Hardware
Fantastic Reliable Plat-Admn-202 Exam Syllabus - Win Your Salesforce Certificate
Posted at 1/12/2026 10:15:23
View229
Replies3
A Salesforce Certified Platform App Builder (Plat-Admn-202) practice questions is a helpful, proven strategy to crack the Salesforce Certified Platform App Builder (Plat-Admn-202) exam successfully. It helps candidates to know their weaknesses and overall performance. BraindumpStudy software has hundreds of Salesforce Certified Platform App Builder (Plat-Admn-202) exam dumps that are useful to practice in real-time.
Nowadays, using computer-aided software to pass the Plat-Admn-202 exam has become a new trend. Because the new technology enjoys a distinct advantage, that is convenient and comprehensive. In order to follow this trend, our company product such a Plat-Admn-202 exam questions that can bring you the combination of traditional and novel ways of studying. The passing rate of our study material is up to 99%. If you are not fortune enough to acquire the Plat-Admn-202 Certification at once, you can unlimitedly use our Plat-Admn-202 product at different discounts until you reach your goal and let your dream comes true.
Reliable Plat-Admn-202 Exam Syllabus Is Valid to Pass Salesforce Certified Platform App BuilderThe clients can download our products and use our Plat-Admn-202 study materials immediately after they pay successfully with their credit cards. Our system will send our Plat-Admn-202 learning prep in the form of mails to the client in 5-10 minutes after their successful payment. The mails provide the links and if only the clients click on the links they can log in our software immediately to learn our Plat-Admn-202 Guide materials. If there are something they can't understand, they can contact with our service and we will solve them right away.
Salesforce Certified Platform App Builder Sample Questions (Q194-Q199):NEW QUESTION # 194
Cloud Kicks has a sales rep who is stating that their Contact is unavailable for other users to see within Salesforce.
In which three ways can an app builder troubleshoot this issue?
Choose 3 answers
- A. Create a new Contact and have the users try again.
- B. Confirm whether Default Organization-Wide Sharing Settings provide access to the Account.
- C. Review the Contact record and ensure it is linked to an Account.
- D. Create an Account Sharing Rule to give the users access to all records.
- E. Verify the users with the issue have access to the Contact object.
Answer: B,C,E
To troubleshoot the issue of a contact being unavailable for other users to see, an app builder should check the following things:
Confirm whether Default Organization-Wide Sharing Settings provide access to the Account. This setting determines the baseline level of access that users have to each other's records.
Review the Contact record and ensure it is linked to an Account. Contacts that are not linked to an account are private and only visible to the owner and administrators.
Verify the users with the issue have access to the Contact object. Users need to have at least read permission on the Contact object to view contact records. Option A and E are not relevant for troubleshooting this issue.
NEW QUESTION # 195
The appraisal team at DreamHouse Realty wants to leverage Salesforce mobile app.
What are three things an app builder should do to optimize mobile experience?
Choose 3 answers
- A. Create individual customized layouts for different phone operating systems.
- B. Put the most important fields in the compact layout so they are easy to find.
- C. Minimize the amount of formula fields and lookup fields to reduce page load time.
- D. Use Global Actions to make it easy to perform vital functionality on mobile.
- E. Avoid using default field values so that the user is required to fill in all fields on the screen.
Answer: B,C,D
The app builder should do three things to optimize mobile experience:
Use Global Actions to make it easy to perform vital functionality on mobile: Global actions are actions that allow users to create records or perform tasks from anywhere in Salesforce. They are displayed in various places in Salesforce mobile app, such as action bar, action menu, or publisher. By using global actions, the app builder can make it easy for the appraisal team to perform common tasks on mobile, such as creating a new appraisal record or logging a call.
Minimize the amount of formula fields and lookup fields to reduce page load time: Formula fields and lookup fields are types of fields that can affect the performance of Salesforce mobile app. Formula fields are fields that calculate a value based on an expression or formula. Lookup fields are fields that create a relationship between two objects and allow users to select a value from a list of records. Both types of fields can increase the page load time on mobile devices, especially if they are complex or reference many other fields. By minimizing the amount of formula fields and lookup fields, the app builder can optimize the mobile experience for the appraisal team.
Put the most important fields in the compact layout so they are easy to find: Compact layouts are layouts that display a record's key information at a glance. They are used in various places in Salesforce mobile app, such as record highlights, list views, related lists, and lookup dialogs. By putting the most important fields in the compact layout, the app builder can ensure that the appraisal team can easily find the information they need on mobile devices. Option B and D are not things that an app builder should do to optimize mobile experience.
