[General] 100% Pass Quiz 2026 FCP_FGT_AD-7.6: Latest FCP - FortiGate 7.6 Administrator Tes
82
General 100% Pass Quiz 2026 FCP_FGT_AD-7.6: Latest FCP - FortiGate 7.6 Administrator Tes
Posted at 1/13/2026 04:17:35      View175 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free & New FCP_FGT_AD-7.6 dumps are available on Google Drive shared by Pass4sures: https://drive.google.com/open?id=1VCXFA7S_BAuPrBUeP5iFhfYAKHmntAQZ
You may be in a condition of changing a job, but having your own career is unbelievably hard. Then how to improve yourself and switch the impossible mission into possible is your priority. If you want to pass FCP_FGT_AD-7.6 exam, here come our FCP_FGT_AD-7.6 exam prep giving you a helping hand. Our company has the highly authoritative and experienced team to help you pass the FCP_FGT_AD-7.6 Exam. You can not only get the most helpful and valid FCP_FGT_AD-7.6 exam questions, but also you can get according suggestions on how to pass the FCP_FGT_AD-7.6 exam.
Fortinet FCP_FGT_AD-7.6 Exam Syllabus Topics:
  • Firewall policies and authentication: This section of the exam measures the skills of firewall administrators and covers the implementation and management of security policies. It involves configuring basic and advanced firewall rules, applying Source NAT (SNAT) and Destination NAT (DNAT) options, and enforcing various firewall authentication methods. The section also includes deploying and configuring Fortinet Single Sign-On (FSSO) to streamline user access across the network.
  • Deployment and system configuration: This section of the exam measures the skills of network security engineers and covers essential tasks for setting up a FortiGate device in a production environment. Candidates are expected to perform the initial configuration, establish basic connectivity, and integrate the device within the Fortinet Security Fabric. They must also be able to configure a FortiGate Cluster Protocol (FGCP) high availability setup and troubleshoot resource and connectivity issues to ensure system readiness and network uptime.
  • Routing: This section of the exam measures the skills of firewall administrators and covers the configuration of routing features on FortiGate devices. It includes defining and applying static routes for directing traffic within and outside the network, as well as setting up Software-Defined WAN (SD-WAN) to distribute and balance traffic loads across multiple WAN connections efficiently.
  • Content inspection: This section of the exam measures the skills of network security engineers and covers the setup and management of content inspection features on FortiGate. Candidates must demonstrate an understanding of encrypted traffic inspection using digital certificates, identify and apply FortiGate inspection modes, and configure web filtering policies. The ability to implement application control for monitoring and regulating network application usage, configure antivirus profiles to detect and block malware, and set up Intrusion Prevention Systems (IPS) to shield the network from threats and vulnerabilities is also assessed.
Topic 5
  • VPN: This section of the exam measures the skills of network security engineers and covers the configuration and deployment of Virtual Private Network (VPN) solutions. Candidates are required to implement SSL VPNs to grant secure remote access to internal resources and configure IPsec VPNs in either meshed or partially redundant topologies to ensure encrypted communication between distributed network locations.
Excellent FCP_FGT_AD-7.6 Exam Questions provide you the most reliable Training Brain Dumps - Pass4suresWith over a decade's business experience, our FCP_FGT_AD-7.6 test torrent attached great importance to customers' purchasing experience. There is no need to worry about the speed on buying electronic products. For we make endless efforts to assess and evaluate our FCP_FGT_AD-7.6 exam prep' reliability for a long time and put forward a guaranteed purchasing scheme. If neccessary, you can also have our remotely online guidance to use our FCP_FGT_AD-7.6 Test Torrent. Normally, you can get our FCP_FGT_AD-7.6 practice questions in a few minutes after purchase with high efficiency!
Fortinet FCP - FortiGate 7.6 Administrator Sample Questions (Q70-Q75):NEW QUESTION # 70
Which statement correctly describes NetAPI polling mode for the FSSO collector agent?
  • A. The collector agent uses a Windows API to query DCs for user logins.
  • B. The collector agent must search Windows application event logs.
  • C. NetAPI polling can increase bandwidth usage in large networks.
  • D. The NetSessionEnum function is used to track user logouts.
