[General] JN0-336C & JN0-336}d
77
General JN0-336C & JN0-336}d
Posted at 1/13/2026 01:41:55      View342 | Replies4        Print      Only Author   [Copy Link] 1#
⣬@ЩPDFExamDumps JN0-336ԇ}IJփݬFMģhttps://drive.google.com/open?id=1FoIwN_cZbJtC2buYNZqi5Qku5xmQDcJb
Ҫͨ^Juniper JN0-336ԇJCxӖǷdzбҪģPJuniper JN0-336ԇJCоǺҪһ֣҂PDFExamDumpsܺЧṩPͨ^Juniper JN0-336ԇJCYϣPDFExamDumpsIT҂njӽMɵģоIJϺ挍Ŀ}ܽӽ׺һӣPDFExamDumpsnjTҪJCԇṩľWվЧĎͨ^ԇ
ܮrЈS Juniper ĕ]һǰٷ֮ٽBHġSP Juniper ÷ĕҲֻõijЩ֣KṩϢʹxؽ͜yԇá PDFExamDumps JN0-336 }һpͨ^ Juniper ԇ҂ṩ JN0-336 }wˮǰµ挍}Kȫ_𰸡ڜʂ俼ԇѵČW֣ͨ^ԇȡ JN0-336 JCĽݏ
JN0-336}d - JN0-336WYMxxһo㎧^Ҹxo^ęCһe^xֻ PDFExamDumps JuniperJN0-336ԇӖYÿITʿͨ^ITJC횵ӖYϣ@ݿԇYϾ͵УеĿԇy}ӭж⡣ PDFExamDumps JuniperJN0-336ԇӖYᘌԏwV¿죬ӖYϣеITJCҪ£㶼ͨ^ġ
µ JNCIS-SEC JN0-336 Mԇ} (Q64-Q69):} #64
Your network uses a single JSA host and you want to implement a cluster.
In this scenario, which two statements are correct? (Choose two.)
  • A. The software versions on both primary and secondary hosts
  • B. The primary and secondary hosts must be configured with the same storage devices.
  • C. The secondary host can backup multiple JSA primary hosts.
  • D. The cluster virtual IP will need an unused IP address assigned.
𰸣A,D
}f
According to the Juniper Networks JNCIP-SEC Study Guide, when setting up a cluster with a single JSA host, both the primary and secondary hosts must have the same software version installed. Additionally, an unused IP address must be assigned to the cluster virtual IP. The primary and secondary hosts do not need to be configured with the same storage devices, and the secondary host cannot be used to backup multiple JSA primary hosts.
} #65
Which two statements about SRX chassis clustering are correct? (Choose two.)
  • A. SRX chassis clustering supports active/passive and active/active for the data plane.
  • B. SRX chassis clustering supports active/passive for the control plane.
  • C. SRX chassis clustering supports active/active for the control plane.
  • D. SRX chassis clustering only supports active/passive for the data plane.
𰸣A,B
}f
SRX chassis clustering allows for both active/passive and active/active configurations for the data plane.
In an active/passive setup, one node is active (handling traffic) while the other remains passive (idle and waiting to take over in case of failure). In an active/active setup, both nodes can handle traffic simultaneously, distributing different traffic flows or services between them for load balancing and redundancy.
For the control plane, SRX chassis clustering typically operates in an active/passive mode. This means one node actively handles the control plane responsibilities, such as managing routing tables and maintaining sessions, while the other stands by ready to take over these tasks if the active node fails.
} #66
You enable chassis clustering on two devices and assign a cluster ID and a node ID to each device.
In this scenario, what is the correct order for rebooting the devices?
  • A. Reboot only the secondary device since the primary will assign itself the correct cluster and node ID.
  • B. Reboot only the primary device since the secondary will assign itself the correct cluster and node ID.
  • C. Reboot the secondary device, then the primary device.
  • D. Reboot the primary device, then the secondary device.
𰸣C
}f
When chassis clustering is enabled and IDs are assigned, it is typically recommended to first reboot the secondary device. This allows the secondary device to fully integrate and recognize its role and settings within the cluster without affecting the ongoing traffic that the primary device might be handling.
Once the secondary device has successfully rebooted and is operational within the cluster, the primary device can then be rebooted. This ensures that the primary device's reboot does not cause any network downtime, as the secondary device, now fully operational, can take over the traffic and roles as needed.
} #67
Which statement defines the function of an Application Layer Gateway (ALG)?
  • A. The ALG uses software processes for managing specific protocols.
  • B. The ALG contains protocols that use one application session for each TCP session.
  • C. The ALG uses software that is used by a single TCP session using the same port numbers as the application.
  • D. The ALG uses software processes for permitting or disallowing specific IP address ranges.
