[General] AWS-Solutions-Associate Vce Exam - Reliable AWS-Solutions-Associate Test Pass4su
49
General AWS-Solutions-Associate Vce Exam - Reliable AWS-Solutions-Associate Test Pass4su
Posted at 1/12/2026 20:29:17      View170 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Amazon AWS-Solutions-Associate dumps are available on Google Drive shared by DumpStillValid: https://drive.google.com/open?id=1AFVK-9mS-XK7aImHU1vqNJsBXXcEQd5x
Sometime, most candidates have to attend an exam, they may feel nervious and don't know what to do. If you happen to be one of them, our AWS-Solutions-Associate learning materials will greatly reduce your burden and improve your possibility of passing the exam. Our advantages of time-saving and efficient can make you no longer be afraid of the AWS-Solutions-Associate Exam, and you will find more about the benefits of our AWS-Solutions-Associate exam questions later on.
The AWS Certified Solutions Architect - Associate (SAA-C02) exam is a highly respected certification in the IT industry, and passing the exam can lead to better job opportunities and higher salaries. AWS-Solutions-Associate Exam is challenging and requires a solid understanding of AWS services and solutions, as well as hands-on experience in building and deploying cloud architectures on AWS. With the increasing demand for cloud solutions, becoming an AWS Certified Solutions Architect can be a wise investment for IT professionals looking to advance their careers.
Amazon Web Services (AWS) is a cloud computing platform that provides a wide range of services and tools for businesses and organizations of all sizes. The AWS Certified Solutions Architect - Associate (SAA-C02) exam covers a variety of topics, including AWS architecture, AWS services, security, and deployment. Candidates must possess a strong understanding of AWS services and infrastructure, as well as experience designing and deploying scalable, highly available, and fault-tolerant systems.
Reliable Amazon AWS-Solutions-Associate Test Pass4sure & AWS-Solutions-Associate Certification Exam InforWe provide a guarantee on all of our AWS-Solutions-Associate test products, and you will be able to get your money back if we fail to deliver the results as advertised. We provide 100% money back guarantee for all of us AWS-Solutions-Associate test questions products, and we are always available to provide you top notch support and new AWS-Solutions-Associate Questions. If you are facing issues in downloading the AWS-Solutions-Associate study guides, then all you have to do is to contact our support professional, and they will be able to help you out with AWS-Solutions-Associate answers.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q20-Q25):NEW QUESTION # 20
A company is hosting a web application on AWS using a single Amazon EC2 instance that stores user-uploaded documents in an Amazon EBS volume For better scalability and availability the company duplicated the architecture and created a second EC2 instance and EBS volume in another Availability Zone:
placing both behind an Application Load Balancer After completing this change users reported that each time they refreshed the website they could see one subset of their documents or the other but never all of the documents at the same time What should a solutions architect propose to ensure users see all of their documents at once?
  • A. Configure the Application Load Balancer to direct a user to the server with the documents
  • B. Copy the data so both EBS volumes contain all the documents
  • C. Configure the Application Load Balancer to send the request to both servers Return each document from the correct server
  • D. Copy the data from both EBS volumes to Amazon EFS Modify the application to save new documents to Amazon EFS
https://docs.aws.amazon.com/efs/ ... ml#how-it-works-ec2 Amazon EFS provides file storage in the AWS Cloud. With Amazon EFS, you can create a file system, mount the file system on an Amazon EC2 instance, and then read and write data to and from your file system. You can mount an Amazon EFS file system in your VPC, through the Network File System versions 4.0 and 4.1 (NFSv4) protocol. We recommend using a current generation Linux NFSv4.1 client, such as those found in the latest Amazon Linux, Redhat, and Ubuntu AMIs, in conjunction with the Amazon EFS Mount Helper. For instructions, see Using the amazon-efs-utils Tools.
For a list of Amazon EC2 Linux Amazon Machine Images (AMIs) that support this protocol, see NFS Support. For some AMIs, you'll need to install an NFS client to mount your file system on your Amazon EC2 instance. For instructions, see Installing the NFS Client.
You can access your Amazon EFS file system concurrently from multiple NFS clients, so applications that scale beyond a single connection can access a file system. Amazon EC2 instances running in multiple Availability Zones within the same AWS Region can access the file system, so that many users can access and share a common data source.
How Amazon EFS Works with Amazon EC2
NEW QUESTION # 21
A company runs a legacy application with a single-tier architecture on an Amazon EC2 Instance. Disk I/O is low, with occasional small spikes during business hours. The company requires the instance to be stopped from 8 PM to 8 AM daily.
Which storage option is MOST appropriate for this workload?