NEW QUESTION # 196
An app builder needs to create new automation on an object.
What best practice should the app builder follow when building out automation?
- A. One Workflow rule per object.
- B. One invocable process per object.
- C. One record change process per object.
- D. One Flow per object.
The best practice that the app builder should follow when building out automation is one record change process per object. A record change process is a type of process in Process Builder that starts when a record is created or updated. Having one record change process per object can avoid conflicts or errors when multiple processes try to update the same record at the same time. Option A is incorrect because one workflow rule per object is not a best practice, as workflow rules are considered legacy tools and have limitations compared to Process Builder. Option B is incorrect because one flow per object is not a best practice, as flows are more complex and require more resources than processes. Option C is incorrect because one invocable process per object is not a best practice, as invocable processes are used to invoke other processes from within a process or a flow.
NEW QUESTION # 197
DreamMouse Realty has a mentorship program that pairs experienced Realtors with new Realtors. Each experienced Realtor can mentor one or several new Realtors, and each new Realtor is required to work with a single experienced Realtor they report to for a probationary period.
What type of relationship would an app builder set up to meet this specification?
- A. Master-detail
- B. Indirect lookup
- C. Many-to-many
- D. Lookup
Lookup is the type of relationship that would be set up to meet the specification of pairing experienced Realtors with new Realtors. According to the Salesforce documentation, "A lookup relationship creates a loose association between objects. The lookup field allows users to select a record from another object." Indirect lookup is used for junction objects on different platforms. Many-to-many is not a type of relationship, but a result of using junction objects. Master-detail is used for creating parent-child relationships.
NEW QUESTION # 198
Ursa Major Solar's sales team has been struggling to enter data on mobile since rollout; the team dislikes scrolling through all of the fields to input only the necessary data.
How could the app builder solve this with minimal impact to desktop users?
- A. Deselect the phone radio button on the Lightning record page assignment.
- B. Update the training documentation with better screenshots.
- C. Reorder the fields to make sense for the reps when in the field.
- D. Filter components by device using Form Factor.
The best way to solve this problem is to filter components by device using Form Factor. Form Factor is an attribute that can be applied to components on a Lightning record page to control their visibility based on the device type, such as desktop, phone, or tablet. By using Form Factor, the app builder can hide some components that are not relevant for mobile users, such as charts or reports, and show only the components that are necessary for data entry, such as fields or actions. This way, the mobile users do not have to scroll through all the components and can enter data more easily. Reordering the fields may not solve the problem completely, as there may still be too many components on the page for mobile users. Updating the training documentation may not help either, as it does not address the root cause of the problem, which is the layout of the page. Deselecting the phone radio button on the Lightning record page assignment may not be desirable, as it will prevent mobile users from accessing the record page at all, which may affect their productivity and functionality.
NEW QUESTION # 199
After you used BraindumpStudy Salesforce Plat-Admn-202 Dumps, you still fail in Plat-Admn-202 test and then you will get FULL REFUND. This is BraindumpStudy's commitment to all candidates. What's more, the excellent dumps can stand the test rather than just talk about it. BraindumpStudy test dumps can completely stand the test of time. BraindumpStudy present accomplishment results from practice of all candidates. Because it is right and reliable, after a long time, BraindumpStudy exam dumps are becoming increasingly popular.
Exam Plat-Admn-202 Reviews: https://www.braindumpstudy.com/Plat-Admn-202_braindumps.html
We eliminated the filler and simplified the Exam Plat-Admn-202 Reviews - Salesforce Certified Platform App Builder preparation process so you can ace the Salesforce Exam Plat-Admn-202 Reviews certification exam on your first try, At entry level, professionals can choose to build their server knowledge through the Exam Plat-Admn-202 Reviews: IT infrastructure, We can promise that our Plat-Admn-202 exam questions are always the latest and valid for we are always trying to do better for our worthy customers.
So now I know what happens, Therefore, in principle, the following conclusions Plat-Admn-202 are drawn, We eliminated the filler and simplified the Salesforce Certified Platform App Builder preparation process so you can ace the Salesforce certification exam on your first try.