𰸣A
}f
The statement that defines the function of an Application Layer Gateway (ALG) is: The ALG uses software processes for managing specific protocols. An ALG is a security component that operates at the application layer (layer 7) of the OSI model and handles data associated with certain application protocols, such as SIP, FTP, RTSP, etc. An ALG acts as a proxy or intermediary between the client and the server applications and performs various functions, such as address and port translation, resource allocation, application response control, and synchronization of data and control traffic. An ALG can also inspect and modify the application payload to enable firewall or NAT traversal, prevent spoofing or DoS attacks, or enforce granular security policies based on application-specific commands. Reference: = Application-level gateway - Wikipedia, What Is an Application Layer Gateway (ALG)? | F5, What is ALG
** Application Layer Gateway | 3CX
} #68
Which three statements about SRX Series device chassis clusters are true? (Choose three.)
  • A. Heartbeat messages verify that the chassis cluster control link is working.
  • B. Recovery from a control link failure requires that the secondary member device be rebooted.
  • C. A control link failure causes the secondary cluster node to be disabled.
  • D. Chassis cluster member devices synchronize configuration using the control link.
  • E. Chassis cluster control links must be configured using RFC 1918 IP addresses.
𰸣A,C,D
}f
B: Chassis cluster member devices synchronize configuration using the control link: This statement is correct because the control link is used for configuration synchronization among other functions.
C: A control link failure causes the secondary cluster node to be disabled: This statement is correct because a control link failure causes the secondary node to become ineligible for primary role and remain in secondary role until the control link is restored.
E: Heartbeat messages verify that the chassis cluster control link is working: This statement is correct because heartbeat messages are sent periodically over the control link to monitor its status.
} #69
PDFExamDumpsԺͨ^Juniper JN0-336ԇһ·LԇJuniper JN0-336ԇxPDFExamDumpsJuniper JN0-336ӖߣdJuniper JN0-336}ʹ𰸣㿼ԇģЧͨ^Juniper JN0-336ԇmȻϾWվҲPJuniper JN0-336JCԇPӖߣ҂ĮaƷƷ|Ƿdzá҂Ŀԇ}ʹ𰸜ʴ_ԸߣӖϸw󣬲ĸº͏Ԟṩһʴ_ԷdzߵĿԇʂ䣬xPDFExamDumpsԞ㹝srg׌õJuniper JN0-336JCC׌ɞJuniper ITИIеČIʿ
JN0-336}d: https://www.pdfexamdumps.com/JN0-336_valid-braindumps.html
иƷ|Ŀ}Yϣ܎ͨ^һ·LԇJN0-336ԇxJN0-336ԇrЛ]xPĿԇṇPDFExamDumpsľWվdPDFExamDumpsµPJuniper JN0-336 JCԇ}MLԇˣŲ׌ʧģJuniper JN0-336C @}QһֱڌҵĖ|҂ṩ Juniper Security, Specialist (JNCIS-SEC) - JN0-336 }ͨ^ˌ`ęzõƷ|ĮaƷԎͨ^ Juniper Security, Specialist (JNCIS-SEC) JCԇɞһۺITңͨ^ JN0-336 JCԇԇ᣿
ɾڴ˕rҼɚCD°ʲǽnѲ߉LиƷ|Ŀ}Yϣ܎ͨ^һ·LԇJN0-336ԇxJN0-336ԇrЛ]xPĿԇṇPDFExamDumpsľWվdPDFExamDumpsµPJuniper JN0-336 JCԇ}MLԇˣŲ׌ʧġ
ֵهJN0-336C |ͨ^ʵĿԇ|ڙJN0-336}d@}QһֱڌҵĖ|҂ṩ Juniper Security, Specialist (JNCIS-SEC) - JN0-336 }ͨ^ˌ`ęzõƷ|ĮaƷԎͨ^ Juniper Security, Specialist (JNCIS-SEC) JCԇɞһۺITҡ
2026 PDFExamDumpsµJN0-336 PDF濼ԇ}JN0-336ԇ}ʹMhttps://drive.google.com/open?id=1FoIwN_cZbJtC2buYNZqi5Qku5xmQDcJb
Posted at 1/14/2026 20:07:22        Only Author  2#
ޤޤITINǤϡAvaya78202TԇYJǷȤǤʤJ^ǤFast2testx顢һؤAvaya78202TJԇY˺ϸ񤹤Τ^ޤ⤷Fast2testAvaya78202TԇYȥ`˥YϤُ뤷ᡢѧ̲Ĥφ}С򤤤ԇY˲ϸˤʤϤϡ˽ȫ~𤹤뤳Ȥ^ޤ
Posted at 1/21/2026 02:42:55        Only Author  3#
Your article has truly left me speechless, thank you for sharing! Level up your IT skills by grabbing free New CTFL-AcT exam labs. Best of luck on your exams!
Posted at 2/14/2026 02:55:14        Only Author  4#
Your article is fantastic, I really appreciate you sharing it! Wish me all the best for the Valid 312-97 exam guide materials exam coming up!
Posted at 2/18/2026 15:37:44        Only Author  5#
Thank you for sharing your article, its truly amazing! New exam ACNS collection materials provides fantastic content for free.
