[Hardware] New MB-820 Exam Preparation, Latest MB-820 Test Simulator
94
Hardware New MB-820 Exam Preparation, Latest MB-820 Test Simulator
Posted at 1/13/2026 06:14:46      View170 | Replies3        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Dumps4PDF MB-820 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1xE4kIakHdlaIFNfxSMWUKvTiNygpCS9X
Our product is revised and updated according to the change of the syllabus and the latest development situation in the theory and the practice. The MB-820 exam torrent is compiled elaborately by the experienced professionals and of high quality. The contents of MB-820 guide questions are easy to master and simplify the important information. It conveys more important information with less answers and questions, thus the learning is easy and efficient. The language is easy to be understood makes any learners have no obstacles. The MB-820 Test Torrent is suitable for anybody no matter he or she is in-service staff or the student, the novice or the experience people who have worked for years. The software boosts varied self-learning and self-assessment functions to check the results of the learning.
Microsoft MB-820 Exam Syllabus Topics:
  • Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic.  It also explains implementation of APIs.
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
  • Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
Pass Guaranteed Quiz MB-820 - Updated New Microsoft Dynamics 365 Business Central Developer Exam PreparationWith the Microsoft MB-820 qualification certificate, you are qualified to do this professional job. Therefore, getting the test MB-820 certification is of vital importance to our future employment. And the Microsoft Dynamics 365 Business Central Developer MB-820 Study Tool can provide a good learning platform for users who want to get the test Microsoft Dynamics 365 Business Central Developer MB-820 certification in a short time.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q58-Q63):NEW QUESTION # 58
You need to call the Issue API action from the mobile application.
Which action should you use?
  • A. POST/issues(88122e0e-5796-ec11-bb87-000d3a392eb5)/MicrosoftNAV.Copy
  • B. POST /issues (88122e0e-5796-ec11 -bb87-000d3a392eb5)/copy
  • C. POST /issues (88122e0e-5796-ec11 -bb87-000d3a392eb5)/Copy
  • D. POST/issues (88122e0e-5796-ec11-bb87-000d3a392eb5yMicrosoit.NAV.copy
  • E. PATCH /issues {88122 eOe-5796-ed 1 -bb87-000d3a392eb5)/Mkrosotl.NAV.Copy
In the context provided by the case study, when calling an API action from a mobile application, the correct format for a POST request to an action in Business Central typically involves specifying the entity (/issues), the ID of the entity (88122e0e-5796-ec11-bb87-000d3a392eb5), and the action to be called (/Copy). The action name should match the exact name as defined in the AL code, which is case-sensitive.
Option A is incorrect because it uses a non-standard format for the action call.
Option B uses the PATCH method, which is generally used for update operations, not for calling actions.
Option C is correct as it uses the POST method, which is appropriate for calling actions, and correctly specifies the entity, ID, and action name.
Option D is incorrect because the action name /copy is in lowercase, while AL is case-sensitive, and it should match the case exactly as defined in the code.
Option E incorrectly adds 'MicrosoftNAV' before the action name, which is not standard for calling actions in Business Central APIs.
Hence, the correct action to use when calling the Issue API action from the mobile application is given in Option C.
NEW QUESTION # 59
A company plans to integrate tests with its build pipelines.
The company has two Docket sandbox environments: SandboxA and SandboxB.
You observe the following:
* SandboxA is configured without the Test Toolkit installed.
* SandboxB must be configured from scratch. The Test Toolkit must be installed in SandboxB during configuration.
You need to configure the sandbox environments.
How should you complete the cmdlets? To answer, select the appropriate options in the answer area.
Based on the PowerShell script snippet you've provided and the scenario described, you need to configure Docker sandbox environments for a company with specific requirements for Test Toolkit installations.
For SandboxA, since it is configured without the Test Toolkit installed, you would typically use the PowerShell cmdlet Install-TestToolkitToBcContainer to install the Test Toolkit into the Business Central Docker container.
