Salient Features of Palo Alto Networks SD-WAN-Engineer Web-Based Practice Test S
Posted at 1/12/2026 14:53:35
It is convenient for the user to read. The SD-WAN-Engineer test materials have a biggest advantage that is different from some online learning platform which has using terminal number limitation, the SD-WAN-Engineer quiz torrent can meet the client to log in to learn more, at the same time, the user can be conducted on multiple computers online learning, greatly reducing the time, and people can use the machine online of SD-WAN-Engineer Test Prep more conveniently at the same time. As far as concerned, the online mode for mobile phone clients has the same function.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
| | Topic 2 | - Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
- Group-based policy implementation.
| | Topic 3 | - Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
| | Topic 4 | - Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
| | Topic 5 | - Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Test SD-WAN-Engineer Objectives Pdf & Top SD-WAN-Engineer DumpsSD-WAN-Engineer eaxm dumps at Itbraindumps are always kept up to date. Every addition or subtraction of SD-WAN-Engineer exam dumps in the exam syllabus is updated in our brain dumps instantly. Practice on real SD-WAN-Engineer exam dumps and we have provided their answers too for your convenience. If you put just a bit of extra effort, you can score the highest possible score in the Real SD-WAN-Engineer Exam because our SD-WAN-Engineer exam preparation dumps are designed for the best results.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q58-Q63):NEW QUESTION # 58
A network engineer is troubleshooting a user complaint regarding "slow application performance" for an internal web application. While viewing the Flow Browser in the Prisma SD-WAN portal, the engineer notices that the Server Response Time (SRT) is consistently high (over 500ms), while the Network Transfer Time (NTT) and Round Trip Time (RTT) are low (under 50ms).
What does this data indicate about the root cause of the issue?
- A. The issue is likely caused by congestion on the WAN circuit, requiring a QoS policy adjustment.
- B. The issue is caused by a high packet loss rate on the internet path.
- C. The issue is due to a misconfigured DNS server at the branch.
- D. The issue is likely on the application server itself (e.g., high CPU, slow database query), not the network.
NEW QUESTION # 59
An ION 3000 device at a remote branch has suffered a critical hardware failure and must be replaced via the RMA process. The administrator has received the replacement unit.
What is the correct procedure to transfer the configuration and license from the defective unit to the replacement unit to ensure minimal downtime and retention of historical data?
- A. Use the "Replace Device" workflow in the Prisma SD-WAN portal, which automatically transfers the configuration (Device Shell) and re-associates the site to the new serial number.
- B. Delete the old device from the portal, create a new site for the replacement device, and rebuild the policies manually.
- C. Manually configure the new device from scratch, then open a support ticket to transfer the license.
- D. Backup the configuration of the old device to a USB drive and restore it to the new device using the local console.
Comprehensive and Detailed Explanation
The RMA replacement process in Prisma SD-WAN is designed to be seamless, leveraging the decoupling of logical configuration from physical hardware.
Replace Device Workflow: The administrator should use the "Replace Device" (or RMA) function within the portal. This workflow allows you to select the "Defective" device (old serial) and the "Replacement" device (new serial).
Configuration Transfer: Once executed, the system automatically binds the existing Device Shell (which contains all interface configs, routing policies, and site associations) to the new hardware's serial number. The new device, once connected to the internet, will "call home," identify itself, and download the exact configuration of the previous unit.
License Transfer: While the configuration moves automatically, the Support License transfer typically requires a specific step in the Customer Support Portal (CSP) or happens automatically if processed as a formal RMA order. Options A and D are incorrect because they involve manual reconfiguration, which is unnecessary and error-prone. Option C is incorrect as the ION platform relies on cloud-based config management, not local USB backups for hardware swaps.
NEW QUESTION # 60
In the Prisma SD-WAN portal, an administrator is viewing the "Media" analytics for a branch site to troubleshoot complaints about poor voice quality.
When calculating the Mean Opinion Score (MOS) for voice traffic, which two metrics does the system prioritize active monitoring for, even when no user voice traffic is present on the link? (Choose two.)
- A. Latency (One-Way)
- B. Packet Loss
- C. Jitter
- D. Throughput
Prisma SD-WAN calculates the Mean Opinion Score (MOS) to provide a standardized metric (1-5) for voice quality. To ensure the system always knows the "voice readiness" of a path-even before a call starts-it uses Active Probes (synthetic UDP packets).
While latency is measured, the MOS calculation algorithm is most heavily penalized by Packet Loss (D) and Jitter (B).
Packet Loss: Even a small amount of loss (e.g., >1%) dramatically reduces voice clarity, causing dropouts.
