[General] 2026 100% Free VMA¨CHigh Hit-Rate 100% Free Reliable Study Notes | Testking VMA E
101
¡¾General¡¿ 2026 100% Free VMA¨CHigh Hit-Rate 100% Free Reliable Study Notes | Testking VMA E
Posted at 1/12/2026 10:13:13      View£º197 | Replies£º3        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of FreePdfDump VMA dumps for free: https://drive.google.com/open?id=1o2NhaCHUlk512VEmnVq_Qj2-5snnJ_DM
You can enjoy free update for 365 days if you buying VMA study guide of us, that is to say, in the following year you can obtain the latest information for the exam timely. And the update version for VMA exam dumps will be sent to your email automatically. You just need to receive and exchange your learning ways in accordance with the new changes. In addition, VMA Study Materials are compiled by experienced experts, and they are quite familiar with the exam center, therefore the quality can be guaranteed. We also have online and offline chat service, if you have any questions about VMA exam dumps, you can consult us.
We guarantee that you can enjoy the premier certificate learning experience under our help with our VMA prep guide since we put a high value on the sustainable relationship with our customers. First of all we have fast delivery after your payment in 5-10 minutes, and we will transfer VMA Guide Torrent to you online. Besides if you have any trouble coping with some technical and operational problems while using our VMA exam torrent, please contact us immediately and our 24 hours online services will spare no effort to help you solve the problem in no time.
Testking VMA Exam Questions | Exam VMA SampleThe online version is open to any electronic equipment, at the same time, the online version of our VMA study materials can also be used in an offline state. You just need to use the online version at the first time when you are in an online state; you can have the right to use the version of our VMA Study Materials offline. And if you are willing to take our VMA study materials into more consideration, it must be very easy for you to pass your VMA exam in a short time.
SAVE International Value Methodology Associate Sample Questions (Q22-Q27):NEW QUESTION # 22
Which of the three levels of filters used for evaluating ideas during the Evaluation Phase applies an evaluation matrix technique?
  • A. Fine
  • B. Medium
  • C. Coarse
  • D. Reasonable
The Evaluation Phase of the Value Methodology (VM) Job Plan involves assessing ideas using a three-level filtering process, as taught in the VMF 1 course (Core Competency #7: Evaluation and Selection of Alternatives). According to SAVE International's Value Methodology Standard, the three levels of filters are Coarse, Medium, and Fine (as confirmed in Question 33). The standard further specifies that "the Fine filter applies detailed evaluation techniques, such as an evaluation matrix, to select the best ideas for development by scoring them against weighted criteria." An evaluation matrix (e.g., a weighted matrix, as noted in Question 11) is a tool where ideas are scored based on criteria like cost, performance, and risk, with weights reflecting their importance (as in Question 51). This detailed, quantitative approach is used in the Fine filter to make final selections after the Coarse (initial screening) and Medium (shortlisting) filters have narrowed down the ideas.
* Option A (Fine) is correct, as the Fine filter uses an evaluation matrix technique for detailed idea selection.
* Option B (Reasonable) is incorrect because "Reasonable" is not one of the three filter levels; the correct levels are Coarse, Medium, and Fine.
* Option C (Medium) is incorrect because the Medium filter involves a more general assessment (e.g., comparing ideas against criteria), not the detailed matrix technique.
* Option D (Coarse) is incorrect because the Coarse filter is for initial screening (eliminating unfeasible ideas), not detailed evaluation with a matrix.
SAVE International, "Value Methodology Standard and Body of Knowledge," available athttps://www.value- eng.org, detailing the Fine filter's use of an evaluation matrix in the Evaluation Phase.
SAVE International, VMF 1 Core Competency #7 (Evaluation and Selection of Alternatives), emphasizing the three-level filtering process and the Fine filter's techniques (consistent with Questions 11 and 33).
NEW QUESTION # 23
Which of the following defines the effects of time, value, and money, converting all costs to a common reference point in today's dollars?
