[General] Unique, Full Length Exams - New Juniper JN0-664 Pratice Exam
44
General Unique, Full Length Exams - New Juniper JN0-664 Pratice Exam
Posted at 1/12/2026 09:41:37      View238 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest Actual4dump JN0-664 PDF Dumps and JN0-664 Exam Engine Free Share: https://drive.google.com/open?id=1-E2sc9dUDOeCP2y9VAK6ZdMjZZdz_sgA
Experts at Actual4dump strive to provide applicants with valid and updated Juniper JN0-664 exam questions to prepare from, as well as increased learning experiences. We are confident in the quality of the Juniper JN0-664 preparational material we provide and back it up with a money-back guarantee.
Juniper JN0-664 (Service Provider, Professional (JNCIP-SP)) Exam is a professional-level certification for those who aspire to become service provider experts. Service Provider, Professional (JNCIP-SP) certification is designed to test the knowledge, skills, and abilities of the candidates in configuring and troubleshooting Junos-based service provider networks. The JN0-664 Exam is designed to validate the skills and knowledge of candidates in the field of service provider networking, including virtualization, troubleshooting, and security.
Premium JN0-664 Exam | JN0-664 Top Exam DumpsUsers of this format don't need to install excessive plugins or software to attempt the Service Provider, Professional (JNCIP-SP) (JN0-664) web-based practice exams. Another format of the Service Provider, Professional (JNCIP-SP) (JN0-664) practice test is the desktop-based software. This JN0-664 Exam simulation software needs installation only on Windows computers to operate. The third format of the Actual4dump Juniper JN0-664 exam dumps is the JN0-664 Dumps PDF.
The Juniper JN0-664 Exam consists of multiple choice questions, as well as simulation and configuration tasks that require candidates to demonstrate their ability to apply their knowledge to real-world scenarios. To pass the exam, candidates must achieve a minimum score of 65% on the overall exam and score at least 65% on each of the exam sections.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q12-Q17):NEW QUESTION # 12
Which three mechanisms are used by Junos platforms to evaluate incoming traffic for CoS purposes? (Choose three.)
  • A. traffic shapers
  • B. behavior aggregate classifiers
  • C. fixed classifiers
  • D. multifield classifiers
  • E. rewrite rules
Answer: B,C,D
NEW QUESTION # 13
Which two statements are correct about a sham link? (Choose two.)
  • A. The PEs exchange Type 1 OSPF LSAs instead of Type 3 OSPF LSAs for the L3VPN routes
  • B. It creates an OSPF multihop neighborship between two PE routers.
  • C. The PEs exchange Type 3 OSPF LSAs instead of Type 1 OSPF LSAs for the L3VPN routes.
  • D. It creates a BGP multihop neighborship between two PE routers.
NEW QUESTION # 14
Referring to the exhibit, a working L3VPN exists that connects VPN-A sites. CoS is configured correctly to match on the MPLS EXP bits of the LSP. but when traffic is sent from Site-1 to Site-2.
PE-2 is not classifying the traffic correctly.
What should you do to solve the problem?
  • A. Configure VPN prefix mapping for the PE-1_to_PE-2 LSP.
  • B. Configure the explicit-null statement on PE-1.
  • C. Set a static CoS value for the PE-1_to_PE-2 LSP.
  • D. Configure the explicit-null statement on PE-2.
NEW QUESTION # 15
Which statement is true regarding BGP FlowSpec?
  • A. It uses a remote triggered black hole to protect a network from a denial-of-service attack.
  • B. It is used to protect a network from denial-of-service attacks dynamically
  • C. It verifies that the source IP of the incoming packet has a resolvable route in the routing table
  • D. It uses dynamically created routing policies to protect a network from denial-of-service attacks
BGP FlowSpec is a feature that extends the Border Gateway Protocol (BGP) to enable routers to exchange traffic flow specifications, allowing for more precise control of network traffic. The BGP FlowSpec feature enables routers to advertise and receive information about specific flows in the network, such as those originating from a particular source or destined for a particular destination. Routers can then use this information to construct traffic filters that allow or deny packets of a certain type, rate limit flows, or perform other actions1. BGP FlowSpec can also help in filtering traffic and taking action against distributed denial of service (DDoS) attacks by dropping the DDoS traffic or diverting it to an analyzer2. BGP FlowSpec rules are internally converted to equivalent Cisco Common Classification Policy Language (C3PL) representing corresponding match and action parameters2. Therefore, BGP FlowSpec uses dynamically created routing policies to protect a network from denial-of-service attacks.
References: 1: https://www.networkingsignal.com/what-is-bgp-flowspec/ 2:
https://www.cisco.com/c/en/us/td ... 16-book/bgp-flowspe
NEW QUESTION # 16
Which two statements are correct about VPLS tunnels? (Choose two.)
  • A. BGP-signaled VPLS tunnels can use either RSVP or LDP between the PE routers.
  • B. LDP-signaled VPLS tunnels only support control bit 0.
  • C. BGP-signaled VPLS tunnels require manual provisioning of sites.
  • D. LDP-signaled VPLS tunnels use auto-discovery to provision sites
https://www.juniper.net/document ... rvice/topics/task/v
https://www.juniper.net/document ... iguring-vpls-routin
NEW QUESTION # 17
Premium JN0-664 Exam: https://www.actual4dump.com/Juniper/JN0-664-actualtests-dumps.html
Posted at 1/18/2026 06:58:08        Only Author  2#
Your article is truly awe-inspiring, thank you for sharing! Dont miss your chance to get the free JN0-750 latest test bootcamp materials questionsthe key to promotion and salary growth!
Posted at 1/29/2026 21:50:16        Only Author  3#
Thank you for the brilliant share, the article is truly eye-opening! The Exam Information-Technology-Management demo exam questions are key to advancing in your careerget them for free!