Jitter: High variance in packet arrival time (jitter) causes the "robotic" voice effect and buffer underruns.
The system continuously measures these specific metrics on all WAN links using synthetic probes. If the packet loss or jitter exceeds the threshold defined in the " ath Quality Profile" (e.g., Voice Profile), the path is marked as non-compliant, and the MOS score drops, triggering a policy action to move the flow. Throughput (C) is less critical for voice as calls consume very little bandwidth (e.g., 64-100 Kbps), making congestion (loss/jitter) the primary enemy, not raw speed.
NEW QUESTION # 61
A network administrator is troubleshooting a critical SaaS application, "SuperSaaSApp", that is experiencing connectivity issues. Initially, the configured active and backup paths for the application were reported as completely down at Layer 3. The Prisma SD-WAN system attempted to route traffic for the application over an L3 failure path that was explicitly configured as a Standard VPN to Prisma Access.
However, users are still reporting a complete outage for the application and monitoring tools show application flows being dropped when attempting to use the Standard VPN L3 failure path, even though the tunnel itself appears to be up. The administrator suspects a policy misconfiguration related to how the Standard VPN path interacts with destination groups.
What is the most likely reason for flows being dropped when attempting to use the Standard VPN L3 failure path?
- A. The "Move Flows Forced" action was not enabled in the performance policy for "SuperSaaSApp", preventing the system from actively shifting traffic to the L3 failure path.
- B. The path policy rule for "SuperSaaSApp" has the "Required" checkbox selected for its Service & DC Group, but no direct paths were configured alongside it, creating a conflict.
- C. The path policy rule explicitly designates a Standard VPN as the L3 failure path, but it does not include a designated Standard Services and DC Group, causing traffic to be dropped.
- D. The Standard VPN in the path policy was not configured to "Minimize Cellular Usage", leading to the depletion of metered data and subsequent flow drops.
According to Palo Alto Networks Prisma SD-WAN administrator documentation regarding Path Policy configuration, specific rules apply when utilizing Standard VPNs (IPSec tunnels to non-ION devices, such as Prisma Access or third-party firewalls) as an L3 Failure Path.
When a Path Policy rule is configured, the administrator defines Active Paths, Backup Paths, and L3 Failure Paths. The L3 Failure Path is a "last resort" mechanism used when all Active and Backup paths are unavailable (Layer 3 down).
If Standard VPN is selected as the L3 Failure Path type, the system explicitly requires that the administrator also associates it with a specific Standard Services and DC Group within that same policy rule.
The ION device uses the Standard Services and DC Group to identify the specific remote endpoint (tunnel destination) where the traffic should be routed. Unlike a "Direct" (Internet) path which can simply route out to the WAN, a Standard VPN represents a logical tunnel. If the policy rule designates "Standard VPN" as the failure path but leaves the "Standard Services and DC Group" field empty or unselected, the ION effectively has a directive to "use a VPN" but lacks the instruction on which VPN group to use for this specific application context. Consequently, even if the IPSec tunnel to Prisma Access is physically up and stable, the policy engine cannot resolve the next hop for the "SuperSaaSApp" traffic, resulting in the packets being dropped. To resolve this, the administrator must edit the Path Policy rule to ensure the specific Standard Service/DC Group representing Prisma Access is checked/selected for the L3 Failure Path.
NEW QUESTION # 62
What is the number and structure of Prisma SD-WAN QoS queues supported per WAN interface?
- A. 12 queues
4 classes1
3 application criteria within each class - B. 8 queues
1 priority queue
7 non-priority queues - C. 16 queues
4 classes
4 application criteria with each class - D. 8 queues
2 classes
4 application criteria within each class
The Prisma SD-WAN (ION) QoS engine utilizes a hierarchical queuing structure designed to provide granular control over application performance. Each WAN interface on an ION device supports a total of 16 QoS queues.
This 16-queue structure is derived from a matrix of 4 Classes (often referred to as Priority Classes) multiplied by 4 Application Criteria (Traffic Types).2
4 Priority Classes: The system defines four high-level business priority categories:3 Platinum (Highest priority)4 Gold Silver Bronze (Lowest priority/Best Effort)5
4 Application Criteria (Sub-queues): Within each of the four priority classes, the system further categorizes traffic into four specific application types to ensure proper handling (e.g., ensuring voice doesn't get stuck behind bulk data even within the same priority level):6 Real-Time Video Real-Time Audio Transactional Bulk7 Calculation: 4 Priority Classes × 4 Application Types = 16 Total Queues per interface. This structure allows the scheduler to ensure that a " latinum" voice call is prioritized over " latinum" bulk data, and both are prioritized over "Gold" traffic.