  • A. Simple Payback (or Breakeven Point)
  • B. Discount Rate
  • C. Return on Investment (ROI)
  • D. Present Worth (or Net Present Value)
In Value Methodology, cost analysis often involves evaluating the economic impact of alternatives over time, which requires understanding the time value of money. The VMF 1 course, under Core Competency #4 (Cost Analysis), includes financial concepts like discounting cash flows to assess long-term value. The concept of converting all costs to a common reference point in today's dollars refers toPresent Worth (or Net Present Value, NPV). According to SAVE International's Value Methodology Standard, Present Worth (or NPV) is used to "evaluate the economic feasibility of alternatives by discounting future cash flows to their present value, accounting for the time value of money." This process converts all costs and benefits (adjusted for time, value, and money) to a single value in today's dollars using a discount rate, allowing for a fair comparison of alternatives.
* Option A (Return on Investment or ROI) is incorrect because ROI measures profitability as a percentage and does not convert costs to a present value.
* Option B (Present Worth or Net Present Value) is correct because NPV accounts for the effects of time, value, and money by discounting future cash flows to today's dollars.
* Option C (Discount Rate) is incorrect because the discount rate is the rate used in NPV calculations, not the method of converting costs itself.
* Option D (Simple Payback or Breakeven Point) is incorrect because payback measures the time to recover an investment and does not account for the time value of money or convert costs to present value.
SAVE International, "Value Methodology Standard and Body of Knowledge," available athttps://www.value- eng.org, section on cost analysis, referencing Present Worth (NPV) for economic evaluation.
SAVE International, VMF 1 Core Competency #4 (Cost Analysis), which includes discounting techniques for comparing alternatives.
NEW QUESTION # 24
Which phase enables the VM team to select viable ideas?
  • A. Development
  • B. Function Analysis
  • C. Presentation
  • D. Evaluation
The Value Methodology (VM) Job Plan, as outlined in the VMF 1 course and SAVE International's Value Methodology Standard, consists of six phases, one of which is the Evaluation Phase, where the VM team selects viable ideas. In the Evaluation Phase, the team assesses ideas generated during the Creative Phase to determine their feasibility, cost impact, and alignment with project goals. According to the VMF 1 Core Competency #3 (Value Methodology Job Plan), the Evaluation Phase involves "evaluating the ideas for their potential to improve value, using criteria such as cost savings, performance, quality, and feasibility, to select the most viable alternatives for further development." Tools like weighted evaluation matrices may be used to rank ideas systematically.
* Option A (Function Analysis) is incorrect because this phase focuses on identifying and analyzing functions, not selecting ideas.
* Option B (Presentation) is incorrect because this phase involves communicating recommendations to stakeholders, after ideas have already been selected and developed.
* Option C (Evaluation) is correct, as it is the phase where the VM team filters and selects viable ideas based on defined criteria.
* Option D (Development) is incorrect because this phase involves refining selected ideas into actionable proposals, which happens after the Evaluation Phase.
SAVE International, "Value Methodology Standard and Body of Knowledge," available athttps://www.value- eng.org, detailing the Evaluation Phase in the VM Job Plan.
SAVE International, "Value Methodology Associate (VMA) Certification,"https://www.value-eng.org/page
/VMA, referencing VMF 1 Core Competency #3 (Value Methodology Job Plan).
NEW QUESTION # 25
A Random Function Identification table contains:
  • A. Costs, time, and risks
  • B. Components, resources, and criteria
  • C. Inputs, objectives, and sequence
  • D. Elements, functions, and classifications
Random Function Identification is a technique used in Value Methodology's Function Analysis phase to identify and organize functions before creating a Function Analysis System Technique (FAST) diagram, as taught in the VMF 1 course (Core Competency #2). According to SAVE International's Value Methodology Standard, Random Function Identification involves "listing all functions of a system or project in a table, typically including the elements (components or parts), their associated functions (in verb-noun format), and their classifications (e.g., basic, secondary, higher-order)." This table helps the VM team systematically identify and categorize functions during the early stages of analysis, ensuring all functions are captured before structuring them in a FAST diagram.
* Option A (Inputs, objectives, and sequence) is incorrect because inputs and objectives are part of the Information Phase, and sequence is addressed in FAST diagramming, not in the Random Function Identification table.
* Option B (Costs, time, and risks) is incorrect because these are related to cost analysis or implementation planning, not function identification.
* Option C (Elements, functions, and classifications) is correct, as it aligns with the purpose of the Random Function Identification table in VM.
* Option D (Components, resources, and criteria) is incorrect because resources and criteria are not part of function identification; criteria are used in the Evaluation Phase.
SAVE International, VMF 1 Core Competency #2 (Function Analysis), which includes Random Function Identification as a precursor to FAST diagramming.
