Pass Guaranteed Perfect Oracle - 1z0-076 - New Oracle Database 19c: Data Guard A
Posted at 1/13/2026 02:58:33
View186
Replies2
P.S. Free & New 1z0-076 dumps are available on Google Drive shared by PDFVCE: https://drive.google.com/open?id=1UJ0nM3Cl2nclRrY0D7SKB95zugg7iH1D
Our 1z0-076 latest preparation materials provide users with three different versions, including a PDF version, a software version, and an online version. Although involved three versions of the 1z0-076 teaching content is the same, but for all types of users can realize their own needs, whether it is which version of 1z0-076 Learning Materials, believe that can give the user a better 1z0-076 learning experience. Below, I would like to introduce you to the main advantages of our research materials, and I'm sure you won't want to miss it.
Oracle 1z0-076 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
| | Topic 2 | - Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
| | Topic 3 | - Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
| | Topic 4 | - Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
| | Topic 5 | - Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
| | Topic 6 | - Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
| | Topic 8 | - Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
| | Topic 9 | - Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
| | Topic 10 | - Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
| | Topic 11 | - Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
| | Topic 12 | - Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
Oracle 1z0-076 Lead2pass - Exam Cram 1z0-076 PdfIf you buy PDFVCE exam dumps, you will obtain free update for a year. Once the dumps update, PDFVCE will immediately send the latest 1z0-076 Certification 1z0-076 training materials to your mailbox. You can also request we provide you with the latest dumps at any time. If you want to know the latest exam questions, even if you have passed the certification test, PDFVCE will also free update exam dumps for you.
Oracle Database 19c: Data Guard Administration Sample Questions (Q12-Q17):NEW QUESTION # 12
You created the PRODSBY1 physical standby database for the PROD primary database using gql and RMAN.
You are planning to create a Data Guard Broker configuration. You execute the command:
Which three statements are true regarding the execution of the command?
- A. The PRODSBY1 standby database is automatically added to the configuration if DG_BROKER_START is TRUE for PRODSBYl.
- B. The PRODSBYI standby database is automatically added to the configuration if Oracle Net connectivity to the PRODSBYl database instance is defined on the primary host.
- C. The command will execute successfully only if Oracle Net connectivity to the PROD and PRODSBYl database instances are defined on the primary host.
- D. The Data Guard Broker configuration files is automatically created in the destinations specified by the DG_BROKER_CONFIG_FILEn initialization parameters on the primary database.
- E. The command will execute successfully only if the DG_BROKER_START initialization parameter is set to TRUE for the PROD database instance.
- F. The command will execute successfully only if Oracle Net connectivity to the PROD database instance is defined on the primary host.
Answer: D,E,F
The command executed (CREATE CONFIGURATION 'DGConfig' AS PRIMARY DATABASE IS ' PROD' CONNECT IDENTIFIER IS PROD;) is used to create a Data Guard Broker configuration named
'DGConfig'. The successful execution of this command depends on several conditions:
* A: The DG_BROKER_START parameter must be set to TRUE on the primary database to start the Data Guard Broker processes. Without the broker processes running, the configuration cannot be created.
* D: Oracle Net connectivity to the PROD database instance must be established on the primary host. This is because the Data Guard Broker requires network accessibility to communicate with the primary database and manage the configuration.
* E: When the configuration is created, the Data Guard Broker configuration files are indeed automatically created in the locations specified by the DG_BROKER_CONFIG_FILEn parameters on the primary database.
It's important to note that the command will not automatically add the PRODSBY1 standby database to the configuration (thus B and C are not correct), and there is no requirement for the standby database to have Oracle Net connectivity defined on the primary host for the execution of this command (making F incorrect as well).
References: This information can be validated in Oracle's Data Guard Broker documentation, which outlines the requirements for setting up and managing a Data Guard configuration using the Data Guard Broker.
NEW QUESTION # 13
You created a physical standby database prodsbyi from the primary database prod using SQL and RMAN.
Which THREE are prerequisites for creating a Data Guard Broker configuration to manage these databases?
- A. A local net service name to enable connectivity to the PRODSBYI database instance must be defined on the primary database host.
