Hardware
1Z0-182 Exam Pass4sure | 1Z0-182 Latest Test Bootcamp
Posted at 1/13/2026 06:48:08
View340
Replies8
BTW, DOWNLOAD part of ValidVCE 1Z0-182 dumps from Cloud Storage: https://drive.google.com/open?id=1SXyl5d_Vq0K-edb64Pi06UeJCoRB5yhH
The versions of our 1Z0-182 study guide includes the PDF version, PC version, APP online version. Each version's using method and functions are different and the client can choose the most convenient version to learn our 1Z0-182 exam materials. For example, the PDF version is convenient for you to download and print our 1Z0-182 Test Questions and is suitable for browsing learning. If you use the PDF version you can print our 1Z0-182 test torrent on the papers and it is convenient for you to take notes. You can learn our 1Z0-182 test questions at any time and place.
ValidVCE's product is prepared for people who participate in the Oracle certification 1Z0-182 exam. ValidVCE's training materials include not only Oracle certification 1Z0-182 exam training materials which can consolidate your expertise, but also high degree of accuracy of practice questions and answers about Oracle Certification 1Z0-182 Exam. ValidVCE can guarantee you passe the Oracle certification 1Z0-182 exam with high score the even if you are the first time to participate in this exam.
Oracle 1Z0-182 Latest Test Bootcamp - Actual 1Z0-182 Test AnswersThey work together and put all their expertise to ensure the top standard of Channel Partner Program Oracle Database 23ai Administration Associate 1Z0-182 valid dumps. Now the Oracle Database 23ai Administration Associate 1Z0-182 exam dumps have become the first choice of Oracle 1Z0-182 Exam candidates. With the top-notch and updated Oracle 1Z0-182 test questions you can pass your Oracle Database 23ai Administration Associate 1Z0-182 exam successfulily
Oracle Database 23ai Administration Associate Sample Questions (Q57-Q62):NEW QUESTION # 57
Which three statements are true about an SPFILE?
- A. It must exist for a database instance to start.
- B. It can be used to create a PFILE.
- C. It contains only static initialization parameters.
- D. It can be created by SYS from an idle instance.
- E. It contains initialization parameters whose values can be changed using the ALTER SYSTEM statement.
Answer: B,D,E
A .True. CREATE SPFILE FROM PFILE works when idle.
B .False. Includes dynamic parameters too.
C .True. CREATE PFILE FROM SPFILE generates a PFILE.
D .False. A PFILE can start the instance if no SPFILE exists.
E .True. Dynamic parameters (e.g., DB_CACHE_SIZE) are modifiable.
NEW QUESTION # 58
One of your database instances was shut down normally and then started in NOMOUNT state. You then executed this command: ALTER DATABASE MOUNT; Which two of these actions are performed?
- A. Online redo logs are opened.
- B. The alert log has instance startup details written to it.
- C. The initialization parameter file is read.
- D. Oracle shared memory structures are allocated.
- E. Control files are read.
- F. Online data files are opened.
Answer: B,E
A .False. Data files open in OPEN.
B .False. Redo logs open in OPEN.
C .False. PFILE/SPFILE is read at NOMOUNT.
D .False. SGA is allocated at NOMOUNT.
E .True. Alert log records mount event.
F .True. Control files are read in MOUNT.
NEW QUESTION # 59
Which two are true about shrinking a segment online?
- A. To shrink a table it must have row movement enabled.
- B. To shrink a table it must have a PRIMARY KEY constraint.
- C. It must be in a tablespace that uses Automatic Segment Space Management (ASSM).
- D. It is not possible to shrink either indexes or Index Organized Tables (IOTs).
- E. To shrink a table it must have a UNIQUE KEY constraint.
A .True. ROW MOVEMENT must be enabled for SHRINK SPACE.
B .False. Indexes and IOTs can be shrunk with CASCADE.
C .False. No such constraint requirement.
D .True. ASSM is required for online shrinking.
E .False. No primary key requirement.
NEW QUESTION # 60
Which two AWR-based tools listed below are part of Oracle Database self-tuning components?
- A. Automatic Application Tracing used to collect High-Load SQL statements and statistics.
- B. Automatic Diagnostic Collector used to capture and store database errors and hung analysis.
- C. ADDM, a server-based expert that reviews database performance statistics captured by Snapshots to identify potential problems before system performance degrades noticeably.
- D. Automatic population of performance views (V$ views) from statistical data stored in AWR repository and using Automatic Database Diagnostic.
- E. Automatic Application Tracing used to collect High-Load SQL statements and statistics.
- F. Automatic capture of statistical information from the SGA and storing it in the AWR using Automatic Database Diagnostic.
Answer: C,F
False. No "Automatic Application Tracing" exists as an AWR tool. SQL tracing (e.g., DBMS_MONITOR) is manual, and high-load SQL is captured by AWR indirectly via V$SQL snapshots, not a distinct tracing tool.
Why Incorrect:Conflates manual tracing with AWR's passive collection.
