1Z0-1072-25 Pr¨¹fung, 1Z0-1072-25 Online Test
88
Posted at 1/13/2026 02:51:17      View£º161 | Replies£º5        Print      Only Author   [Copy Link] 1#
BONUS!!! Laden Sie die vollständige Version der ExamFragen 1Z0-1072-25 Pr¨¹fungsfragen kostenlos herunter: https://drive.google.com/open?id=1mVNQOXuNnMCLZ9fmTfz8PAWaD0LmHS9s
Wenn Sie finden, dass unsere 1Z0-1072-25 Pr¨¹fungsmaterialien Qualitätsproblem hat oder wenn Sie die Pr¨¹fung nicht bestanden haben, zahlen wir Ihnen bedingungslos die gesammte Summe zur¨¹ck. Die Fragen und Antworten zur Oracle 1Z0-1072-25 Zertifizierungspr¨¹fung von ExamFragen umfassen fast alle Wissensgebiete der Oracle 1Z0-1072-25 Zertifizierungspr¨¹fung.
Oracle 1Z0-1072-25 Pr¨¹fungsplan:
ThemaEinzelheiten
Thema 1
  • Networking: Targeting network architects designing secure cloud architectures, this domain focuses on Virtual Cloud Network (VCN) implementation, including subnet design, IP address management, and routing through gateways (NAT, service, internet). It assesses expertise in VPN
  • FastConnect deployment, DNS configuration, load balancer setup, and advanced tools like Network Path Analyzer for troubleshooting latency or connectivity issues.
Thema 2
  • Compute: This section measures skills of cloud architects responsible for designing scalable and resilient infrastructure, covering compute instance configuration, autoscaling policies, and OS management. It evaluates understanding of OCI compute image options, infrastructure maintenance processes, and strategies for optimizing instance performance across availability domains.
Thema 3
  • Identity and Access Management (IAM): This domain validates skills of security architects implementing granular access controls, emphasizing IAM policy creation, compartment organization, and dynamic group configuration. It covers identity domain management, network source restrictions, and tag-based access mechanisms to enforce least-privilege principles across OCI resources
Thema 4
  • Storage: Designed for storage administrators managing enterprise data solutions, this section tests proficiency in deploying Block
  • File
  • Object Storage with lifecycle management, cross-region replication, and tiered storage strategies. It includes configuring volume groups, snapshots, versioning, and security controls while analyzing storage performance metrics and cost optimization techniques.
Wir machen 1Z0-1072-25 leichter zu bestehen!Wenn Sie hoffen, dass Ihre Berufsaussichten in der IT-Branche besser werden. Die Oracle 1Z0-1072-25 Pr¨¹fung zu bestehen ist eine effiziente Weise. Beklagen Sie sich nicht ¨¹ber die Schwierigkeit der Oracle 1Z0-1072-25, weil eine wirkungsvolle Methode von uns ExamFragen schon bereit ist, die Ihnen bei der Erwerbung der Zertifizierung der Oracle 1Z0-1072-25 helfen können. Wir aktualisieren immer wieder die Simulations-Software, um zu garantieren, dass Sie die Pr¨¹fung der Oracle 1Z0-1072-25 mit befriedigten Zeugnisse bestehen.
Oracle Cloud Infrastructure 2025 Architect Associate 1Z0-1072-25 Pr¨¹fungsfragen mit Lösungen (Q27-Q32):27. Frage
Which statement is true about pre-authenticated requests?
  • A. You need to provide your OCI credentials to the partner company.
  • B. Deleting a pre-authenticated request does not revoke access.
  • C. You cannot edit a pre-authenticated request.
  • D. Pre-authenticated requests can be used to delete buckets.
Antwort: C
Begr¨¹ndung:
In Oracle Cloud Infrastructure (OCI), pre-authenticated requests (PARs) allow users to grant access to specific objects in Object Storage without requiring the recipient to have an OCI account or credentials. This feature is useful for sharing objects securely without exposing broader access.
Cannot Edit a PAR: Once a pre-authenticated request is created, you cannot edit it. If you need to change the settings, such as the expiration date or the object being shared, you must delete the existing PAR and create a new one.
Other Statements:
Deleting a PAR does indeed revoke access immediately, contradicting option B.
Providing OCI credentials (C) is not required for using PARs. The purpose of PARs is to avoid sharing credentials.
Deleting Buckets (D): PARs are designed for accessing objects, not for administrative actions like deleting buckets.
