[General] SC-200 Test Torrent and SC-200 Preparation Materials: Microsoft Security Operati
61
【General】 SC-200 Test Torrent and SC-200 Preparation Materials: Microsoft Security Operati
Posted at 1/12/2026 22:27:32      View:158 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New SC-200 dumps are available on Google Drive shared by PassExamDumps: https://drive.google.com/open?id=1nWB8vDRx1V2W-CyVfx_hvGBYDb9OCZlC
If you want to find a good job,you must own good competences and skillful major knowledge. So owning the SC-200 certification is necessary for you because we will provide the best SC-200 study materials to you. Our SC-200 exam torrent is of high quality and efficient, and it can help you pass the test successfully. For the SC-200 training guide we provide with you is compiled by professionals elaborately and boosts varied versions which aimed to help you learn the SC-200 study materials by the method which is convenient for you. And you can pass the exam with success guaranteed.
Microsoft SC-200 exam, also known as the Microsoft Security Operations Analyst exam, is a highly sought-after certification for professionals working in the field of cybersecurity. SC-200 Exam is designed to test the candidate's knowledge and skills in threat detection, incident response, and compliance management.
Microsoft SC-200 PDF Questions FormatThe software creates an Microsoft Security Operations Analyst (SC-200) exam-like scenario for you which helps to kill anxiety about the Microsoft SC-200 Certification Exams Questions. Customizable SC-200 practice test software enables you to change settings of practice exam time and questions. Since the PassExamDumps software tracks your progress, you can know mistakes and overcome them before the Microsoft SC-200 final test.
Microsoft SC-200 (Microsoft Security Operations Analyst) Certification Exam is a highly sought-after certification for security professionals. It is designed to validate the skills required to proactively detect, respond to, and prevent security threats using Microsoft Azure Sentinel, Microsoft 365 Defender, and Azure Defender.
Microsoft Security Operations Analyst Sample Questions (Q206-Q211):NEW QUESTION # 206
You have an Azure subscription that contains 100 Linux virtual machines.
You need to configure Microsoft Sentinel to collect event logs from the virtual machines.
NEW QUESTION # 207
You deploy Azure Sentinel.
You need to implement connectors in Azure Sentinel to monitor Microsoft Teams and Linux virtual machines in Azure. The solution must minimize administrative effort.
Which data connector type should you use for each workload? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... /connect-office-365
https://docs.microsoft.com/en-us/azure/sentinel/connect-syslog
NEW QUESTION # 208
You need to implement the Azure Information Protection requirements. What should you configure first?
  • A. Device health and compliance reports settings in Microsoft Defender Security Center
  • B. scanner clusters in Azure Information Protection from the Azure portal
  • C. Advanced features from Settings in Microsoft Defender Security Center
  • D. content scan jobs in Azure Information Protection from the Azure portal
To show labeled files from Windows 10 endpoints in the Azure Information Protection - Data discovery dashboard, you must first enable the built-in integration between Microsoft Defender for Endpoint and Azure Information Protection (AIP). This is turned on in the Microsoft Defender Security Center under Settings # Advanced features. When enabled, Defender for Endpoint inventories sensitivity labels seen on files across managed Windows devices and streams that telemetry to the AIP Data discovery experience, providing visibility into where labeled data resides on endpoints. Scanner clusters and content scan jobs in AIP are intended for on-premises repositories (file shares/SharePoint servers), not for endpoint discovery.
Device health/compliance reports do not surface or forward label inventory to AIP. Therefore, the first configuration step is enabling the AIP integration advanced feature in Defender for Endpoint so labeled files on Windows clients appear in the AIP Data discovery dashboard.
NEW QUESTION # 209
Your on-premises network contains 100 servers that run Windows Server.
You have an Azure subscription that uses Microsoft Sentinel.
You need to upload custom logs from the on-premises servers to Microsoft Sentinel.
What should you do? To answer, select the appropriate options m the answer area.
To upload custom logs from the on-premises servers to Microsoft Sentinel, you should install the Log Analytics agent on each of the 100 servers. The Log Analytics agent is a lightweight agent that runs on the server and allows it to connect to the cloud-based Microsoft Defender Security Center. Once installed, the agent will allow the Microsoft Sentinel service to collect and analyze the custom log data from the servers.
NEW QUESTION # 210
You have a custom detection rule that includes the following KQL query.
For each of the following statements, select Yes if True. Otherwise select No.
NEW QUESTION # 211
Valid SC-200 Practice Materials: https://www.passexamdumps.com/SC-200-valid-exam-dumps.html
Posted at 1/24/2026 18:22:13        Only Author  2#
No second guesses, this content gets my like. Exam FCSS_SASE_AD-25 Guide was a game-changer for my career and income, and I’m offering it to you for free today!
Posted at 2/8/2026 08:34:31        Only Author  3#
Your article is absolutely mind-blowing, thank you for sharing! The Latest CS0-003 exam questions and answers helped me secure a promotion and raise. It’s now free to all. Wishing you success in your promotion journey!
