Valid Dumps SC-401 Book & Latest SC-401 Exam Pdf
Posted at 1/13/2026 08:30:42
BTW, DOWNLOAD part of Exam4Docs SC-401 dumps from Cloud Storage: https://drive.google.com/open?id=1YhBS8N1_zqN4tVvvYrU3oyIOzN_qp7J-
Sometimes hesitating will lead to missing a lot of opportunities. If you think a lot of our SC-401 exam dumps PDF, you should not hesitate again. Too much hesitating will just waste a lot of time. Our SC-401 exam dumps PDF can help you prepare casually and pass exam easily. If you make the best use of your time and obtain a useful certification you may get a senior position ahead of others. Chance favors the prepared mind. Exam4Docs provide the best SC-401 Exam Dumps Pdf materials in this field which is helpful for you.
Microsoft SC-401 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Implement Information Protection: This section measures the skills of Information Security Analysts in classifying and protecting data. It covers identifying and managing sensitive information, creating and applying sensitivity labels, and implementing protection for Windows, file shares, and Exchange. Candidates must also configure document fingerprinting, trainable classifiers, and encryption strategies using Microsoft Purview.
| | Topic 2 | - Protect Data Used by AI Services: This section evaluates AI Governance Specialists on securing data in AI-driven environments. It includes implementing controls for Microsoft Purview, configuring Data Security Posture Management (DSPM) for AI, and monitoring AI-related security risks to ensure compliance and protection.
| | Topic 3 | - Manage Risks, Alerts, and Activities: This section assesses Security Operations Analysts on insider risk management, monitoring alerts, and investigating security activities. It covers configuring risk policies, handling forensic evidence, and responding to alerts using Microsoft Purview and Defender tools. Candidates must also analyze audit logs and manage security workflows.
| | Topic 4 | - Implement Data Loss Prevention and Retention: This section evaluates Data Protection Officers on designing and managing data loss prevention (DLP) policies and retention strategies. It includes setting policies for data security, configuring Endpoint DLP, and managing retention labels and policies. Candidates must understand adaptive scopes, policy precedence, and data recovery within Microsoft 365.
The Best Valid Dumps SC-401 Book | Realistic Latest SC-401 Exam Pdf and New Free Administering Information Security in Microsoft 365 Brain DumpsWe all know that pass the SC-401 exam will bring us many benefits, but it is not easy for every candidate to achieve it. The SC-401 guide torrent is a tool that aimed to help every candidate to pass the exam. Our SC-401 exam materials can installation and download set no limits for difficulty of the computers and persons. You can use our SC-401 Practice Questions directly. We guarantee you that the SC-401 study materials we provide to you are useful and can help you pass the test.
Microsoft Administering Information Security in Microsoft 365 Sample Questions (Q19-Q24):NEW QUESTION # 19
Hotspot Question
You have a Microsoft 365 E5 subscription that contains the device configurations shown in the following table.
Each configuration uses either Google Chrome or Firefox as a default browser.
You need to implement Microsoft Purview and deploy the Microsoft Purview browser extension to the configurations.
To which configuration can each extension be deployed? To answer, select the appropriate options in the answer area.
Microsoft Purview browser extensions for Endpoint DLP are supported on:
- Windows 10/11 (Config1)
- macOS (Config2)
- Not supported on Android (Config3)
Since Microsoft Purview does not support browser extensions on Android, Config3 is excluded from both Google Chrome and Firefox.
NEW QUESTION # 20
Hotspot Question
You have a Microsoft 365 sensitivity label that is published to all the users in your Microsoft Entra tenant as shown in the following exhibit.
Statement 1 - No. The sensitivity label includes content marking (watermark: INTERNAL), but it only applies to documents where the label is manually or automatically applied, not to all documents by default.
Statement 2 - No. The sensitivity label only specifies a watermark, not a header. If a header marking was configured, it would explicitly appear in the label settings.
Statement 3 - No. There is no indication that auto-labeling is configured to apply the label only to documents with the word "rebranding". Auto-labeling is an optional setting that needs explicit configuration.
NEW QUESTION # 21
You have a Microsoft 36S ES subscription.
You need to create the Microsoft Purview insider risk management policies shown in the following table.
Which policy template should you use for each policy? To answer, drag the appropriate policy templates to the correct polices Each template may be used once more than once or not at all. You may need to drag the split bar between panes or scroll to view..
Policy1 monitors printing of files by users that submitted their resignation. In Insider Risk Management, the Data theft by departing users template is designed for users marked as leaving and watches for exfiltration indicators such as printing, USB copy, or uploads to cloud services.
Ref: Microsoft Purview Insider Risk Management - Policy templates: Data theft by departing users (monitors exfiltration activities for departing users).
Policy2 monitors accidental sharing of data outside the organization by users in a priority user group. The template for this is Data leaks by priority users, which targets a defined priority user group and focuses on oversharing/leak indicators (external sharing, email to external, cloud uploads, etc.).
Ref: Insider Risk Management - Data leaks by priority users template.
Policy3 monitors downloading of files from SharePoint Online to personal cloud storage services. This is a classic data leak/exfiltration scenario without a departing/priority qualifier, so the general Data leaks template is appropriate (covers uploads to personal cloud services and other exfiltration vectors).
Ref: Insider Risk Management - Data leaks template (monitors exfiltration such as uploads to personal cloud services).
These mappings align with Microsoft's template purposes: Departing user exfiltration # Data theft by departing users; Priority users oversharing # Data leaks by priority users; Generic exfiltration # Data leaks.