Relevant OCI Documentation:
Managing Pre-Authenticated Requests
This reference outlines the features and limitations of pre-authenticated requests, including the inability to edit them once created.
28. Frage
Which TWO are key benefits of setting up Site-to-Site VPN on Oracle Cloud Infrastructure (OCI)?
  • A. When setting up Site-to-Site VPN, customers can expect bandwidth above 2 Gbps.
  • B. When setting up Site-to-Site VPN, it creates a private connection that provides consistent network experience.
  • C. When setting up Site-to-Site VPN, customers can configure it to use static or dynamic routing (BGP).
  • D. When setting up Site-to-Site VPN, OCI provisions redundant VPN tunnels.
Antwort: C,D
Begr¨¹ndung:
Setting up a Site-to-Site VPN on Oracle Cloud Infrastructure offers several key benefits related to connectivity and reliability:
Static or Dynamic Routing (BGP): OCI allows customers to configure Site-to-Site VPN with either static routing or dynamic routing using Border Gateway Protocol (BGP). This flexibility enables customers to choose the routing method that best suits their network configuration and requirements.
Redundant VPN Tunnels: OCI automatically provisions redundant VPN tunnels when you set up a Site-to-Site VPN. These redundant tunnels ensure high availability and fault tolerance, so if one tunnel fails, traffic can continue to flow through the other tunnel without interruption.
Bandwidth Considerations: While the VPN provides a reliable connection, it typically does not exceed 2 Gbps in bandwidth. Higher bandwidth connections usually require FastConnect.
Private Connection: The VPN does create a secure and private connection between on-premises data centers and OCI, but it does not inherently provide a consistent network experience in the way that a dedicated connection like FastConnect does.
Site-to-Site VPN Overview
Configuring Routing for VPNs
These references detail the benefits and technical specifications of setting up Site-to-Site VPNs on OCI.
29. Frage
Why is the OCI Inter-Region Latency dashboard useful for optimizing data transfer and backup strategies?
  • A. It's designed for troubleshooting latency issues within your specific applications.
  • B. It offers a current and historical view of latency snapshots.
  • C. It provides real-time data specific to your tenancy's workloads.
  • D. It focuses solely on latency within your own tenancy.
Antwort: B
Begr¨¹ndung:
The OCI Inter-Region Latency dashboard is useful for optimizing data transfer and backup strategies because it provides both current and historical views of latency snapshots between OCI regions. This information helps you understand the network performance between regions over time, allowing you to optimize the placement of resources and data transfer operations.
Optimization Use: By analyzing latency data, you can make informed decisions on where to store backups and how to efficiently transfer data across regions, potentially reducing costs and improving performance.
Oracle Cloud Infrastructure Documentation: Inter-Region Latency Dashboard
30. Frage
Which Oracle Cloud Infrastructure (OCI) Identity and Access Management (IAM) policy is invalid?
  • A. Allow dynamic-group 'Default'/'FrontEnd' to manage instance-family in compartment Project-A
  • B. Allow group 'Default'/'A-Admins' to manage all-resources in compartment Project-A
  • C. Allow group 'Default'/'A-Developers' to create volumes in compartment Project-A
  • D. Allow any-user to inspect users in tenancy
Antwort: D
Begr¨¹ndung:
In Oracle Cloud Infrastructure (OCI), Identity and Access Management (IAM) policies are used to control access to resources. The policy in option C is invalid because "any-user" is not a valid principal in OCI IAM policies. OCI policies can only grant permissions to groups or dynamic groups, but not to arbitrary users.
Here's an explanation for each option:
A . Allow dynamic-group 'Default'/'FrontEnd' to manage instance-family in compartment Project-A: This is valid. It grants the dynamic group 'FrontEnd' the ability to manage instances within the Project-A compartment.
B . Allow group 'Default'/'A-Admins' to manage all-resources in compartment Project-A: This is valid. It provides full administrative access to all resources in the Project-A compartment for the 'A-Admins' group.
C . Allow any-user to inspect users in tenancy: This is invalid because OCI does not allow the use of "any-user" in policies. You must specify a valid group or dynamic group to define permissions.
D . Allow group 'Default'/'A-Developers' to create volumes in compartment Project-A: This is valid. It permits the 'A-Developers' group to create volumes in the Project-A compartment.
For reference:
OCI Policy Reference
31. Frage
Which compute capacity type would you select to meet these requirements?
