JN0-481 Exam Demo, JN0-481 Best Study Material
Posted at 1/12/2026 17:20:08
P.S. Free & New JN0-481 dumps are available on Google Drive shared by Exams4sures: https://drive.google.com/open?id=1UbdiFw14fVAypSf1za4RqxaB8e_7zbp4
To buy after trial! Our Exams4sures is responsible for every customer. We provide for you free demo of JN0-481 exam software to let you rest assured to buy after you have experienced it. And we have confidence to guarantee that you will not regret to buy our JN0-481 Exam simulation software, because you feel it's reliability after you have used it; you can also get more confident in JN0-481 exam.
Achieving success in the Juniper JN0-481 certification exam opens doors to lucrative job opportunities and career advancements. The Data Center, Specialist (JNCIS-DC) (JN0-481) credential is highly valuable in today's industry. However, many candidates face the frustration of exam failure and wasted time and resources by relying on outdated Juniper JN0-481 Practice Questions. To save both time and money, it is crucial to prepare with the most up-to-date and reliable JN0-481 exam questions.
JN0-481 Best Study Material, JN0-481 Reliable Learning MaterialsOur Data Center, Specialist (JNCIS-DC) test torrent was designed by a lot of experts in different area. You will never worry about the quality and pass rate of our study materials, it has been helped thousands of candidates pass their exam successful and helped them find a good job. If you choose our JN0-481 study torrent, we can promise that you will not miss any focus about your exam. There are three different versions to meet customers’ needs you can choose the version that is suitable for you to study. If you buy our Data Center, Specialist (JNCIS-DC) test torrent, you will have the opportunity to make good use of your scattered time to learn whether you are at home, in the company, at school, or at a metro station.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q53-Q58):NEW QUESTION # 53
Which statement about Juniper Apstra role-based access control is correct?
- A. The user role can create roles.
- B. The administrator role is the only predefined role.
- C. The administrator role can see all permissions.
- D. The viewer role is predefined and can be deleted.
Juniper Apstra role-based access control (RBAC) is a feature that allows you to specify access permissions for different users based on their roles. RBAC servers are remote network servers that authenticate and authorize network access based on roles assigned to individual users within an enterprise. Juniper Apstra has four predefined user roles: administrator, device_ztp, user, and viewer. The administrator role is the most powerful role, and it can see all permissions and perform all actions in the Apstra software application. The administrator role can also create, clone, edit, and delete user roles, except for the four predefined user roles, which cannot be modified. Therefore, the statement that the administrator role can see all permissions is correct.
NEW QUESTION # 54
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Lead and Leat6 using the same virtual network identifier (VNI). Which two statements are correct in this scenario? (Choose two.)
- A. The underlay must be provisioned with PIMv2.
- B. The underlay must use IRB interfaces.
- C. The underlay EBGP peering's must be established between leaf and spine devices.
- D. Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices.
In the EVPN-VXLAN data center fabric bridged overlay architecture shown in the exhibit, the servers are connected to Leaf1 and Leaf6 using the same virtual network identifier (VNI). This means that the servers belong to the same Layer 2 domain and can communicate with each other using VXLAN tunnels across the fabric. The underlay network provides the IP connectivity between the leaf and spine devices, and it uses EBGP as the routing protocol. Therefore, the following two statements are correct in this scenario:
Loopback IPv4 addresses must be advertised into the EBGP underlay from leaf and spine devices. This is because the loopback addresses are used as the source and destination IP addresses for the VXLAN tunnels, and they must be reachable by all the devices in the fabric.
The loopback addresses are also used as the router IDs and the BGP peer addresses for the EBGP sessions.
The underlay EBGP peering's must be established between leaf and spine devices. This is because the EBGP sessions are used to exchange the underlay routing information and the EVPN routes for the overlay network. The EBGP sessions are established using the loopback addresses of the devices, and they follow a spine-and-leaf topology, where each leaf device peers with all the spine devices, and each spine device peers with all the leaf devices.
NEW QUESTION # 55
Referring to the exhibit, what needs to change in the IP fabric to make it a valid IP fabric?
- A. The connection between the two spine nodes must be increased to 40 Gbps.
- B. The IP fabric connections must be increased to a speed greater than 10 Gbps.
- C. The connection between the two spine nodes must be removed.