The Automatic Workload Repository (AWR) is a cornerstone of Oracle's self-tuning capabilities, collecting and storing performance statistics for analysis. Let's dissect each option:
A : Automatic capture of statistical information from the SGA and storing it in the AWR using Automatic Database Diagnostic.
True. AWR automatically captures statistics (e.g., wait events, SQL stats) from the System Global Area (SGA) via the MMON (Manageability Monitor) process, storing them in the AWR repository (in SYSAUX). This is part of the Automatic Database Diagnostic Monitor (ADDM) framework, though "Automatic Database Diagnostic" likely refers to this broader mechanism.
Mechanics:Snapshots are taken hourly by default (configurable via DBMS_WORKLOAD_REPOSITORY.MODIFY_SNAPSHOT_SETTINGS), persisting data like DBA_HIST_SYSSTAT for self-tuning analysis.
Practical Use:Enables historical performance tracking, feeding tools like ADDM and SQL Tuning Advisor.
Edge Case:If STATISTICS_LEVEL=BASIC, AWR collection is disabled, haltingself-tuning.
Historical Note:Introduced in 10g, enhanced in 23ai for finer granularity.
B : ADDM, a server-based expert that reviews database performance statistics captured by Snapshots to identify potential problems before system performance degrades noticeably.
True. The Automatic Database Diagnostic Monitor (ADDM) analyzes AWR snapshots to proactively detect issues (e.g., high CPU usage, I/O bottlenecks) and recommend fixes. It runs automatically after each snapshot in maintenance windows.
Mechanics:ADDM uses DBA_ADVISOR_FINDINGS to log issues, leveraging AWR data like DBA_HIST_SQLSTAT. Example: It might suggest adding an index for a slow query.
Practical Use revents performance degradation in production systems by catching trends early.
Edge Case imited by snapshot frequency; real-time issues may need manual intervention.
C : Automatic Diagnostic Collector used to capture and store database errors and hung analysis.
False. No such tool exists as an "Automatic Diagnostic Collector" in AWR context. This likely confuses the Incident Packaging Service (IPS) or ADR (Automatic Diagnostic Repository), which handles errors but isn't AWR-based or self-tuning.
Why Incorrect:ADR collects trace files and logs, not AWR statistics, and isn't part of self-tuning.
D : Automatic population of performance views (V$ views) from statistical data stored in AWR repository and using Automatic Database Diagnostic.
False. V$ views (e.g., V$SESSION) are real-time memory structures in the SGA, not populated from AWR, which is historical (e.g., DBA_HIST_*). AWR doesn't back-feed V$ views; the reverse occurs via snapshots.
Why Incorrect:Misunderstands the data flow; AWR is a sink, not a source for V$ views.
NEW QUESTION # 61
How do you validate that the database was migrated to Unified Auditing?
- A. By using the LSINVENTORY Command to query the Oracle Database Software Library.
- B. By executing DBMS_AUDIT_MGMT PL/SQL package in Verify mode.
- C. By querying the DBA_UNIFIED_AUDIT_OPTION view.
- D. By querying V$OPTION for parameter Unified Auditing.
Unified Auditing is enabled at database creation or migration in 23ai. Let's analyze:
A . By querying V$OPTION for parameter Unified Auditing.
True. SELECT VALUE FROM V$OPTION WHERE PARAMETER = 'Unified Auditing'; returns TRUE if enabled. It's the definitive way to confirm Unified Auditing is active at the database level.
Mechanics:V$OPTION reflects compiled-in features; TRUE indicates the binary was linked with Unified Auditing (uniauflt=on during relink).
Practical Use uick, reliable check post-migration or upgrade.
B . By using the LSINVENTORY Command to query the Oracle Database Software Library.
False. LSINVENTORY (from OPatch) lists installed software components, not runtime features like auditing mode.
C . By querying the DBA_UNIFIED_AUDIT_OPTION view.
False. This view doesn't exist; DBA_AUDIT_POLICIES or UNIFIED_AUDIT_TRAIL show policies and records but not migration status.
D . By executing DBMS_AUDIT_MGMT PL/SQL package in Verify mode.
False. No "Verify mode" exists in DBMS_AUDIT_MGMT; it manages audit trails, not migration validation.
NEW QUESTION # 62
For candidates, one of the most important things for you is to know the latest information of the exam. 1Z0-182 Training Materials of us will meet your needs. And our system will send the latest version to you automatically, so that you can know the recent information. We have free update for one year, that is to say, you can get free update version for 365 days after purchasing. In addition, we will pass guarantee and money back guarantee.
1Z0-182 Latest Test Bootcamp: https://www.validvce.com/1Z0-182-exam-collection.html
If you purchased our 1Z0-182 Latest Test Bootcamp - Oracle Database 23ai Administration Associate test questions and dumps before, and want to purchase other exam cram sheet we will give you discount, As an adult or a student, I believe you are quite familiar with the point that maybe you will encounter what you are to be tested in the exam when you go through 1Z0-182 exam pdf cram originally designed for it, If you want to get success with good grades then these Oracle 1Z0-182 dumps exam questions and answers are splendid platform for you I personally review this web many times thats why I am suggesting you this one.
