Reliable CWNA-109 Test Voucher, CWNA-109 Testking Exam Questions
Posted at 1/12/2026 11:18:49
View157
Replies3
BONUS!!! Download part of ValidTorrent CWNA-109 dumps for free: https://drive.google.com/open?id=1UZ_t-FA0PHFxCJ4Tl4TMduHmaiHynd0q
Perhaps you have also seen the related training tools about CWNP certification CWNA-109 exam on other websites, but our ValidTorrent has a pivotal position in the field of IT certification exam. ValidTorrent research materials can 100% guarantee you to pass the exam. With ValidTorrent your career will change and you can promote yourself successfully in the IT area. When you select ValidTorrent you'll really know that you are ready to pass CWNP Certification CWNA-109 Exam. We not only can help you pass the exam successfully, but also will provide you with a year of free service.
CWNP CWNA-109 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - WLAN Network Security: It addresses the concepts of weak security options, security mechanisms for enterprise WLANs, and security options and tools used in wireless networks.
| | Topic 2 | - WLAN Network Architecture and Design Concepts: This topic deals with describing and implementing Power over Ethernet (PoE). Furthermore, the topic covers different wireless LAN architectures, coverage requirements, roaming considerations, and common proprietary features in wireless networks.
| | Topic 3 | - Radio Frequency (RF) Technologies: This topic explains the basic features and behavior of RF. It also discusses applying the basic concepts of RF mathematics and measurement. Lastly, the topic covers RF signal characteristics and the functionality of RF antennas.
| | Topic 4 | - WLAN Regulations and Standards: The topic discusses the roles of WLAN and networking industry organizations. It also addresses the concepts of various Physical Layer (PHY) solutions, spread spectrum technologies, and 802.11 WLAN functional concepts.
CWNA-109 Testking Exam Questions, Latest CWNA-109 Exam QuestionMore successful cases of passing the CWNA-109 exam can be found and can prove our powerful strength. As a matter of fact, since the establishment, we have won wonderful feedback and ceaseless business, continuously working on developing our CWNA-109 test prep. We have been specializing CWNA-109 Exam Dumps many years and have a great deal of long-term old clients, and we would like to be a reliable cooperator on your learning path and in your further development. We will be your best friend to help you pass the CWNA-109 exam and get certification.
CWNP Wireless Network Administrator (CWNA) Sample Questions (Q48-Q53):NEW QUESTION # 48
You are configuring an access point to use channel 128. What important fact should be considered about this channel?
- A. It is a 22 MHz channel so it will overlap with the channels above and below it
- B. It is a channel that may require DFS when used
- C. It is a channel that is unsupported by all access points in all regulatory domains
- D. It is a 2.4 GHz frequency band 40 MHz channel, so it should not be used
It is a channel that may require DFS when used is an important fact that should be considered about channel
128. Channel 128 is a 5 GHz frequency band 20 MHz channel that has a center frequency of 5.64 GHz.
Channel 128 is one of the channels that are subject to DFS (Dynamic Frequency Selection) rules, which require Wi-Fi devices to monitor and avoid using channels that are occupied by radar systems or other primary users. DFS is a feature that is defined in the IEEE 802.11h amendment and is mandated by some regulatory bodies, such as the FCC and the ETSI, to protect the licensed users of the 5 GHz band from interference by unlicensed Wi-Fi devices. DFS works by using a mechanism called channel availability check (CAC), which requires Wi-Fi devices to scan a channel for a certain period of time before using it. If a radar signal is detected during the CAC or while using the channel, the Wi-Fi devices must switch to another channel that is free from radar interference.
When configuring an access point to use channel 128, it is important to consider the implications of DFS rules, such as:
* The access point must support DFS and comply with the local regulations and standards that apply to DFS channels.
* The access point may experience delays or interruptions in its operation due to CAC or channel switching.
* The access point may have limited channel selection or availability due to radar interference or other Wi-Fi devices using DFS channels.
* The access point may have compatibility or interoperability issues with some client devices that do not support DFS or use different DFS parameters.
* The access point may have performance or quality issues due to co-channel or adjacent-channel interference from other Wi-Fi devices using non-DFS channels.
Therefore, it is advisable to use channel 128 only when necessary and after performing a thorough site survey and spectrum analysis to determine the best channel for the access point. References: 1, Chapter 3, page
117; 2, Section 3.2
NEW QUESTION # 49
You are performing a post-implementation validation survey. What basic tool can be used to easily locate areas of high co-channel interference?
