[Linux] Can not Sync Code while Build the build environment
46
Linux Can not Sync Code while Build the build environment
Posted at 7/1/2022 22:19:59      View2584 | Replies4        Print      Only Author   [Copy Link] 1#
Hello,
im trying Build the build environment for Linux for mb-jm3-rk3568 motheroard with core board Core-3568
I use this link
https://wiki.t-firefly.com/en/Co ... _compile_linux.html
But i get error  while making repo sync:
.repo/repo/repo sync -l
error: in `sync -l`: revision refs/tags/rk356x/linux_release_v1.2.4a in device/rockchip not found
can you help me with that ?
Posted at 7/4/2022 10:28:07        Only Author  2#
Just execute `.repo/repo/repo sync -c --no-tags` directly.
Posted at 7/4/2022 20:35:56        Only Author  3#
ʱĺ Posted at 7/4/2022 10:28
Thank you a lot, it helped ! Can you change official document in this part ?
Posted at 7/5/2022 11:14:55        Only Author  4#
Maverick_by Posted at 7/4/2022 20:35
Thanks for your feedback, the document has been adjusted.
Posted at 1/22/2026 06:08:53        Only Author  5#
I am so grateful for your share, the article is amazing! The Valid test CIS-CSM passing score resources are top-quality and free to use.