- B. The primary database must have FORCE LOGGING enabled.
- C. The DG_BROKER_START parameter must be set to TRUE for both database instances.
- D. The standby database must have supplemental logging enabled.
- E. The primary database must have supplemental logging enabled.
- F. The LOG_ARCHIVE_DEST_n parameters with the service attribute set must be cleared.
Answer: A,C,E
When setting up a Data Guard Broker configuration for a primary database and its physical standby, the following prerequisites must be met:
* A: Oracle Net connectivity must be defined on both the primary and standby hosts to enable the respective database instances to communicate with each other.
* B: Supplemental logging is required on the primary database because it provides additional logging necessary for the standby database to be able to apply changes from the primary database accurately.
* F: The DG_BROKER_START parameter must be set to TRUE for both the primary and standby
* database instances. This parameter is used to start the Data Guard Broker process which manages the configuration.
Options C and D are not prerequisites for creating a Data Guard Broker configuration. Additionally, while FORCE LOGGING mode (option E) is recommended as a best practice to prevent possible data inconsistencies during media recovery, it is not a strict prerequisite for creating a Data Guard Broker configuration.
References: This guidance is based on Oracle's best practices for setting up Data Guard configurations, as found in the Oracle Data Guard Broker documentation and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 14
Which TWO statements are true about Far Sync instances?
- A. They do not work with Logical Standby databases.
- B. They work in Maximum Performance mode.
- C. They work in Maximum Availability mode.
- D. They do not work with Snapshot Standby databases.
- E. They work in Maximum Protection mode.
NEW QUESTION # 15
Which three are true about using Flashback database through role transitions in a Data Guard environment?
- A. Physical standby databases retain their current role when you flash back to a point in time before the switchover occurred which caused this database to become a physical standby.
- B. Physical standby databases retain their current role when you flash back to a point in time before a reinstate occurred which caused this database to become a physical standby.
- C. Logical standby database roles are reverted to their original role when you flash back to a point in time before the switchover occurred which caused this database to become a logical standby.
- D. Logical standby databases retain their current role when you flash back through to a point in time before the switchover occurred which caused this database to become a logical standby.
- E. Flashback database may not be used to undo a physical standby database activation.
Answer: A,B,E
NEW QUESTION # 16
Which four factors can influence the rate of SQL apply on a logical standby database?
- A. the number of coordinator processes on the standby database instance
- B. the size of the undo tablespace on the logical standby database
- C. the number of PREPAER processes
- D. the number of full table scans performed by SQL apply
- E. the number of applier processes
- F. the size of the shared pool
Answer: A,C,D,E
The rate of SQL apply on a logical standby database can be influenced by:
A: The number of PREPARER processes (which seems to be a typographical error and should read as PREPARER or similar) which prepare the redo data for the applier processes.
B: The number of coordinator processes on the standby database instance which coordinate the SQL apply activities.
C: The number of full table scans performed by SQL apply since full table scans can be resource-intensive and slow down the apply rate.
E: The number of applier processes which apply the redo data to the logical standby database.
Option D is incorrect as the size of the undo tablespace on the logical standby database is more likely to affect the SQL apply lag rather than the rate of SQL apply.
Option F is incorrect because the size of the shared pool would typically not influence the rate of SQL apply. The shared pool is more related to the caching of shared SQL and PL/SQL code and control structures.
NEW QUESTION # 17
If you cannot complete the task efficiently, we really recommend using 1z0-076 learning materials. Through the assessment of your specific situation, we will provide you with a reasonable schedule, and provide the extensible version of 1z0-076 exam training you can quickly grasp more knowledge in a shorter time. In the same time, you will do more than the people around you. This is what you can do with 1z0-076 Test Guide. Our 1z0-076 learning guide is for you to improve your efficiency and complete the tasks with a higher quality. You will stand out from the crowd both in your studies and your work. The high quality of 1z0-076 exam training is tested and you can be assured of choice.
