Android
Jack server error for AIO-Rk3399 Android 7.1 Build
Posted at 5/28/2022 14:03:10
View3933
Replies5
Hi,
I am using AIO-RK3399 Android 7.1 Build on Ubuntu 18.04
UBuntu -
Linux 5.4.0-113-generic #127~18.04.1-Ubuntu SMP Wed May 18 15:40:23 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
While compiling Android 7.1 on AIO-RK3399J I faced below error -
[ 24% 10189/41233] host C++: libartd <= art/runtime/native/java_lang_reflect_Field.cc
[ 24% 10190/41233] host C++: libartd <= art/runtime/native/java_lang_reflect_AbstractMethod.cc
[ 24% 10191/41233] host C++: libartd <= art/runtime/native/java_lang_reflect_Method.cc
[ 24% 10192/41233] host C++: libartd <= art/runtime/oat.cc
[ 24% 10193/41233] host C++: libartd <= art/runtime/native/java_lang_reflect_Proxy.cc
[ 24% 10194/41233] host C++: libartd <= art/runtime/native/java_lang_reflect_Constructor.cc
[ 24% 10195/41233] host C++: libartd <= art/runtime/native/org_apache_harmony_dalvik_ddmc_DdmVmInternal.cc
[ 24% 10196/41233] Ensure Jack server is installed and started
FAILED: /bin/bash -c "(prebuilts/sdk/tools/jack-admin install-server prebuilts/sdk/tools/jack-launcher.jar prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 2>&1 || (exit 0) ) && (JACK_SERVER_VM_ARGUMENTS=\"-Dfile.encoding=UTF-8 -XX:+TieredCompilation\" prebuilts/sdk/tools/jack-admin start-server 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update server prebuilts/sdk/tools/jack-server-4.8.ALPHA.jar 4.8.ALPHA 2>&1 || exit 0 ) && (prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-2.28.RELEASE.jar 2.28.RELEASE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-3.36.CANDIDATE.jar 3.36.CANDIDATE || exit 47; prebuilts/sdk/tools/jack-admin update jack prebuilts/sdk/tools/jacks/jack-4.7.BETA.jar 4.7.BETA || exit 47 )"
Writing client settings in /home/Maneesh/.jack-settings
Installing jack server in "/home/Maneesh/.jack-server"
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using "keytool -importkeystore -srckeystore /home/Maneesh/.jack-server/server.jks -destkeystore /home/Maneesh/.jack-server/server.jks -deststoretype pkcs12".
Warning:
The JKS keystore uses a proprietary format. It is recommended to migrate to PKCS12 which is an industry standard format using "keytool -importkeystore -srckeystore /home/Maneesh/.jack-server/client.jks -destkeystore /home/Maneesh/.jack-server/client.jks -deststoretype pkcs12".
Launching Jack server java -XX:MaxJavaStackTraceDepth=-1 -Djava.io.tmpdir=/tmp -Dfile.encoding=UTF-8 -XX:+TieredCompilation -cp /home/Maneesh/.jack-server/launcher.jar com.android.jack.launcher.ServerLauncher
Jack server failed to (re)start, try 'jack-diagnose' or see Jack server log
SSL error when connecting to the Jack server. Try 'jack-diagnose'
[ 24% 10196/41233] host C++: libartd <= art/runtime/native/org_apache_harmony_dalvik_ddmc_DdmServer.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/native/sun_misc_Unsafe.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/object_lock.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/verifier/register_line.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/oat_file_assistant.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/oat_file.cc
[ 24% 10196/41233] host C++: libartd <= art/runtime/oat_file_manager.cc
ninja: build stopped: subcommand failed.
build/core/ninja.mk:148: recipe for target 'ninja_wrapper' failed
make: *** [ninja_wrapper] Error 1 |
