[General] Latest New CIS-Discovery Exam Dumps | 100% Free CIS-Discovery Exam Engine
83
General Latest New CIS-Discovery Exam Dumps | 100% Free CIS-Discovery Exam Engine
Posted at 1/12/2026 09:17:51      View128 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New CIS-Discovery dumps are available on Google Drive shared by FreePdfDump: https://drive.google.com/open?id=1bRlc-0lgYxzdi32fz7XBaxeYmSm1nMoz
All the advandages of our CIS-Discovery exam braindumps prove that we are the first-class vendor in this career and have authority to ensure your success in your first try on CIS-Discovery exam. We can claim that prepared with our CIS-Discovery study guide for 20 to 30 hours, you can easy pass the exam and get your expected score. Also we offer free demos for you to check out the validity and precise of our CIS-Discovery Training Materials. Just come and have a try!
ServiceNow CIS-Discovery certification is an excellent opportunity for IT professionals to validate their skills and knowledge in implementing and managing ServiceNow Discovery. Certified Implementation Specialist - Discovery certification provides individuals with a competitive edge in the job market and demonstrates their ability to work with ServiceNow solutions. With the rising demand for ServiceNow solutions worldwide, becoming a certified CIS-Discovery Implementation Specialist can open up many career opportunities for IT professionals.
ServiceNow CIS-Discovery Exam Engine | CIS-Discovery Certification Exam InforOne of the biggest advantages of our CIS-Discovery learning guide is that it you wont loss anything if you have a try with our CIS-Discovery study materials. you can discover the quality of our exam dumps as well as the varied displays that can give the most convenience than you can ever experience. Both of the content and the displays are skillfully design on the purpose that CIS-Discovery Actual Exam can make your learning more targeted and efficient.
The CIS-Discovery exam is a 90-minute test that consists of 60 multiple-choice questions. CIS-Discovery exam is designed to evaluate the candidate's knowledge of ServiceNow Discovery, including its configuration, implementation, and troubleshooting. CIS-Discovery exam is available in multiple languages, and candidates must achieve a passing score of 70% or higher to earn the certification. The ServiceNow CIS-Discovery Certification is recognized globally and is highly valued by IT organizations that use ServiceNow to manage their IT operations. It is a great opportunity for IT professionals to gain recognition for their skills and expertise in ServiceNow Discovery.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q64-Q69):NEW QUESTION # 64
What would you see in the Discovery pattern log that you would not see in the ECC Queue?
  • A. Shazzam probe payload
  • B. Payload of CI attributes and relationships
  • C. Relationships created
  • D. Success or failure of the individual pattern steps
The Discovery pattern log is a log that records the execution of a pattern during Discovery or Service Mapping1. It shows the success or failure of the individual pattern steps, as well as the input and output variables, the CI attributes and relationships, and the errors or warnings2. The ECC Queue is a table that displays the input and output messages from and to MID Servers3. It shows the payload of CI attributes and relationships, the Shazzam probe payload, and the relationships created, but not the success or failure of the individual pattern steps4. The success or failure of the individual pattern steps is specific to the Discovery pattern log and can be used to debug or troubleshoot the pattern execution2.
1: Discovery pattern log 2: View the Discovery pattern log 3: ECC Queue 4: ECC Queue Processing and Debugging, with "Discovery - Sensors" used as an example
NEW QUESTION # 65
Which of the below choices are benefits of Tracked Configuration Files? (Choose two.)
  • A. Unwanted files removed from target
  • B. Files tracked as CIs
  • C. No credentials needed
  • D. Content version comparison
Tracked configuration files are files that contain settings and parameters of certain applications or devices that Discovery can find and add to the CMDB. Some of the benefits of tracked configuration files are:
* Content version comparison: You can compare the content of different versions of the same configuration file and see the changes that occurred over time. This can help you troubleshoot issues, audit changes, and restore previous configurations if needed.
* Files tracked as CIs: You can view the configuration files as configuration items (CIs) in the CMDB and see their relationships with other CIs, such as the applications or devices they belong to. This can help you understand the dependencies and impact of the configuration files on your IT environment.
1: Configuration file tracking, Modify tracking changes in configuration files
NEW QUESTION # 66
A discovery runs against a Windows Server returning the following attribute values for the first time:
name = WindowsSN1 serial_number = 12321
A subsequent discovery is ran against a different Windows Server returning the following attribute values:
name = WindowsSN2
With only base system CI Identifiers configured, which of the following is true?
  • A. A Windows Server CI is created, then updated with WindowsSN2 as the name.
  • B. Two Windows Server CIs are created, without serial_number values.
  • C. Two Windows Sewer CIs are created, with WindowsSN1 AND WindowsSN2 for names.
  • D. A Windows Server CI is created, then updated with WindowsSN1 as the name.
According to the ServiceNow Discovery documentation, the base system CI Identifiers for Windows Server class are name and serial_number. These are the attributes that Discovery uses to uniquely identify a Windows Server CI. If both attributes match an existing CI, Discovery updates that CI. If only one attribute matches, Discovery creates a new CI. If neither attribute matches, Discovery also creates a new CI. In this scenario, the serial_number is the same for both Windows Servers, but the name is different. Therefore, Discovery will create two separate CIs, one with WindowsSN1 as the name and one with WindowsSN2 as the name.
* Create a Discovery CI classification - Product Documentation: Tokyo - Now Support Portal
* Identification rules - Product Documentation: Tokyo - Now Support Portal
* ServiceNow IRE: Identification Rules Explained - Cookdown
NEW QUESTION # 67
Which of the following fields are editable from a Merge Table pattern operation?
Choose 3 answers
  • A. First Table
  • B. Primary Table
  • C. Second Table
  • D. Target Table
Answer: A,C,D
In a Merge Table pattern operation within ServiceNow Discovery, the editable fields typically include the Target Table, Second Table, and First Table. These fields are configurable and allow users to specify the tables involved in the merge operation. The Target Table is where the merged data will be stored, while the First and Second Tables are the source tables whose data is being merged. The Primary Table is not typically an editable field in this context. References = ServiceNow Discovery documentation, particularly the sections discussing pattern design and operations, including Merge Table operations within Discovery Patterns.
NEW QUESTION # 68
Identification process is the process of ______ .
Response:
  • A. identifying the operating system type (Windows, Linux,...) on server CIs that is present in the CMDB
  • B. linking a unique identifier to a matching service
  • C. identifying specific devices without IPs
  • D. uniquely identifying CIs to determine if it is a newly discovered CI or if it already exists in the CMDB
NEW QUESTION # 69
CIS-Discovery Exam Engine: https://www.freepdfdump.top/CIS-Discovery-valid-torrent.html
2026 Latest FreePdfDump CIS-Discovery PDF Dumps and CIS-Discovery Exam Engine Free Share: https://drive.google.com/open?id=1bRlc-0lgYxzdi32fz7XBaxeYmSm1nMoz
Posted at 1/17/2026 10:00:58        Only Author  2#
This content is gold, liking it right now. Wish me all the best for the Certification FCSS_NST_SE-7.6 exam dumps exam coming up!
Posted at 2/16/2026 21:50:49        Only Author  3#
Thank you for sharing such a positive and motivating article! Sharing the Practice 212-89 questions test questions with you for freepromotions and salary boosts are within reach!
