1Z0-1123-25考試內容,1Z0-1123-25證照信息
Posted at 1/12/2026 22:02:19
言與行的距離到底有多遠?關鍵看人心,倘使心神明淨,意志堅強,則近在咫尺,垂手可及 。我想你應該就是這樣的人吧。既然選擇了要通過Oracle的1Z0-1123-25認證考試,當然就得必須通過,Fast2test Oracle的1Z0-1123-25考試培訓資料是幫助通過考試的最佳選擇,也是表現你意志堅強的一種方式,Fast2test網站提供的培訓資料在互聯網上那是獨一無二的品質好,如果你想要通過Oracle的1Z0-1123-25考試認證,就購買Fast2test Oracle的1Z0-1123-25考試培訓資料。
Fast2test為每個需要通過Oracle的1Z0-1123-25考試認證的考生提供了一個明確和卓越的解決方案,我們為你提供Oracle的1Z0-1123-25考試詳細的問題及答案, 我們團隊的IT專家是最有經驗和資格的,我們的考試測試題及答案幾乎和真實得考試一樣,做到這樣的確很了不起,更重要的是我們Fast2test網站在全球範圍內執行這項考試培訓通過率最大。
1Z0-1123-25證照信息 & 1Z0-1123-25測試題庫將Fast2test的產品加入購物車吧!你將以100%的信心去參加考試,一次性通過Oracle 1Z0-1123-25 認證考試,你將不會後悔你的選擇的。
Oracle 1Z0-1123-25 考試大綱:| 主題 | 簡介 | | 主題 1 | - Migrate Oracle Databases to OCI Database Services: This section tests the knowledge of Database Migration Specialists in planning and executing successful database migrations to OCI. It covers database migration strategies, different OCI database services, and the available methods for transferring databases to the cloud. Candidates will learn how to analyze existing database workloads and select the most efficient migration approach for maintaining data integrity and performance.
| | 主題 2 | - Migrate Infrastructure Workloads Between OCI Regions: This section assesses the skills of Cloud Operations Engineers in managing workload replication across OCI regions. It covers OCI Object Storage Replication, Block Volume Replication, and File System Replication to ensure business continuity. Additionally, candidates will learn how to design and implement full-stack disaster recovery strategies using OCI Full Stack Disaster Recovery Service to minimize downtime and data loss.
| | 主題 3 | - Fundamentals of Cloud Migrations: This section of the exam measures the skills of Cloud Migration Engineers in understanding the core principles of cloud migrations. It covers the key drivers behind cloud adoption, the benefits of moving to Oracle Cloud Infrastructure (OCI), and the challenges businesses may face during migration. Candidates will gain insights into the different migration strategies and methodologies used to ensure seamless transitions from on-premises environments to the cloud.
| | 主題 4 | - OCI Networking Services for Migrations: This section evaluates the knowledge of Cloud Network Architects in utilizing OCI networking services for cloud migrations. It covers the fundamentals of OCI networking, including Virtual Cloud Networks (VCN), subnets, gateways, and connectivity options. The focus is on ensuring secure and optimized networking configurations that support smooth data migration and integration between on-premises and OCI environments.
最新的 Oracle Cloud Infrastructure 1Z0-1123-25 免費考試真題 (Q20-Q25):問題 #20
Which resource type would you create in Full Stack Disaster Recovery (FSDR) to represent a consistency grouping of Oracle Cloud Infrastructure (OCI) resources for disaster recovery purposes?
- A. Disaster Recovery Protection Group
- B. Disaster Recovery Plan
- C. Disaster Recovery Instance
- D. Disaster Recovery Policy
答案:A
解題說明:
In Full Stack Disaster Recovery (FSDR), a Disaster Recovery Protection Group is the resource type used to represent a consistency grouping of OCI resources for disaster recovery purposes.
問題 #21
Which statement describes the transferring phase in the Delta Cycle of Oracle Cloud Infrastructure (OCI) File System replication?
- A. The replication process remains idle without capturing or applying data
- B. It focuses solely on capturing differentiated data in the source snapshot
- C. Data is committed to the target file system during this phase
- D. The replication captures as well as commits snapshot data
答案:D
解題說明:
The transferring phase in the Delta Cycle of OCI File System replication involves capturing and committing snapshot data from the source to the target file system. This ensures that the changes in the source snapshot are replicated accurately to the target.
問題 #22
A company is assessing different strategies for migrating their applications from on-premises to Oracle Cloud Infrastructure. The applications are running on virtual machines, and a business requirement has been raised to containerize all applications within the OCI environment as part of the migration process. Which migration strategy fits well with this requirement?
- A. Migrate VMs to OCI Container Engine for Kubernetes (OKE)
- B. Migrate VMs to a native OCI Compute instance
- C. Migrate VMs to Oracle Cloud VMware Solution (OCVS)
- D. Migrate VMs to a Software-as-a-Service solution in OCI
答案:A
解題說明:
Migrating VMs to OCI Container Engine for Kubernetes (OKE) is the most suitable strategy for containerizing applications within the OCI environment. OKE is a managed Kubernetes service that allows for the deployment, management, and scaling of containerized applications on OCI.
問題 #23
Your company wants to expand its cloud infrastructure footprint by adopting Oracle Cloud VMware Solution (OCVS). The OCVS Software Defined Data Center (SDDC) platform will be dedicated to hosting business-critical workloads and should avoid single points of failure within its architecture. Which two would be considered while setting up the solution?
