[Linux] Consult rk3328-roc-cc kernel problem
11
Posted at 4/27/2022 14:31:50
[ Last edited by liuhw In 4/27/2022 14:34 Editor ]\n\nCompile 5.15, 5, 17 versions of the kernel, the same problem occurs when starting, please enlighten me
DDR version 1.16 20190528
In
DDR4
786MHz
Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
ddrconfig:19
OUT
Boot1 Release Time: May 13 2019 17:34:36, version: 2.50
ChipType = 0x11, 239
mmc2:cmd1,400
emmc reinit
mmc2:cmd1,400
emmc reinit
mmc2:cmd1,400
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30720MB
FwPartOffset=2000 , 0
StorageInit ok = 18149
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret0)
GPT 0x337a9f0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0x9b6f0
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):0e4d696
NOTICE:  BL31: Built : 09:22:40, Aug 27 2019
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09 (Feb 24 2022 - 22:29:21 +0800)
Model: Rockchip RK3328 EVB
DRAM:  2 GiB
Relocation Offset is: 7fd1e000
PMIC:  RK8050 (on=0x02, off=0x00)
vdd_logic 1100000 uV
vdd_arm 1100000 uV
MMC:   rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
Using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
CLK:      apll           400000000 Hz
          dpll          1572000000 Hz
          cpll          1200000000 Hz
          gpll           491009999 Hz
          npll           600000000 Hz
        armclk           600000000 Hz
      aclk_bus           150000000 Hz
      hclk_bus            75000000 Hz
      pclk_bus            75000000 Hz
     aclk_peri           150000000 Hz
     hclk_peri            75000000 Hz
     pclk_peri            75000000 Hz
Net:   No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
160 bytes read in 3 ms (51.8 KiB/s)
1:      rk3328-roc-cc
Retrieving file: /Image
reading /Image
22043136 bytes read in 943 ms (22.3 MiB/s)
append: earlycon=uart8250,mmio32,0xff130000 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4
Retrieving file: /rk3328-roc-cc.dtb
reading /rk3328-roc-cc.dtb
35620 bytes read in 4 ms (8.5 MiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Device Tree to 000000007deff000, end 000000007df0ab23 ... OK
Adding bank: start=0x00200000, size=0x7fe00000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.17.4 (liuhw@lenovo) (aarch64-linux-gnu-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #1 SMP PREEMPT Tue Apr 26 22:14:54 CST 2022
[    0.000000] Machine model: Firefly roc-rk3328-cc
[    0.000000] earlycon: uart8250 at MMIO32 0x00000000ff130000 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] NUMA: NODE_DATA [mem 0x7fbc8b40-0x7fbcafff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000007fffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] cma: Reserved 32 MiB at 0x0000000079c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 19 pages/cpu s40280 r8192 d29352 u77824
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 515592
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff130000 rw root=/dev/mmcblk0p2 rootwait rootfstype=ext4
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stackff, heap allocff, heap freeff
[    0.000000] Memory: 1999824K/2095104K available (12736K kernel code, 1302K rwdata, 4888K rodata, 2496K init, 458K bss, 62512K reserved, 32768K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x484/0x678 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002011] Console: colour dummy device 80x25
[    0.002454] printk: console [tty0] enabled
[    0.002875] printk: bootconsole [uart8250] disabled
[    0.003510] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003583] pid_max: default: 32768 minimum: 301
[    0.003788] LSM: Security Framework initializing
[    0.004058] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.004127] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.007327] cblist_init_generic: Setting adjustable number of callback queues.
[    0.007390] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.007814] rcu: Hierarchical SRCU implementation.
[    0.008898] EFI services will not be available.
[    0.009536] smp: Bringing up secondary CPUs ...
[    0.010745] Detected VIPT I-cache on CPU1
[    0.010871] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.012082] Detected VIPT I-cache on CPU2
[    0.012197] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.013368] Detected VIPT I-cache on CPU3
[    0.013490] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.013684] smp: Brought up 1 node, 4 CPUs
[    0.013815] SMP: Total of 4 processors activated.
[    0.013849] CPU features: detected: 32-bit EL0 Support
[    0.013884] CPU features: detected: 32-bit EL1 Support
[    0.013917] CPU features: detected: CRC32 instructions
[    0.029031] CPU: All CPU(s) started at EL2
[    0.029173] alternatives: patching kernel code
[    0.032493] devtmpfs: initialized
[    0.052652] KASLR disabled due to lack of seed
[    0.053247] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.053362] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.055634] pinctrl core: initialized pinctrl subsystem
[    0.057210] DMI not present or invalid.
