Linux
Linux SDK Build Error
Posted at 5/10/2022 22:23:28
View7979
Replies11
Hello,
I'm using the Linux SDK, an rk3566 aio board.
I build it with this commands:
./build.sh aio-3566-jd4-ubuntu.mk
./build.sh
But when building it the device doesn't start and is throwing an error, does someone have an idea?
- mount: mounting /dev/mmcblk1p6 on /root failed: Invalid argument
- done.
- Begin: Running /scripts/local-bottom ... done.
- Begin: Running /scripts/init-bottom ... [ 4.651715] vendor storage:20190527 r et = -1
- [ 4.835173] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- Warning: overlayroot: configuring overlayroot with driver=overlay mode=device op ts='dev=PARTLABEL=userdata,fstype=ext4,mkfs=1' per kernel cmdline
- [ 4.963550] EXT4-fs (mmcblk1p7): recovery complete
- [ 4.965832] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. O pts: (null)
- mount: mounting /root on /root-ro failed: Invalid argument
- Failure: overlayroot: failed to move root away from /root to /root-ro
- mount: mounting /dev on /root/dev failed: No such file or directory
- Warning: Something odd, no /lib/modules/4.19.219 in initramfs.
- done.
- mount: mounting /run on /root/run failed: No such file or directory
- run-init: current directory on the same filesystem as the root: error 0
- Target filesystem doesn't have requested /sbin/init.
- No init found. Try passing init= bootarg.
- BusyBox v1.27.2 (Ubuntu 1:1.27.2-2ubuntu3.2) built-in shell (ash)
- Enter 'help' for a list of built-in commands.
- (initramfs) [ 5.848415] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 6.861753] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 7.875081] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 8.888413] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 9.901730] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 10.915082] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x3
- [ 11.928402] rk-pcie 3c0000000.pcie: PCIe Link Fail
- [ 11.928469] rk-pcie 3c0000000.pcie: failed to initialize host
- [ 32.061826] vcc5v0_otg: disabling
- [ 32.061903] vcc3v3_lcd0_n: disabling
Copy the code |
