EXIN CDCS Latest Version & Valid CDCS Test Answers
Posted at 1/12/2026 16:29:37
View191
Replies3
What's more, part of that BraindumpsVCE CDCS dumps now are free: https://drive.google.com/open?id=1QlSkXDfUCk67m79QEupLi_7avcngjMKn
The quality of the CDCS exam product is very important. A high-quality CDCS exam study material can save your time spent on the study and can also enhance your confidence. Here, our EXIN CDCS exam vce dumps will be the right study material for you. CDCS Training Pdf cannot only help you pass your exam, but also widen your horizons. Then passing the CDCS exam test is a certain thing. Equipped with the skills of CDCS certification, you will have more opportunity in your career.
EXIN CDCS Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Designing and Implementing a Data Centre: In this module, the exam assesses the knowledge of Exin data center professionals tasked with the design and implementation of data centers. Candidates will learn the key principles of creating an efficient data center layout, including considerations for scalability, redundancy, and security.
| | Topic 2 | - Data Centre Life Cycle and Standards: This section of the exam measures the skills of data center professionals and covers the various stages involved in the life cycle of a data center, from planning and design to implementation and decommissioning.
| | Topic 3 | - Data Centre Environmental Considerations and Efficiency: This section evaluates the proficiency of data center professionals in addressing environmental factors and promoting efficiency within data center operations. The target audience, including data center managers and engineers, will be tested on their ability to identify and implement measures that enhance energy efficiency, cooling management, and sustainable practices.
Pass Guaranteed 2026 Newest CDCS: EXIN EPI Certified Data Centre Specialist Latest VersionReal CDCS questions in our PDF document can be viewed at any time from any place using your smartphone, tablet, and laptop. If you are busy and don't have time to sit and study for the EXIN EPI Certified Data Centre Specialist CDCS test, download and use EXIN CDCS PDF dumps on the go. To pass the EXIN CDCS exam, it is recommended that you simply use BraindumpsVCE CDCS real dumps for a few days.
EXIN EPI Certified Data Centre Specialist Sample Questions (Q64-Q69):NEW QUESTION # 64
What is needed to determine the Relative Humidity (RH)?
- A. Dry bulb temperature, wet bulb temperature, and psychrometric chart
- B. Dry bulb temperature, airflow, and conversion table
- C. Wet bulb temperature, local atmospheric pressure, and calculator
- D. Cold surface with dew collection counter
Relative Humidity (RH) is defined as the ratio of the actual water vapor content in the air to the maximum possible water vapor content at a given temperature. To calculate RH:
* Dry bulb temperature (DBT): the ambient air temperature.
* Wet bulb temperature (WBT): the temperature measured by a thermometer covered with a wet wick, influenced by evaporative cooling.
Using DBT and WBT, the humidity ratio and dew point can be determined with a psychrometric chart or Mollier diagram. From there, RH is calculated as:
A black text on a white background AI-generated content may be incorrect.
Options A and B are incomplete, while option C is an experimental method, not standard practice. The recognized method is option D.
References: ASHRAE Fundamentals Handbook - Psychrometrics, ISO 7726 (Measurement of Physical Quantities in Thermal Environments).
NEW QUESTION # 65
A data center requires an audit for ANSI/TIA-942 Rated-3 compliance. Will the network architecture be part of this audit?
- A. No, only the type of cabling used will be audited
- B. Yes, amongst other aspects the network architecture should be Rated-3 compliant with ANSI/TIA-942
- C. Yes, but only if network administration does not comply with ANSI/TIA-606
- D. No, as concurrent maintainability only applies to electrical and mechanical
ANSI/TIA-942 defines ratings across four areas:
* Architectural
* Electrical
* Mechanical
* Telecommunications (network cabling + architecture)
A data center cannot be considered Rated-3 unless all four areas meet the concurrent maintainability criteria.
For telecom/networking, this means dual redundant backbone cabling, proper pathways, and separate routes to ensure no single point of failure.
* A and B are incorrect because they limit scope to electrical/mechanical or cabling only.