Include prospective managers in strategy discussions to Valid Exam 1Z0-182 Book help them acquire planning and leadership skills, as well as a broad vision of the company and its goals.
Supercharging your templates with JavaScript, If you purchased 1Z0-182 Exam Pass4sure our Oracle Database 23ai Administration Associate test questions and dumps before, and want to purchase other exam cram sheet we will give you discount.
Prepare Your Oracle 1Z0-182 Exam with Real Oracle 1Z0-182 Exam Pass4sure EasilyAs an adult or a student, I believe you are quite familiar with the point that maybe you will encounter what you are to be tested in the exam when you go through 1Z0-182 Exam PDF cram originally designed for it.
Please prepare well with the 1Z0-182 study material we provide for you, After finishing your task, you can review them plenty of times and find out the wrong items, some questions 1Z0-182 may have explanations for your understanding, and you can practice many times day to day.
- 1Z0-182 Reliable Braindumps Book 🔑 Practice 1Z0-182 Exams Free 🧼 Valid 1Z0-182 Test Preparation 🖍 Search for ⇛ 1Z0-182 ⇚ on ▛ [url]www.dumpsquestion.com ▟ immediately to obtain a free download 🕟1Z0-182 Reliable Test Camp[/url]
- 1Z0-182 Latest Dumps - 1Z0-182 Dumps Torrent - 1Z0-182 Valid Dumps 🤸 Search for 1Z0-182 and download it for free immediately on [ [url]www.pdfvce.com ] 🥳Exam 1Z0-182 Cram Review[/url]
- 1Z0-182 Real Question 💭 Braindumps 1Z0-182 Downloads ⏫ 1Z0-182 Free Brain Dumps 🍪 Easily obtain free download of ⏩ 1Z0-182 ⏪ by searching on ⇛ [url]www.prepawayexam.com ⇚ 🤠
remium 1Z0-182 Files[/url] - Magnificent 1Z0-182 Preparation Dumps: Oracle Database 23ai Administration Associate Represent the Most Popular Simulating Exam - Pdfvce ✴ The page for free download of [ 1Z0-182 ] on ⏩ [url]www.pdfvce.com ⏪ will open immediately 🦟Latest 1Z0-182 Learning Materials[/url]
- 1Z0-182 Brain Dump Free ⛳ Premium 1Z0-182 Files 🏔 Premium 1Z0-182 Files 🆕 Search for ➠ 1Z0-182 🠰 and download it for free immediately on [url]www.validtorrent.com 🔢Exam 1Z0-182 Cram Review[/url]
- 100% Pass-Rate 1Z0-182 Exam Pass4sure - Leading Offer in Qualification Exams - Fantastic 1Z0-182: Oracle Database 23ai Administration Associate 🤨 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for ➠ 1Z0-182 🠰 for free download 🛌
ractice 1Z0-182 Exams Free[/url] - Latest updated 1Z0-182 Exam Pass4sure - Latest 1Z0-182 Latest Test Bootcamp - Useful Actual 1Z0-182 Test Answers 🎎 Search for [ 1Z0-182 ] on ➥ [url]www.testkingpass.com 🡄 immediately to obtain a free download 🛐1Z0-182 Exam Blueprint[/url]
- 1Z0-182 Free Learning Cram 🏚 1Z0-182 Exam Blueprint 🥪 1Z0-182 Brain Dump Free 🤱 Immediately open ▛ [url]www.pdfvce.com ▟ and search for 1Z0-182 to obtain a free download 🌖1Z0-182 Real Question[/url]
- Magnificent 1Z0-182 Preparation Dumps: Oracle Database 23ai Administration Associate Represent the Most Popular Simulating Exam - [url]www.practicevce.com 🧅 Search for ➥ 1Z0-182 🡄 and download exam materials for free through ➥ www.practicevce.com 🡄 💎1Z0-182 Free Learning Cram[/url]
- Find Success In Exam With Oracle 1Z0-182 PDF Questions 🏋 Search for ➡ 1Z0-182 ️⬅️ on [url]www.pdfvce.com immediately to obtain a free download 🙈1Z0-182 Free Learning Cram[/url]
- Authoritative 1Z0-182 Exam Pass4sure - Pass 1Z0-182 in One Time - Complete 1Z0-182 Latest Test Bootcamp 🆎 Search for 1Z0-182 on ▶ [url]www.pdfdumps.com ◀ immediately to obtain a free download 🦄1Z0-182 Reliable Braindumps Book[/url]
- shortcourses.russellcollege.edu.au, bbs.t-firefly.com, training.siyashayela.com, 121.199.46.216, writeablog.net, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, vxlxemito123.blogspot.com, xm.wztc58.cn, www.flirtic.com, paidforarticles.in, Disposable vapes
DOWNLOAD the newest ValidVCE 1Z0-182 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1SXyl5d_Vq0K-edb64Pi06UeJCoRB5yhH