- A. Laptop-based spectrum analyzer
- B. Access point spectrum analyzer
- C. Wi-Fi scanner
- D. Throughput tester
A Wi-Fi scanner is a basic tool that can be used to easily locate areas of high co-channel interference. A Wi-Fi scanner is a software application that can run on a laptop, tablet, smartphone, or other device that has a Wi-Fi adapter. A Wi-Fi scanner can scan the wireless environment and display information about the detected access points and client stations, such as their SSID, BSSID, channel, signal strength, security, and data rate. A Wi-Fi scanner can also show the channel utilization and overlap of different access points, which can indicate the level of co-channel interference. Co-channel interference is a type of interference that occurs when multiple access points use the same or adjacent channels within the same coverage area. Co-channel interference can reduce the throughput and performance of the WLAN, as the access points and client stations have to contend for the channel access and avoid collisions. To identify areas of high co-channel interference, a Wi-Fi scanner can be used to measure the signal strength and channel utilization of different access points and compare them with a threshold or a baseline. Alternatively, a Wi-Fi scanner can also use a color-coded heat map to visualize the co-channel interference level in different locations. References: 1, Chapter 7, page
279; 2, Section 4.3
NEW QUESTION # 50
The BSA of an AP covers the area used by the sales and marketing department. Thirty-five stations operate in this space. The users indicate that they need more throughput and all stations are 5 GHz capable 802.11ac clients. The current AP configuration uses 20 MHz channels in both 2.4 GHz and 5 GHz. What is the least expensive solution available for increasing throughput for these users without implementing configuration options that are not recommended?
- A. Install a second AP in the coverage area
- B. Use a 40 MHz channel on the 2.4 GHz radio
- C. Use a 40 MHz channel on the 5 GHz radio
- D. Use a 160 MHz channel on the 5 GHz radio
The least expensive solution available for increasing throughput for these users without implementing configuration options that are not recommended is to use a 40 MHz channel on the 5 GHz radio. This solution can double the channel bandwidth and increase the data rates for the 5 GHz capable 802.11ac clients. Using a
40 MHz channel on the 5 GHz radio is also less likely to cause co-channel interference or overlap with other channels than using a 40 MHz channel on the 2.4 GHz radio, which has only three non-overlapping channels.
Using a 160 MHz channel on the 5 GHzradio may provide even higher throughput, but it may also consume too much of the available spectrum and cause more interference with other devices or networks. Installing a second AP in the coverage area may also improve the throughput, but it may require additional costs and configuration. References: [CWNP Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 216; [CWNA: Certified Wireless Network Administrator Official Study Guide:
ExamCWNA-109], page 206.
NEW QUESTION # 51
You are troubleshooting a controller-based AP that is unable to locate the controller. DHCP is not use and the controller is located at 10.10.10.81/24 while the AP is on the 10.10.16.0/24 network. What should be inspected to verify proper configuration?
- A. BOOTH
- B. AP hosts file
- C. NTP
- D. DNS
What should be inspected to verify proper configuration is DNS. DNS stands for Domain Name System and is a service that resolves hostnames to IP addresses. In a controller-based AP deployment, DNS can be used to help the AP locate the controller by using a predefined hostname such as CISCO-CAPWAP-CONTROLLER or aruba-master. The AP sends a DNS query for this hostname and receives an IP address of the controller as a response. Therefore, if DNS is not configured properly or if there is no DNS entry for the controller hostname, the AP may not be able to locate the controller. NTP, BOOTP, and AP hosts file are not relevant for this scenario. References: [CWNP Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 374; [CWNA: Certified Wireless Network Administrator Official Study Guide: Exam CWNA-109], page 364.
NEW QUESTION # 52
You are managing a wireless access point in autonomous mode using the Web based interface. You capture traffic during this management task and notice that you can see the HTML code of the Web pages used for access point management. What error in administration could be the cause of this security concern?
- A. WPA2 is disabled on the WLAN
- B. IPsec is not in use of the management connection as recommended
- C. HTTP is in use instead of HTTPS
- D. A VPN with the AP is not established
The error in administration that could be the cause of this security concern is that HTTP is in use instead of HTTPS. HTTP is an unencrypted protocol that transfers data in plain text over the network. This means that anyone who captures the traffic can see the HTML code of the Web pages used for access point management, as well as any sensitive information such as passwords or configuration settings. HTTPS is an encrypted protocol that uses SSL/TLS to secure the data transmission between the Web browser and the Web server.