SAVE International, "Value Methodology Standard," section on Function Analysis, describing the Random Function Identification table as listing elements, functions, and classifications.
NEW QUESTION # 26
During the life cycle of a project or product, the greatest possibility to influence impacts and costs takes place during:
  • A. Planning
  • B. Maintaining
  • C. Organizing
  • D. Operating
Value Methodology emphasizes applying VM early in a project or product lifecycle to maximize its impact on costs and outcomes, as taught in the VMF 1 course (Core Competency #1: Value Methodology Overview).
According to SAVE International's Value Methodology Standard, "the greatest opportunity to influence a project's impacts and costs occurs during the planning phase, when decisions about design, scope, and requirements are made." Early intervention allows the VM team to optimize functions and reduce costs before they are locked in by detailed design or implementation. This principle is often illustrated by the "cost influence curve," which shows that the ability to influence costs decreases as the project progresses, while the cost to make changes increases.
* Option A (Operating) is incorrect because, during operation, most costs are already incurred, and changes are costly and limited in impact.
* Option B (Planning) is correct, as it is the phase where VM can most effectively influence design and cost decisions, per VM standards.
* Option C (Organizing) is incorrect because organizing is a management function, not a distinct lifecycle phase for applying VM.
* Option D (Maintaining) is incorrect because maintenance occurs late in the lifecycle, when cost influence is minimal.
SAVE International, "Value Methodology Standard and Body of Knowledge," available athttps://www.value- eng.org, emphasizing early application of VM in the planning phase.
SAVE International, VMF 1 Core Competency #1 (Value Methodology Overview), highlighting the cost influence curve and the importance of early VM intervention.
NEW QUESTION # 27
You should prepare with FreePdfDump VMA Questions that are in compliance with VMA exam content. More than 90,000 professionals worldwide have provided their feedback, helping create and launch VMA questions in the market. So, if you're determined to pass the SAVE International exam and achieve VMA Certification to accelerate your career, it's time to build your knowledge and skills. You can try the demo version of Value Methodology Associate (VMA) practice dumps before payment.
Testking VMA Exam Questions: https://www.freepdfdump.top/VMA-valid-torrent.html
To make a great effort about your personal ability and then pass the VMA testking exam successfully has been an ultimate goal of many friends like you, SAVE International Reliable VMA Study Notes We will soon solve your problems at the first time, In a word, the three different versions will meet your all needs; you can use the most suitable version of our VMA study torrent according to your needs, If you are hesitating, please try to download our free demo of VMA test guide materials.
Use one hard drive for your data, one as a backup, VMA If the capture failed, the `no_exp` will be matched, if given, To make a great effort about your personal ability and then pass the VMA Testking exam successfully has been an ultimate goal of many friends like you.
VMA valid exam answers & VMA practice engine & VMA training pdfWe will soon solve your problems at the first time, In a word, the three different versions will meet your all needs; you can use the most suitable version of our VMA study torrent according to your needs.
If you are hesitating, please try to download our free demo of VMA test guide materials, You can operate the VMA questions pdf in different modes so you can improve your preparation and clear the SAVE International VMA VMA exam on the first attempt.
2026 Latest FreePdfDump VMA PDF Dumps and VMA Exam Engine Free Share: https://drive.google.com/open?id=1o2NhaCHUlk512VEmnVq_Qj2-5snnJ_DM
Posted at 1/20/2026 21:13:21        Only Author  2#
여러분은 먼저 우리 Fast2test사이트에서 제공되는SAP인증C-TS4FI-2023시험덤프의 일부분인 데모를 다운받으셔서 체험해보세요. Fast2test는 여러분이 한번에SAP인증C-TS4FI-2023시험을 패스하도록 하겠습니다. 만약SAP인증C-TS4FI-2023시험에서 떨어지셨다고 하면 우리는 덤프비용전액 환불입니다.
Posted at 1/24/2026 23:22:59        Only Author  3#
I¡¯m amazed by the depth of your article, thank you for sharing! FCP_FAC_AD-6.5 valid exam question gives you a wealth of free content, created to assist you.
Posted at 1/26/2026 10:30:41        Only Author  4#
Thank you for sharing this insightful article, it really stood out to me. Hope I can conquer the New C_THR84_2505 exam questions vce exam. Wish me luck!
