[Hardware] 1Z0-1195-25 Updated Test Cram, Free 1Z0-1195-25 Updates
85
Hardware 1Z0-1195-25 Updated Test Cram, Free 1Z0-1195-25 Updates
Posted at 1/13/2026 01:33:40      View217 | Replies3        Print      Only Author   [Copy Link] 1#
P.S. Free & New 1Z0-1195-25 dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1xvYdRlgap_d7bXBZZlJxmXJZHlhNdzN_
The Oracle Data Platform 2025 Foundations Associate (1Z0-1195-25) practice test software also shows changes and improvements done by the candidates on every step during the 1Z0-1195-25 exam. So this reduces your chance of failure in the actual 1Z0-1195-25 Exam. It requires no special plugins to function properly. So just start your journey with Pass4sureCert and prepare for the 1Z0-1195-25 exam instantly.
Oracle 1Z0-1195-25 Exam Syllabus Topics:
  • Converged Database: This section evaluates the expertise of Multi-Model Database Specialists and Application Developers in using Oracle's converged database for multi-model use cases. It covers JSON, graph, and spatial data capabilities within the Oracle Database.
  • Upgrades and Migrations: This section tests the knowledge of Migration Specialists and Cloud Architects in planning cloud migrations. It includes various migration strategies to OCI, as well as upgrade options for transitioning existing databases to newer versions or cloud environments.
  • MySQL and NoSQL: This section measures the skills of Database Developers and Data Engineers in working with Oracle MySQL HeatWave Database Service. It focuses on their features and uses cases for modern application development.
  • Data Lake, Data Warehouse, and Machine Learning: This section evaluates the expertise of Data Scientists and Big Data Engineers in understanding UCI's Data Lakehouse architecture, Oracle Machine Learning capabilities, and Data Mesh architecture for managing distributed data environments.
Topic 5
  • Developing on Oracle Database: This section measures the skills of Application Developers and DevOps Engineers in managing Autonomous Databases using REST APIs, Oracle's data toolset, low-code development with APEX, and CI
  • CD processes for database tools and APEX applications.
Free PDF Oracle 1Z0-1195-25 - Marvelous Oracle Data Platform 2025 Foundations Associate Updated Test CramDo you want to obtain your certificate as quickly as possible? If you do, just choose us. You can get your downloading link within ten minutes after your payment for 1Z0-1195-25 training materials, and you can start your learning as quickly as possible. In addition, 1Z0-1195-25 training materials of us are high quality, and you just need to spend 48 to 72 hours on practicing, and you can pass the exam successfully. If you have any questions about the 1Z0-1195-25 Exam Dumps, just contact us, we will give you reply as soon as possible.
Oracle Data Platform 2025 Foundations Associate Sample Questions (Q32-Q37):NEW QUESTION # 32
Which two actions can be performed from the OCI Console for an Oracle Autonomous Database?
  • A. Increase Network Bandwidth
  • B. Scale up/down CPU
  • C. Scale up/down Memory
  • D. Increase Storage allocated for Database
From the OCI Console for an "Oracle Autonomous Database," you can "Scale up/down CPU" (A) to adjust compute resources dynamically and "Increase Storage allocated for Database" (D) to expand capacity, both with no downtime. "Increase Network Bandwidth" (B) is not a console-adjustable parameter (managed by Oracle), and "Scale up/down Memory" (C) is not independently configurable (tied to CPU scaling). Oracle's documentation confirms CPU and storage scaling as user-controlled actions.
NEW QUESTION # 33
Which command for the MySQL Data Service will resume OCPU billing?
  • A. Start
  • B. Stop
  • C. Restart
  • D. Backup
For the "MySQL Database Service," the "Start" command (A) resumes OCPU billing, as it activates the database instance, incurring compute costs. "Stop" (B) halts billing by suspending the instance, "Restart" (C) is a stop-then-start sequence, and "Backup" (D) affects storage, not OCPU billing. Oracle's MySQL Service documentation ties billing to the Start command.
NEW QUESTION # 34
Which Oracle Cloud Infrastructure (OCI) service is NOT available as part of Oracle Cloud Free Tier?
  • A. Monitoring
  • B. Exadata DB Systems
  • C. Autonomous Data Warehouse
  • D. Compute
"Exadata DB Systems" (B) is not available in the Oracle Cloud Free Tier. The Free Tier includes "Autonomous Data Warehouse" (A) with limited resources, "Compute" (C) instances, and "Monitoring" (D) services, but Exadata DB Systems, being a high-performance, premium offering, requires a paid subscription. Oracle's Free Tier documentation lists eligible services, explicitly excluding Exadata.
NEW QUESTION # 35
Which workload CANNOT be run on Oracle Database 19c?
  • A. Gaming
  • B. Machine Learning
  • C. Hadoop Clusters
  • D. Translytical
"Oracle Database 19c" supports "Machine Learning" (A) via in-database algorithms, "Translytical" (B) workloads combining transactional and analytical processing, and "Gaming" (C) through high-performance transaction support. However, "Hadoop Clusters" (D) cannot run directly on 19c, as Hadoop is a distributed framework requiring a separate ecosystem (e.g., Oracle Big Data Service), not a workload natively supported within the database engine. Oracle's 19c documentation details its converged database capabilities, excluding Hadoop as a direct workload.
NEW QUESTION # 36
What are two typical reasons why customers CANNOT move their database into the public cloud?
  • A. Public cloud does not provide storage for more than 10TB
  • B. Putting data in the cloud would break data residency rules
  • C. Regulations that prevent moving data into the public cloud
  • D. Total Cost of Ownership in public cloud is higher than on-premises
Customers may not move databases to the public cloud due to "Putting data in the cloud would break data residency rules" (A), where laws mandate data remain in specific regions, and "Regulations that prevent moving data into the public cloud" (B), such as industry-specific compliance requirements (e.g., GDPR, HIPAA). "Total Cost of Ownership in public cloud is higher" (C) is a consideration but not a universal barrier, and "Public cloud does not provide storage for more than 10TB" (D) is false, as OCI offers vast storage options. Oracle's cloud adoption guides cite residency and regulatory constraints as common blockers.
NEW QUESTION # 37
Getting tired of humdrum life, you may want to get some successful feeling or try something different instead. We all know that is of important to pass the 1Z0-1195-25 exam and get the 1Z0-1195-25 certification for someone who wants to find a good job in internet area, and it is not a simple thing to prepare for exam. So you are in the right place now. The thoughtfulness of our 1Z0-1195-25 Study Materials services is insuperable. What we do surly contribute to the success of 1Z0-1195-25 practice materials.
Free 1Z0-1195-25 Updates: https://www.pass4surecert.com/Oracle/1Z0-1195-25-practice-exam-dumps.html
Posted at 1/28/2026 14:13:34        Only Author  2#
This article gave me a new perspective, thank you for sharing! You can access Latest study guide AP-221 pdf for free, filled with rich content to assist your learning.
Posted at 2/5/2026 03:30:45        Only Author  3#
After reading this article, I have a more in-depth understanding of the related topics. Free Latest test 78202T simulator online questionsunlock your career advancement and salary boost!
Posted at 3/8/2026 15:06:31        Only Author  4#
KaoGuTi BCICBCIĿԇY؄eOӋһɌIITӢFꠌTゃĿ}Yϣᘌ؄eͨ^JCITИIwFHrֵSDӖϵḶ́Cͨ^ BCICBCIĿԇʹĮaƷKaoGuTicеľWվȣ@ѽɞvʷˣ҂ŒfԒ׌ҊCEĕŕC҂fÿһԒ