[    0.058357] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.061779] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.062305] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.062813] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.063008] audit: initializing netlink subsys (disabled)
[    0.063398] audit: type=2000 audit(0.064:1): state=initialized audit_enabled=0 res=1
[    0.065445] thermal_sys: Registered thermal governor 'step_wise'
[    0.065468] thermal_sys: Registered thermal governor 'power_allocator'
[    0.066150] cpuidle: using governor menu
[    0.066748] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.067022] ASID allocator initialised with 65536 entries
[    0.067416] Serial: AMBA PL011 UART driver
[    0.081715] platform ff3c0000.hdmi: Fixing up cyclic dependency with ff370000.vop
[    0.100969] rockchip-gpio ff210000.gpio: probed /pinctrl/gpio@ff210000
[    0.102576] rockchip-gpio ff220000.gpio: probed /pinctrl/gpio@ff220000
[    0.103905] rockchip-gpio ff230000.gpio: probed /pinctrl/gpio@ff230000
[    0.105078] rockchip-gpio ff240000.gpio: probed /pinctrl/gpio@ff240000
[    0.135612] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.135693] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.135736] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.135766] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.139211] ACPI: Interpreter disabled.
[    0.142732] iommu: Default domain type: Translated
[    0.142789] iommu: DMA domain TLB invalidation policy: strict mode
[    0.145137] vgaarb: loaded
[    0.145946] SCSI subsystem initialized
[    0.146922] usbcore: registered new interface driver usbfs
[    0.147074] usbcore: registered new interface driver hub
[    0.147241] usbcore: registered new device driver usb
[    0.148117] pps_core: LinuxPPS API ver. 1 registered
[    0.148161] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]>
[    0.148248] PTP clock support registered
[    0.148362] EDAC MC: Ver: 3.0.0
[    0.150664] FPGA manager framework
[    0.150979] Advanced Linux Sound Architecture Driver Initialized.
[    0.153437] clocksource: Switched to clocksource arch_sys_counter
[    0.154067] VFS: Disk quotas dquot_6.6.0
[    0.154233] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.154777] pnp: PnP ACPI: disabled
[    0.170527] NET: Registered PF_INET protocol family
[    0.170865] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.173280] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.173470] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.173760] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    0.174296] TCP: Hash tables configured (established 16384 bind 16384)
[    0.174567] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.174692] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.175084] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.175994] RPC: Registered named UNIX socket transport module.
[    0.176050] RPC: Registered udp transport module.
[    0.176094] RPC: Registered tcp transport module.
[    0.176124] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.176177] PCI: CLS 0 bytes, default 64
[    0.178001] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.179024] kvm [1]: IPA Size Limit: 40 bits
[    0.182006] kvm [1]: vgic interrupt IRQ9
[    0.182307] kvm [1]: Hyp mode initialized successfully
[    0.185877] Initialise system trusted keyrings
[    0.186322] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    0.204044] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.205842] NFS: Registering the id_resolver key type
[    0.205929] Key type id_resolver registered
[    0.205957] Key type id_legacy registered
[    0.206194] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.206231] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.206643] 9p: Installing v9fs 9p2000 file system support
[    0.277142] Key type asymmetric registered
[    0.277202] Asymmetric key parser 'x509' registered
[    0.277353] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.277405] io scheduler mq-deadline registered
[    0.277473] io scheduler kyber registered
[    0.286611] EINJ: ACPI disabled.
[    0.291931] dma-pl330 ff1f0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.292016] dma-pl330 ff1f0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.302029] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.306515] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 20, base_baud = 1500000) is a 16550A
[    0.387551] printk: console [ttyS2] enabled
[    0.409137] loop: module loaded
[    0.410944] megasas: 07.719.03.00-rc1
[    0.421168] tun: Universal TUN/TAP device driver, 1.6
[    0.423196] thunder_xcv, ver 1.0
[    0.423653] thunder_bgx, ver 1.0
[    0.424080] nicpf, ver 1.0
[    0.425253] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.425981] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.426663] hclge is initializing
[    0.427023] e1000: Intel(R) PRO/1000 Network Driver
[    0.427474] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.428116] e1000e: Intel(R) PRO/1000 Network Driver
[    0.428574] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.429223] igb: Intel(R) Gigabit Ethernet Network Driver
[    0.429768] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.430406] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.430986] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.431585] sky2: driver version 1.30
[    0.432967] VFIO - User Level meta-driver version: 0.3
[    0.436974] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    0.438130] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    0.451793] dwc2 ff580000.usb: DWC OTG Controller
[    0.452324] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1
[    0.453035] dwc2 ff580000.usb: irq 40, io mem 0xff580000
[    0.455253] hub 1-0:1.0: USB hub found
[    0.455711] hub 1-0:1.0: 1 port detected
[    0.458561] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.459194] ehci-pci: EHCI PCI platform driver
[    0.459708] ehci-platform: EHCI generic platform driver
[    0.463091] ehci-platform ff5c0000.usb: EHCI Host Controller
[    0.463694] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2
[    0.464685] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000
[    0.477492] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00
[    0.479584] hub 2-0:1.0: USB hub found
[    0.480041] hub 2-0:1.0: 1 port detected
[    0.481465] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.482092] ohci-pci: OHCI PCI platform driver
[    0.482633] ohci-platform: OHCI generic platform driver
[    0.483877] ohci-platform ff5d0000.usb: Generic Platform OHCI controller
[    0.484557] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3
[    0.485570] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000
[    0.551060] hub 3-0:1.0: USB hub found
[    0.551510] hub 3-0:1.0: 1 port detected
[    0.553828] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    0.554416] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4
[    0.555427] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
[    0.556420] xhci-hcd xhci-hcd.0.auto: irq 43, io mem 0xff600000
[    0.558992] hub 4-0:1.0: USB hub found
[    0.559459] hub 4-0:1.0: 1 port detected
[    0.560587] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    0.561189] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
[    0.561996] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    0.562760] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.564937] hub 5-0:1.0: USB hub found
[    0.565378] hub 5-0:1.0: 1 port detected
[    0.566985] usbcore: registered new interface driver usb-storage
[    0.570940] i2c_dev: i2c /dev entries driver
[    0.576678] rk808 1-0018: chip id: 0x8050
[    0.585375] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    0.586102] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    0.611771] dw_wdt ff1a0000.watchdog: No valid TOPs array specified
[    0.617321] cpu cpu0: EM: created perf domain
[    0.620586] sdhci: Secure Digital Host Controller Interface driver
[    0.621166] sdhci: Copyright(c) Pierre Ossman
[    0.622156] Synopsys Designware Multimedia Card Interface Driver
[    0.623178] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.623715] dwmmc_rockchip ff520000.mmc: IDMAC supports 32-bit address mode.