* C is incomplete: administration (ANSI/TIA-606) is part of compliance but architecture redundancy is mandatory.
References: ANSI/TIA-942-B 5.2 (Rated Levels), Annex E (Telecommunications infrastructure examples).
NEW QUESTION # 66
An air-conditioner unit needs to be selected. Two types are available:
Unit-A has a Sensible Heat Ratio (SHR) of 0.7.
Unit-B has a Sensible Heat Ratio (SHR) of 0.9.
From an efficiency point of view, which one should be selected?
- A. Not relevant, as Sensible Heat Ratio is only specified for air-conditioner equipment to indicate the ratio between intake temperature and exhaust temperature.
- B. It does not matter, as the Sensible Heat Ratio has nothing to do with efficiency.
- C. Unit A
- D. Unit B
From an efficiency standpoint, Unit B with a Sensible Heat Ratio (SHR) of 0.9 is preferable. A higher SHR indicates that a greater proportion of the air conditioner's capacity is dedicated to sensible cooling (temperature reduction) rather than latent cooling (moisture removal). In data centers, sensible cooling is more critical since IT equipment primarily generates heat without adding significant moisture.
Detailed Explanation:
An SHR of 0.9 means that 90% of the cooling capacity is used for sensible cooling, which is more efficient for environments like data centers where humidity control is typically less of a concern. Opting for an air conditioner with a higher SHR ensures that most of the cooling energy is focused on temperature reduction, making Unit B more efficient in this scenario.
EPI Data Center Specialist References:
EPI data center best practices recommend choosing cooling units with higher SHR values in data centers, as they better match the cooling needs of IT equipment. High SHR units improve cooling efficiency by concentrating on sensible heat removal, which is vital for maintaining the optimal thermal environment.
NEW QUESTION # 67
You are working on the design of a new facility. The electrical riser of the building with high current power is located close to the area where sensitive IT equipment in the computer room will be located.
What should you recommend to reduce the amount of EMF coming from the electrical riser?
- A. Install single-phase power cabling
- B. Install three-phase power cabling based on three individual core wires
- C. Install bus bar trunking
- D. Install three-phase power cabling based on a combined cable (e.g. XLPE etc.)
To reduce Electromagnetic Fields (EMF) emanating from the electrical riser near sensitive IT equipment, three-phase power cabling in a combined cable (such as XLPE) is effective. Combined cabling helps reduce EMF by keeping the conductors tightly packed, which minimizes magnetic fields generated by current flow.
Cables like XLPE (cross-linked polyethylene) also offer better insulation, which helps mitigate EMF interference with nearby IT equipment.
Using a combined three-phase cable reduces EMF because the magnetic fields generated by each phase tend to cancel each other out when in close proximity. This arrangement helps reduce the overall magnetic field strength. In addition, XLPE and similar materials provide good insulation, making them a preferred choice for reducing EMF emissions around sensitive equipment.
EPI data center best practices recommend mitigating EMF interference through combined cabling arrangements, especially near areas where sensitive IT equipment is located. Reducing EMF is crucial to maintaining equipment reliability and ensuring compliance with safety standards.
NEW QUESTION # 68
What is a potential disadvantage of using a hypoxic-based fire suppression system as a fire extinguishing system?
- A. It can only be used in non-continuous occupied areas.
- B. The gas containers need to be close to the hazard area.
- C. It can only be used in computer rooms where you have sufficient positive pressure.
- D. It can only be used in computer rooms which have sufficient air changes per hour.
A hypoxic-based fire suppression system works by reducing the oxygen level in a room to below what is necessary to sustain combustion. This makes it effective in fire prevention, but it is not suitable for continuous occupancy by personnel. Low oxygen levels can cause discomfort or even health risks for people spending extended periods in the space. Therefore, these systems are typically deployed in areas where continuous human occupancy is not required, such as storage rooms or data halls with limited personnel access.