NetAPI polling mode involves frequent queries to domain controllers, which can cause increased bandwidth usage, especially in large networks with many login events.
NEW QUESTION # 71
Refer to the exhibit, which contains a RADIUS server configuration.
An administrator added a configuration for a new RADIUS server. While configuring, the administrator enabled Include in every user group.
What is the impact of enabling Include in every user group in a RADIUS configuration?
  • A. This option places all FortiGate users and groups required to authenticate into the RADIUS server, which, in this case, is FortiAuthenticator.
  • B. This option places the RADIUS server, and all users who can authenticate against that server, into every FortiGate user group.
  • C. This option places all users into every RADIUS user group, including groups that are used for the LDAP server on FortiGate.
  • D. This option places the RADIUS server, and all users who can authenticate against that server, into every RADIUS group.
Enabling Include in every user group in the RADIUS configuration means the RADIUS server is automatically added to all FortiGate user groups. As a result, any user who can authenticate successfully against that RADIUS server becomes a member of every FortiGate user group, without needing to be manually assigned. This can inadvertently grant excessive access if not carefully controlled.
NEW QUESTION # 72
Refer to the exhibit, which shows a routing table.
An administrator wants to create a new static route so the traffic to the subnet 172.20.1.0/24 is routed through port2 only.
What are the two criteria that the administrator can use to achieve this objective? (Choose two.)
  • A. The new static route must have the priority set to 3.
  • B. The new static route must have the metric set to 1.
  • C. The existing static route through port3 must have the distance set to 11.
  • D. The new static route must have the distance set to 9.
Currently, subnet 172.20.1.0/24 is routed through port3 with distance 9 and priority 2. To force routing through port2, the administrator must:
- Increase the distance of the existing route via port3 (e.g., to 11), making it less preferred.
- Configure the new static route on port2 with a higher priority value (e.g., 3) so it overrides the current port3 route when distances are equal.
NEW QUESTION # 73
Based on the Exhibits:
A web filter profile configuration and firewall policy configuration are shown.
You are trying to access www.facebook.com, but you are redirected to a FortiGuard web filtering block page.
Based on the exhibits, what is the possible cause of the issue?
  • A. The web rating override configuration is incorrect.
  • B. For www.facebook.com, the URL filter action is incorrect.
  • C. The firewall policy inspection mode is incorrect.
  • D. The web filter profile feature set is configured incorrectly.
NEW QUESTION # 74
Refer to the exhibits. You have implemented the application sensor and the corresponding firewall policy as shown in the exhibits.
You cannot access any of the Google applications, but you are able to access www.fortinet.com.
What would you do to resolve this issue?
  • A. Move up Google in the Application and Filter Overrides section to set its priority to 1.
  • B. Set SSL inspection to deep-content-inspection.
  • C. Add *Google*.com to the URL category in the security profile.
  • D. Change the Inspection mode to Proxy-based.
In the Application and Filter Overrides, the Excessive-Bandwidth filter (set to Block) is priority 1, and Google (set to Monitor) is priority 2. Since overrides are evaluated by priority, Google traffic is being blocked by the higher-priority rule. Moving Google to the top (priority 1) ensures it is matched first, allowing access while still monitoring it.
NEW QUESTION # 75
Many of the candidates like the Soft version of our FCP_FGT_AD-7.6 exam questions. The software of FCP_FGT_AD-7.6 guide torrent boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our FCP_FGT_AD-7.6 Exam Questions boost timing function and the function to stimulate the exam. Our product sets the timer to stimulate the exam to adjust the speed and keep alert. So it is worthy for you to buy our FCP_FGT_AD-7.6 exam questions.
FCP_FGT_AD-7.6 Practice Guide: https://www.pass4sures.top/Network-Security/FCP_FGT_AD-7.6-testking-braindumps.html
DOWNLOAD the newest Pass4sures FCP_FGT_AD-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1VCXFA7S_BAuPrBUeP5iFhfYAKHmntAQZ
Posted at 2/13/2026 19:50:24        Only Author  2#
It was such a valuable learning experience. New PEGACPSSA24V1 test braindumps has outstanding resources that are free of charge.