- D. The IP fabric must consist of only one device model throughout the fabric.
To make the IP fabric a valid IP fabric, the connection between the two spine nodes must be removed. This is because an IP fabric is a network topology that uses a spine-leaf architecture, where the spine devices are only connected to the leaf devices, and the leaf devices are only connected to the spine devices. This creates a non-blocking, high-performance, and scalable network that supports Layer 3 routing protocols such as BGP or OSPF. The connection between the two spine nodes in the exhibit violates the spine-leaf design principle and introduces unnecessary complexity and potential loops in the network.
NEW QUESTION # 56
In the Juniper Apstra design phase, which object dictates port count, port speed, and how the ports would be used?
- A. logical devices
- B. rack type
- C. network devices
- D. interface map
Interface maps are objects that map interfaces between logical devices and physical hardware devices in the Juniper Apstra design phase. They dictate port count, port speed, and how the ports would be used for achieving the intended network configuration rendering. Interface maps also allow you to select device ports, transformations, and interfaces, provision breakout ports, and disable unused ports.
NEW QUESTION # 57
In the Juniper Apstra Ul, which three resources are assigned under the Resources menu?
(Choose three.)
- A. logical device pools
- B. VTEP pools
- C. IP address pools
- D. ASN pools
- E. VNI pools
Answer: C,D,E
In the Juniper Apstra UI, the Resources menu allows you to create and manage global and local resources that are used for various elements of the network design and configuration. The Resources menu includes the following three types of resources that can be assigned to the network devices and virtual networks:
ASN pools: These are pools of autonomous system numbers (ASNs) that are used for the underlay routing protocol (EBGP) between the leaf and spine devices. You can create ASN pools with either 2-byte or 4-byte ASNs, and assign them to the logical devices in the blueprint. VNI pools: These are pools of virtual network identifiers (VNIs) that are used for the overlay network (VXLAN) between the end hosts. You can create VNI pools with a range of VNIs, and assign them to the virtual networks in the blueprint.
IP address pools: These are pools of IPv4 or IPv6 addresses that are used for various purposes in the network, such as the loopback addresses for the devices, the IP prefixes for the virtual networks, the host IP addresses for the end hosts, and the gateway IP addresses for the IRB interfaces. You can create IP address pools with a range of IP addresses, and assign them to the logical devices and virtual networks in the blueprint.
The following two types of resources are not assigned under the Resources menu:
VTEP pools: These are not resources that can be created or assigned by the user. VTEPs are VXLAN tunnel endpoints that are automatically generated by the Apstra server based on the loopback IP addresses of the devices. VTEPs are used as the source and destination IP addresses for the VXLAN tunnels in the overlay network.
Logical device pools: These are not resources that can be created or assigned by the user.
Logical device pools are groups of logical devices that share the same role, interface map, and resource assignments in the blueprint. Logical device pools are used to simplify the network design and configuration by applying the same settings to multiple devices.
NEW QUESTION # 58
Exams4sures's Juniper JN0-481 Exam Training materials is virtually risk-free for you at the time of purchase. Before you buy, you can enter Exams4sures website to download the free part of the exam questions and answers as a trial. So you can see the quality of the exam materials and we Exams4suresis friendly web interface. We also offer a year of free updates. If you do not pass the exam, we will refund the full cost to you. We absolutely protect the interests of consumers. Training materials provided by Exams4sures are very practical, and they are absolutely right for you. We can make you have a financial windfall.
JN0-481 Best Study Material: https://www.exams4sures.com/Juniper/JN0-481-practice-exam-dumps.html
If you are satisfied with the demo so, you can buy JN0-481 exam questions PDF or Practice software, So far, we have helped lots of candidates get success by using our valid and accurate JN0-481 latest VCE collection, No only that you will pass your JN0-481 exam for sure, according you will get the certificate, but also you will get more chances to have better jobs and higher salaries, They work together and put all their efforts and ensure the top standard of Exams4sures Data Center, Specialist (JNCIS-DC) (JN0-481) exam dumps all the time.
It is an excellent book, Let's consider all JN0-481 these questions in sequence to start you on your way through this book, knowing your goal and the road to it, If you are satisfied with the demo so, you can buy JN0-481 Exam Questions Pdf or Practice software.