[    0.624385] dwmmc_rockchip ff520000.mmc: Using internal DMA controller.
[    0.624999] dwmmc_rockchip ff520000.mmc: Version ID is 270a
[    0.625606] dwmmc_rockchip ff520000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo
[    0.627023] ledtrig-cpu: registered to indicate activity on CPUs
[    0.627708] mmc_host mmc1: card is non-removable.
[    0.628916] usbcore: registered new interface driver usbhid
[    0.629480] usbhid: USB HID core driver
[    0.633326] NET: Registered PF_PACKET protocol family
[    0.634088] 9pnet: Installing 9P2000 support
[    0.634558] Key type dns_resolver registered
[    0.635459] Loading compiled-in X.509 certificates
[    0.640931] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    0.671850] ALSA device list:
[    0.672161]   No soundcards found.
[    0.672718] dw-apb-uart ff130000.serial: forbid DMA for kernel console
[    0.673521] Waiting for root device /dev/mmcblk0p2...
[    0.681032] rockchip-pm-domain ff100000.syscon:power-controller: failed to get ack on domain 'hevc', val=0x88220
[    1.162279] dwmmc_rockchip ff520000.mmc: Busy; trying anyway
[    1.662833] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[    1.677499] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    2.198961] dwmmc_rockchip ff520000.mmc: Busy; trying anyway
[    2.699505] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[    2.714078] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    3.239625] dwmmc_rockchip ff520000.mmc: Busy; trying anyway
[    3.740171] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[    3.754870] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[    3.782300] random: fast init done
[    4.289030] dwmmc_rockchip ff520000.mmc: Busy; trying anyway
[    4.789596] mmc_host mmc1: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000)
[   31.709523] vcc_sd: disabling
Posted at 4/28/2022 15:28:21
What specific problem are you encountering and can I help you?
Posted at 4/29/2022 11:26:50
thanks you, using this config file can start normally
linux-5.17.4-config.gz
43.56 KB, Down times: 13
Posted at 12/23/2024 10:20:27
This article dives deep into its topic with such precisionlike assembling tech magic piece by piece! It got me thinking: what if parenting had its own manual? Enter bad parenting
Posted at 10/27/2025 14:42:24
Hey there! Kernel compilation issues can be tricky, especially across multiple versions. Have you checked for any missing dependencies or config mismatches? By the way, if you ever need a break from debugging, unwind with some Fnafits oddly relaxing between coding marathons. Hope you solve it soon!
Posted at 11/22/2025 16:24:28
It's fascinating to see technical details like this. I've had experiences with storage initialization issues in the past, and they can be frustrating. If you're looking to test and streamline your systems, I highly recommend using the Cps Test platform. It's user-friendly and effective for troubleshooting various tech problems. It definitely helped me diagnose issues faster!
Posted at 11/27/2025 10:25:16
It sounds like you're facing some challenges with the rk3328-roc-cc kernel! Have you checked out the resources available on Monkey Mart? Their community often discusses similar issues, and you might find helpful insights there. Its great to connect with others who are navigating the same tech landscape. Just in case, heres the link to explore more about it: Monkey Mart. Good luck!
Posted at 1/11/2026 03:42:04
Im deeply thankful for your article, it really stood out to me. About to face the New SAFe-RTE test cram pdf exam C hoping for good results!
Posted at 1/11/2026 04:24:47
Your article is exceptional, thank you for sharing it with us! Latest free C_ARSOR_2404 study questions test questions available for free. Wishing you success in your exam!
Posted at 2/14/2026 06:35:01
Im so grateful I read that article. The NCA-AIIO reliable study questions sheet exam papers are free for all! Best of luck to everyone!
