[General] 100% Pass 4A0-113 - Authoritative Latest Nokia OSPF Routing Protocol Exam Exam O
90
General 100% Pass 4A0-113 - Authoritative Latest Nokia OSPF Routing Protocol Exam Exam O
Posted at 1/13/2026 05:38:41      View148 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PracticeDump 4A0-113 dumps for free: https://drive.google.com/open?id=1avG_4BngHvo0gdaSbOGKFsHJXl7VQSba
Our experts update the 4A0-113 training materials every day and provide the latest update timely to you. If you have the doubts or the questions about our product and the purchase procedures you can contact our online customer service personnel at any time. We provide the discounts to the old client and you can have a free download and tryout of our 4A0-113 Test Question before your purchase. So there are many merits of our product. Read the introduction of the characteristics and the functions of our 4A0-113 practice test as follow carefully before you purchase our product.
It never needs an internet connection. Nokia Nokia OSPF Routing Protocol Exam practice exam software has several mock exams, designed just like the real exam. Nokia 4A0-113 Practice Exam software contains all the important questions which have a greater chance of appearing in the final exam. PracticeDump always tries to ensure that you are provided with the most updated Nokia OSPF Routing Protocol Exam Exam Questions to pass the exam on the first attempt.
4A0-113 Relevant Answers & Exam 4A0-113 TutorialPracticeDump Nokia 4A0-113 Practice Test dumps are doubtless the best reference materials compared with other 4A0-113 exam related materials. If you still don't believe it, come on and experience it and then you will know what I was telling you was true. You can visit PracticeDump.com to download our free demo. There are two versions of PracticeDump dumps. The one is PDF version and another is SOFT version. You can experience it in advance. In this, you can check its quality for yourself.
Nokia OSPF Routing Protocol Exam Sample Questions (Q83-Q88):NEW QUESTION # 83
Which of the following LSA types stay within an OSPF area, and are not flooded outside of the area? Choose two answers.
  • A. Summary router LSA
  • B. Network LSA
  • C. Router LSA
  • D. Summary network LSA
  • E. Type 5 (AS external) LSAs
From Nokia 7750 SR OS Routing Protocols Guide (OSPF LSA Types Summary):
A (Router LSA - Type 1): Always area-scoped.
B (Network LSA - Type 2): Always area-scoped.
C & D (Summary LSAs - Type 3): Flooded between areas.
E (AS-External LSAs - Type 5): Have AS-wide scope.
Thus, correct answers: A, B.
NEW QUESTION # 84
When are virtual links used in OSPF?
  • A. When two areas need to communicate and there is no area 0.
  • B. When two areas are connected to area 0, but there is no direct path between them.
  • C. When an area needs to connect directly to another area without using area 0.
  • D. When an area needs to traverse another area to reach area 0.
FromNokia 7750 SR OS OSPF Guide - Virtual Links Section:
"A virtual link is used when an area that is not physically connected to area 0 needs to logically connect through another area to maintain OSPF backbone integrity." Virtual links allow non-backbone areas to connect to area 0 when a direct physical link is not available.
OSPF requires that all areas must be logically attached to area 0.
Thus, the correct answer is B.
NEW QUESTION # 85
If a Router originates a type 1 router LSA with the E bit set, what types of areas can it belong to? Select all that apply.
  • A. Not So Stubby Area
  • B. Standard Area
  • C. Backbone Area
  • D. Stub Area
Answer: A,B,C
From Nokia 7750 SR OS Routing Protocols Guide (OSPF LSA Type 1 - Router LSAs):
The E-bit indicates that external LSAs (Type 5) are allowed in the area.
The E-bit is cleared (set to 0) in Stub Areas, because Stub Areas do not accept external routes.
In Standard Areas (Normal Areas) and Backbone Areas, the E-bit remains set.
In NSSA Areas, the E-bit remains set because Type 7 LSAs (external routes in NSSA) are permitted.
Thus, correct answers: A, C, D.
NEW QUESTION # 86
Which of the following statements best describes the function of an OSPF Type 4 LSA?
  • A. A Type 4 LSA is originated by an ABR that is connected to a stub area. The LSA is injected into the stub area to provide routing information.
  • B. A Type 4 LSA is originated by an ABR to describe a route to an ASBR to routers outside the area.
  • C. A Type 4 LSA is originated by an ABR that is connected to a stub area. The LSA is injected into the backbone area to provide routing information.
  • D. A Type 4 LSA is originated by an ASBR to describe a route to itself to routers outside the area.
NEW QUESTION # 87
Which of the following OSPF area types are supported by the Alcatel-Lucent 7750 SR? Choose two answers.
  • A. Level1 area WC
  • B. Partially stubby areas
  • C. Stub areas
  • D. Level 2 areas
  • E. Not so stubby areas
Answer: C,E
FromNokia 7750 SR OS OSPF Guide - Area Types Section:
"The 7750 SR supports standard areas, stub areas, and not-so-stubby areas (NSSA)." NSSA (Not-So-Stubby Areas) are supported.
Stub Areas are supported.
Terms like Level 1, Level 2, or WC do not apply to OSPF but rather to IS-IS.
Thus, the correct answers are A and C.
NEW QUESTION # 88
PracticeDump is a website which can give much convenience and meet the needs and achieve dreams for many people participating 4A0-113 Certification exams. If you are still worrying about passing some Nokia certification exams, please choose PracticeDump to help you. PracticeDump can make you feel at ease, because we have a lot of Nokia certification exam related training materials with high quality, coverage of the outline and pertinence, too, which will bring you a lot of help. You won't regret to choose PracticeDump, it can help you build your dream career.
4A0-113 Relevant Answers: https://www.practicedump.com/4A0-113_actualtests.html
The third format of the PracticeDump Nokia 4A0-113 exam dumps is the 4A0-113 Dumps PDF, Purchasing 4A0-113 exam training materials, we provide you with free updates for a year, Nokia Latest 4A0-113 Exam Online If your answer is noyou are a right place now, With our 4A0-113 learning materials, what you receive will never be only the content of the material, but also our full-time companionship and meticulous help, Because passing the test certification can help you prove that you are competent in some area and if you buy our 4A0-113 study materials you will pass the test almost without any problems.
The Purpose of Contracts, To build on your understanding of these 4A0-113 information security building blocks, you need to understand how the discipline of cryptography is applied to distributed messages.
4A0-113 Pass-Sure Materials - 4A0-113 Quiz Bootcamp & 4A0-113 Test QuizThe third format of the PracticeDump Nokia 4A0-113 Exam Dumps is the 4A0-113 Dumps PDF, Purchasing 4A0-113 exam training materials, we provide you with free updates for a year.
If your answer is noyou are a right place now, With our 4A0-113 learning materials, what you receive will never be only the content of the material, but also our full-time companionship and meticulous help.
DOWNLOAD the newest PracticeDump 4A0-113 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1avG_4BngHvo0gdaSbOGKFsHJXl7VQSba
Posted at 1/24/2026 11:10:57        Only Author  2#
Thank you for your wonderful share; this article really opened my eyes! Time to take the Latest S2000-022 test blueprint exam. Hope I pass with flying colors!
