[General] Certification NS0-528 Training - Minimum NS0-528 Pass Score
96
General Certification NS0-528 Training - Minimum NS0-528 Pass Score
Posted at 1/12/2026 23:03:51      View144 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New NS0-528 dumps are available on Google Drive shared by DumpTorrent: https://drive.google.com/open?id=1-qwScQZnsA8QvlVxNLU5KOtmPXrE-ZaT
The DumpTorrent Implementation Engineer - Data Protection Exam (NS0-528) PDF dumps file is a collection of real, valid, and updated NS0-528 practice questions that are also easy to install and use. The NS0-528 PDF dumps file can be installed on a desktop computer, laptop, and even on your smartphone devices. Just download DumpTorrent Implementation Engineer - Data Protection Exam in NS0-528 PDF Questions on your desired device and start Network Appliance NS0-528 exam dumps preparation today.
Network Appliance NS0-528 Exam Syllabus Topics:
  • NetApp ONTAP Core Data Protection Features: This section of the exam measures the skills of Systems Administrators and validates core knowledge of data protection and redundancy within the ONTAP environment. It encompasses understanding how data efficiencies impact protection strategies and the practical knowledge required to deploy these data protection solutions effectively in a hybrid cloud infrastructure.
  • NetApp ONTAP Business Continuity Solutions: This section of the exam measures the skills of Disaster Recovery Specialists and covers advanced business continuity technologies. This includes the configuration and operation of SnapMirror active sync for continuous data replication and the execution of SVM-DR (Storage Virtual Machine Disaster Recovery) operations to ensure high availability.
  • Troubleshooting and Testing: This section of the exam measures the skills of Support Engineers and focuses on the practical skills needed to maintain data integrity. It involves troubleshooting common data protection configuration issues, executing well-defined Disaster Recovery (DR) procedures, and performing data restore operations to recover from data loss.
  • Data Protection Solutions: This section of the exam measures the skills of Storage Architects and covers the foundational principles of designing data protection solutions. It focuses on creating comprehensive design documentation, understanding the various components involved, and identifying all critical solution dependencies to ensure a robust and reliable data protection strategy.
Topic 5
  • NetApp Data Protection Software: This section of the exam measures the skills of DevOps Engineers and focuses on the deployment and administration of NetApp's proprietary data protection software. A key part of this domain involves applying these solutions to protect modern containerized applications running in Kubernetes environments.
Updated and Reliable Network Appliance NS0-528 Exam Questions for Guaranteed SuccessIf you are worried that it is not easy to obtain the certification of NS0-528. Our NS0-528 study questions can meet your needs. Once you use our NS0-528 exam materials, you don't have to worry about consuming too much time, because high efficiency is our great advantage. You only need to spend 20 to 30 hours on practicing and consolidating of our NS0-528 learning material, you will have a good result. After years of development practice, our NS0-528 test torrent is absolutely the best. You will embrace a better future if you choose our NS0-528 exam materials.
Network Appliance Implementation Engineer - Data Protection Exam Sample Questions (Q253-Q258):NEW QUESTION # 253
You want to conserve disk space in your SnapVault destinations. You enable storage efficiency on each of the secondary volumes.
Which two statements are true in this scenario? (Choose two.)
  • A. Storage efficiency can be enabled on the secondary volume, but a manual schedule will need to be assigned.
  • B. If storage efficiency is enabled on the primary volume, it will be preserved on the secondary volume.
  • C. SnapVault implicitly uses storage efficiency.
  • D. Storage efficiency can be enabled on the secondary volume and SnapVault will manage the schedule.
NEW QUESTION # 254
An administrator needs to maintain 10 snapshots per volume on a NetApp AFF system and replicate to a destination with a snapshot retention of 120.
Which NetApp feature should the administrator use?
  • A. SnapMirror active sync
  • B. XCP
  • C. MetroCluster
  • D. SnapMirror
SnapMirror supports asymmetric snapshot retention, allowing the source volume (on the AFF system) to retain 10 snapshots while the destination retains up to 120 snapshots. This is useful for long-term retention or compliance at the destination without consuming extra capacity on the source.
NEW QUESTION # 255
Which two NetApp features would help you to recover from a file share that was encrypted by a ransomware event? (Choose two.)
  • A. SnapMirror
  • B. Snapshot
  • C. SnapLock
  • D. SnapRestore
NEW QUESTION # 256
Your customer wants to create application-aware backups of their SAP HANA databases, which are running on VMware vSphere.
What two steps must be completed to create these backups? (Choose two.)
  • A. Install the plug-in for SAP HANA in SnapCenter software.
  • B. Install the plug-in for VMware vSphere in SnapCenter software.
  • C. Create a policy when given the retention requirements by the customer.
  • D. Install the plug-in for Unix file systems.
To create application-aware backups of SAP HANA databases:
* You must install the SnapCenter Plug-in for SAP HANA, which provides database-consistent backup and restore operations.
* You must also create a backup policy that aligns with the customer's retention requirements to manage how long backups are kept and how often they're performed.
NEW QUESTION # 257
You have set up a SnapMirror relationship between two SVMs for data protection. The data in the source volume is unavailable due to an event related to a virus infection leading to data corruption.
In this scenario, which three actions are required to activate the SnapMirror destination volume and provide data access to the users? (Choose three.)
  • A. Disable the source volume by taking it offline.
  • B. Configure the destination volume for data access.
  • C. Perform a SnapMirror quiesce operation.
  • D. Verify the status of the source and destination volumes.
  • E. Perform a SnapMirror break operation.
Answer: B,D,E
NEW QUESTION # 258
One of the main unique qualities of the DumpTorrent Network Appliance Exam Questions is its ease of use. Our practice exam simulators are user and beginner friendly. You can use Implementation Engineer - Data Protection Exam (NS0-528) PDF dumps and Web-based software without installation. Implementation Engineer - Data Protection Exam (NS0-528) PDF questions work on all the devices like smartphones, Macs, tablets, Windows, etc. We know that it is hard to stay and study for the Implementation Engineer - Data Protection Exam (NS0-528) exam dumps in one place for a long time.
Minimum NS0-528 Pass Score: https://www.dumptorrent.com/NS0-528-braindumps-torrent.html
DOWNLOAD the newest DumpTorrent NS0-528 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1-qwScQZnsA8QvlVxNLU5KOtmPXrE-ZaT
