes alphanumeric characters and not just integers.
B . DateTime for the Non-Conformity Date field: This is not correct because there is no requirement to store the time alongside the date.
C . Char for the Non-Conformity Number field: Char data type is not typically used in Business Central for number series or identifiers. The Code data type is preferred for this purpose.
Topic 2, Contoso, Ltd.
Overview
Contoso, Ltd. Is a sales company in the manufacturing industry. It has subsidiaries in multiple countries/regions, each with its own localization. The subsidiaries must be data-independent from each other. Contoso. Ltd. uses an external business partner to manage the subcontracting of some manufacturing items. Contoso. Ltd. has different sectors with data security between sectors required.
Contoso, Ltd. uses Business Central online as the main ERP for financial. sales, purchase, warehouse, and manufacturing processes. It has employees that use the Business Central web application and external applications. The company has a custom external mobile app under development The IT department and its partners installed custom extensions to satisfy the company's requirements where the functionality is not available natively.
Contoso. Ltd. interacts with external services provided by customers and partners. Different applications interact with SOAP and OData endpoints exposed from Business Central.
An external business partner of Contoso, Ltd exposed a REST API for receiving details about new subcontracting orders and for sending the planned release date of each subcontracting order received.
Contoso. Ltd. has not activated the monitoring of the tenant and has no internal telemetry for its apps.
Custom reporting must be created to meet the requirements of the different departments.
Contoso, Ltd. has the following tenant management considerations:
IT department
* The IT department requires the ability to monitor the tenant to prevent performance problems and detect possible anomalies.
* The IT department plans to use Azure Application Insights and Log Analytics to inspect the ingested telemetry signals.
* All tenant upgrades are automatically handled by Microsoft. The IT department does not check for update availability or for tenant-related notifications.
* The IT department has not configured the receipt of tenant-related notifications from the Business Central admin center.
External business partner
* The external business partner must add custom telemetry to an application created for Contoso. Ltd. to monitor a business process.
* Custom telemetry signals for the application must be visible only on the partner's telemetry.
SOAP
* Contoso, Ltd. plans to dismiss using the SOAP protocol for integrations.
* Contoso, Ltd. must be able to detect if external applications are using its Business Central SOAP endpoints.
Issue
The Business Central tenant is upgraded by Microsoft to a new major version during the night.
Users report that one of the Contoso. ltd. extensions disappeared from the tenant The IT department confirms that the extension is still published.
Contoso. Ltd. plans to create a custom mobile application that has the following requirements:
* The app must be used by employees to check item details from the ERP in real time and to report issues that occur during the manufacturing process.
* An AL extension must be created for handling archived issues.
* Business Central development guidelines must be followed when implementing modules.
* A module must be implemented for the reporting and tracking of issues information. You plan to call this module Issue Management The module must expose a method nan Postlude.
* Code modifications will be required over time.
* The Issue Management process must be split into two extensions:
* ISSUE BASE: main extension
* ISSUE EXT: second extension with dependency from ISSUE BASE
* In the version 1.0.0.0 of the ISSUE BASE extension, you plan to create an Issue table that contains a global Decimal variable named Issue Total.
* In the version 1.0.0.0 of the ISSUE BASE extension, you plan to define a table named Issue Category with a Description field defined as follows:
field (2; Description; Text[SG])
DataClassificstion * CustoaerContent;
* The Issue table defined in ISSUE BASE extension contains a Clone procedure defined as follows:
procedure Corte () begin end;
* In the ISSUE EXT extension, you create a table extension object of the Issue table.
* The table extension object of the Issue table must access the Issue Total: Decimal variable.
After weeks of usage, you discover that you must remove the Description field and the Clone procedure because they are no longer required.
In a new version of the ISSUE BASE extension, you create a new Issue Type table. You must move data row by row from a previously obsolete Issue Category table to the new Issue Type table. Because a large amount of data must be moved, you must write an Upgrade codeunit by using the DataTransfer object.
The IT department creates a custom API for exposing the custom Issue table. The API provides an action for copying an issue to a new table. The action is defined as follows:
(Service Enabled]
procedure Copy (vary action Context: WebServiceActionContext)
begin
end;
Contoso, Ltd. must create an API in Business Central to expose item details to the mobile application.
* The API must have the lowest possible impact on the production environment when used during working hours.
* The API must only support Get operations.
A user of the ISSUE BASE extension in Business Central reports a problem.
To debug the problem, snapshot debugging with the following configuration was activated:
You discover that the debugging is not triggering.
Contoso, Ltd. must connect Business Central to the external API provided by the business partner. This will be used for the partner to send the details of new subcontracting orders to fulfill the sales demand, and for receiving the planned release date of each order sent. The integration requirements are as follows:
* The business partner will provide a REST API secured with basic authentication. Credentials to access the API will be shared with Contoso, ltd.
