[General] Order-Management-Administrator Free Study Material - Order-Management-Administra
General Order-Management-Administrator Free Study Material - Order-Management-Administra
Posted at 1/12/2026 13:56:29      View286 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest ExamcollectionPass Order-Management-Administrator PDF Dumps and Order-Management-Administrator Exam Engine Free Share: https://drive.google.com/open?id=1rfrw595-EZBtExcS8qGnkDJMeC7kp6f2
One of the biggest highlights of the Order-Management-Administrator exam materials is the availability of three versions: PDF, app/online, and software/pc, each with its own advantages: The PDF version of Order-Management-Administrator exam materials has a free demo available for download. You can print exam materials out and read it just like you read a paper. The online version of Order-Management-Administrator Exam Materials is based on web browser usage design and can be used by any browser device. At the same time, the first time it is opened on the Internet, it can be used offline next time. You can practice anytime, anywhere.
Many people are afraid of walking out of their comfortable zones. So it is difficult for them to try new things. But you will never grow up if you reject new attempt. Now, our Order-Management-Administrator study materials can help you have a positive change. It is important for you to keep a positive mind. Our Order-Management-Administrator Study Materials can become your new attempt. It is not difficult for you. We have simplified all difficult knowledge. So you will enjoy learning our Order-Management-Administrator study materials. During your practice of our Order-Management-Administrator study materials, you will find that it is easy to make changes.
Order-Management-Administrator Latest Test Bootcamp & New Order-Management-Administrator Practice QuestionsOur Order-Management-Administrator study materials are compiled and tested by our expert. Order-Management-Administrator try hard to makes Order-Management-Administrator exam preparation easy with its several quality features. We send learning information in the form of questions and answers, and our Order-Management-Administrator study materials are highly relevant to what you need to pass Order-Management-Administrator certification exam. Our free demo will show you the actual Order-Management-Administrator Certification Exam. You can learn about real exams in advance by studying our Order-Management-Administrator study materials and improve your confidence in the exam so that you can pass Order-Management-Administrator exams with ease. This is also the reason that has been popular by the majority of candidates.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q105-Q110):NEW QUESTION # 105
An Administrator has created a change set with two items, a new apex class and a new apex trigger. When attempting to deploy the change set, and error occurs? What could be the cause?
  • A. <br>
  • B. An Apex Trigger cannot be deployed via change set <br>
  • C. The new apex class and trigger have lowered the sent *** **** the ********* threshold
  • D. Different Metadata types cannot be deployed within a single change set <br>
  • E. Apex Classes require a header file when deployed <br>
Answer: E
NEW QUESTION # 106
A customer orders two shirts and one jacket in B2C Commerce. The Order is ingested into Order Management. However, the customer decides to cancel the order prior to fulfillment. What object is created and linked to the Order Summary?
  • A. Return Order
  • B. Suspend Order
  • C. Cancel Order
  • D. Change Order
The object that is created and linked to the Order Summary when a customer cancels an order prior to fulfillment is Cancel Order. A Cancel Order is a record that represents a cancellation request for an order or part of an order. A Cancel Order has a lookup relationship to both Order Summary and Change Order objects, and it contains information such as the cancellation reason, status, date, etc. Verified References:https://help.salesforce.com/s/ar ... rder.htm&type=5
NEW QUESTION # 107
A customer wants to change the layout of the out of the box Order Summary Lightning Record Page to three columns instead of two. How can an administrator satisfy this requirement?
  • A. Change the page layout template to Three Regions in the layout editor
  • B. Add another column component lo the existing Lightning Record Page
  • C. Edit the Lightning Record Page and change the Template lo Three Regions
  • D. Create a new Lightning Record Page and select the Three Regions template
The best way for the administrator to satisfy this requirement is to edit the Lightning Record Page and change the Template to Three Regions. A Lightning Record Page is a type of page that displays details and related information about a specific record in Lightning Experience or Salesforce mobile app. A Lightning Record Page can be customized using the Lightning App Builder, which is a tool that allows administrators to drag and drop components onto a page layout. A Template is a predefined layout that determines how components are arranged on a page. A Three Regions template is a type of template that divides the page into three columns or regions. The administrator can edit the Lightning Record Page for the Order Summary object, and change the Template to Three Regions in the Lightning App Builder. Verified Reference: https://help.salesforce.com/s/ar ... ages.htm&type=5 https://help.salesforce.com/s/ar ... ates.htm&type=5
NEW QUESTION # 108
What ate two reasons an admin should choose an Event over a Trigger when it comes to building out a solution?