HTTPS prevents anyone from snooping on or tampering with the Web traffic. Therefore, HTTPS should always be used for Web based management of wireless access points, especially in autonomous mode where there is no centralized controller to enforce security policies. References: [CWNP Certified Wireless Network Administrator Official Study Guide: ExamCWNA-109], page 431; [HTTP vs HTTPS: What's The Difference And Why Should You Care?].
NEW QUESTION # 53
There is not much disparity among these versions of CWNA-109 simulating practice, but they do helpful to beef up your capacity and speed up you review process to master more knowledge about the CWNA-109exam, so the review process will be unencumbered. Though the content of these three versions is the same, the displays of them are different. And you can try our CWNA-109 Study Materials by free downloading the demos to know which one is your favorite.
CWNA-109 Testking Exam Questions: https://www.validtorrent.com/CWNA-109-valid-exam-torrent.html
- New CWNA-109 Exam Preparation 📋 CWNA-109 Latest Dumps Ebook 🪓 CWNA-109 Top Exam Dumps 📞 Search for [ CWNA-109 ] and download it for free on [url]www.prep4sures.top website 🛥CWNA-109 Flexible Testing Engine[/url]
- New CWNA-109 Exam Preparation 🦋 CWNA-109 Valid Braindumps Ppt 🦘 Latest CWNA-109 Exam Price 🏵 Search for CWNA-109 and download it for free immediately on ⮆ [url]www.pdfvce.com ⮄ 🧵CWNA-109 Top Exam Dumps[/url]
- Pass Guaranteed CWNA-109 - Marvelous Reliable CWNP Wireless Network Administrator (CWNA) Test Voucher 👾 Immediately open { [url]www.easy4engine.com } and search for CWNA-109 to obtain a free download 🙆
ractice CWNA-109 Test[/url] - Valid CWNA-109 Exam Tips 🔄 CWNA-109 Top Exam Dumps ↔ Latest CWNA-109 Exam Price 😇 Search for ⮆ CWNA-109 ⮄ and download it for free on ➽ [url]www.pdfvce.com 🢪 website ⏲Latest CWNA-109 Exam Review[/url]
- CWNA-109 Training Online 📊 CWNA-109 Valid Braindumps Ppt 🎈 CWNA-109 Exam PDF 💇 Search for [ CWNA-109 ] and download exam materials for free through [url]www.easy4engine.com 🛹CWNA-109 Test Practice[/url]
- 100% Pass CWNP - Unparalleled Reliable CWNA-109 Test Voucher 😉 Search for CWNA-109 and easily obtain a free download on [url]www.pdfvce.com 🏤CWNA-109 Pdf Dumps[/url]
- CWNA-109 Flexible Testing Engine 🍤 CWNA-109 Valid Braindumps Ppt 👔 New CWNA-109 Exam Preparation 🎺 Easily obtain free download of ➡ CWNA-109 ️⬅️ by searching on ➠ [url]www.dumpsquestion.com 🠰 🦏CWNA-109 Top Exam Dumps[/url]
- CWNP CWNA-109 Exam | Reliable CWNA-109 Test Voucher - Most Reliable Website for you 👋 Open website ✔ [url]www.pdfvce.com ️✔️ and search for ▛ CWNA-109 ▟ for free download 👽CWNA-109 Top Exam Dumps[/url]
- Study CWNA-109 Test 🧺 CWNA-109 Valid Braindumps Ppt 🧛 CWNA-109 Top Exam Dumps ✡ Search for ➡ CWNA-109 ️⬅️ and easily obtain a free download on [url]www.exam4labs.com 🚇CWNA-109 Training Online[/url]
- Latest CWNA-109 Exam Review 👆 Practice CWNA-109 Test 🏔 Practice CWNA-109 Test 🙄 Open website ➽ [url]www.pdfvce.com 🢪 and search for CWNA-109 for free download 🥉CWNA-109 Test Practice[/url]
- Reliable CWNA-109 Real Test 🥠 Latest CWNA-109 Exam Price 📴 CWNA-109 Flexible Testing Engine 😺 Copy URL ➠ [url]www.exam4labs.com 🠰 open and search for ➤ CWNA-109 ⮘ to download for free 👧Valid CWNA-109 Exam Tips[/url]
- asmtechnolabs.com, wanderlog.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, truetraders.co.in, royalblue-training.co.uk, www.meilichina.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
2026 Latest ValidTorrent CWNA-109 PDF Dumps and CWNA-109 Exam Engine Free Share: https://drive.google.com/open?id=1UZ_t-FA0PHFxCJ4Tl4TMduHmaiHynd0q
