[General] 2026 Newest Juniper Pass JN0-664 Guaranteed
93
General 2026 Newest Juniper Pass JN0-664 Guaranteed
Posted at 1/13/2026 05:26:02      View200 | Replies1        Print      Only Author   [Copy Link] 1#
2026 Latest Lead2Passed JN0-664 PDF Dumps and JN0-664 Exam Engine Free Share: https://drive.google.com/open?id=1wPdWa6dcAQ0aSEkjQPBGf_aSIngl0u02
Our experts are well-aware of the problems of exam candidates particularly of those who cant manage to spare time to study the JN0-664 exam questions due to their heavy work pressure. Hence, our JN0-664 study materials have been developed into a simple content and language for our worthy customers all over the world. What is more, you will find there are only the keypoints in our JN0-664 learning guide.
Juniper JN0-664 exam is an essential certification for IT professionals who want to demonstrate their expertise in service provider routing and switching. JN0-664 exam is challenging and requires a solid understanding of Juniper Networks' service provider routing and switching platforms. However, with the right preparation and resources, candidates can successfully pass the JN0-664 Exam and become certified professionals in service provider routing and switching.
JN0-664 Download Pdf - Well JN0-664 PrepIn a year after your payment, we will inform you that when the JN0-664 exam guide should be updated and send you the latest version. Our company has established a long-term partnership with those who have purchased our JN0-664 exam questions. We have made all efforts to update our products in order to help you deal with any change, making you confidently take part in the JN0-664 Exam. Every day they are on duty to check for updates of JN0-664 study materials for providing timely application. We also welcome the suggestions from our customers, as long as our clients propose rationally.
Juniper Service Provider, Professional (JNCIP-SP) Sample Questions (Q31-Q36):NEW QUESTION # 31
Click the Exhibit button.
Which two statements are correct about the class-of-service configuration shown in the exhibit? (Choose two.)
  • A. The best-effort queue can never transmit more than 40% of the total bandwidth on the ge-0/0/0 interface, even if that bandwidth is available.
  • B. Incoming traffic will not be classified because no classifier exists in the configuration.
  • C. Incoming traffic will be classified using the default classifier.
  • D. The best-effort queue can transmit more than 40% of the total bandwidth on the ge-0/0/0 interface, if no other queue is using that bandwidth.
The class-of-service (CoS) configuration in the exhibit shows how traffic is scheduled on the ge-0/0/0 interface. Let's analyze each statement to determine its correctness:
A: Incoming traffic will not be classified because no classifier exists in the configuration.
* This statement is correct. The configuration shown does not include any classifier, so no explicit classification is defined. As a result, incoming traffic will not be classified according to any custom criteria.
B: The best-effort queue can transmit more than 40% of the total bandwidth on the ge-0/0/0 interface, if no other queue is using that bandwidth.
* This statement is correct. The transmit-rate percent 40 means that 40% of the bandwidth is guaranteed for the best-effort queue, but it can use more bandwidth if other queues (like the priority scheduler) are not utilizing their allocated bandwidth.
C: Incoming traffic will be classified using the default classifier.
* This statement is incorrect. Without an explicit classifier in the configuration, there is no mention of a default classifier being used. Therefore, the incoming traffic won't be classified based on the configuration shown.
D: The best-effort queue can never transmit more than 40% of the total bandwidth on the ge-0/0/0 interface, even if that bandwidth is available.
* This statement is incorrect. The transmit-rate percent 40 sets a guaranteed minimum bandwidth but does not set a maximum limit. The best-effort queue can utilize more bandwidth if other queues are not using their allocated portions.
NEW QUESTION # 32
(Choose two.)
  • A. The drop probability gradually increases from 20% to 60% as the queue level increases from 50% full to 75% full.
  • B. To use this drop profile, you apply it directly to an interface.
  • C. To use this drop profile, you reference it in a scheduler.
  • D. The drop probability jumps immediately from 20% to 60% when the queue level reaches 75% full.
NEW QUESTION # 33
Exhibit
A network is using IS-IS for routing.
In this scenario, why are there two TLVs shown in the exhibit?
  • A. Wide metrics have specifically been requested
  • B. Both IPv4 and IPv6 are being used in the topology
  • C. There are both narrow and wide metric devices in the topology
  • D. The interface specified a metric of 100 for L2.