  • A. Events do not participate in a transaction scope
  • B. Event order is not guaranteed within a topic
  • C. Events cannot be subscribed lo in a batch for bulk operations
  • D. Events are asynchronous
Two reasons an admin should choose an Event over a Trigger when it comes to building out a solution are:
Events are asynchronous. This means that events are processed in the background, without blocking the main execution thread. This can improve the performance and user experience of the solution, as well as avoid governor limits and timeouts.
Events do not participate in a transaction scope. This means that events are independent of the transaction that publishes them, and they do not affect the rollback or commit behavior of the transaction. This can avoid unwanted side effects and errors in the solution, as well as decouple the logic from the data.
https://developer.salesforce.com ... form_events_intro.h
https://developer.salesforce.com ... tform_events_consid
NEW QUESTION # 109
When can an Invoice be created?
  • A. At any point before the Fulfillment Order is created, by customizing flow "Create invoice"
  • B. At any point after the Fulfillment Order is created, by customizing flow 'Create Invoice and Ensure Funds*
  • C. At any point before the Fulfillment Order is created, by customizing flow "Create Invoice and Ensure Funds"
  • D. At any point after the Fulfillment Order is created, by customizing flow "Create Invoice'
The correct time and way for creating an Invoice is at any point after the Fulfillment Order is created, by customizing flow "Create Invoice". This flow is a core action that creates an Invoicerecord from a Fulfillment Order record, and updates the status of both records accordingly. The administrator can customize this flow to suit their business needs, such as adding conditions, actions, or subflows. Verified References:https://help.salesforce.com/s/ar ... te_invoice.htm&
NEW QUESTION # 110
With the Salesforce Order Management Administrator Accredited Professional Order-Management-Administrator exam, you will have the chance to update your knowledge while obtaining dependable evidence of your proficiency. You can benefit from a number of additional benefits after completing the Salesforce Order Management Administrator Accredited Professional Order-Management-Administrator Certification Exam. But keep in mind that the Order-Management-Administrator certification test is a worthwhile and challenging certificate.
Order-Management-Administrator Latest Test Bootcamp: https://www.examcollectionpass.com/Salesforce/Order-Management-Administrator-practice-exam-dumps.html
The online test engine mode is exam simulations that make you feel the atmosphere of Order-Management-Administrator actual test and the score is revealed at the end of test, Our dumps are 100% accurate and guaranteed to pass: ExamcollectionPass PDF for Salesforce Order Management Order-Management-Administrator is written according to the latest actual exams, This helps you memorize actual Order-Management-Administrator exam questions beforehand and clear the Order-Management-Administrator certification test on the first attempt, Salesforce Order-Management-Administrator Free Study Material We are all well aware that a major problem in the industry is that there is a lack of quality study materials.
Arriving at a Consensus, HR professionals planning analytics projects, The online test engine mode is exam simulations that make you feel the atmosphere of Order-Management-Administrator Actual Test and the score is revealed at the end of test.
Salesforce Order-Management-Administrator Exam Real and Updated Dumps are Ready for DownloadOur dumps are 100% accurate and guaranteed to pass: ExamcollectionPass PDF for Salesforce Order Management Order-Management-Administrator is written according to the latest actual exams, This helps you memorize actual Order-Management-Administrator exam questions beforehand and clear the Order-Management-Administrator certification test on the first attempt.
We are all well aware that a major problem in Order-Management-Administrator the industry is that there is a lack of quality study materials, ExamcollectionPass offer you two formats of the Salesforce Order Management Order-Management-Administrator braindumps: PDF format (Printable Version): Print Salesforce Order Management Order-Management-Administrator braindumps out.
P.S. Free 2026 Salesforce Order-Management-Administrator dumps are available on Google Drive shared by ExamcollectionPass: https://drive.google.com/open?id=1rfrw595-EZBtExcS8qGnkDJMeC7kp6f2
Posted at 1/31/2026 12:43:10        Only Author  2#
I was really impressed by the depth of the article. Valid 101-500 soft simulations offers outstanding content, all for free.
