[General] Use CompTIA SK0-005 PDF Questions To Get Better Results
87
【General】 Use CompTIA SK0-005 PDF Questions To Get Better Results
Posted at 1/12/2026 12:29:38      View:173 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 CompTIA SK0-005 dumps are available on Google Drive shared by PremiumVCEDump: https://drive.google.com/open?id=1Vzz0HyskuQ3P3-IskYO0AsmLVmh4xiMj
Our SK0-005 study tool prepared by our company has now been selected as the secret weapons of customers who wish to pass the exam and obtain relevant certification. If you are agonizing about how to pass the exam and to get the CompTIA certificate, now you can try our SK0-005 learning materials. Our reputation is earned by high-quality of our SK0-005 Learning Materials. Once you choose our SK0-005 training materials, you chose hope. Our SK0-005 learning materials are based on the customer's point of view and fully consider the needs of our customers.
According to various predispositions of exam candidates, we made three versions of our SK0-005 study materials for your reference: the PDF, Software and APP online. And the content of them is the same though the displays are different. Untenable materials may waste your time and energy during preparation process. But our SK0-005 Practice Braindumps are the leader in the market for ten years. As long as you try our SK0-005 exam questions, we believe you will fall in love with it.
Latest Released CompTIA SK0-005 Test Dates: CompTIA Server+ Certification ExamAs a responsible company with great reputation among the market, we trained our staff and employees with strict beliefs to help you with any problems about our SK0-005 Learning materials 24/7. Even you have finished buying activity with us, we still be around you with considerate services on the SK0-005 Exam Questions. And we will update our SK0-005 training guide from time to time, once we update our SK0-005 study guide, we will auto send it to our customers. And you can enjoy our updates of SK0-005 learning prep for one year after your payment.
CompTIA Server+ Certification Exam Sample Questions (Q163-Q168):NEW QUESTION # 163
Which of the following BEST measures how much downtime an organization can tolerate during an unplanned outage?
  • A. SLA
  • B. BIA
  • C. RTO
  • D. MTTR
RTO (Recovery Time Objective) is a metric that measures how much downtime an organization can tolerate during an unplanned outage before it affects its business continuity and reputation. RTO is usually expressed in hours or minutes and is determined by the criticality of the business processes and the impact of the outage on the revenue, customers, and stakeholders. RTO helps to define the recovery strategy and the resources needed to restore the normal operations as quickly as possible. Verified References: [RTO vs RPO]
NEW QUESTION # 164
The network's IDS is giving multiple alerts that unauthorized traffic from a critical application server is being sent to a known-bad public IP address.
One of the alerts contains the following information:
Exploit Alert
Attempted User Privilege Gain
2/2/07-3: 09:09 10.1.200.32
--> 208.206.12.9:80
This server application is part of a cluster in which two other servers are also servicing clients. The server administrator has verified the other servers are not sending out traffic to that public IP address. The IP address subnet of the application servers is 10.1.200.0/26. Which of the following should the administrator perform to ensure only authorized traffic is being sent from the application server and downtime is minimized? (Select two).
  • A. Enable GPO to install an antivirus on all the servers and perform a weekly reboot.
  • B. Perform an antivirus scan on all servers within the cluster and reboot each server.
  • C. Block access to 208.206.12.9 from all servers on the network.
  • D. Change the IP address of all the servers in the cluster to the 208.206.12.0/26 subnet.
  • E. Perform a vulnerability scan on all the servers within the cluster and patch accordingly.
  • F. Disable all services on the affected application server.
Answer: B,E
The administrator should perform an antivirus scan on all servers within the cluster and reboot each server, and block access to 208.206.12.9 from all servers on the network. These actions will help to remove any malware that may have infected the application server and prevent any further unauthorized traffic to the known-bad public IP address. An antivirus scan can detect and remove malicious software that may be sending data to an external source, and a reboot can clear any temporary files or processes that may be related to the malware. Blocking access to 208.206.12.9 from all servers on the network can prevent any future attempts to communicate with the malicious IP address.
References: CompTIA Server+ SK0-005 Certification Study Guide, Chapter 3, Lesson 3.4, Objective 3.4; Chapter 6, Lesson 6.2, Objective 6.2
NEW QUESTION # 165
A server administrator was asked to implement a site backup solution. The backup window during regular business days is from midnight to 6:00 a.m. because end-of-cycle payroll processing will occur for the next three months. Which of the following backup methodologies would satisfy this restriction in performing short backups?
  • A. Perform daily normal backups.