Hot Reliable Plat-Admn-202 Exam Syllabus | Valid Exam Plat-Admn-202 Reviews: Salesforce Certified Platform App BuilderAt entry level, professionals can choose to Exam Plat-Admn-202 Reviews build their server knowledge through the Salesforce Developer: IT infrastructure, We can promise that our Plat-Admn-202 Exam Questions are always the latest and valid for we are always trying to do better for our worthy customers.
Thus you can study Salesforce Plat-Admn-202 on your preferred smart device such as your smartphone or in hard copy format, There are no limits for the amount of the using persons and equipment at the same time.
- Plat-Admn-202 Certification Sample Questions 🚾 Plat-Admn-202 Reliable Real Exam 🧰 New Plat-Admn-202 Exam Objectives 🚛 Easily obtain ⇛ Plat-Admn-202 ⇚ for free download through { [url]www.prep4away.com } ☸
lat-Admn-202 Reliable Test Book[/url] - Free PDF 2026 Plat-Admn-202 - Reliable Salesforce Certified Platform App Builder Exam Syllabus 🥧 Search for ➡ Plat-Admn-202 ️⬅️ and easily obtain a free download on ▶ [url]www.pdfvce.com ◀ 🥫Study Plat-Admn-202 Center[/url]
- The Salesforce Plat-Admn-202 Online Practice Test Engine 🌃 Easily obtain free download of ➠ Plat-Admn-202 🠰 by searching on ☀ [url]www.vceengine.com ️☀️ 🥟
lat-Admn-202 Examcollection Dumps[/url] - Plat-Admn-202 Reliable Real Exam 😶 New Plat-Admn-202 Exam Objectives 🚣 New Plat-Admn-202 Exam Objectives 🦗 Open ➡ [url]www.pdfvce.com ️⬅️ enter Plat-Admn-202 and obtain a free download 🥙Official Plat-Admn-202 Practice Test[/url]
- Free PDF 2026 Plat-Admn-202 - Reliable Salesforce Certified Platform App Builder Exam Syllabus 🦼 Search for ➡ Plat-Admn-202 ️⬅️ on ▶ [url]www.verifieddumps.com ◀ immediately to obtain a free download 🥦
lat-Admn-202 Valid Exam Notes[/url] - The Salesforce Plat-Admn-202 Online Practice Test Engine 🎬 Search on [url]www.pdfvce.com for [ Plat-Admn-202 ] to obtain exam materials for free download 🙆
lat-Admn-202 Certification Sample Questions[/url] - 2026 Salesforce - Plat-Admn-202 - Reliable Salesforce Certified Platform App Builder Exam Syllabus 🌵 Search for ➤ Plat-Admn-202 ⮘ and obtain a free download on ▶ [url]www.dumpsmaterials.com ◀ ↩Complete Plat-Admn-202 Exam Dumps[/url]
- Official Plat-Admn-202 Practice Test 🔓 Plat-Admn-202 Examcollection Dumps 🚏 Question Plat-Admn-202 Explanations 🛫 Search for ⮆ Plat-Admn-202 ⮄ and obtain a free download on ▶ [url]www.pdfvce.com ◀ 🍥
lat-Admn-202 Free Exam Dumps[/url] - Quiz 2026 Salesforce Plat-Admn-202 Fantastic Reliable Exam Syllabus 👓 Open ⇛ [url]www.pass4test.com ⇚ enter ⇛ Plat-Admn-202 ⇚ and obtain a free download 🏘Dumps Plat-Admn-202 Collection[/url]
- Pass Guaranteed 2026 Plat-Admn-202: Salesforce Certified Platform App Builder Newest Reliable Exam Syllabus 🕚 The page for free download of ✔ Plat-Admn-202 ️✔️ on ➥ [url]www.pdfvce.com 🡄 will open immediately ❤
lat-Admn-202 Pass4sure Exam Prep[/url] - Test Plat-Admn-202 Objectives Pdf 🎭 Plat-Admn-202 Examcollection Dumps 👜 Question Plat-Admn-202 Explanations 🍸 Download ⇛ Plat-Admn-202 ⇚ for free by simply searching on ▷ [url]www.troytecdumps.com ◁ 🐩
lat-Admn-202 Reliable Real Exam[/url] - app.parler.com, www.flirtic.com, www.stes.tyc.edu.tw, pct.edu.pk, dorahacks.io, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, estar.jp, academia.ragif.com.ar, www.stes.tyc.edu.tw, www.competize.com, Disposable vapes