1z0-076 Lead2pass: https://www.pdfvce.com/Oracle/1z0-076-exam-pdf-dumps.html
- 1z0-076 Practice Exam Pdf 📫 1z0-076 Test Questions Fee 👮 Exam 1z0-076 Simulator Fee 🕕 Search for 1z0-076 and easily obtain a free download on ☀ [url]www.prepawaypdf.com ️☀️ 👇1z0-076 Test Quiz[/url]
- Latest Released New 1z0-076 Test Discount - Oracle Oracle Database 19c: Data Guard Administration Lead2pass 🌺 The page for free download of ☀ 1z0-076 ️☀️ on [url]www.pdfvce.com will open immediately 🕚1z0-076 Test Passing Score[/url]
- 1z0-076 Practice Exam Pdf 🧎 1z0-076 Online Tests 🥐 1z0-076 Pass Guarantee 🦦 Search for ▛ 1z0-076 ▟ and easily obtain a free download on [url]www.examdiscuss.com 🧭1z0-076 Sample Questions[/url]
- Latest Released New 1z0-076 Test Discount - Oracle Oracle Database 19c: Data Guard Administration Lead2pass 🏐 Open [url]www.pdfvce.com enter ⏩ 1z0-076 ⏪ and obtain a free download 🌑Reliable 1z0-076 Test Vce[/url]
- 100% Pass 2026 High Pass-Rate Oracle New 1z0-076 Test Discount 😟 Enter ▶ [url]www.dumpsquestion.com ◀ and search for ⇛ 1z0-076 ⇚ to download for free 🗓1z0-076 Test Passing Score[/url]
- Interactive 1z0-076 Practice Exam 👤 1z0-076 Practice Exam Pdf 😤 1z0-076 Test Passing Score 🩲 Download 1z0-076 for free by simply entering { [url]www.pdfvce.com } website 🤭1z0-076 Exam PDF[/url]
- Latest Released New 1z0-076 Test Discount - Oracle Oracle Database 19c: Data Guard Administration Lead2pass 📔 Copy URL ➡ [url]www.prepawayexam.com ️⬅️ open and search for ⇛ 1z0-076 ⇚ to download for free 🎼1z0-076 Test Questions Fee[/url]
- [url=https://www.nowleads.fr/?s=Valid%20Dumps%201z0-076%20Free%20%f0%9f%90%ba%20Exam%20Questions%201z0-076%20Vce%20%e2%ad%95%201z0-076%20Practice%20Exam%20Pdf%20%f0%9f%8d%a5%20Easily%20obtain%20free%20download%20of%20[%201z0-076%20]%20by%20searching%20on%20%e2%9e%a4%20www.pdfvce.com%20%e2%ae%98%20%f0%9f%a6%af1z0-076%20Sample%20Questions]Valid Dumps 1z0-076 Free 🐺 Exam Questions 1z0-076 Vce ⭕ 1z0-076 Practice Exam Pdf 🍥 Easily obtain free download of [ 1z0-076 ] by searching on ➤ www.pdfvce.com ⮘ 🦯1z0-076 Sample Questions[/url]
- Exam Questions 1z0-076 Vce 🐁 Valid Dumps 1z0-076 Free 🔊 Valid Dumps 1z0-076 Free 🌉 Search on ▶ [url]www.practicevce.com ◀ for { 1z0-076 } to obtain exam materials for free download 🐥1z0-076 Practice Exam Pdf[/url]
- Expertly Crafted Online Oracle 1z0-076 Practice Test Engine 🔅 Search for ➡ 1z0-076 ️⬅️ and download it for free immediately on ⏩ [url]www.pdfvce.com ⏪ 🗯Interactive 1z0-076 Practice Exam[/url]
- Latest Released New 1z0-076 Test Discount - Oracle Oracle Database 19c: Data Guard Administration Lead2pass ⏮ Copy URL { [url]www.practicevce.com } open and search for 1z0-076 to download for free ❗Test 1z0-076 Dumps[/url]
- gataxiom19.blogspot.com, knowyourmeme.com, bbs.t-firefly.com, www.203060.vip, issuu.com, zenwriting.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, www.rohitgaikwad.com, Disposable vapes