* The API for sending subcontracting orders must be called by sending an authenticated POST request to the given endpoint.
* The API for retrieving the order no. and planned release date of each subcontracting order responds with the following JSON:
Each order no. must be retrieved.
NEW QUESTION # 87
Our MB-820 test questions are available in three versions, including PDF versions, PC versions, and APP online versions. Each version has its own advantages and features, MB-820 test material users can choose according to their own preferences. The most popular version is the PDF version of MB-820 exam prep. The PDF version of MB-820 Test Questions can be printed out to facilitate your learning anytime, anywhere, as well as your own priorities. The PC version of MB-820 exam prep is for Windows users. If you use the APP online version, just download the application. Program, you can enjoy our MB-820 test material service.
MB-820 Exam Engine: https://www.actual4labs.com/Microsoft/MB-820-actual-exam-dumps.html
- MB-820 Exams Torrent 🦈 Sample MB-820 Test Online 😍 Pdf MB-820 Exam Dump 🏯 The page for free download of 《 MB-820 》 on ⮆ [url]www.practicevce.com ⮄ will open immediately 🍱Latest MB-820 Exam Tips[/url]
- 100% Pass Quiz 2026 Efficient MB-820: Real Microsoft Dynamics 365 Business Central Developer Exams 🚕 Open ⮆ [url]www.pdfvce.com ⮄ and search for ➠ MB-820 🠰 to download exam materials for free 🕞MB-820 Reliable Exam Braindumps[/url]
- Real MB-820 Exams - Pass Guaranteed 2026 MB-820: Microsoft Dynamics 365 Business Central Developer First-grade Exam Engine 🛢 Search for 【 MB-820 】 and download it for free on 【 [url]www.examcollectionpass.com 】 website 👩MB-820 Exams Torrent[/url]
- Real MB-820 Exams - How to Study - Well Prepare for Microsoft MB-820 Exam ♻ { [url]www.pdfvce.com } is best website to obtain ➽ MB-820 🢪 for free download ⛺Exam Dumps MB-820 Free[/url]
- 100% Pass Quiz 2026 Efficient MB-820: Real Microsoft Dynamics 365 Business Central Developer Exams 🧜 Search for 【 MB-820 】 on ⮆ [url]www.pass4test.com ⮄ immediately to obtain a free download 💢Exam MB-820 Tutorials[/url]
- Study Materials MB-820 Review 🌱 Latest MB-820 Exam Tips 🌌 Real MB-820 Dumps 🚠 Open { [url]www.pdfvce.com } and search for ⏩ MB-820 ⏪ to download exam materials for free ⏮Sample MB-820 Test Online[/url]
- Pass Guaranteed 2026 Microsoft MB-820: Microsoft Dynamics 365 Business Central Developer –Valid Real Exams 🏓 Immediately open [ [url]www.prepawaypdf.com ] and search for ⮆ MB-820 ⮄ to obtain a free download 😢MB-820 Exams Torrent[/url]
- Real MB-820 Exams - Pass Guaranteed 2026 MB-820: Microsoft Dynamics 365 Business Central Developer First-grade Exam Engine ❇ Search for ➠ MB-820 🠰 and download exam materials for free through ➠ [url]www.pdfvce.com 🠰 👳Latest MB-820 Exam Tips[/url]
- Pass Guaranteed 2026 Microsoft MB-820: Microsoft Dynamics 365 Business Central Developer –Valid Real Exams 🆖 Download ☀ MB-820 ️☀️ for free by simply searching on ➽ [url]www.pdfdumps.com 🢪 🙃MB-820 Reliable Exam Braindumps[/url]
- 2026 Efficient MB-820: Real Microsoft Dynamics 365 Business Central Developer Exams 🐂 Open ➡ [url]www.pdfvce.com ️⬅️ and search for ✔ MB-820 ️✔️ to download exam materials for free 💇Exam Dumps MB-820 Free[/url]
- MB-820 Exam Success 🖐 MB-820 Reliable Exam Braindumps 🍎 MB-820 Exams Torrent ⛪ Open website 《 [url]www.examcollectionpass.com 》 and search for ( MB-820 ) for free download 🕡Sample MB-820 Test Online[/url]
- bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.so0912.com, learning.investagoat.co.za, www.stes.tyc.edu.tw, bbs.t-firefly.com, gettr.com, mamathonline.co.in, shangjiaw.cookeji.com, bbs.t-firefly.com, Disposable vapes
P.S. Free 2026 Microsoft MB-820 dumps are available on Google Drive shared by Actual4Labs: https://drive.google.com/open?id=1b7tmJUJ0pYVEEASsVUx6p4RK1lvG4yS1