  • A. Amazon EC2 instance storage
  • B. Amazon EBS General Purpose SSD (gp2) storage
  • C. Amazon EBS Provision IOPS SSD (io1) storage
  • D. Amazon S3
NEW QUESTION # 22
A company uses Amazon Redshift to store structured data and Amazon S3 to store unstructured data. The company wants to analyze the stored data and create business intelligence reports. The company needs a data visualization solution that is compatible with Amazon Redshift and Amazon S3.
Which solution will meet these requirements?
  • A. Use Amazon OpenSearch Service to analyze data stored in Amazon Redshift and Amazon S3. Use Amazon Managed Grafana to access OpenSearch Service, visualize the data analyses, and create business intelligence reports.
  • B. Use Amazon Redshift Serverless to analyze data stored in Amazon Redshift. Use Amazon S3 Object Lambda to analyze data stored in Amazon S3. Use Amazon Managed Grafana to access Amazon Redshift and Object Lambda, visualize the data analyses, and create business intelligence reports.
  • C. Use Amazon Redshift Spectrum to analyze data stored in Amazon Redshift. Use Amazon Athena to analyze data stored in Amazon S3. Use Amazon QuickSight to access Amazon Redshift and Athena, visualize the data analyses, and create business intelligence reports.
  • D. Use Amazon Redshift query editor v2 to analyze data stored in Amazon Redshift. Use Amazon Athena to analyze data stored in Amazon S3. Use Amazon QuickSight to access Amazon Redshift and Athena, visualize the data analyses, and create business intelligence reports.
This solution leverages:
Amazon Redshift Spectrum to query S3 data directly from Redshift.
Amazon Athena for ad-hoc analysis of S3 data.
Amazon QuickSight for unified visualization from multiple data sources.
"Redshift Spectrum enables you to run queries against exabytes of data in Amazon S3 without having to load or transform the data."
"QuickSight supports both Amazon Redshift and Amazon Athena as data sources."
- Redshift Spectrum
- Amazon QuickSight Supported Data Sources
This architecture allows scalable querying and visualization with minimum ETL overhead, ideal for BI dashboards.
Incorrect Options:
A: The query editor is not a BI tool.
B, D: Grafana is better for time-series data, not structured analytics or BI reports.
Redshift Spectrum
Amazon QuickSight Integration
NEW QUESTION # 23
A shipping company wants to run a Kubernetes container-based web application in disconnected mode while the company's ships are in transit at sea. The application must provide local users with high availability.
  • A. Use AWS Snowball Edge as the primary site, and use an AWS Local Zone as the secondary site.
  • B. Use AWS Snowball Edge as the primary site, and use an AWS Outposts server as the secondary site.
  • C. Use AWS Snowball Edge as the primary site, and use an AWS Wavelength Zone as the secondary site.
  • D. Use AWS Snowball Edge as the primary and secondary sites.
When operating in disconnected or limited-connectivity environments, such as ships at sea, AWS recommends using AWS Snowball Edge devices to host local compute and storage workloads. Snowball Edge supports Amazon EC2 instances and AWS IoT Greengrass, and can run Amazon EKS Anywhere for local Kubernetes cluster deployments.
From AWS Documentation:
"You can use AWS Snowball Edge devices to run compute-intensive applications in remote or disconnected locations. Snowball Edge devices support running Amazon EC2 instances and Amazon EKS Anywhere clusters." (Source: AWS Snow Family - Developer Guide) Why A is correct:
Snowball Edge provides local compute and storage even without internet connectivity.
Multiple Snowball Edge devices can be clustered together for high availability and failover.
Fully self-contained environment suitable for ships or field operations.
Why the others are incorrect:
B, C, D require network connectivity to AWS Regions or Zones (Local Zone, Outposts, Wavelength), which is not available at sea. These options cannot operate fully disconnected.
AWS Snow Family Developer Guide - "Running Compute Applications on AWS Snowball Edge" AWS Well-Architected Framework - Resilience Pillar AWS Architecture Blog - "Edge Computing with Snow Family"
NEW QUESTION # 24
True or False: Common points of failures like generators and cooling equipment are shared across Availability Zones.
  • A. FALSE
  • B. TRUE
NEW QUESTION # 25
We all know that it is not easy to prepare the AWS-Solutions-Associate exam; there are thousands of candidates to compete with you. So it is a fierce competition. If you want to win out in the exam, you need the professional study materials to guide you. Our AWS-Solutions-Associate Study Materials are confident to ensure that you will acquire the certificate. And the pass rate of our AWS-Solutions-Associate practice guide is high to 98% to 100%.
Reliable AWS-Solutions-Associate Test Pass4sure: https://www.dumpstillvalid.com/AWS-Solutions-Associate-prep4sure-review.html
DOWNLOAD the newest DumpStillValid AWS-Solutions-Associate PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1AFVK-9mS-XK7aImHU1vqNJsBXXcEQd5x