For SandboxB, which must be configured from scratch with the Test Toolkit installed during configuration, you would include the Test Toolkit as part of the New-BcContainer script block that creates the container.
The relevant cmdlets and parameters for SandboxB would include:
* -includeTestToolkit: This parameter ensures that the Test Toolkit is included during the creation of the new container.
Given the limited context from the image, here's how you should complete the cmdlets for SandboxB:
* Add -includeTestToolkit in the New-BcContainer script to ensure the Test Toolkit is installed when creating SandboxB.
* Since you are setting up SandboxB from scratch, you don't need to run Install- TestToolkitToBcContainer separately as the toolkit will be included at the time of container creation with the -includeTestToolkit parameter.
For the New-BcContainer cmdlet, you would fill in the placeholders with the appropriate values for artifactUrl, imageName, and licenseFile if they are required for your specific setup.
NEW QUESTION # 60
You need to create the API page according to the requirements.
How should you complete the code segment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 61
A company plans to import and export data with Business Central
You must configure an XMLport that provides the following implementation;
* Specifies import 01 export on the Request page at run time
* Formats the data in a non-fixed length CSV format
You need to create the XMLport.
How should you complete the code segment' To answer, select the appropriate options in the answer area.
Direction: Both
Format: VariableText
You are configuring an XMLport for Business Central with the following requirements:
* Specifies import or export on the Request page at runtime.
* Formats the data in a non-fixed length CSV format.
XMLport Configuration:
* Specifies import or export on the Request page at runtime.The Direction property must be set to Both.
* This allows the XMLport to both import and export data depending on user selection during runtime.
* Formats the data in a non-fixed length CSV format.The Format property must be set to VariableText.
* VariableText is used for delimited text formats like CSV, which do not have a fixed length for fields.
NEW QUESTION # 62
A company has a page named New Job Status connected to a source table named Job. The page has an action named Item Ledger Entries. The company requires the following changes to the page:
* Filter the page to display only jobs with open or quote status.
* Add the following comment for internal use: This page does not include completed jobs.
* Item Ledger Entries action must open the selected job on the page and display it in the Ul for users to modify.
You need to select the property selections to use for each requirement.
Which property selections should you use? To answer, select the appropriate options in the answer area.
NEW QUESTION # 63
Three formats of Microsoft Dynamics 365 Business Central Developer (MB-820) practice material are always getting updated according to the content of real Microsoft Dynamics 365 Business Central Developer (MB-820) examination. The 24/7 customer service system is always available for our customers which can solve their queries and help them if they face any issues while using the MB-820 Exam product. Besides regular updates, Dumps4PDF also offer up to 1 year of free real Microsoft Dynamics 365 Business Central Developer (MB-820) exam questions updates.
Latest MB-820 Test Simulator: https://www.dumps4pdf.com/MB-820-valid-braindumps.html
Posted at 1/15/2026 06:44:36        Only Author  2#
Sie können jetzt Fortinet FCP_FMG_AD-7.6 Zertifikat erhalten. Unser PrfungFrage bietet die neue Version von Fortinet FCP_FMG_AD-7.6 Prfung. Sie brauchen nicht mehr, die neuesten Schulungsunterlagen von Fortinet FCP_FMG_AD-7.6 zu suchen. Weil Sie die besten Schulungsunterlagen von Fortinet FCP_FMG_AD-7.6 gefunden haben. Benutzen Sie beruhigt unsere FCP_FMG_AD-7.6 Schulungsunterlagen. Sie werden sicher die Fortinet FCP_FMG_AD-7.6 Zertifizierungsprfung bestehen.
Posted at 1/31/2026 10:34:59        Only Author  3#
Thank you for sharing this inspiring piece, it's really uplifting! The Mule-Con-201 exam quiz content is impressive, and its available at no cost.
Posted at 2/11/2026 10:32:50        Only Author  4#
This is so good, a like is mandatory. I used the RCDDv15 new study questions ebook to get a promotion and raise. Now its free to all. Best wishes for your professional growth!