TLVs are tuples of (Type, Length, Value) that can be advertised in IS-IS packets. TLVs can carry different kinds of information in the Link State Packets (LSPs). IS-IS supports both narrow and wide metrics for link costs. Narrow metrics use a single octet to encode the link cost, while wide metrics use three octets. Narrow metrics have a maximum value of 63, while wide metrics have a maximum value of 16777215. If there are both narrow and wide metric devices in the topology, IS-IS will advertise two TLVs for each link: one with the narrow metric and one with the wide metric. This allows backward compatibility with older devices that only support narrow metrics12.
NEW QUESTION # 34
Referring to the exhibit, which two statements are true? (Choose two.)
  • A. The multipath configuration is used for load balancing.
  • B. This route is learned from the same AS number.
  • C. This route is learned from two different AS numbers.
  • D. The multihop configuration is used for load balancing.
In the exhibit, the output of the `show route protocol bgp` command is shown for the prefix `172.16.20.4/30`.
Let's analyze the provided BGP routing table to determine which statements are correct.
1. **AS Path Analysis**:
- The AS path for the route `172.16.20.4/30` is shown as `2 I`.
- This indicates that the route was learned from AS 2 and it is an internal (iBGP) route within the same AS.
2. **Multiple Paths**:
- The route has two next-hop IP addresses: `10.0.18.2` via interface `ge-1/0/4.0` and `10.0.19.2` via interface
`ge-1/0/5.0`.
- This indicates that BGP multipath is configured, which allows multiple equal-cost paths to be used for load balancing.
- BGP multipath must be explicitly configured to use multiple paths for the same prefix.
3. **Multihop vs. Multipath**:
- **Multihop Configuration**: This is typically used for establishing BGP sessions with peers that are not directly connected. It is not related to load balancing.
- **Multipath Configuration**: This is used to enable load balancing across multiple paths for the same prefix, which is the case here.
**Conclusion**:
Given the above analysis:
- **C. This route is learned from the same AS number**: Correct. The AS path `2 I` indicates the route was learned from the same AS number (AS 2).
- **D. The multipath configuration is used for load balancing**: Correct. The presence of multiple next-hops indicates that BGP multipath is configured for load balancing.
Thus, the correct answers are:
**C. This route is learned from the same AS number.**
**D. The multipath configuration is used for load balancing.**
**References**:
- Junos OS BGP Multipath Documentation: [Junos OS BGP
Multipath](https://www.juniper.net/document ... /bgp-multipath.html)
- Junos OS BGP Configuration Guide: [Junos OS BGP
Configuration](https://www.juniper.net/document ... uting-overview.html)
NEW QUESTION # 35
Exhibit
R1 and R8 are not receiving each other's routes
Referring to the exhibit, what are three configuration commands that would solve this problem? (Choose three.)
  • A. Configure as-override on advertisement from AS 64500 toward AS 64512.
  • B. Configure loops and advertise-peer-as on routers in AS 64497 and AS 64450.
  • C. Configure remove-private on advertisements from AS 64497 toward AS 64498
  • D. Configure loops on routers in AS 65412 and advertise-peer-as on routers in AS 64498.
  • E. Configure remove-private on advertisements from AS 64500 toward AS 64499
Answer: C,D,E
The problem in this scenario is that R1 and R8 are not receiving each other's routes because of private AS numbers in the AS path. Private AS numbers are not globally unique and are not advertised to external BGP peers. To solve this problem, you need to do the following:
* Configure loops on routers in AS 65412 and advertise-peer-as on routers in AS 64498. This allows R5 and R6 to advertise their own AS number (65412) instead of their peer's AS number (64498) when sending updates to R7 and R8. This prevents a loop detection issue that would cause R7 and R8 to reject the routes from R5 and R62.
* Configure remove-private on advertisements from AS 64497 toward AS 64498 and from AS 64500
* toward AS 64499. This removes any private AS numbers from the AS path before sending updates to external BGP peers. This allows R2 and R3 to receive the routes from R1 and R4, respectively3.
NEW QUESTION # 36
Don't worry because "Lead2Passed" is here to save you from these losses with its updated and real Juniper JN0-664 exam questions. We provide you with the latest prep material which is according to the content of Juniper JN0-664 Certification Exam and enhances your knowledge to crack the test. Lead2Passed practice material is made by keeping in focus all the sections of the current syllabus.
JN0-664 Download Pdf: https://www.lead2passed.com/Juniper/JN0-664-practice-exam-dumps.html
BONUS!!! Download part of Lead2Passed JN0-664 dumps for free: https://drive.google.com/open?id=1wPdWa6dcAQ0aSEkjQPBGf_aSIngl0u02
Posted at 1/25/2026 08:07:08        Only Author  2#
I cant thank you enough for your article, it really made an impression. With MB-820 test valid, you get access to valuable content at no cost, designed for your benefit.