  • A. Capacity reservation
  • B. Dedicated host
  • C. On-demand capacity
  • D. Preemptible capacity
Antwort: C
Begr¨¹ndung:
On-demand capacity is the compute capacity type in Oracle Cloud Infrastructure (OCI) that allows you to provision and use compute instances whenever needed, without any long-term commitment. This flexibility is ideal for various workloads, including development, testing, and production environments, where immediate availability and scalability are crucial.
Key Points:
On-Demand Capacity: On-demand compute instances provide users with the flexibility to spin up instances as required and only pay for the time the instances are running. This model is most suitable for workloads with unpredictable usage patterns or short-term requirements.
Flexibility and Scalability: With on-demand capacity, you can quickly scale your resources up or down based on your application's needs, ensuring that you only pay for the resources you actually use.
No Commitment: Unlike reserved capacity, on-demand capacity does not require any long-term commitment or upfront payment, making it an attractive option for organizations looking to avoid capital expenditures.
Oracle Cloud Infrastructure Documentation: OCI Compute Pricing
Oracle Cloud Infrastructure Documentation: Compute Instance Lifecycle
Explanation of Incorrect Options:
A . Capacity reservation: This option allows you to reserve capacity in advance, ensuring that resources are available when needed. It's ideal for predictable workloads but may not be as cost-effective for fluctuating demands.
B . Preemptible capacity: Preemptible instances are a lower-cost option where instances can be terminated by OCI if resources are needed elsewhere. This is suitable for non-critical workloads that can tolerate interruptions.
D . Dedicated host: Dedicated hosts provide physical servers for your exclusive use, offering isolation and predictable performance. This option is more suitable for workloads requiring dedicated resources or compliance needs.
Thus, Option C: On-demand capacity is the correct choice for most general-purpose workloads needing flexibility and immediate availability without long-term commitment.
32. Frage
Wenn Sie die Fragen und Antworten zur Oracle 1Z0-1072-25 Pr¨¹fung von ExamFragen kaufen, können Sie ihre wichtige Vorbereitung im leben treffen und die Fragenkataloge von guter Qualität bekommen. Kaufen Sie unsere Produkte heute, dann öffnen Sie sich eine T¨¹r, um eine bessere Zukunft zu haben. Sie können auch mit weniger M¨¹he den großen Erfolg erzielen.
1Z0-1072-25 Online Test: https://www.examfragen.de/1Z0-1072-25-pruefung-fragen.html
P.S. Kostenlose 2026 Oracle 1Z0-1072-25 Pr¨¹fungsfragen sind auf Google Drive freigegeben von ExamFragen verf¨¹gbar: https://drive.google.com/open?id=1mVNQOXuNnMCLZ9fmTfz8PAWaD0LmHS9s
Posted at 1/25/2026 08:48:07        Only Author  2#
Your article is truly amazing; I appreciate your sharing! Explore E_S4CON_2025 valid test passing score, which is packed with valuable content, freely available to help you.
Posted at 2/4/2026 14:42:03        Only Author  3#
So much wisdom in this article, thank you for sharing it! Using this Latest 350-801 vce exam simulator, I secured a promotion and salary boost. Now it¡¯s free for everyone. Wishing you all success in your professional paths!
Posted at 2/7/2026 06:40:27        Only Author  4#
Die angemessene Bildung ist die Garantie des Erfolgs. Deshalb ist es sehr wichtig, diese Pr¨¹fung auszuwählen. Wir bieten Ihnen die neuesten und effektivsten Pr¨¹fungsfragen und Testantworten zur Cisco 300-745 Zertifizierung. Und Wir ZertPruefung garantieren 100% Erfolg. Und der Preis ist auch g¨¹nstig. Die Bezahlung bei Paypal kann Ihre Sicherheit garantieren. Wir ZertPruefung bieten die besten Lernhilfe f¨¹r Cisco 300-745 Pr¨¹fungen und auch aktualisieren immer die Pr¨¹fungsunterlagen.
Posted at 2/15/2026 22:34:13        Only Author  5#
Your article was truly unforgettable, thank you for sharing it. Here's the Reliable OMG-OCEB2-FUND100 exam camp test that helped me land my promotion and raise. It's free today¡ªgood luck with your career progress!
Posted at 2/18/2026 05:11:01        Only Author  6#
Thank you for sharing your article, it¡¯s been truly enlightening. Improve your IT skills and grab the free L4M2 test blueprint. Best of luck with everything!