- A. vSphere Distributed Resource Scheduler (DRS)
- B. HCX Mobility Groups
- C. OCI Fault Domain
- D. vSAN Fault Domain
答案:C,D
解題說明:
OCI Fault Domains and vSAN Fault Domains are critical considerations to avoid single points of failure and ensure high availability for business-critical workloads hosted on the OCVS SDDC platform.
問題 #24
Your company is planning to migrate on-premises workloads to Oracle Cloud Infrastructure (OCI). As a migration cloud architect, you are considering Oracle Cloud Migrations service for this initiative. Which two are core features of Oracle Cloud Migrations service?
- A. Transfer large volumes of data through a storage appliance
- B. Automatic containerization of Virtual Machines to Oracle Container Engine for Kubernetes (OKE)
- C. Provide detailed application topology to choose the target OCI Region
- D. Group and organize discovered workloads to represent applications & lines of business
- E. Estimate the cost to run the migrated workloads in the OCI environment
答案:D,E
解題說明:
Estimating the cost to run the migrated workloads in the OCI environment and grouping and organizing discovered workloads to represent applications & lines of business are core features of the Oracle Cloud Migrations service.
問題 #25
Fast2test 考題網覆蓋了真實的 1Z0-1123-25 考試指南,並根據其編定適合全球考生都能通用的 1Z0-1123-25 題庫,讓每一位考生都能順利通過 Oracle 1Z0-1123-25 考試。我們承諾使用 1Z0-1123-25 考題的考生可以一次通過相關認證考試,對于一次不過的全額退款,避免您的後顧之憂。你現在就可以去網上可以免費下載我們提供的部分關於 Oracle 1Z0-1123-25 題庫的模擬測試題和答案作為嘗試。
1Z0-1123-25證照信息: https://tw.fast2test.com/1Z0-1123-25-premium-file.html
- 信賴可靠1Z0-1123-25考試內容是最快捷的通過方式Oracle Cloud Infrastructure 2025 Migration Architect Professional 💌 ( [url]www.vcesoft.com )上搜索[ 1Z0-1123-25 ]輕鬆獲取免費下載1Z0-1123-25考試資料[/url]
- 高效的1Z0-1123-25考試內容和資格考試和免費下載中的領先提供商1Z0-1123-25證照信息 🕧 免費下載⏩ 1Z0-1123-25 ⏪只需進入✔ [url]www.newdumpspdf.com ️✔️網站1Z0-1123-25考題資訊[/url]
- 1Z0-1123-25 PDF 😞 1Z0-1123-25題庫資訊 🕌 1Z0-1123-25考試資料 🥣 請在「 [url]www.pdfexamdumps.com 」網站上免費下載➤ 1Z0-1123-25 ⮘題庫1Z0-1123-25新版題庫上線[/url]
- 1Z0-1123-25新版題庫上線 ✋ 1Z0-1123-25更新 🈵 最新1Z0-1123-25試題 📮 在➽ [url]www.newdumpspdf.com 🢪網站下載免費▛ 1Z0-1123-25 ▟題庫收集1Z0-1123-25題庫更新[/url]
- 1Z0-1123-25題庫資訊 🤼 1Z0-1123-25測試 💽 1Z0-1123-25下載 🔃 ➤ [url]www.kaoguti.com ⮘上的免費下載☀ 1Z0-1123-25 ️☀️頁面立即打開1Z0-1123-25考題套裝[/url]
- 高效的1Z0-1123-25考試內容和資格考試和免費下載中的領先提供商1Z0-1123-25證照信息 😝 打開網站➡ [url]www.newdumpspdf.com ️⬅️搜索▛ 1Z0-1123-25 ▟免費下載1Z0-1123-25新版題庫上線[/url]
- 1Z0-1123-25題庫更新 📄 1Z0-1123-25題庫更新 🎋 最新1Z0-1123-25試題 👰 ☀ [url]www.pdfexamdumps.com ️☀️網站搜索⇛ 1Z0-1123-25 ⇚並免費下載1Z0-1123-25下載[/url]
- 想要順利的拿到1Z0-1123-25考試證書 - 1Z0-1123-25考古題是你的第一選擇 💎 立即在➥ [url]www.newdumpspdf.com 🡄上搜尋「 1Z0-1123-25 」並免費下載1Z0-1123-25考試資料[/url]
- 1Z0-1123-25認證考試 🧵 1Z0-1123-25考題資訊 👝 1Z0-1123-25測試 🛹 請在「 [url]www.newdumpspdf.com 」網站上免費下載☀ 1Z0-1123-25 ️☀️題庫1Z0-1123-25測試引擎[/url]
- 1Z0-1123-25真實考試題庫 💂 打開➡ [url]www.newdumpspdf.com ️⬅️搜尋✔ 1Z0-1123-25 ️✔️以免費下載考試資料1Z0-1123-25下載[/url]
- 最新更新的Oracle 1Z0-1123-25:Oracle Cloud Infrastructure 2025 Migration Architect Professional考試內容 - 可靠的tw.fast2test.com 1Z0-1123-25證照信息 🦖 在➡ tw.fast2test.com ️⬅️搜索最新的➥ 1Z0-1123-25 🡄題庫1Z0-1123-25考題套裝
- lifepass.site, p.me-page.com, hazopsiltraining.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
