[Hardware] JN0-460 Practice Exam Fee | JN0-460 Valid Test Vce Free
87
【Hardware】 JN0-460 Practice Exam Fee | JN0-460 Valid Test Vce Free
Posted at 1/13/2026 01:26:07      View:128 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Juniper JN0-460 dumps are available on Google Drive shared by PracticeMaterial: https://drive.google.com/open?id=1hl6m2BUZRgPMnx2DDCJAv1BoiFTgK5IR
I know you must want to get a higher salary, but your strength must match your ambition! The opportunity is for those who are prepared! JN0-460 exam questions can help you improve your strength! You will master the most practical knowledge in the shortest possible time. It is also very easy if you want to get the JN0-460 certificate. As long as you buy our JN0-460 study braindumps and practice step by step, you are bound to pass the exam.
Juniper JN0-460 Exam Syllabus Topics:
  • Wired Assurance Provisioning or Deployment: This section of the exam measures the skills of Network Deployment Specialists and focuses on the provisioning and deployment processes of Wired Assurance. It includes the essential steps and options involved in setting up networks, from configuration templates to deployment methodologies. Candidates learn about provisioning procedures, supported architectures, and the use of site variables to streamline automation and consistency across wired infrastructures.
  • Campus Fabric Architecture: This section of the exam measures the skills of Network Design Engineers and focuses on understanding and deploying Campus Fabric Architectures. It introduces essential design concepts such as EVPN multihoming, IP Clos architecture, and micro-segmentation. The section also compares CRB and ERB models, explains scaling requirements, and highlights how the Campus Fabric Core-Distribution design supports high-performance, scalable, and secure enterprise networks.
  • Campus EVPN-VXLAN: This section of the exam measures the skills of Data Center Network Engineers and explores the key principles of VXLAN and EVPN technologies. Candidates learn about Layer 2 tunneling, data and control plane operations, and the functions of VTEPs and VXLAN gateways. Additionally, it covers advanced EVPN concepts such as multipath routing, route types, and identifiers. The section concludes with a focus on MAC learning and policy applications to ensure efficient, scalable, and resilient network fabrics.
  • Wired Assurance Fundamentals: This section of the exam measures the skills of Network Support Engineers and covers the foundational elements of Wired Assurance within the MistAI ecosystem. It introduces candidates to key concepts such as supported devices, solution architecture, and the main features and components that define Wired Assurance functionality. Additionally, it highlights how MistAI accounts, analytics, and subscriptions integrate to deliver intelligent insights for network performance and operations.
Topic 5
  • Wired Assurance Management or Operations: This section of the exam measures the skills of Network Operations Engineers and focuses on the management and operational aspects of Wired Assurance. It covers switch management, port profiles, and dynamic port configuration to ensure optimal network performance. The section also explores service-level expectations, client insights, and the use of APIs for improved monitoring and automation. Candidates gain an understanding of how MistAI enables proactive management and predictive troubleshooting to maintain service quality.
PracticeMaterial Offers Free Juniper JN0-460 Questions Demo and UP To 1 year of Free UpdatesUsing our JN0-460 study braindumps, you will find you can learn about the knowledge of your exam in a short time. Because you just need to spend twenty to thirty hours on the practice exam, our Juniper JN0-460 Study Materials will help you learn about all knowledge, you will successfully pass the Juniper JN0-460 exam and get your certificate.
Juniper Mist AI Wired, Specialist (JNCIS-MistAI-Wired) Sample Questions (Q82-Q87):NEW QUESTION # 82
The main advantage of Campus Fabric IP Clos architecture is:
  • A. Increased network complexity
  • B. Decreased scalability
  • C. Limited data flow control
  • D. Enhanced fault tolerance
NEW QUESTION # 83
Which two fields arerequiredwhen creating anew site? (Choose two.)
  • A. location
  • B. RF template
  • C. site name
  • D. time zone
Creating a new site requires asite nameandtime zone.
Other parameters (like templates or location data) are optional but recommended for proper reporting.
Mist AI for Wired - Site Creation Workflow
Create a Mist Account and Organization Documentation
NEW QUESTION # 84
Which provisioning process is supported by Wired Assurance?
  • A. Manual entry of MAC addresses
  • B. Zero-Touch Provisioning (ZTP)
  • C. Postal mailing of configurations
  • D. Physical device inspection
NEW QUESTION # 85
You have two sites connected to an EVPN network. Each site is using the172.16.1.0/24network for its own respective site.
How does EVPN prevent overlap in this scenario?
  • A. It elects a designated forwarder.
  • B. It uses an Ethernet segment identifier (ESI).
  • C. It uses a Layer 2 gateway.
  • D. It uses a route distinguisher.
EVPN, when used with VXLAN, leveragesBGP MPLS/VXLAN control plane mechanisms. To prevent overlapping IP prefixes between different tenants or sites, EVPN uses aRoute Distinguisher (RD).
"In EVPN-VXLAN, the route distinguisher (RD) makes routes unique when overlapping IP prefixes or MAC addresses are advertised between multiple tenants or sites." Option A(designated forwarder) applies to multi-homing in EVPN, not prefix uniqueness.
Option B(Layer 2 gateway) does not prevent IP overlap; it bridges VLANs.
Option D(ESI) is used for identifying multi-homed Ethernet segments, not to differentiate overlapping subnets.
Option C(Route Distinguisher) is correct, as it uniquely identifies routes even if the IP addresses are the same across sites.
Juniper Mist AI for Wired - EVPN-VXLAN Overview
Juniper Validated Design - EVPN-VXLAN Fundamentals
Junos OS EVPN Configuration Guide
NEW QUESTION # 86
Dynamic port configuration in Wired Assurance allows for:
  • A. Manual port management
  • B. Static IP assignment only
  • C. Decreased network flexibility
  • D. Automatic adjustment of port settings based on connected devices
NEW QUESTION # 87
The JN0-460 exam simulator plays a vital role in increasing your knowledge for exam. The PracticeMaterial’ Juniper Testing Engine provides an expert help and it is an exclusive offer for those who spend most of their time in searching relevant content in the books. It offers demos free of cost in the form of the Free JN0-460 Dumps. The Juniper JN0-460 exam questions aid its customers with updated and comprehensive information in an innovative style.
JN0-460 Valid Test Vce Free: https://www.practicematerial.com/JN0-460-exam-materials.html
BONUS!!! Download part of PracticeMaterial JN0-460 dumps for free: https://drive.google.com/open?id=1hl6m2BUZRgPMnx2DDCJAv1BoiFTgK5IR
Posted at 1/13/2026 16:21:52        Only Author  2#
Thank you for sharing such an impactful article, it really stayed with me. The New testcollection PCAP-31-03 content is excellent, and it’s available to everyone free of charge.
Posted at 2/4/2026 03:17:06        Only Author  3#
What an extraordinary article, I’m truly thankful for your share! This is the Dumps NCP-CN discount test that helped me secure a promotion and raise. It's free for everyone today—wishing you all the best in your career!
Posted at 2/15/2026 16:40:33        Only Author  4#
Many viewpoints in the article have been very inspiring, and I’ve benefited greatly. Reliable SAP-C02 exam dumps.zip offers in-depth material for free to enhance your learning.