  • B. Perform daily full backups.
  • C. Perform daily differential backups.
  • D. Perform daily incremental backups.
NEW QUESTION # 166
A server administrator just installed a new physical server and needs to harden the applications on the server.
Which of the following best describes a method of application hardening?
  • A. Install the latest patches.
  • B. Enable a BIOS password.
  • C. Disable unneeded hardware.
  • D. Set the boot order.
A method of application hardening is installing the latest patches. Application hardening is a process of reducing the attack surface and vulnerabilities of an application by applying security measures and best practices. Installing the latest patches is one way to harden an application, as patches are updates that fix bugs, errors, or security issues in an application. By installing the latest patches, an application can be protected from known exploits or threats.
References: CompTIA Server+ SK0-005 Certification Study Guide, Chapter 3, Lesson 3.5, Objective 3.5
NEW QUESTION # 167
A newly hired systems administrator is concerned about fileshare access at the company. The administrator turns on DLP for the fileshare and lets it propagate for a week. Which of the following can the administrator perform now?
  • A. Audit the access to the physical fileshare.
  • B. Manage the fileshare from an RDP session.
  • C. Manage the permissions from the fileshare.
  • D. Audit the permissions of the fileshare.
DLP, or Data Loss Prevention, is a type of security measure that aims to prevent unauthorized access, use, or transfer of sensitive dat a) DLP can be applied to various types of data, such as email, cloud storage, network traffic, or fileshares1. DLP for fileshares can help monitor and control who can access, modify, or share files on a network share2. By turning on DLP for the fileshare and letting it propagate for a week, the administrator can audit the permissions of the fileshare and see if there are any violations or anomalies in the access patterns. This can help the administrator identify and remediate any potential risks or compliance issues related to the fileshare2. The other options are incorrect because they are not directly related to DLP for fileshares. Managing the fileshare from an RDP session or from the fileshare itself are administrative tasks that do not require DLP. Auditing the access to the physical fileshare is a physical security measure that is not affected by DLP.
NEW QUESTION # 168
Many candidates find the CompTIA exam preparation difficult. They often buy expensive study courses to start their CompTIA SK0-005 certification exam preparation. However, spending a huge amount on such resources is difficult for many CompTIA Server+ Certification Exam applicants. The Latest SK0-005 Exam Dumps are the right option for you to prepare for the SK0-005 certification test at home.
Accurate SK0-005 Prep Material: https://www.premiumvcedump.com/CompTIA/valid-SK0-005-premium-vce-exam-dumps.html
In addition, SK0-005 test materials are high-quality, since we have a professional team to edit and verify them, therefore they can help you pass the exam just one time, It copies the exact pattern and style of the real CompTIA Server+ Certification Exam (SK0-005) exam to make your preparation productive and relevant, Comparing to attending classes, SK0-005 valid dumps provided by our website can not only save your money and time, but also ensure you pass CompTIA actual test with high rate.
and Cisco Intrusion Detection System features and products, The retailer SK0-005 is advised to explain" the reasons behind its lower costs if it wants to reassure its customers that quality of products has not been sacrificed.
Switch Your Nervousness in SK0-005 Exam by Using CompTIA SK0-005 ExamIn addition, SK0-005 test materials are high-quality, since we have a professional team to edit and verify them, therefore they can help you pass the exam just one time.
Year by year, the passing rate is reaching highly to about 98%-100%, that is to say, everyone who use our SK0-005 exam prep gets good grades in the test, which is also the goal that our company is dedicated to.
It can also be used on any smartphone or tablet.
2026 Latest PremiumVCEDump SK0-005 PDF Dumps and SK0-005 Exam Engine Free Share: https://drive.google.com/open?id=1Vzz0HyskuQ3P3-IskYO0AsmLVmh4xiMj
Posted at 1/15/2026 01:58:20        Only Author  2#
I can’t thank you enough for your article, it really made an impression. Free Study materials PRINCE2Practitioner review materials—wishing you the best of luck!
Posted at 1/25/2026 19:15:54        Only Author  3#
立派な生活を送るために、彼らはこの試験に関する専門知識の厳密な研究を行いました。 SAP Certified Associate - Back-End Developer - ABAP Cloudのトレーニング資料がありますので、完璧な練習資料の検索に時間をかけないでください。 C_ABAPD_2507試験準備の熟練度を保証できます。 ですから、これは決定的な選択です。つまり、C_ABAPD_2507実践教材は、あなたが成功の成果を得るのに役立つことを意味します。