NEW QUESTION # 63
Preparing for the Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) certification test can be a difficult task for candidates. They often face several challenges during their preparation for the Palo Alto Networks SD-WAN Engineer (SD-WAN-Engineer) exam, including fear, lack of updated SD-WAN-Engineer Exam Dumps, and time constraints. Fortunately, there is a solution to these challenges. Itbraindumps is a reliable website that provides genuine and updated SD-WAN-Engineer Practice Test.
Test SD-WAN-Engineer Objectives Pdf: https://www.itbraindumps.com/SD-WAN-Engineer_exam.html
- Pass SD-WAN-Engineer Guide ⛳ Minimum SD-WAN-Engineer Pass Score 🍵 SD-WAN-Engineer Exam Cram Review 🔧 Simply search for { SD-WAN-Engineer } for free download on ▛ [url]www.prepawayexam.com ▟ 👔SD-WAN-Engineer Official Cert Guide[/url]
- New SD-WAN-Engineer Test Vce 🆚 SD-WAN-Engineer Exam Cram Review 🍀 SD-WAN-Engineer Valid Exam Materials 🗼 The page for free download of ➡ SD-WAN-Engineer ️⬅️ on “ [url]www.pdfvce.com ” will open immediately 🏝
ass SD-WAN-Engineer Guide[/url] - SD-WAN-Engineer Official Cert Guide 🥇 SD-WAN-Engineer Reliable Exam Braindumps ↖ Exam SD-WAN-Engineer Fees 🕗 Search for ▷ SD-WAN-Engineer ◁ and download it for free on ⮆ [url]www.examdiscuss.com ⮄ website 🌠Reliable SD-WAN-Engineer Test Question[/url]
- Pass Guaranteed 2026 Pass-Sure Palo Alto Networks SD-WAN-Engineer: Reliable Palo Alto Networks SD-WAN Engineer Test Vce 😻 Search on ▶ [url]www.pdfvce.com ◀ for 【 SD-WAN-Engineer 】 to obtain exam materials for free download 🕣
df SD-WAN-Engineer Format[/url] - www.vce4dumps.com SD-WAN-Engineer Web-Based Practice Tests 🧓 Search for 「 SD-WAN-Engineer 」 and easily obtain a free download on ⏩ [url]www.vce4dumps.com ⏪ ☁SD-WAN-Engineer Exam Pattern[/url]
- Hot Reliable SD-WAN-Engineer Test Vce | Pass-Sure Test SD-WAN-Engineer Objectives Pdf: Palo Alto Networks SD-WAN Engineer 🧃 Copy URL { [url]www.pdfvce.com } open and search for { SD-WAN-Engineer } to download for free 🙇New SD-WAN-Engineer Test Vce[/url]
- Free PDF SD-WAN-Engineer - Palo Alto Networks SD-WAN Engineer Newest Reliable Test Vce 🐾 Download ➠ SD-WAN-Engineer 🠰 for free by simply searching on 《 [url]www.troytecdumps.com 》 🩱SD-WAN-Engineer Pdf Format[/url]
- SD-WAN-Engineer Updated Test Cram 🔛 SD-WAN-Engineer Official Cert Guide 🛒 SD-WAN-Engineer Pdf Format 🍮 Simply search for ✔ SD-WAN-Engineer ️✔️ for free download on ⇛ [url]www.pdfvce.com ⇚ ⏩SD-WAN-Engineer Updated Test Cram[/url]
- Latest Reliable SD-WAN-Engineer Test Vce - Find Shortcut to Pass SD-WAN-Engineer Exam 🦨 Enter ➽ [url]www.practicevce.com 🢪 and search for ➠ SD-WAN-Engineer 🠰 to download for free 🏗New SD-WAN-Engineer Test Vce[/url]
- Professional Reliable SD-WAN-Engineer Test Vce - Perfect Test SD-WAN-Engineer Objectives Pdf: Palo Alto Networks SD-WAN Engineer ♣ ✔ [url]www.pdfvce.com ️✔️ is best website to obtain ➡ SD-WAN-Engineer ️⬅️ for free download 📦
df SD-WAN-Engineer Format[/url] - Free PDF SD-WAN-Engineer - Palo Alto Networks SD-WAN Engineer Newest Reliable Test Vce 🚐 Download 《 SD-WAN-Engineer 》 for free by simply searching on 《 [url]www.prepawayete.com 》 🧇Certificate SD-WAN-Engineer Exam[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, pianowithknight.com, mk.xyuanli.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, dkpacademy.in, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.alreemsedu.com, jszst.com.cn, Disposable vapes