Hypoxic fire suppression systems lower oxygen levels to around 15-16%, which is safe for short periods but not sustainable for continuous occupancy without risk to health. Data center environments where staff need to spend long periods monitoring and maintaining equipment would need alternative systems, like gas-based suppression that allows for safe evacuation rather than oxygen reduction.
The EPI Data Center Specialist curriculum emphasizes that fire suppression systems must be chosen based on occupancy requirements. Hypoxic systems are specifically noted as unsuitable for spaces requiring continuous human presence due to the low oxygen environment they create.
NEW QUESTION # 69
Time is valued especially when we are all caught up with plans and still step with the handy matters. If you suffer from procrastination and cannot make full use of your sporadic time during your learning process, it is an ideal way to choose our CDCS training materials. We can guarantee that you are able not only to enjoy the pleasure of study but also obtain your CDCS Certification successfully. You will have a full understanding about our CDCS guide torrent after you have a try on our CDCS exam questions.
Valid CDCS Test Answers: https://www.braindumpsvce.com/CDCS_exam-dumps-torrent.html
- New CDCS Mock Test 🧓 CDCS PDF 🆎 CDCS New Braindumps Book 🆚 Search for CDCS and download it for free immediately on ▷ [url]www.prep4away.com ◁ 🔗CDCS Online Bootcamps[/url]
- Realistic CDCS Latest Version - Passing CDCS Exam is No More a Challenging Task ⏺ The page for free download of ⮆ CDCS ⮄ on ⮆ [url]www.pdfvce.com ⮄ will open immediately 😦Exam CDCS Price[/url]
- Test CDCS Questions Vce 🕞 CDCS Certification Exam Cost 💜 Passing CDCS Score ✔️ Go to website { [url]www.pdfdumps.com } open and search for [ CDCS ] to download for free 🐼CDCS Exam Overview[/url]
- CDCS Valid Test Book 🎬 CDCS PDF 🤯 Exam CDCS Cost 🏎 Open website { [url]www.pdfvce.com } and search for CDCS for free download ⛴CDCS Online Bootcamps[/url]
- Reliable CDCS Guide Files 🏤 CDCS Free Sample 🦡 CDCS Free Sample 🙄 Easily obtain free download of ⮆ CDCS ⮄ by searching on ✔ [url]www.prepawaypdf.com ️✔️ 🕧Exam CDCS Price[/url]
- Pdfvce EXIN CDCS Free Dumps Demo Download Facility 🍌 Search for ➽ CDCS 🢪 and download it for free immediately on ⏩ [url]www.pdfvce.com ⏪ 🚂Reliable CDCS Guide Files[/url]
- Easily Get EXIN CDCS Certification 🧼 Search for ☀ CDCS ️☀️ on ▶ [url]www.prepawaypdf.com ◀ immediately to obtain a free download ⤵CDCS Certification Exam Cost[/url]
- CDCS Test Torrent 🚇 Latest CDCS Exam Book 🤑 CDCS Certification Exam Cost 🧲 Open website ⏩ [url]www.pdfvce.com ⏪ and search for ➥ CDCS 🡄 for free download 🏹Latest CDCS Braindumps Files[/url]
- CDCS PDF 🔮 Passing CDCS Score 📣 Test CDCS Questions Vce 🔵 Open website [ [url]www.prepawayexam.com ] and search for ➤ CDCS ⮘ for free download 🏐CDCS Online Bootcamps[/url]
- 100% Pass Quiz EXIN - The Best CDCS Latest Version 🍛 ➠ [url]www.pdfvce.com 🠰 is best website to obtain ➠ CDCS 🠰 for free download 🦢CDCS Exam Overview[/url]
- www.prep4sures.top EXIN CDCS Free Dumps Demo Download Facility 🥴 The page for free download of ⏩ CDCS ⏪ on [url]www.prep4sures.top will open immediately 💏Test CDCS Objectives Pdf[/url]
- www.stes.tyc.edu.tw, myspace.com, yetis.agenceyeti.fr, conceptplusacademy.com, pastebin.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.pcsq28.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, giphy.com, Disposable vapes