Juniper JN0-481 Exam Questions - Pass With Confidence!So far, we have helped lots of candidates get success by using our valid and accurate JN0-481 latest VCE collection, No only that you will pass your JN0-481 exam for sure, according you will get the certificate, but also you will get more chances to have better jobs and higher salaries.
They work together and put all their efforts and ensure the top standard of Exams4sures Data Center, Specialist (JNCIS-DC) (JN0-481) exam dumps all the time, One major difference which makes the Juniper JN0-481 exam dumps different from others is that the exam questions are updated after feedback from more than 90,000 professionals and experts around the globe.
- Pass Guaranteed 2026 JN0-481: Valid Data Center, Specialist (JNCIS-DC) Exam Demo 💞 Search on ▛ [url]www.prepawayete.com ▟ for ( JN0-481 ) to obtain exam materials for free download 🐯Real JN0-481 Testing Environment[/url]
- Latest JN0-481 Exam Review 🐋 Upgrade JN0-481 Dumps 😕 JN0-481 Reliable Exam Papers 🧝 Open website ▛ [url]www.pdfvce.com ▟ and search for ☀ JN0-481 ️☀️ for free download 🔼Test JN0-481 Score Report[/url]
- Pass-Sure JN0-481 Exam Demo Offers Candidates Reliable Actual Juniper Data Center, Specialist (JNCIS-DC) Exam Products 🌖 Go to website ( [url]www.exam4labs.com ) open and search for ➤ JN0-481 ⮘ to download for free 🐻Test JN0-481 Score Report[/url]
- JN0-481 Test Registration 🏌 JN0-481 PDF 🥌 Test JN0-481 Score Report 🕘 Search for 《 JN0-481 》 and easily obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 🌲JN0-481 Reliable Exam Papers[/url]
- www.easy4engine.com Study Guide Helps You Master All the Topics on the JN0-481 Exam 🦱 Search for ⇛ JN0-481 ⇚ and download it for free immediately on [ [url]www.easy4engine.com ] 🐖JN0-481 Reliable Exam Papers[/url]
- JN0-481 Test Registration 🆕 Real JN0-481 Testing Environment ↩ Test JN0-481 Sample Online 🍭 Search for ☀ JN0-481 ️☀️ and download it for free immediately on ( [url]www.pdfvce.com ) ⤵Real JN0-481 Testing Environment[/url]
- Pass Guaranteed 2026 JN0-481: Valid Data Center, Specialist (JNCIS-DC) Exam Demo 🕍 Immediately open ➤ [url]www.verifieddumps.com ⮘ and search for ▷ JN0-481 ◁ to obtain a free download ☝JN0-481 Test Questions[/url]
- Pass Guaranteed 2026 Juniper JN0-481: Efficient Data Center, Specialist (JNCIS-DC) Exam Demo 💗 Search for ✔ JN0-481 ️✔️ on 《 [url]www.pdfvce.com 》 immediately to obtain a free download 🏍Upgrade JN0-481 Dumps[/url]
- JN0-481 Valid Test Voucher 🛢 Test JN0-481 Objectives Pdf ⛹ JN0-481 Valid Exam Notes 🖕 Simply search for ⮆ JN0-481 ⮄ for free download on ⮆ [url]www.pass4test.com ⮄ 🎨JN0-481 Brain Dump Free[/url]
- Pdfvce Study Guide Helps You Master All the Topics on the JN0-481 Exam 🚁 Open ✔ [url]www.pdfvce.com ️✔️ and search for ⇛ JN0-481 ⇚ to download exam materials for free 💬JN0-481 Valid Test Voucher[/url]
- Pass-Sure JN0-481 Exam Demo Offers Candidates Reliable Actual Juniper Data Center, Specialist (JNCIS-DC) Exam Products 🪁 Open website ☀ [url]www.prepawayete.com ️☀️ and search for 《 JN0-481 》 for free download ⛵Latest JN0-481 Exam Simulator[/url]
- www.hulkshare.com, bbs.t-firefly.com, printertech.xyz, www.hulkshare.com, bbs.t-firefly.com, eduberrys.com, whatoplay.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, building.lv, Disposable vapes
2026 Latest Exams4sures JN0-481 PDF Dumps and JN0-481 Exam Engine Free Share: https://drive.google.com/open?id=1UbdiFw14fVAypSf1za4RqxaB8e_7zbp4