NEW QUESTION # 22
You have a Microsoft 365 E5 subscription that uses Microsoft Defender for Cloud Apps.
You need to ensure that you receive an alert when a user uploads a document to a third-party cloud storage service.
What should you use?
- A. a file policy
- B. an insider risk policy
- C. a sensitivity label
- D. an activity policy
Activity Policy (MCAS): Monitors and alerts on specific user actions such as uploading files, downloads, or logins to cloud apps. Perfect for detecting "upload to third-party storage".
Sensitivity label: Used for classifying and protecting content, not generating alerts.
File policy (MCAS): Inspects and governs files already stored in sanctioned apps, not upload activity.
Insider risk policy: Focuses on risky behavior like data exfiltration or security violations, not direct activity alerts in cloud apps.
The answer: A. an activity policy
Reference: Defender for Cloud Apps activity policies
NEW QUESTION # 23
Hotspot Question
You have a Microsoft 365 E5 subscription that uses Microsoft Purview.
You need ensure that an incident will be generated when a user visits a phishing website.
Box 1: Insider Risk Management policies in Microsoft Purview can be configured to detect risky behavior, such as accessing phishing websites. These policies monitor user activity, generate alerts, and help organizations investigate potential security threats.
Box 2: Microsoft Defender Browser Protection extension helps in detecting unsafe or phishing websites and integrating this detection with Insider Risk Management policies. This extension works with Microsoft Edge and Google Chrome to identify risky browsing activity and trigger alerts.
NEW QUESTION # 24
Due to extremely high competition, passing the Administering Information Security in Microsoft 365 (SC-401) exam is not easy; however, possible. You can use Exam4Docs products to pass the Administering Information Security in Microsoft 365 (SC-401) exam on the first attempt. The Administering Information Security in Microsoft 365 (SC-401) practice exam gives you confidence and helps you understand the criteria of the testing authority and pass the Administering Information Security in Microsoft 365 (SC-401) exam on the first attempt.
Latest SC-401 Exam Pdf: https://www.exam4docs.com/SC-401-study-questions.html
- 2026 Valid Dumps SC-401 Book | High-quality Microsoft SC-401: Administering Information Security in Microsoft 365 100% Pass 💋 Go to website ▶ [url]www.examcollectionpass.com ◀ open and search for 「 SC-401 」 to download for free 🤵SC-401 Exam Tutorial[/url]
- Pass Guaranteed Quiz Authoritative SC-401 - Valid Dumps Administering Information Security in Microsoft 365 Book 🛢 Simply search for { SC-401 } for free download on ➡ [url]www.pdfvce.com ️⬅️ 🌭Valid SC-401 Exam Notes[/url]
- Updated Microsoft Questions Ensure Thorough SC-401 Exam Preparation 🥿 Open ☀ [url]www.prepawaypdf.com ️☀️ enter ⏩ SC-401 ⏪ and obtain a free download 🕯Dumps SC-401 Questions[/url]
- SC-401 Valid Exam Sample 😄 SC-401 Guide Torrent ☔ SC-401 Exam Tutorial 🎾 Go to website 「 [url]www.pdfvce.com 」 open and search for ➡ SC-401 ️⬅️ to download for free 🕥Test SC-401 Voucher[/url]
- SC-401 Latest Exam Tips 🌶 Dumps SC-401 Questions 📰 SC-401 Latest Exam Tips 😍 Open ⇛ [url]www.validtorrent.com ⇚ and search for ➥ SC-401 🡄 to download exam materials for free 👲New SC-401 Exam Dumps[/url]
- SC-401 Guide Torrent 🤧 Valid Test SC-401 Tips 😲 SC-401 Guide Torrent 🤓 Search for 「 SC-401 」 and obtain a free download on ▛ [url]www.pdfvce.com ▟ 🍦SC-401 Learning Engine[/url]
- 2026 Valid Dumps SC-401 Book | High-quality Microsoft SC-401: Administering Information Security in Microsoft 365 100% Pass 🖱 Open website ⏩ [url]www.examcollectionpass.com ⏪ and search for [ SC-401 ] for free download 🍽Dumps SC-401 Questions[/url]
- First-rank SC-401 Practice Materials Stand for Perfect Exam Dumps - Pdfvce 😊 Easily obtain ✔ SC-401 ️✔️ for free download through ✔ [url]www.pdfvce.com ️✔️ 👪SC-401 Premium Files[/url]
- New SC-401 Exam Dumps 🖋 Reliable SC-401 Test Sims 🍸 SC-401 Flexible Learning Mode 🌠 The page for free download of ⏩ SC-401 ⏪ on “ [url]www.pdfdumps.com ” will open immediately 🦦SC-401 Premium Files[/url]
- Valid SC-401 Exam Notes 🍪 Test SC-401 Voucher 🧥 Reliable SC-401 Test Sims 🏃 Copy URL ➤ [url]www.pdfvce.com ⮘ open and search for 【 SC-401 】 to download for free 🐷SC-401 Minimum Pass Score[/url]
- Valid SC-401 Exam Notes 📭 Current SC-401 Exam Content 🚵 New SC-401 Exam Dumps 🎿 Search on 「 [url]www.examcollectionpass.com 」 for ☀ SC-401 ️☀️ to obtain exam materials for free download ❗SC-401 Study Center[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, tooter.in, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.yongrenqianyou.com, www.stes.tyc.edu.tw, www.61921b.com, darwinacademia.com, Disposable vapes
P.S. Free & New SC-401 dumps are available on Google Drive shared by Exam4Docs: https://drive.google.com/open?id=1YhBS8N1_zqN4tVvvYrU3oyIOzN_qp7J-
